MKT642U05
MKT642U05
    MK(米客方德)
    DFN2510
    ESD抑制器/TVS二极管 VRWM=5V 0.5pF ±20KV(air) ±15KV(contact)
MKT642U05 数据手册
MKT642U05 DFN2510 Datasheet 4 Channel Ultra-Low Capacitance ESD Protection Diode 1. Features  Ultra-Low capacitance:0.5pF(typ.)  Reverse stand-off voltage:5V  IEC 61000-4-2 (Air): ±20KV 2. Pin Description 4. Schematic Diagram IEC 61000-4-2 (Contact): ±15KV 3. Applications  USB 3.0, USB 2.0  HDMI 1.3/1.4, Display Port 1.3, eSATA  Unified Display Interface (UDI)  Digital Visual Interface (DVI)  High speed serial interfaces Top View 5. 6. Order Information Type Package Size (mm) Delivery Form Delivery Quantity MKT642U05 DFN2510 2.50x1.00x0.50 7” T&R 3,000 Limiting Values(TA = 25 °C, unless otherwise specified) Symbol Parameter Conditions VESD Electrostatic Discharge Voltage IPPM Rated Peak Pulse Current Min Max Unit IEC 61000-4-2; Contact Discharge - ±15 kV IEC 61000-4-2; Air Discharge - ±20 kV tP = 8/20 µs - 5 A TA Ambient Temperature Range - -55 125 ℃ Tstg Storage Temperature Range - -55 150 ℃ Product Datasheet 1 www.mkfounder.com 11-Jun-2018 © MK Founder Co., LTD. All right reserved Reversion:0.2 MKT642U05 DFN2510 Datasheet 4 Channel Ultra-Low Capacitance ESD Protection Diode 7. Electrical Characteristics(TA = 25 °C unless otherwise specified) Symbol VRWM VBR IR Parameter Conditions Reverse Working Voltage Min Typ. Max Unit TA = 25 °C - - 5 V Breakdown Voltage IR = 1 mA; TA = 25 °C 6 - - V Reverse Leakage Current VRWM = 5V; TA = 25 °C - - 1 µA - 8.5 12 V - 12 16 V VR = 0V, f = 1 MHz,I/O to I/O - 0.3 0.4 pF VR = 0V, f = 1 MHz, I/O to GND - 0.5 0.8 pF IPP=1A,tP=8/20µs, Any I/O to VC Clamping Voltage GND , Positive IPP=5A,tP=8/20µs, Any I/O to GND , Positive CL 8. Junction Capacitance Typical Characteristics Fig.1 Peak Pulse Power Rating Curve Fig.2 Pulse Derating Curve Fig.3 Pulse Waveform-8/20μs Fig.4 Pulse Waveform-ESD(IEC61000-4-2) Product Datasheet 2 www.mkfounder.com 11-Jun-2018 © MK Founder Co., LTD. All right reserved Reversion:0.2 MKT642U05 DFN2510 4 Channel Ultra-Low Capacitance ESD Protection Diode 9. Datasheet Package Dimension DFN2510 Package Outline Symbol A A1 b b1 b2 c D e Nd E L L1 L2 h R Product Datasheet Dimensions in millimeters Min Nom Max 0.45 0.15 0.35 0.20 0.10 2.45 0.50 0.02 0.20 0.40 0.25 0.15 2.50 0.50BSC 2.00 BSC 1.00 0.40 0.075 REF 0.05 REF 0.12 0.10 0.55 0.05 0.25 0.45 0.30 0.20 2.55 0.95 0.35 0.08 0.05 3 www.mkfounder.com 1.05 0.45 0.15 0.15 11-Jun-2018 © MK Founder Co., LTD. All right reserved Reversion:0.2 MKT642U05 DFN2510 4 Channel Ultra-Low Capacitance ESD Protection Diode 10. Datasheet Soldering Parameters FIG.5: Reflow condition tp TP Critical Zone TL to TP Ramp-up TL tL Temperature TS(max) Ramp-down Preheat TS(min) ts 25 time to peak temperatue (t 25℃ to peak) Reflow Condition Pre-heat Pb-Free Assembly -Temperature Min (Ts(min)) +150°C -Temperature Max(Ts(max)) +200°C -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3°C/sec. Max Ts(max) to TL - Ramp-up Rate 3°C/sec. Max Reflow Product Datasheet Time -Temperature(TL)(Liquid us) +217°C -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)°C Time within 5°C of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6°C/sec. Max xTime 25°C to Peak Temp (TP) 8 min. Max Do not exceed +260°C 4 www.mkfounder.com 11-Jun-2018 © MK Founder Co., LTD. All right reserved Reversion:0.2 MKT642U05 DFN2510 4 Channel Ultra-Low Capacitance ESD Protection Diode 11. Datasheet Contact Information Online product information is available at www.mkfounder.com Buy our products or get free samples, for further information and requests, e-mail us at: sales@mkfounder.com 12. Copyrights & Disclaimer Copyright MK Founder, trademarks Registered. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. Devices sold by MK Founder are covered by the warranty and patent indemnification provisions appearing in its General Terms of Trade. MK Founder makes no warranty, express, statutory, implied, or by description regarding the information set forth herein. MK Founder reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with MK Founder for current information. This product is intended for use in commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by MK Founder for each application. This product is provided by MK Founder “AS IS” and any express or implied warranties, including, but not limited to the implied warranties of merchantability and fitness for a particular purpose are disclaimed. MK Founder shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of MK Founder rendering of technical or other services. 13. Reversion History Document ID Release Date Sheet Status Change Notice Supersedes 0.1 08-Mar-2018 Product data sheet - - 0.2 11-Jun-2018 Product Datasheet Change IPP、PPP 5 www.mkfounder.com 11-Jun-2018 © MK Founder Co., LTD. All right reserved Reversion:0.2
MKT642U05 价格&库存
很抱歉,暂时无法提供与“MKT642U05”相匹配的价格&库存,您可以联系我们找货
