P6KE24CA
P6KE24CA
    YENJI(台湾元基)
    DO-15
    DO15 DIP 20.5V 33.2V
P6KE24CA 数据手册
P6KE SERIES TRANSIENT VOLTAGE SUPPRESSORS FEATURE Plastic package. Glass passivated chip junction in DO-15 Package 600W peak pulse power capability on 10/1000μs waveform. Excellent clamping capability. Low zener impedance. Fast response time: typically less than 1.0ps from 0 Volts to BV min. Typical IR less than 1μA above 10V. High temperature soldering guaranteed: 265ć/10 seconds/.375”, (9.5mm) lead length, 5lbs., (2.3kg) tension. DO-204AC/DO-15 MECHANICAL DATE Case: JEDEC DO-15 Molded Plastic. Terminals: Axial leads, solderable per MIL-STD-750, Method 2026. Polarity: Color band denoted cathode except bidirectional. Mounting Position: Any. Weight: 0.015 ounce, 0.4grams. DEVICES FOR BIPOLAR APPLICATION For bidirectional use C or CA suffix for types P6KE6.8 thru types P6KE550 (e.g.P6KE6.8C, P6KE550CA), electrical characteristics apply in both directions. MAXIMUM RATINGS AND CHARACTERISTICS Ratings at 25ć ambient temperature unless otherwise specified. RATING SYMBOL VALUE UNITS Peak Pulse Power Dissipation on 10/1000ȝs waveform (Note1, Fig.1). PPPM Minimum 600 Watts Peak Pulse Current of on 10/1000ȝs waveform.(Note1,Fig.3) IPPM See Table Amps Steady State Power Dissipation at TL =75ć,Lead lengths.375”, (9.5mm) (Fig.5). PM(AV) 5.0 Watts Peak Forward Surge Current,8.3ms Single Half Sine-Wave Superimposed on Rated Load, (JEDEC Method) (Note 2,Fig.6). IFSM 100 Amps TJ , TSTG -55 to +175 ć Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25ć per Fig. 2. 2. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum. 1/4 P6KE SERIES DIMENSIONS d s DIA. DIA. L T L DO-204AC/DO-15 Millimeters Item Inches Min. Max. Min. Max. L 25.40 - 1.000 - T 5.80 7.60 0.230 0.300 d 2.60 3.60 0.104 0.140 s 0.71 0.86 0.028 0.034 ELECTRICAL CHARACTERISTICS Part Number Reverse Stand-Off Voltage Breakdown Voltage NIN.@IT Breakdown Voltage MAX.@IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM UNT-POLAR BI-POLAR VRWM(V) VBR MIN.(V) VBR MAX.(V) IT(mA) VC(V) IPP(A) IR(ȝA) P6KE6.8A P6KE6.8CA 5.80 6.45 7.14 10 10.5 58.1 1000 P6KE7.5A P6KE7.5CA 6.40 7.13 7.88 10 11.3 54.0 500 P6KE8.2A P6KE8.2CA 7.02 7.79 8.61 10 12.1 50.4 200 P6KE9.1A P6KE9.1CA 7.78 8.65 9.55 1 13.4 45.5 50 P6KE10A P6KE10CA 8.55 9.50 10.50 1 14.5 42.1 10 P6KE11A P6KE11CA 9.40 10.50 11.60 1 15.6 39.1 5 P6KE12A P6KE12CA 10.20 11.40 12.60 1 16.7 36.5 5 P6KE13A P6KE13CA 11.10 12.40 13.70 1 18.2 33.5 1 P6KE15A P6KE15CA 12.80 14.30 15.80 1 21.2 28.8 1 P6KE16A P6KE16CA 13.60 15.20 16.80 1 22.5 27.1 1 P6KE18A P6KE18CA 15.30 17.10 18.90 1 25.2 24.2 1 P6KE20A P6KE20CA 17.10 19.00 21.00 1 27.7 22.0 1 P6KE22A P6KE22CA 18.80 20.90 23.10 1 30.6 19.9 1 P6KE24A P6KE24CA 20.50 22.80 25.20 1 33.2 18.4 1 P6KE27A P6KE27CA 23.10 25.70 28.40 1 37.5 16.3 1 2/4 P6KE SERIES ELECTRICAL CHARACTERISTICS Part Number Reverse Stand-Off Voltage Breakdown Voltage NIN.@IT Breakdown Voltage MAX.@IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM UNT-POLAR BI-POLAR VRWM(V) VBR MIN.(V) VBR MAX.(V) IT(mA) VC(V) IPP(A) IR(ȝA) P6KE30A P6KE30CA 25.60 28.50 31.50 1 41.4 14.7 1 P6KE33A P6KE33CA 28.20 31.40 34.70 1 45.7 13.3 1 P6KE36A P6KE36CA 30.80 34.20 37.80 1 49.9 12.2 1 P6KE39A P6KE39CA 33.30 37.10 41.00 1 53.9 11.3 1 P6KE43A P6KE43CA 36.80 40.90 45.20 1 59.3 10.3 1 P6KE47A P6KE47CA 40.20 44.70 49.40 1 64.8 9.4 1 P6KE51A P6KE51CA 43.60 48.50 53.60 1 70.1 8.7 1 P6KE56A P6KE56CA 47.80 53.20 58.80 1 77.0 7.9 1 P6KE62A P6KE62CA 53.00 58.90 65.10 1 85.0 7.2 1 P6KE68A P6KE68CA 58.10 64.60 71.40 1 92.0 6.6 1 P6KE75A P6KE75CA 64.10 71.30 78.80 1 103.0 5.9 1 P6KE82A P6KE82CA 70.10 77.90 86.10 1 113.0 5.4 1 P6KE91A P6KE91CA 77.80 86.50 95.50 1 125.0 4.9 1 P6KE100A P6KE100CA 85.50 95.00 105.00 1 137.0 4.5 1 P6KE110A P6KE110CA 94.00 105.00 116.00 1 152.0 4.0 1 P6KE120A P6KE120CA 102.00 114.00 126.00 1 165.0 3.7 1 P6KE130A P6KE130CA 111.00 124.00 137.00 1 179.0 3.4 1 P6KE150A P6KE150CA 128.00 143.00 158.00 1 207.0 2.9 1 P6KE160A P6KE160CA 136.00 152.00 168.00 1 219.0 2.8 1 P6KE170A P6KE170CA 145.00 162.00 179.00 1 234.0 2.6 1 P6KE180A P6KE180CA 154.00 171.00 189.00 1 246.0 2.5 1 P6KE200A P6KE200CA 171.00 190.00 210.00 1 274.0 2.2 1 P6KE220A P6KE220CA 185.00 209.00 231.00 1 328.0 1.9 1 P6KE250A P6KE250CA 214.00 237.00 263.00 1 344.0 1.8 1 P6KE300A P6KE300CA 256.00 285.00 315.00 1 414.0 1.5 1 P6KE350A P6KE350CA 300.00 332.00 368.00 1 482.0 1.3 1 P6KE400A P6KE400CA 342.00 380.00 420.00 1 548.0 1.1 1 P6KE440A P6KE440CA 376.00 418.00 462.00 1 602.0 1.04 1 P6KE480A P6KE480CA 408.00 456.00 504.00 1 658.0 0.9 1 P6KE510A P6KE510CA 434.00 485.00 535.00 1 698.0 0.9 1 P6KE530A P6KE530CA 450.00 503.50 556.50 1 725.0 0.8 1 P6KE540A P6KE540CA 459.00 513.00 567.00 1 740.0 0.8 1 P6KE550A P6KE550CA 467.00 522.50 577.50 1 760.0 0.8 1 P6KE600A P6KE600CA 512.00 570.00 630.00 1 828.0 0.75 1 Notes: For bidirectional type having VRWM of 10 volts and less, the IR limit is double. 3/4 P6KE SERIES RATINGS AND CHARACTERISTIC CURVES Figure 2 - Pulse Derating Curve Figure 1 - Peak Pulse Power Rating Curve Non-repetitive Pulse Waveform shown in Fig 3. TA=25ûC 10 1 0.1 1.0μs 10μs 100μs 1.0ms 100 Peak Pulse Power (PPP) or Current (IPPM) Derating in Percentage, % PPPM- Peak Pulse Power (kW) 100 0.1μs (TA=25ć unless otherwise noted) 75 50 25 0 0 10ms td- Pulse Width (sec.) 100 125 150 175 200 10000 tr=10μsec TJ=25°C Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM Peak Value IPPM 100 Bi-directional V=0V Uni-directional @VR Half Value IPPM IPPM ( ) 2 50 100 10/1000μsec. Waveform as defined by R.E.A Bi-directional @VR 10 Tj=25C f=1.0MHz Vsig=50mVp-p td 1.0 0 Uni-directional V=0V 1000 Cj (pF) IPPM- Peak Pulse Current, % IRSM 75 Figure 4 - Typical Junction Capacitance Uni-Directional 150 2.0 3.0 1 1.0 4.0 10.0 100.0 1000.0 VBR - Reverse Breakdown Voltage (V) t-Time (ms) Figure 6 - Maximum Non-Repetitive Forward Surge Current Uni-Directional Only Figure 5 - Steady State Power Dissipation Derating Curve 6 120 IFSM - Peak Forward Surge Current (A) Steady State Power Dissipation (W) 50 TA- Ambient Temperature (oC) Figure 3 - Pulse Waveform 0 25 5 4 3 2 L = 0.375” (9.5mm) Lead Lengths 1 0 0 25 50 75 100 125 150 175 100 80 60 40 20 0 200 1 TL-Lead Temperature(ºC) 10 Number of Cycles at 60 Hz 4/4 100
P6KE24CA
PDF文档中包含了以下信息:
物料型号:P6KE系列 器件简介:瞬态电压抑制二极管,用于保护电子设备免受电压突波的损害。
引脚分配:P6KE系列瞬态电压抑制二极管通常有2个引脚,分别为阳极和阴极。
参数特性:击穿电压、漏电流、电容、封装类型等。
功能详解:P6KE系列瞬态电压抑制二极管的主要功能是保护电子设备免受静电放电、电感性负载开关、电源线路浪涌等瞬态电压的损害。
应用信息:广泛应用于电子设备的电源线路、信号线路、数据线等的保护。
封装信息:P6KE系列瞬态电压抑制二极管有多种封装形式,如SOD-123、SMA、SMB等。
P6KE24CA 价格&库存
很抱歉,暂时无法提供与“P6KE24CA”相匹配的价格&库存,您可以联系我们找货
P6KE24CA
  • 20+0.22840
  • 200+0.19250
  • 500+0.16390
  • 2000+0.14090
  • 4000+0.12960
库存:239
