SMD4532-075-LF
SMD4532-075-LF
    YENJI(台湾元基)
    气体放电管 75V ±30% 0.5pF
SMD4532-075-LF 数据手册
SMD4532 SERIES Gas Discharge Tube (GDT)  Features 1. RoHS & HF compliant 2. SMD s tructure 3. DC spark- over voltage : 75~600V 4. Low c apacitance 5. Operating temperature: -40℃ ~ +85℃ Storage temperature: -40℃ ~ +115℃ 4532  Recommended Applications 1. Cable m odem 2. xDSL 3. Set top box - 4. TV sets 5. Ethernet port 6. Consumer electronics  Part Number Code SMD4532 1/2 SMD4532 SERIES Gas Discharge Tube (GDT)  Characteristics Part No. DC Spark-over Voltage Max. Impulse Discharge Current Impulse Withstanding Voltage Capacity Impulse Life 100V/S 8/20μs 10/700μs 8/20μs,100A (V) (KA) (KV) (Times) SMD4532-075-LF 75 ±30% SMD4532-090-LF 90 ±30% SMD4532-150-LF 150 ±30% SMD4532-200-LF 200 ±30% SMD4532-230-LF 230 ±30% SMD4532-300-LF 300 ±30% SMD4532-350-LF 350 ±30% SMD4532-400-LF 400 ±30% SMD4532-470-LF 470 ±30% SMD4532-500-LF 500 ±30% SMD4532-600-LF 600 ±30% Maximum Capacitance Minimum Insulation Resistance 1MHz (MΩ) (pF) Min. 1000 (@DC 50V) 3KA (Positive/ Negative 5 Times) 4KV R=40Ω (Positive/ Negative 5 Times) 300 0.5 Min. 100 (@DC 100V)  Dimensions 1.5mm 0.5±0.1mm 4.5±0.3mm 2.7±0.3mm 3.0mm Recommended Pad Size 2/2
SMD4532-075-LF 价格&库存
很抱歉,暂时无法提供与“SMD4532-075-LF”相匹配的价格&库存,您可以联系我们找货
SMD4532-075-LF
    • 1+0.66960
    库存:2500
