SS52L-SS510L
Surface Mount Schottky Barrier Rectifiers
REVERSE VOLTAGE: 20 --- 100 V
CURRENT: 5.0 A
Features
111
SMB/DO-214AA
Plastic package has Underwriters Laborator
Flammability Classification 94V-0
0.180(4.57)
0.160(4.06)
For surface mounted applications
Low profile package
Built-in strain relief
Metal silicon junction, majority carrier conduction
High surge capability
High current capability,low forward voltage drop
111
11
0.086(2.20)
0.077(1.95)
0.155(3.94)
0.130(3.30)
0.209(5.30)
0.201(5.10)
0.012(0.30)
0.006(0.15)
Low power loss,high effciency
0.096(2.44)
0.084(2.13)
For use in low voltage high frequency inverters,free
wheeling and polarity protection applications
Guardring for overvoltage protection
0.059(1.50)
0.035(0.90)
High temperature soldering guaranteed:250oC/10 1
seconds at terminals
0.008(0.20)
0.002(0.05)
Dimensions in inches and(millimeters)
Mechanical Data
Case:JEDEC SMB,molded plastic over
1111passivated chip
Polarity: Color band denotes cathode end
Weight: 0.093 gram
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25oC ambient temperature unless otherwise specified
SS52L SS53L SS54L SS55L SS56L SS58L SS59L SS510L UNITS
VRRM
Maximum recurrent peak reverse voltage
40
50
60
80
90
100
V
63
70
V
90
100
V
Maximum RMS voltage
VRWS
14
21
28
35
42
56
Maximum DC blocking voltage
V DC
40
50
60
80
Maximum average forw ord rectified current at
c TL(SEE FIG.1) (NOTE 2)
I(AV)
5.0
A
Peak forw ard surge current 8.3ms single halfc sine-w ave superimposed on rated load(JEDEC
c Method)
IFSM
175
A
Maximum instantaneous forw ard voltage at
v 5.0A(NOTE.1)
Maximum DC reverse current @TA=25oC
at rated DC blockjing voltage(NOTE1) @TA=100oC
Typical thermal resitance (NOTE2)
Operating junction temperature range
Storage temperature range
0.45
VF
0.52
0.5
IR
10
RθJA
55
RθJL
17
V
0.72
mA
o
C/W
TJ
-55--- +150
o
TSTG
-55--- +150
o
C
C
NOTE: 1.Pulse test:300μS pulse width,1%duty cy cle
2. P.C.B.mounted with 0.55"X0.55"(14.0X14.0mm 2)copper pad areas
ht t p : //
Revision:20170701-P1
www.lgesem i .c o m
mail:lge@lgesemi.com
SS52L-SS510L
Ratings AND Charactieristic Curves
FIG.2-- PEAK FORWARD SURGE CURRENT
175
5.0
Resistive or
inductive Load
PEAK FORWARD SURGE
CURRENT,AMPERES
AVERAGE FORWARD RECTIFIED
CURRENT,AMPERES
FIG.1 -- FORWARD DERATING CURVE
2.5
PCB MOUNTED ON
0.6X0.6"(16X16mm)
COPPER PAD AREAS
50
60
70 80
90 100 110 120 130 140 150 160 170
140
8.3ms Single Half Sine Wave
TJ=125
105
70
35
AMBIENT TEMPERATURE ℃
NUMBER OF CYCLES AT 60HZ
FIG.4 -- TYPICAL REVERSE CHARACTERISTICS
FIG.3 -- TYPICAL FORWARD CHARACTERISTICS
10
SS52L-SS54L
SS58L-SS510L
SS55L-SS56L
1
TJ =25
Pulse width=300 s
1% duty Cycle
.1
.1
.3
.5
.7
.9
1.1
1.3
1.5
1.7
1.9
2.1
INSTANTANEOUS REVERSE
CURRENT,MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
100
10
5.0
.5
.1
.05
TJ = 25
.01
INSTANTANEOUS FORWARD VOLTAGE,VOLTS
ht t p : //
TJ = 125
1.0
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE,%
www.lgesem i .c o m
很抱歉,暂时无法提供与“SS510L”相匹配的价格&库存,您可以联系我们找货
