SR54 0L THRU SR52 00L
5.0 AMP. L O W
V F Schottky Barrier Rectifiers
Features
•Plastic package has Underwriters Laboratory
Flammability Classification 94V-0 utilizing
DO-201AD/DO-27
Flame Retardant Epoxy Molding Compound.
• Guard ring for overvoltage protection
• High current capability, low forward voltage drop
0.96(24.5)
• Low power loss, high efficiency
MIN.
• High surge capability
DIA.
Mechanical Data
· Case: Molded plastic DO-201AD/DO-27
· Terminals: Plated leads solderable per
MIL-STD-202,Method 208 guaranteed
· Polarity: Color band dentes cathode end
DIA.
0.96(24.5)
MIN.
· Mounting Position: Any
· Making: Type Number
· Lead Free: For RoHS/Lead Free Version
Dimensions in inches and (millimeters)
Maximum Ratings and Electrical Characteristics
Rating at 25℃ ambient temperature unless otherwise specified
Single phase,half wave,60Hz,resistive or inductive load
For capacitive load derate current by 20%
SYMBOL
SR
540L
SR
545L
SR
550L
SR
560L
SR
580L
Maximum Recurrent Peak Reverse Voltage
VRRM
40
45
50
60
80
100
150
200
V
Maximum RMS Voltage
VRMS
28
31.5
35
42
56
70
105
140
V
Maximum DC Blocking Voltage
VDC
40
45
50
60
80
100
150
200
V
Type Number
Average Rectified Output Current (Note 1)
@TL =100℃
Peak Forward Surge Current 8.3ms Single half
sine-wave superimposed on rated load (JEDEC
Method)
I2t Rating for Fusing (t < 8.3ms)
Forward Voltage
@IF=5.0A
Peak Reverse Current
IF(AV)
5.0
A
IFSM
140
A
81.34
A2s
I 2t
VFM
@TA=25℃
At Rated DC Blocking Voltage @TA=100℃
SR
SR
SR
Unit
5100L 5150L 5200L
0.45
IR
0.72
0.55
0.82
0.2
0.1
10.0
5.0
500
mA
Typical Junction Capacitance (Note 2)
CJ
Typical Thermal Resistance Junction to
Ambient(Note 1)
RθJA
25
℃/W
TJ
-55 to + 150
TSTG
-55 to + 150
Operating Temperature Range
Storage Temperature Range
350
V
pF
Note: 1. Leads maintained at ambient temperature at a distance of 9.5mm from the case
2. Measured at 1.0 MHz and Applied reverse Voltage of 4.0V D.C
Revision:20170301-P1
ht t p : //
www.lgesem i .c o m
mail:lge@lgesemi.com
FIG.2-TYPICAL FORWARD CHARACTERISTICS
FIG. 1 - FORWARD CURRENT DERATING CURVE
INSTANTANEOUS FORWARD CURRENT,(A)
AVERAGE FORWARD CURRENT (A)
10
5.0
4.0
3.0
2.0
1.0
50
75
100
125
150
175
SR540L-550L
SR560L
5.0
SR580L- SR5100L
1.0
SR5150L- 5200L
TA = 25 ℃
0.1
0.1
LEAD TEMPERATURE( C)
O
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1.0
INSTANTANEOUS FORWARD VOLTAGE, (V)
FIG. 3
FIG.4TYPICALREVERSE CHRACTERISTIC
MAXIMUM NON-REPETITIVE SURGE CURRENT
200
REVERSE CURRENT (uA)
PEAK FORWARD SURGE CURRENT,(A)
10 5
150
100
50
PULSE WIDTH 8.3ms
SINGLE HALF-SINE-WAVE
(JEDEC METHOD)
10 4
10 3
T J =125 OC
10 2
T J =75 OC
10
1
10 0
10
-1
10
-2
T J =25 OC
2
5
10
NUMBER OF CYCLES AT 60Hz
ht t p : //
100
60
80
100
PERCENT OF RATED PEAK REVERSE VOLTAGE ,%
www.lgesem i .c o m
很抱歉,暂时无法提供与“SR5200L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.09782
- 50+0.86940
- 150+0.77145
- 1250+0.62198
- 2500+0.56754
- 5000+0.53493
