0.155(3.94)
0.130(3.30)
0.083(2.11)
0.075(1.91)
LED Shunt Protector
Features
Applications
■ Fast switching
■ LED streetlights
■ Automatic reset
■ LCD backlighting
■ SMB package
■ Display lighting
■ Suitable for industrial lighting environments
■ Intrinsically safe lighting
0.185(4.70)
0.160(4.06)
0.096(2.44)
0.083(2.13)
0.012(0.305)
0.006(0.152)
■ RoHS compliant*
0.050(1.27)
0.030(0.76)
0.220(5.59)
0.200(5.08)
DO-214AA(SMB)
General Information
PLED Series protectors are electronic shunts that provide a current bypass
when an LED element in an LED string fails open circuit. This ensures the remaining
string of LEDs will continue to function. There are many cases where high reliability
of the LED lighting must be maintained, such as LCD backlighting, transport lighting,
avionics, intrinsically safe and low maintenance lighting.
Anode
LSPxx00
Control
Circuit
LSP Series
The PLED
Seriesisisavailable
availableininsurface
surfacemount
mountpackage
packageDO-214AA
DO-214AA(SMB)
(SMB)size
sizeformat.
format.
Cathode
Absolute Maximum Ratings (@ TA = 25 °C Unless Otherwise Noted)
Rating
Repetitive peak off-state voltage
LSP0600
PLED6S
PLED9S
LSP0900
LSP1300
PLED13S
LSP1800
PLED18S
6
Symbol
Value
Unit
VDRM
6
9
13
18
V
1
A
A
Operating junction temperature
IT
TJ
-40 to +150
°C
Storage temperature
Ts
-65 to +150
°C
260
°C
Average on-state current (Note 1)
Lead temperature, soldering (10 s)
Notes:
1. Using 75 mm x 75 mm 4-Layer PCB (EIA/JESD51-7).
Electrical Characteristics (@ TA = 25 °C Unless Otherwise Noted)
Parameter
Test Conditions
IDRM Repetitive peak off-state current
VD = VDRM
V(BO) Breakover voltage
dv/dt = 750 V/ms,
RSOURCE = 300
IH
IBO
Breakover current
IT = 1 A, di/dt = 30 mA/ms
di/dt = 0.8 A/ms
VT
On-state voltage
IT = 1 A
Holding current
Min.
LSP0600
PLED6S
PLED9S
LSP0900
PLED13S
LSP1300
PLED18S
LSP1800
Nom.
6
9
13
18
5
Max.
Unit
10
µA
16
18
26
33
V
75
mA
1.2
V
Max.
Unit
30
mA
Thermal Characteristics (@ TA = 25 °C Unless Otherwise Noted)
Parameter
Test Conditions
Junction to free air thermal resistance
EIA/JESD51-3 PCB, IT= 350 mA,
TA= 25 °C
Min.
230
°C/W
EIA/JESD51-7, 75 mm x 75 mm 4-Layer
PCB, IT = 1.0 A, TA= 25 °C
90
°C/W
1/2
Nom.
LED Shunt Protector
V-I Characteristic
On-state Voltage vs. Junction Temperature
+i
1.05
VT
1.00
On-State Voltage (V)
IT
V(BO)
I(BO)
IH
IDRM
ID
-v
VD
VDRM
+v
0.95
0.90
0.85
Characteristics not defined
in this quadrant.
0.80
25
50
75
100
125
150
TJ - Junction Temperature (°C)
-i
Normalized Breakover Voltage vs. Junction Temperature
Typical Application
Normalized Breakover Voltage (V)
1.06
1.05
Current
Source
1.04
1.03
LED1
1.02
Control
Circuit
1.01
1.00
LED2
Control
Circuit
0.99
0.98
25
50
75
100
125
150
Control
Circuit
LEDn
Control
Circuit
Note: The interaction between the YENJI ® PLED device and thepower supply for the LED string dictates
the power supply architecture. Proper care must be taken in the design of the power supplyarchitecture to
ensure that the YENJI ® PLED devices operate asintended and the design maintains integrity.
2/2
很抱歉,暂时无法提供与“PLED6S”相匹配的价格&库存,您可以联系我们找货
