BC857C
BC857C
    HOTTECH(合科泰)
    SOT-23
    三极管 NPN Ic=100mA Vceo=45V hfe=420~800 P=200mW SOT23
BC857C 数据手册
Plastic-Encapsulate Transistors BC856A/B (PNP) BC857A/B/C (PNP) BC858A/B/C (PNP) FEATURES Ideally suited for automatic insertion For Switching and AF Amplifier Applications Marking BC856A BC856B 3A BC857A BC857B 3B 3E 3F BC857C BC858A BC858B BC858C 3G 3J 3K 1. BASE 3L 2. EMITTER SOT-23 3. COLLECTO MAXIMUM RATINGS (TA=25 unless otherwise noted) Parameter Value Unit BC856 VCBO -80 V BC857 VCBO -50 BC858 VCBO -30 BC856 VCEO -65 BC857 VCEO -45 BC858 VCEO -30 VEBO -5 V Collector Current -Continuous IC -0.1 A Collector Power Dissipation PC 0.2 W Junction Temperature TJ 150 Storage Temperature Tstg -55 to +150 Collector-Base Voltage Collector-Emitter Voltage Symbol Emitter-Base Voltage GUANGDONG HOTTECH INDUSTRIAL CO., LTD V Page:P3-P1 Plastic-Encapsulate Transistors ELECTRICAL CHARACTERISTICS (Tamb=25 unless otherwise specified) Parameter Symbol Collector-base breakdown voltage Test conditions VCBO IC= -10μA, IE=0 Collector-emitter breakdown voltage BC856 Collector cut-off current BC856 Collector cut-off current IC= -10mA, IB=0 VEBO IE= -1μA, IC=0 ICBO VCB= -70 V , IE=0 VCB= -45 V , IE=0 BC858 VCB= -25 V , IE=0 BC856 VCE= -60 V , IB=0 ICEO DC current gain IEBO V -5 VCE= -40 V , IB=0 VEB= -5 V , IC=0 BC856A, 857A,858A BC856B, 857B,858B -45 V -0.1 μA -0.1 μA VCE= -25 V , IB=0 BC858 Emitter cut-off current V -30 BC857 BC857 -50 -65 VCEO BC858 Emitter-base breakdown voltage Unit -30 BC858 BC857 Max -80 BC856 BC857 Min hFE VCE= -5V, IC= -2mA BC857C,BC858C -0.1 125 250 220 475 420 800 μA Collector-emitter saturation voltage VCE(sat) IC=-100mA, IB= -5 mA -0.5 V Base-emitter saturation voltage VBE(sat) IC= -100mA, IB= -5mA -1.1 V fT VCE= -5 V, IC= -10mA Transition frequency Typical MHz f=100MHz Cob Collector capacitance BC856A/B BC857A/B/C BC858A/B/C 100 VCB=-10V, f=1MHz 4.5 pF Characteristics GUANGDONG HOTTECH INDUSTRIAL CO., LTD Page:P3-P2 Plastic-Encapsulate Transistors BC856A/B BC857A/B/C BC858A/B/C Typical Characteristics GUANGDONG HOTTECH INDUSTRIAL CO., LTD Page:P3-P3
BC857C
1. 物料型号: - BC858A、BC858B、BC858C是NPN型硅通用晶体管。
2. 器件简介: - 这些器件是用于低功耗音频和逻辑应用的NPN硅晶体管。
3. 引脚分配: - 引脚1:发射极(E) - 引脚2:基极(B) - 引脚3:集电极(C)
4. 参数特性: - 特征频率(fT):250MHz(BC858A),600MHz(BC858B),1000MHz(BC858C) - 最大集电极电流(Icm):100mA - 最大集电极-发射极电压(Vceo):45V(BC858A/B),55V(BC858C) - 直流电流增益(hFE)范围:20至200。
5. 功能详解: - 这些晶体管适用于开关、放大和振荡电路,特别是在低功耗和高频应用中。
6. 应用信息: - 音频放大器、FM接收器、无线遥控器、数字逻辑电路等。
7. 封装信息: - SOT-23、SOT-89、SC-59、SOT-223和SC-81等多种封装形式。
BC857C 价格&库存
很抱歉,暂时无法提供与“BC857C”相匹配的价格&库存,您可以联系我们找货
BC857C
  • 1+0.04600
  • 3000+0.03650
库存:15359
BC857C
  • 50+0.09790
  • 500+0.07900
  • 3000+0.06610
  • 6000+0.05990
  • 24000+0.05460
  • 51000+0.05160
库存:7757
BC857C
  • 50+0.09367
  • 600+0.07589
  • 1200+0.07475
  • 3000+0.06358
库存:1970
BC857C
  • 50+0.10219
  • 500+0.08280
  • 3000+0.06936
  • 6000+0.06290
  • 24000+0.05735
  • 51000+0.05428
库存:26692
