UMW MB6F(0.8A)
UMW MB6F(0.8A)
    UMW(友台)
    DB-4P_3.875X4.69MM_TM
    0.8A表面安装玻璃钝化桥式整流器
UMW MB6F(0.8A) 数据手册
UMW R UMW MB05M-MB10M 0.8 A Single-Phase Glass Passivated Bridge Rectifiers Rectifier Reverse Voltage 50 to 1000V  ∼ Features   N !"#$%!&'(    MB-1  ∼ This series is UL listed under the Recognized Component Index, file number E142814 Ideal for surface mount application The plastic material used carries Underwriters Laboratory flammability recognition 94V-0 Surge overload ratings to 30 amperes High temperature soldering guaranteed 265 C/10 seconds at 5 lbs (2.3kg) tension  E      Mechanical Data Case: Molded plastic Terminals: Plated leads solderable per MIL-STD-202, Method 208 Polarity: Marked on body Mounting Position: Any  A B C D E F G H K L  N        .195 .095 .144 .179 .039 .090 .017 .132 .006 .137  1 .020  .205 .105 .161 .190 .049 .106 .029 .148 .016 .147   5 .028   4.95 2.41 3.65 4.55 0.99 2.30 0.43 3.35 0.15 3.48  1 0.51  5.21 2.67 4.10 4.83 1.24 2.70 0.74 3.75 0.41 3.73   5 0.71   Maximum Ratings & Thermal Characteristics Rating at 25 C ambient temperature unless otherwise specified, Resistive or Inductive load, 60 Hz. For Capacitive load derate current by 20%. Parameter Symbol MB05M MB1M MB2M MB4M MB6M MB8M MB10M unit Maximum repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS bridge input voltage VRMS 35 70 140 280 420 560 700 V VDC 50 100 200 400 600 800 1000 V Maximum DC blocking voltage Maximum average forward rectified output current at TA=40 C (*3) IF(AV) 0.5 0.8* Peak forward surge current single sine-wave superimposed on rated load (JEDEC Method) IFSM 30 A I t 10 A sec ReJA 110 C /W Cj 25.0 pF Rating for fusing ( t
UMW MB6F(0.8A) 价格&库存
很抱歉,暂时无法提供与“UMW MB6F(0.8A)”相匹配的价格&库存,您可以联系我们找货
UMW MB6F(0.8A)
  • 50+0.07200
  • 500+0.06480
  • 5000+0.06000
  • 10000+0.05760
  • 30000+0.05520
  • 50000+0.05376
