MMSZ5238B
MMSZ5238B
    YENJI(台湾元基)
    SOD123
    稳压二极管 SOD123 Vz=8.7V Ir=3µA
MMSZ5238B 数据手册
Zener Diodes MMSZ5221B-MMSZ5259B SOD-123       F Constant Voltage control Wide Voltage Range Selection 2.4V to 39V RoHS compliant / Green EMC Matte Tin (Sn) Lead finish Moisture Level Sensitivity 1 Cathode Band / Device marking Refer to table list ※Mark: refer to Device Marking Absolute Maximum Ratings (Ta = 25 ℃) Symbol Parameter Value Units PD Power Dissipation 500 mW TJ Junction Temperature 150 ℃ TSTG Storage Temperature -65 to +150 ℃ PD/VZ mA IZM Maximum Regulator Current Electrical Characteristics (Ta = 25 ℃) Type Device Number Marking MMSZ5221B C1 MMSZ5223B Vz (V) @IZT Nom(V) IZT ZZT@IZT ZZK@IZK Ω Izk IR VR (mA) (uA) (V) Min(V) Max(V) mA 2.4 2.28 2.52 20 30 1200 0.25 100 1.0 C3 2.7 2.57 2.84 20 30 1300 0.25 75 1.0 MMSZ5225B C5 3.0 2.85 3.15 20 30 1600 0.25 50 1.0 MMSZ5226B G1 3.3 3.14 3.47 20 28 1600 0.25 25 1.0 MMSZ5227B G2 3.6 3.42 3.78 20 24 1700 0.25 15 1.0 MMSZ5228B G3 3.9 3.71 4.10 20 23 1900 0.25 10 1.0 MMSZ5229B G4 4.3 4.09 4.52 20 22 2000 0.25 5 1.0 MMSZ5230B G5 4.7 4.47 4.94 20 19 1900 0.25 5 2.0 MMSZ5231B E1 5.1 4.85 5.36 20 17 1600 0.25 5 2.0 MMSZ5232B E2 5.6 5.32 5.88 20 11 1600 0.25 5 3.0 MMSZ5233B E3 6.0 5.70 6.30 20 7 1600 0.25 5 3.5 Continued next page 1 May.2015, Zener Diodes MMSZ5221B-MMSZ5259B Type Device Number Marking MMSZ5234B E4 6.2 MMSZ5235B E5 MMSZ5236B IZT Vz (V) @IZT ZZT@IZT ZZK@IZK IR VR (mA) (uA) (V) Max(V) mA 5.89 6.51 20 7 1000 0.25 5 4.0 6.8 6.46 7.14 20 5 750 0.25 3 5.0 F1 7.5 7.13 7.88 20 6 500 0.25 3 6.0 MMSZ5237B F2 8.2 7.79 8.61 20 8 500 0.25 3 6.5 MMSZ5238B F3 8.7 8.27 9.14 20 8 600 0.25 3 6.5 MMSZ5239B F4 9.1 8.65 9.56 20 10 600 0.25 3 7.0 MMSZ5240B F5 10 9.50 10.50 20 17 600 0.25 3 8.0 MMSZ5241B H1 11 10.45 11.55 20 22 600 0.25 2.0 8.4 MMSZ5242B H2 12 11.40 12.60 20 30 600 0.25 1.0 9.1 MMSZ5243B H3 13 12.35 13.65 9.5 13 600 0.25 0.5 9.9 MMSZ5244B H4 14 13.30 14.70 9.0 15 600 0.25 0.1 10 MMSZ5245B H5 15 14.25 15.75 8.5 16 600 0.25 0.1 11 MMSZ5246B J1 16 15.20 16.80 7.8 17 600 0.25 0.1 12 MMSZ5248B J3 18 17.10 18.90 7.0 21 600 0.25 0.1 14 MMSZ5250B J5 20 19.00 21.00 6.2 25 600 0.25 0.1 15 MMSZ5251B K1 22 20.90 23.10 5.6 29 600 0.25 0.1 17 MMSZ5252B K2 24 22.80 25.20 5.2 33 600 0.25 0.1 18 MMSZ5253B K3 25 23.75 26.25 5.0 35 600 0.25 0.1 19 MMSZ5254B K4 27 25.65 28.35 5.0 41 600 0.25 0.1 21 MMSZ5255B K5 28 26.60 29.40 4.5 44 600 0.25 0.1 21 MMSZ5256B M1 30 28.50 31.50 4.2 49 600 0.25 0.1 23 MMSZ5257B M2 33 31.35 34.65 3.8 58 700 0.25 0.1 25 MMSZ5258B M3 36 34.20 37.80 3.4 70 700 0.25 0.1 27 MMSZ5259B M4 39 37.05 40.95 3.2 80 800 0.25 0.1 30 Nom(V) Min(V) 2 Ω Izk May.2015, Zener Diodes MMSZ5221B-MMSZ5259B Ordering Information Device Package Shipping MMSZ Series SOD123 Tape & Reel 3000pcs /7” Reel Tape wide Emboss pitch Tape specification 8 mm 4 mm Conductive Notes Package Dimensions Package outline : SOD-123 Unit A A1 A2 b c D E E1 Max. 1.25 0.10 1.15 0.65 0.15 1.70 2.80 3.85 Min. 1.05 0.00 1.05 0.45 0.08 1.50 2.60 3.55 L 0.500 REF. L1 θ 0.45 8° 0.25 0° Note: 1. Halogen free,EMC 2. Pb free solder 3. Lead thickness includes solder plating 4. Lead frame: A42 5. Other Tolerance: ±0.05 SOD123 Package Outline 6. Dimensions are exclusive of Burrs,Mold Flash and Tie Bar extrusions 7. Unit: mm Land Pattern Recommendation 3 May.2015,
MMSZ5238B
1. 物料型号:MMSZ5221B-MMSZ5259B 2. 器件简介:这些稳压二极管提供恒定电压控制,具有宽电压范围选择(2.4V至39V),符合RoHS标准,采用绿色EMC无铅锡(Sn)引脚镀层,对湿度敏感度为1级,带有阴极带和设备标记。 3. 引脚分配:文档中未明确提供引脚分配图,但通常稳压二极管有阳极和阴极两个引脚。 4. 参数特性: - 最大功耗(Po):500mW - 结温(T):最高150°C - 存储温度(TSTG):-65°C至+150°C - 最大稳压电流(IZM):Po/Vz mA 5. 功能详解:文档列出了不同型号的稳压二极管的电气特性,包括标称电压(Nom(V))、最小工作电压(Min(V))、最大工作电压(Max(V))、测试电流(lzr mA)、稳压电压(Zzr@lzr)、齐纳电压(Zzx@1zx)、反向电流(IR (uA))和正向电压(VR (V))。 6. 应用信息:文档未提供具体应用案例,但稳压二极管通常用于电路中提供稳定的参考电压。 7. 封装信息:所有型号均采用SOD-123封装,每卷3000件,卷带宽度8mm,压纹间距4mm,卷带规格为导电性。
MMSZ5238B 价格&库存
很抱歉,暂时无法提供与“MMSZ5238B”相匹配的价格&库存,您可以联系我们找货
MMSZ5238B
  • 20+0.11376
  • 100+0.10296
  • 500+0.09576
  • 1000+0.08856
  • 5000+0.07992
  • 10000+0.07632
库存:950
