RS1AF-RS1MF
SURFACE MOUNT FAST RECOVERY RECTIFIER
FEATURES
Glass Passivated Die Construction
Low reverse leakage
Low Forward Voltage Drop and High Current Capability
Ideally Suited for Automated Assembly
Plastic Material: UL Flammability Classification Rating 94V-0
SMAF
MECHANICAL DATA
10
Case: SMAF Molded plastic
Terminals: Pure tin plated, lead free
Cathode
Polarity: Indicated by cathode band
Weight: 27mg (approx.)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive
load. For capacitive load, derate current by 20%.
RS1AF
RS1BF
RS1DF
RS1GF
RS1JF
RS1KF
RS1MF
Uni
t
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS Voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified
Current at T A =75 °C
I F(AV)
1.0
A
Peak Forward Surge Current 8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC)
I FSM
30.0
A
Maximum Instantaneous Forward Voltage at 1 A
VF
1.3
V
Maximum DC Reverse Current at
Rated DC Blocking Voltage
IR
5.0
50.0
µA
Parameter
Symbol
Maximum Repetitive Peak Reverse Voltage
T A = 25 °C
T A =100 °C
Maximum reverse recovery time (NOTE1)
t rr
Typical Junction Capacitance (NOTE2)
CJ
150
250
500
nS
15.0
pF
°C/
W
°C
Maximum Thermal Resistance (NOTE3)
R θJA
50.0
Operating and Storage Temperature Range
T J, TS
- 50 to + 150
Note: 1.Reverse recovery condition I F =0.5A,I R =1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD
E-mail:hkt@heketai.com
1/3
RS1AF-RS1MF
FIG. 1- FORWARD CURRENT DERATING CURVE
1.0
0.8
0.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.4
0.2
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Typical Characteristics
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
30
25
10
175
5.0
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
NUMBER OF CYCLES AT 60 Hz
1
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
0.01
0.6
0.8
1.0
1.2
1.4
1.5
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
0.1
1,000
100
10
TJ=100 C
1
0.1
TJ=25 C
0.01
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
TJ=25 C
10
TRANSIENT THERMAL IMPEDANCE,
C/W
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
200
100
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
1
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
2/3
RS1AF-RS1MF
SMAF Package Outline Dimensions
∠ALL ROUND
C
A
∠ALL ROUND
HE
E
A
g
Top View
mil
Bottom View
A
C
D
E
e
g
HE
max
1.1
0.20
3.7
2.7
1.6
1.2
4.9
min
0.9
0.12
3.3
2.4
1.3
0.8
4.4
max
43
7.9
146
106
63
47
193
min
35
4.7
130
94
51
31
173
UNIT
mm
g
pad
E
e
A
pad
D
V M
7°
3/3
很抱歉,暂时无法提供与“RS1MF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.10557
- 500+0.08742
- 3000+0.07727
- 6000+0.07121
- 24000+0.06598
- 51000+0.06310
- 国内价格
- 50+0.09677
- 600+0.08013
- 1200+0.07893
- 3000+0.07082
