GSMD41-201M
GSMD41-201M
    YENJI(台湾元基)
    SPG_D2.8X5MM_SM
    玻璃放电管 200V ±20% 1pF
GSMD41-201M 数据手册
GSMD41 Series Spark Gap Protectors  Features 1. 2. 3. 4.  Small size RoHS compliant and halogen-free Fast response time Low electrode capacitance (1pF) and high isolation (100MΩ) Recommended Applications 1. Telephone, Fax, Modem 2. Power supplies 3. High frequency signal transmitters/receivers 4. Satellite antenna 5. Radio amplifies 6. Alarm systems  Structures and Dimensions Unit:mm  Item Spec Tolerance A 0.4 0.1 B 5.0 0.5 C 2.8 0.2 Electrical Characteristics DC Spark-over Voltage Impulse Withstanding Voltage Capacity 10x700μs Impulse Discharge Current 8x20μs VS (V) (KV) (A) IR(MΩ) Min DC(V) (PF) GSMD41-141N 140±30% 2 1000 100 50 1.0 GSMD41-181N 180±30% 2 1000 100 50 1.0 GSMD41-201M 200±20% 2 1000 100 100 1.0 GSMD41-301M 300±20% 2 1000 100 100 1.0 GSMD41-401M 400±20% 2 1000 100 250 1.0 GSMD41-501M 500±20% 2 1000 100 250 1.0 Part No. 1/3 Insulation Resistance Min.DC Capacitance Max GSMD41 Series Spark Gap Protectors  Soldering Recommendation ◎ IR-reflow Soldering Profile ◎ Recommended Reworking Conditions with Soldering Iron: Item Conditions Temperature of Soldering Iron-tip 350±5 ℃ Soldering Time 3 sec. (max.) 2/3 GSMD41 Series Spark Gap Protectors  Packaging Tape Reel Symbol Dimension (mm) W 12.00±0.20 P0 4.00±0.10 P1 4.00±0.10 P2 2.00±0.10 D0 Φ1.5±0.10 D1 Φ1.5±0.10 E 1.75±0.10 F 5.50±0.05 A0 3.00±0.10 B0 6.00±0.10 K0 3.00±0.10 T 0.30±0.05 D 178.0 d 13.0 L 15.0 Quantity: 1500PCS 3/3
GSMD41-201M 价格&库存
很抱歉,暂时无法提供与“GSMD41-201M”相匹配的价格&库存,您可以联系我们找货
