MKT312N15
MKT312N15
    MK(米客方德)
    DFN1006
    ESD抑制器/TVS二极管 VRWM=5V 15pF 60W ±25KV(air) ±25KV(contact)
MKT312N15 数据手册
MKT312N15 DFN1006 Datasheet Bi-directional ESD Protection Diode in DFN1006 Package 1. Features  Capacitance: 15pF(typ.)  Reverse Working Voltage: 5V  IEC 61000-4-2 (ESD Air): ±25KV 2. Pin Description 4. Schematic Diagram IEC 61000-4-2 (ESD Contact): ±25KV IEC 61000-4-5 (Lightning 8/20µs): 5A 3. 5. 6. Applications  Smart Phone and Tablet PC  TV and Set Top Box  Wearable Devices  PDA Order Information Type Package Size (mm) Delivery Form Delivery Quantity MKT312N15 DFN1006 1.00x0.60x0.37 7” T&R 10,000 Limiting Values(TA = 25 °C, unless otherwise specified) Symbol 7. Parameter Conditions Min Max Unit IEC 61000-4-2; Contact Discharge - ±25 kV IEC 61000-4-2; Air Discharge - ±25 kV VESD Electrostatic Discharge Voltage PPP Peak Pulse Power tP = 8/20 µs - 60 W IPPM Rated Peak Pulse Current tP = 8/20 µs - 5 A TA Ambient Temperature Range - -55 125 ℃ Tstg Storage Temperature Range - -55 150 ℃ Electrical Characteristics(TA = 25 °C, unless otherwise specified) Symbol Parameter Conditions Reverse Working Voltage TA = 25 °C Breakdown Voltage IR = 1mA; TA = 25 °C IR Reverse Leakage Current VC Clamping Voltage CJ Junction Capacitance VRWM VBR Product Datasheet Min Typ. Max Unit - - 5.0 V 5.6 6.5 8.4 V VRWM = 5V; TA = 25 °C - - 0.1 µA IPP=1A, tP =8/20µs - - 10 V IPP=5A, tP =8/20µs - - 12 V VR = 0V, f = 1 MHz - 15 18 pF 1 www.mkfounder.com 08-Mar-2018 © MK Founder Co., LTD. All right reserved Reversion:0.2 MKT312N15 DFN1006 Bi-directional ESD Protection Diode in DFN1006 Package 8. Datasheet Typical Characteristics Fig.1 Pulse Waveform-ESD(IEC61000-4-2) Fig.2 Transmission Line Pulse (TLP) Fig.3 V-I Characteristics for Bidirectional Diode Fig.4 IV Curve Fig.5 Clamping Voltage at IEC61000-4-2 Fig.6 Clamping Voltage at IEC61000-4-2 +8kV Pulse Waveform -8kV Pulse Waveform Product Datasheet 2 www.mkfounder.com 08-Mar-2018 © MK Founder Co., LTD. All right reserved Reversion:0.2 MKT312N15 DFN1006 Bi-directional ESD Protection Diode in DFN1006 Package 9. Datasheet Package Outline Dimensions DFN1006 Package Outline Symbol Product Datasheet Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 0.350 0.450 0.014 0.018 D 0.550 0.650 0.022 0.026 E 0.950 1.050 0.037 0.041 D1 0.420 0.520 0.017 0.020 E1 0.550 0.650 0.022 0.026 L 0.270 0.370 0.011 0.015 L1 0.000 0.100 0.000 0.004 3 www.mkfounder.com 08-Mar-2018 © MK Founder Co., LTD. All right reserved Reversion:0.2 MKT312N15 DFN1006 Bi-directional ESD Protection Diode in DFN1006 Package 10. Datasheet Soldering Parameters FIG.5: Reflow condition tp TP Critical Zone TL to TP Ramp-up TL tL Temperature TS(max) Ramp-down Preheat TS(min) ts 25 time to peak temperatue (t 25℃ to peak) Reflow Condition Pre-heat Pb-Free Assembly -Temperature Min (Ts(min)) +150°C -Temperature Max(Ts(max)) +200°C -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3°C/sec. Max Ts(max) to TL - Ramp-up Rate 3°C/sec. Max Reflow Product Datasheet Time -Temperature(TL)(Liquid us) +217°C -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)°C Time within 5°C of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6°C/sec. Max xTime 25°C to Peak Temp (TP) 8 min. Max Do not exceed +260°C 4 www.mkfounder.com 08-Mar-2018 © MK Founder Co., LTD. All right reserved Reversion:0.2 MKT312N15 DFN1006 Bi-directional ESD Protection Diode in DFN1006 Package 11. Datasheet Contact Information Online product information is available at www.mkfounder.com Buy our products or get free samples,for further information and requests, Please e-mail us at:sales@mkfounder.com 12. Copyrights & Disclaimer Copyright MK Founder, trademarks Registered. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. Devices sold by MK Founder are covered by the warranty and patent indemnification provisions appearing in its General Terms of Trade. MK Founder makes no warranty, express, statutory, implied, or by description regarding the information set forth herein. MK Founder reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with MK Founder for current information. This product is intended for use in commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by MK Founder for each application. This product is provided by MK Founder “AS IS” and any express or implied warranties, including, but not limited to the implied warranties of merchantability and fitness for a particular purpose are disclaimed. MK Founder shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of MK Founder rendering of technical or other services. 13. Reversion History Document ID Release Date Sheet Status Change Notice Supersedes 0.1 08-Mar-2018 Product datasheet - - 0.2 14-Aug-2018 Product datasheet Change Dimension - Product Datasheet 5 www.mkfounder.com 08-Mar-2018 © MK Founder Co., LTD. All right reserved Reversion:0.2
MKT312N15 价格&库存
很抱歉,暂时无法提供与“MKT312N15”相匹配的价格&库存,您可以联系我们找货
