PTVS5V5D1BLYL
PTVS5V5D1BLYL
    NEXPERIA(安世)
    DFN1006-2
    TVS二极管 VRWM=5.5 V VBR(Min)=5.6 V VC=12.2 V IPP=35 A Ppp=Original DFN1006-2
PTVS5V5D1BLYL 数据手册
PTVS5V5D1BL Ultra compact transient voltage supressor 23 March 2018 Product data sheet 1. General description Transient voltage supressor in a DFN1006-2 (SOD882) ultra small and leadless Surface-Mounted Device (SMD) package designed to protect one line against high surge currents and other transients. 2. Features and benefits • • • • • • Bidirectional ESD protection of one line Very high surge robustness; IPP = 40 A for 8/20 µs pulse (average measured) Very low clamping voltage: VCL= 10.5 V typ. for 34 A, 8/20 µs pulse ESD protection up to 30 kV Very low dynamical resistance Rdyn = 0.07 Ω (TLP) AEC-Q101 qualified 3. Applications Surge protection for: • • supply and battery lines audio interfaces in portable communication, consumer and computing devices. 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VRWM reverse standoff voltage Tamb = 25 °C - - 5.5 V VCL clamping voltage IPPM = 35 A; tp = 8/20 µs; Tamb = 25 °C - 10.3 12.2 V [1] In accordance with IEC 61000-4-5 (8/20 µs current waveform). [1] PTVS5V5D1BL Nexperia Ultra compact transient voltage supressor 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 K1 cathode (diode 1) 2 K2 cathode (diode 2) Simplified outline 1 Graphic symbol K1 2 K2 sym045 Transparent top view DFN1006-2 (SOD882) 6. Ordering information Table 3. Ordering information Type number Package PTVS5V5D1BL Name Description Version DFN1006-2 plastic, leadless ultra small package; 2 terminals; 0.65 mm pitch; SOD882 1 mm x 0.6 mm x 0.48 mm body 7. Marking Table 4. Marking codes Type number Marking code PTVS5V5D1BL J8 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit IPPM rated peak pulse current tp = 8/20 µs - 35 A Tj junction temperature - 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C [1] ESD maximum ratings VESD [1] [2] electrostatic discharge voltage IEC 61000-4-2; contact discharge [2] - 30 kV IEC 61000-4-2; air discharge [2] - 30 kV In accordance with IEC 61000-4-5 (8/20 µs current waveform). Device stressed with ten non-repetitive ESD pulses. PTVS5V5D1BL Product data sheet All information provided in this document is subject to legal disclaimers. 23 March 2018 © Nexperia B.V. 2018. All rights reserved 2 / 12 PTVS5V5D1BL Nexperia Ultra compact transient voltage supressor 001aaa630 120 IPP 100 % 100 % IPP; 8 µs IPP (%) 80 90 % e-t 50 % IPP; 20 µs 40 10 % 0 Fig. 1. 0 10 20 30 t (µs) 8/20 µs pulse waveform according to IEC 61000-4-5 t tr = 0.6 ns to 1 ns 40 30 ns 60 ns Fig. 2. 001aaa631 ESD pulse waveform according to IEC 61000-4-2 9. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit VRWM reverse standoff voltage Tamb = 25 °C - - 5.5 V VBR breakdown voltage IR = 5 mA; Tamb = 25 °C 5.6 6.4 7.6 V IRM reverse leakage current VR = 5.5 V; Tamb = 25 °C - 10 100 nA Cd diode capacitance f = 1 MHz; VR = 0 V; Tamb = 25 °C - 70 84 pF VCL clamping voltage IPP = 1 A; tp = 8/20 µs; Tamb = 25 °C [1] - 5.7 6.9 V IPPM = 35 A; tp = 8/20 µs; Tamb = 25 °C [1] - 10.3 12.2 V - 7.1 - V - 0.1 - Ω IPP = 16 A; tp = TLP; Tamb = 25 °C Rdyn [1] [2] dynamic resistance IR = 10 A; Tamb = 25 °C [2] In accordance with IEC 61000-4-5 (8/20 µs current waveform). Non-repetitive current pulse, Transmission Line Pulse (TLP); square pulse; ANSI/ESD STM5.5.1-2008 PTVS5V5D1BL Product data sheet All information provided in this document is subject to legal disclaimers. 23 March 2018 © Nexperia B.V. 2018. All rights reserved 3 / 12 PTVS5V5D1BL Nexperia Ultra compact transient voltage supressor IPPM IPP aaa-028334 80 Cd (pF) 60 IR IRM -VCL -VBR -VRWM 40 -IRM -IR VRWM VBR VCL 20 - + 0 -IPP -IPPM Fig. 3. 006aab325 V-I characteristics for a bidirectional ESD protection diode -3 0 3 Fig. 4. 6 Diode capacitance as a function of reverse voltage; typical values aaa-028336 0 IPP (A) VR (V) f = 1 MHz; Tamb = 25 °C aaa-028335 90 -6 Rdyn = 0.08 Ω IPP (A) 60 -30 Rdyn = 0.06 Ω 30 0 -60 0 4 8 VCL (V) -90 -12 12 tp = 100 ns; Transmission Line Pulse (TLP) Fig. 5. Product data sheet -4 VCL (V) 0 tp = 100 ns; Transmission Line Pulse (TLP) Positive clamping voltage (TLP); typical values PTVS5V5D1BL -8 Fig. 6. Negative clamping voltage (TLP); typical values All information provided in this document is subject to legal disclaimers. 23 March 2018 © Nexperia B.V. 2018. All rights reserved 4 / 12 PTVS5V5D1BL Nexperia Ultra compact transient voltage supressor aaa-028337 14 VCL (V) 12 10 -4 8 -6 6 -8 4 -10 2 -12 0 0 10 20 30 40 IPP (A) -14 -50 50 tp = 8/20 μs; according to IEC 61000-4-5 Fig. 7. aaa-028338 0 VCL (V) -2 -40 -30 -20 -10 IPP (A) 0 tp = 8/20 μs; according to IEC 61000-4-5 Positive clamping voltage (8/20 μs pulse); typical values Fig. 8. Negative clamping voltage (8/20 μs pulse); typical values aaa-028339 103 PPPM (W) 102 10 1 Fig. 9. 10 102 103 tp (ms) 104 Rated peak pulse power as a function of square pulse duration; typical values PTVS5V5D1BL Product data sheet All information provided in this document is subject to legal disclaimers. 23 March 2018 © Nexperia B.V. 2018. All rights reserved 5 / 12 PTVS5V5D1BL Nexperia Ultra compact transient voltage supressor ESD TESTER 4 GHz DIGITAL OSCILLOSCOPE RG 223/U 50 Ω coax Rd 40 dB ATTENUATOR Cs 50 Ω DUT (DEVICE UNDER TEST) IEC 61000-4-2 ed.2 Cs = 150 pF; Rd = 330 Ω 10 2 V (kV) 8 V (kV) 0 6 -2 4 -4 2 -6 0 -8 -2 -10 0 10 20 30 40 50 t (ns) 60 -10 -10 70 unclamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) 0 10 20 30 40 50 t (ns) 60 70 unclamped -8 kV ESD pulse waveform (IEC 61000-4-2 network) aaa-003952 Fig. 10. ESD clamping test setup and waveforms aaa-028340 80 aaa-028341 40 VCL (V) VCL (V) 40 0 VCL_ESD at 30 ns = 10 V 0 -40 -10 VCL_ESD at 30 ns = 10 V -40 0 10 20 30 40 50 -80 -10 60 70 t (ns) Fig. 11. Clamped +8 kV pulse waveform (IEC 61000-4-2 network) PTVS5V5D1BL Product data sheet 0 10 20 30 40 50 60 70 t (ns) Fig. 12. Clamped -8 kV pulse waveform (IEC 61000-4-2 network) All information provided in this document is subject to legal disclaimers. 23 March 2018 © Nexperia B.V. 2018. All rights reserved 6 / 12 PTVS5V5D1BL Nexperia Ultra compact transient voltage supressor 10. Application information The device is designed for the protection of one bidirectional data line from surge pulses and ESD damage. The device is suitable on lines where the signal polarities are both positive and negative with respect to ground. line to be protected TVS protection diode GND aaa-026975 Fig. 13. Application diagram Circuit board layout and protection device placement Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT) and surge transients. The following guidelines are recommended: 1. 2. 3. 4. 5. 6. 7. 8. Place the device as close to the input terminal or connector as possible. Minimize the path length between the device and the protected line. Keep parallel signal paths to a minimum. Avoid running protected conductors in parallel with unprotected conductors. Minimize all Printed-Circuit Board (PCB) conductive loops including power and ground loops. Minimize the length of the transient return path to ground. Avoid using shared transient return paths to a common ground point. Use ground planes whenever possible. For multilayer PCBs, use ground vias. 11. Test information Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. PTVS5V5D1BL Product data sheet All information provided in this document is subject to legal disclaimers. 23 March 2018 © Nexperia B.V. 2018. All rights reserved 7 / 12 PTVS5V5D1BL Nexperia Ultra compact transient voltage supressor 12. Package outline DFN1006-2: Leadless ultra small plastic package; 2 terminals; body 1.0 x 0.6 x 0.5 mm L SOD882 L 1 2 b e1 A A1 E D (2) 0 0.5 Dimensions (mm are the original dimensions) Unit A(1) A1 b D E 1 mm scale e1 L max 0.50 0.03 0.55 0.62 1.02 0.30 nom 0.65 min 0.46 0.47 0.55 0.95 0.22 mm Note 1. Including plating thickness 2. The marking bar indicates the cathode (if applicable) Outline version sod882_po References IEC JEDEC JEITA European projection Issue date 14-08-26 14-08-27 SOD882 Fig. 14. Package outline DFN1006-2 (SOD882) PTVS5V5D1BL Product data sheet All information provided in this document is subject to legal disclaimers. 23 March 2018 © Nexperia B.V. 2018. All rights reserved 8 / 12 PTVS5V5D1BL Nexperia Ultra compact transient voltage supressor 13. Soldering 1.3 0.7 R0.05 (8×) solder lands 0.6 0.7 0.8 (2×) (2×) (2×) 0.9 solder resist solder paste occupied area 0.3 (2×) Dimensions in mm 0.4 (2×) 0.5 (2×) sod882_fr Fig. 15. Reflow soldering footprint for DFN1006-2 (SOD882) PTVS5V5D1BL Product data sheet All information provided in this document is subject to legal disclaimers. 23 March 2018 © Nexperia B.V. 2018. All rights reserved 9 / 12 PTVS5V5D1BL Nexperia Ultra compact transient voltage supressor 14. Revision history Table 7. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PTVS5V5D1BL v.1 20180323 Product data sheet - - PTVS5V5D1BL Product data sheet All information provided in this document is subject to legal disclaimers. 23 March 2018 © Nexperia B.V. 2018. All rights reserved 10 / 12 PTVS5V5D1BL Nexperia Ultra compact transient voltage supressor for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. 15. Legal information Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’ aggregate and cumulative liability towards customer Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PTVS5V5D1BL Product data sheet Trademarks All information provided in this document is subject to legal disclaimers. 23 March 2018 © Nexperia B.V. 2018. All rights reserved 11 / 12 PTVS5V5D1BL Nexperia Ultra compact transient voltage supressor 16. Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 2 9. Characteristics..............................................................3 10. Application information............................................. 7 11. Test information..........................................................7 12. Package outline.......................................................... 8 13. Soldering..................................................................... 9 14. Revision history........................................................10 15. Legal information..................................................... 11 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 23 March 2018 PTVS5V5D1BL Product data sheet All information provided in this document is subject to legal disclaimers. 23 March 2018 © Nexperia B.V. 2018. All rights reserved 12 / 12 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: PTVS5V5D1BLYL
PTVS5V5D1BLYL 价格&库存
很抱歉,暂时无法提供与“PTVS5V5D1BLYL”相匹配的价格&库存,您可以联系我们找货
PTVS5V5D1BLYL
    PTVS5V5D1BLYL
    • 1+0.50199
    • 100+0.47689
    • 300+0.45179
    • 500+0.42669
    • 2000+0.41414
    • 5000+0.40661
