RS1A THRU RS1M
Reverse Voltage - 50 to 1000 Volts
Forward Current - 1.0 Ampere
SURFACE MOUNT FAST RECOVERY RECTIFIER
Features
DO-214AC/SMA
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
0.110(2.80)
0.094(2.40)
0.067 (1.70)
0.039 (1.00)
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed:
0.177(4.50)
0.157(3.99)
250℃/ 10 seconds at terminals
0.012(0.305)
0.006(0.152)
Glass passivated chip junction
0.096(2.42)
0.078(1.98)
0.059(1.50)
0.035(0.90)
Mechanical Data
0.008(0.203)MAX.
0.205(5.20)
0.188(4.80)
Case : JEDEC DO-214AC/SMA Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.002 ounce, 0.055grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=125℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
at rated DC blocking voltage
Maximum reverse recovery time
TA=25℃
TA=125℃
(NOTE 1)
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
Operating junction and storage temperature range
VRRM
VRMS
VDC
MDD
RS1A
MDD
RS1B
MDD
RS1D
MDD
RS1G
MDD
RS1J
MDD
RS1K
50
35
50
100
70
200
140
200
400
280
400
600
420
600
800
560
800
100
MDD
RS1M
1000
700
1000
UNITS
V
V
V
I(AV)
1.0
A
IFSM
30
A
VF
1.30
V
IR
5
50
uA
trr
150
250
500
ns
CJ
RθJA
15.0
pF
75.0
TJ,TSTG
-55 to +150
℃/W
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.P.C.B. mounted with 1.0 X 1.0" (2.54 X 2.54 cm) copper pad areas
http://www.microdiode.com
Rev:2024A3
Page :1
RS1A THRU RS1M
Ratings And Characteristic Curves
Fig.2 Typical Reverse Characteristics
Fig.1 Forward Current Derating Curve
Instaneous Reverse Current( μ A)
1.2
Average Forward Current (A)
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
0.0
25
75
50
100
125
150
175
100
1.0
TJ=25°C
0.1
00
Case Temperature (°C)
40
60
80
100
120
140
Reverse Voltage (%)
Fig.4 Typical Junction Capacitance
100
TJ=25°C
pF)
TJ=25°C
JunctionCapacitance (
Instaneous Forward Current (A)
percent of Rated Peak
Fig.3 Typical Instaneous Forward
Characteristics
10
TJ=125 °C
10
1.0
0.1
pulse with 300μ
s
1% duty cycle
0.01
0.0
0.5
1.0
1.5
2.0
10
1
2.5
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
35
30
25
10
05
00
8.3 ms Single Half Sine Wave
(JEDEC Method)
10
1
100
Number of Cycles
The curve above is for reference only.
http//www.microdiode.com
Rev:2024A3
Page :2
RS1A THRU RS1M
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
SMA
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
A
B
C
d
D
D1
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.80
5.33
2.36
1.50
330.00
50.00
178.00
62.00
13.00
1.75
5.50
4.00
4.00
2.00
0.28
12.00
18.00
E
F
B
A
W
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
SMA
REEL SIZE
7"
APPROX.
GROSS WEIGHT
(kg)
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
2,000
4.0
4,000
183*155*183
178
382*356*392
10,000
290*290*38
330
310*310*360
80,000
11.0
15,000
335*335*38
330
350*330*360
120,000
14.5
SMA
11"
5,000
4.0
SMA
13"
7,500
4.0
CARTON
SIZE
(m/m)
CARTON
(pcs)
80,000
16.0
Suggested Pad Layout
Symbol
Unit (mm)
Unit (inch)
A
0.066
B
1.68
1.52
C
3.93
0.154
D
2.41
0.095
E
5.45
0.215
0.060
Rev:2024A3
Page :3
很抱歉,暂时无法提供与“RS1M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.08020
- 500+0.07320
- 1500+0.06920
- 5000+0.04240
- 25000+0.04030
- 50000+0.03920
- 国内价格
- 50+0.07804
- 500+0.07124
- 1500+0.06747
- 5000+0.04139
- 25000+0.03939
- 50000+0.03834
- 国内价格
- 1+0.18920
- 500+0.06281
- 2500+0.04191
- 5000+0.03432
- 国内价格
- 50+0.07375
- 1000+0.06732
- 2000+0.06376
- 5000+0.03911
- 国内价格
- 1000+0.04263
- 5000+0.03319
