YBS0060N-C
YBS0060N-C
    YENJI(台湾元基)
    SMB(DO-214AA)
    半导体放电管 VDRM=6V VT=4V IT=2.2A
YBS0060N-C 数据手册
YBS0060N-C Thyristor Surge Suppressors Description thyristor Series are low capacitance devices designed to protect broadband equipment such as VOIP, DSL modems and DSLAMs from damaging overvoltage transients. The series provides a surface mount solution that enables equipment to comply with global regulatory standards while limiting the impact to broadband signals. DO-214AA/SMB Features and Benefits • Low voltagr overeshoot • Low on-state voltage • Does not degrade with use • Fails short circuit when surged in excess of ratings • Low Capacitance Application Information • Video Electrical Characteristics V DRM@ Part Number V S@ V T@ IDRM=5µA 100V/µS I T=2.2Amps V min V max V max 6 25 4 YBS0060N-C IS IT IH mA max A max mA min 800 Capacitance @1MHz, 2V bias pF min 50 2.2 45 pF max 100 Absolute maximum ratings measured at TA =25° C RH=45%-75%(unless otherwise noted). 1.Vs is measured at 100KV/S 2.Off-state Capacitance is measured at V DC =2V,VRMS =1V,f=1MH Surge Ratings I PP Series YBS 2x10 µs 8x20 µs 10x160 µs 50x320 µs 10x1000 µs A min A min A min A min A min 500 400 200 150 100 ITSM 50/60 H z di/dt A min A/μs max 50 500 - Peak pulse current rating(I pp) is repetitive and guaranteed for the life of the product; - Yenji only makes the test for 5/320us@150A*(10/700us@6KV),but for other IPP value derived from experience is just for reference only.Yenji will not take any obligation for these parameters,so before applying our parts,please make sure to verify the parameters listed in the above table. 1/3 YBS0060N-C Thyristor Surge Suppressors Part Numbering System YBS (1) 0060 (2) N (3) C (4) (1) YENJI Semiconductor Surge Arrester (2) Off-state Voltage,e.g:0060=6V (3) Package:DO-214AA/SMB (4) Rating Surge Voltage:6KV (10/700uS) Characteristics Curves V-I Characteristics t r x t d Pulse Waveform IPP – Peak Pulse Current – %I PP +I IT IS IH IDRM -V +V VT VDRM VS tr = rise time to peak v alue td = decay time to half value Peak Value 100 Waveform = t r x td 50 Half Value 0 0 td tr t – Time (µs) -I S Change vs. Junction Temperature Normalized DC Holding Current vs. Case Temperature 14 12 10 IH 8 6 25 °C 4 2 0 -4 -6 -8 IH (TC = 25ºC) 2.0 Ratio of Percent of V S Change – % Normalized V 1.8 1.6 1.4 1.0 0.8 0.6 0.4 -40 -20 0 -40 20 40 60 80 100 120 140 160 Junction Temperature (T J) 25°C 1.2 -20 0 20 40 60 80 100 120 140 Case Temperature (T C) - ºC – °C 2/3 160 YBS0060N-C Thyristor Surge Suppressors Dimensions — DO-214AA Pad Outline Case Temperature Measurement Point B D 0.110 (2.8) C A 0.079 (2.0) H E inch (millimeter) F G K Inches Dimensions 0.079 (2.0) Min Millimeters Max Symbol 0.156 3.30 B 0.201 0.220 5.10 5.60 C 0.077 0.087 1.95 2.20 DO-214AA 4.60 0.159 0.181 4.05 E 0.030 0.063 0.75 1.60 F 0.075 0.096 1.90 2.45 G 0.002 0.008 0.05 0.20 H 0.077 0.104 1.95 2.65 K 0.006 0.016 0.15 0.41 Unit TJ Operating Junction Temperature Range °C TS Storage Temperature Range °C R0JA Thermal Resistance: Junction to Ambient 90 °C/ W Packing Options Industry Standard YBS0060N-C DO-214AA Tape & Reel Pack 2500 N/A EIA-481-D Tape and Reel Specification-DO-214AA 0.157 (4.0) 0.472 (12.0) 0.36 (9.2) 0.315 (8.0) 0.059 DIA (1.5) 12.99 (330.0) Cover tape Dimensions are in inches (and millimeters). 0.512 (13.0) Arbor Hole Dia. Direction of Feed 0.49 (12.4) 3/3 3.95 D Value Parameter Max 0.130 Thermal Considerations Package Min A
YBS0060N-C 价格&库存
很抱歉,暂时无法提供与“YBS0060N-C”相匹配的价格&库存,您可以联系我们找货
