1.5KE36CA
1.5KE36CA
    YENJI(台湾元基)
    DO201
    ESD抑制器/TVS二极管 双向 30.8V 30.5A 1.5KW DO201
1.5KE36CA 数据手册
1.5KE SERIES TRANSIENT VOLTAGE SUPPRESSORS FEATURE Plastic package. Glass passivated chip junction in DO-201 package. 1500W surge capability at 10/1000μs waveform. Excellent clamping capability. Low zener impedance. Fast response time: typically less than 1.0ps from 0 Volts to BV min. Typical IR less than 1μA above 10V. High temperature soldering guaranteed: 265ć/10 seconds/.375”, (9.5mm) lead length, 5lbs., (2.3kg) tension. DO-201 MECHANICAL DATE Case: JEDEC DO-201 Molded Plastic. Terminals: Axial leads, solderable per MIL-STD-750, Method 2026. Polarity: Color and denotes cathode except Bipolar. Mounting Position: Any. Weight: 0.045 ounce, 1.2 grams. DEVICES FOR BIPOLAR APPLICATION For bidirectional use C or CA suffix for types 1.5KE6.8 thru types 1.5KE550 (e.g.1.5KE6.8C, 1.5KE550CA), electrical characteristics apply in both directions. MAXIMUM RATINGS AND CHARACTERISTICS Ratings at 25ć ambient temperature unless otherwise specified. RATING SYMBOL VALUE UNITS Peak Pulse Power Dissipation on 10/1000ȝs waveform (Note1, Fig.1). PPPM Minimum 1500 Watts Peak Pulse Current of on 10/1000ȝs waveform.(Note1,Fig.3) IPPM See Table Amps Steady State Power Dissipation at TL =75ć,Lead lengths.375”, (9.5mm) (Fig.5). PM(AV) 6.5 Watts Peak Forward Surge Current,8.3ms Single Half Sine-Wave Superimposed on Rated Load, (JEDEC Method) (Note 2,Fig.6). IFSM 200 Amps TJ , TSTG -55 to +175 ć Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above T A = 25ć per Fig. 2. 2. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum. 1/4 1.5KE SERIES DIMENSIONS d s DIA. DIA. L T L DO-201 Millimeters Item Inches Min. Max. Min. Max. L 25.40 - 1.000 - T 7.20 9.50 0.285 0.375 d 4.80 5.30 0.190 0.210 s 0.96 1.07 0.038 0.042 ELECTRICAL CHARACTERISTICS Part Number Reverse Stand-Off Voltage Breakdown Voltage NIN.@IT Breakdown Voltage MAX.@IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM UNT-POLAR BI-POLAR VRWM(V) VBR MIN.(V) VBR MAX.(V) IT(mA) VC(V) IPP(A) IR(ȝA) 1.5KE6.8A 1.5KE6.8CA 5.80 6.45 7.14 10 10.5 144.8 1000 1.5KE7.5A 1.5KE7.5CA 6.40 7.13 7.88 10 11.3 134.5 500 1.5KE8.2A 1.5KE8.2CA 7.02 7.79 8.61 10 12.1 125.6 200 1.5KE9.1A 1.5KE9.1CA 7.78 8.65 9.55 1 13.4 113.4 50 1.5KE10A 1.5KE10CA 8.55 9.50 10.50 1 14.5 104.8 10 1.5KE11A 1.5KE11CA 9.40 10.50 11.60 1 15.6 97.4 5 1.5KE12A 1.5KE12CA 10.20 11.40 12.60 1 16.7 91.0 5 1.5KE13A 1.5KE13CA 11.10 12.40 13.70 1 18.2 83.5 1 1.5KE15A 1.5KE15CA 12.80 14.30 15.80 1 21.2 71.7 1 1.5KE16A 1.5KE16CA 13.60 15.20 16.80 1 22.5 67.6 1 1.5KE18A 1.5KE18CA 15.30 17.10 18.90 1 25.2 60.3 1 1.5KE20A 1.5KE20CA 17.10 19.00 21.00 1 27.7 54.9 1 1.5KE22A 1.5KE22CA 18.80 20.90 23.10 1 30.6 49.7 1 1.5KE24A 1.5KE24CA 20.50 22.80 25.20 1 33.2 45.8 1 1.5KE27A 1.5KE27CA 23.10 25.70 28.40 1 37.5 40.5 1 2/4 1.5KE SERIES ELECTRICAL CHARACTERISTICS Part Number Reverse Stand-Off Voltage Breakdown Voltage NIN.@IT Breakdown Voltage MAX.@IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM UNT-POLAR BI-POLAR VRWM(V) VBR MIN.(V) VBR MAX.(V) IT(mA) VC(V) IPP(A) IR(ȝA) 1.5KE30A 1.5KE30CA 25.60 28.50 31.50 1 41.4 36.7 1 1.5KE33A 1.5KE33CA 28.20 31.40 34.70 1 45.7 33.3 1 1.5KE36A 1.5KE36CA 30.80 34.20 37.80 1 49.9 30.5 1 1.5KE39A 1.5KE39CA 33.30 37.10 41.00 1 53.9 28.2 1 1.5KE43A 1.5KE43CA 36.80 40.90 45.20 1 59.3 25.6 1 1.5KE47A 1.5KE47CA 40.20 44.70 49.40 1 64.8 23.5 1 1.5KE51A 1.5KE51CA 43.60 48.50 53.60 1 70.1 21.7 1 1.5KE56A 1.5KE56CA 47.80 53.20 58.80 1 77.0 19.7 1 1.5KE62A 1.5KE62CA 53.00 58.90 65.10 1 85.0 17.9 1 1.5KE68A 1.5KE68CA 58.10 64.60 71.40 1 92.0 16.5 1 1.5KE75A 1.5KE75CA 64.10 71.30 78.80 1 103.0 14.8 1 1.5KE82A 1.5KE82CA 70.10 77.90 86.10 1 113.0 13.5 1 1.5KE91A 1.5KE91CA 77.80 86.50 95.50 1 125.0 12.2 1 1.5KE100A 1.5KE100CA 85.50 95.00 105.00 1 137.0 11.1 1 1.5KE110A 1.5KE110CA 94.00 105.00 116.00 1 152.0 10.0 1 1.5KE120A 1.5KE120CA 102.00 114.00 126.00 1 165.0 9.2 1 1.5KE130A 1.5KE130CA 111.00 124.00 137.00 1 179.0 8.5 1 1.5KE150A 1.5KE150CA 128.00 143.00 158.00 1 207.0 7.3 1 1.5KE160A 1.5KE160CA 136.00 152.00 168.00 1 219.0 6.9 1 1.5KE170A 1.5KE170CA 145.00 162.00 179.00 1 234.0 6.5 1 1.5KE180A 1.5KE180CA 154.00 171.00 189.00 1 246.0 6.2 1 1.5KE200A 1.5KE200CA 171.00 190.00 210.00 1 274.0 5.5 1 1.5KE220A 1.5KE220CA 185.00 209.00 231.00 1 328.0 4.6 1 1.5KE250A 1.5KE250CA 214.00 237.00 263.00 1 344.0 4.4 1 1.5KE300A 1.5KE300CA 256.00 285.00 315.00 1 414.0 3.7 1 1.5KE350A 1.5KE350CA 300.00 332.00 368.00 1 482.0 3.2 1 1.5KE400A 1.5KE400CA 342.00 380.00 420.00 1 548.0 2.8 1 1.5KE440A 1.5KE440CA 376.00 418.00 462.00 1 602.0 2.5 1 1.5KE480A 1.5KE480CA 408.00 456.00 504.00 1 658.0 2.3 1 1.5KE510A 1.5KE510CA 434.00 485.00 535.00 1 698.0 2.1 1 1.5KE530A 1.5KE530CA 450.00 503.50 556.50 1 725.0 2.1 1 1.5KE540A 1.5KE540CA 459.00 513.00 567.00 1 740.0 2.0 1 1.5KE550A 1.5KE550CA 467.00 522.50 577.50 1 760.0 2.0 1 Notes: For bidirectional type having VRWM of 10 volts and less, the IR limit is double. 3/4 1.5KE SERIES RATINGS AND CHARACTERISTIC CURVES Figure 1 - Peak Pulse Power Rating Curve (TA=25ć unless otherwise noted) Figure 2 - Pulse Derating Curve 100 Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM-Peak Pulse Power (kW) 1000 100 10 1 75 50 25 0 0.1 0.000001 0.00001 0.0001 0 0.001 td-Pulse Width (Sec.) 100 125 150 175 200 100000 tr=10μsec TJ=25°C Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM Peak Value IPPM 100 Bi-directional V=0V 10000 Uni-directional V=0V Cj (pF) IPPM- Peak Pulse Current, % IRSM 75 Figure 4 - Typical Junction Capacitance 150 Half Value IPPM IPPM ( ) 1000 Uni-directional @ VR 100 2 Bi-directional @ VR 50 10/1000μsec. Waveform as defined by R.E.A 10 td 1.0 0 2.0 3.0 Tj=25C f=1.0MHz Vsig=50mVp-p 1 1.0 4.0 Figure 5 - Steady State Power Dissipation Derating Curve 6.5 6 5.5 5 4.5 4 3.5 3 2.5 2 1.5 1 0.5 0 10.0 100.0 1000.0 VBR - Reverse Breakdown Voltage (V) t-Time (ms) Figure 6 - Maximum Non-Repetitive Forward Surge Current Uni-Directional Only 200 IFSM - Peak Forward Surge Current (A) Steady State Power Dissipation (W) 50 TA-Ambient Temperature (ºC) Figure 3 - Pulse Waveform 0 25 L = 0.375” (9.5mm) Lead Lengths 0 25 50 75 100 125 150 175 180 160 140 120 100 80 60 40 20 0 200 1 TL - Lead Temperature(ºC) 4/4 10 Number of Cycles at 60 Hz 100
1.5KE36CA 价格&库存
很抱歉,暂时无法提供与“1.5KE36CA”相匹配的价格&库存,您可以联系我们找货
