BC817-40
BC817-40
    HOTTECH(合科泰)
    SOT-23
    三极管 NPN Ic=500mA Vceo=45V hfe=250~600 P=300mW SOT23
BC817-40 数据手册
Plastic-Encapsulate Transistors FEATURES BC817-16 (NPN) BC817-25 (NPN) BC817-40 (NPN) For general AF applications High collector current High current gain Low collector-emitter saturation voltage Complementary types: BC807 (PNP) Marking BC817-16 BC817-25 6A BC817-40 6B MAXIMUM RATINGS (TA=25 6C unless otherwise noted) Parameter Collector-Base Voltage Symbol Value Unit 50 V VCBO 1. BASE SOT-23 2. EMITTER 3. COLLECTO DCollector-Emitter Voltage VCEO 45 V Emitter-Base Voltage VEBO 5 V Collector Current -Continuous IC 500 mA Collector Power Dissipation PC 300 mW Junction Temperature TJ 150 Storage Temperature Tstg -55 to +150 ELECTRICAL CHARACTERISTICS (Tamb=25 Parameter unless otherwise specified) Symbol Test conditions Min Max Unit Collector-base breakdown voltage VCB IC= 10μA, IE=0 50 V Collector-emitter breakdown voltage VO CE IC= 10mA, IB=0 45 V Emitter-base breakdown voltage VO EB IE= 1μA, IC=0 5 V Collector cut-off current O ICB VCB= 45 V , Emitter cut-off current O IEB VEB= 4V, IC=0 IE=0 0.1 μA 0.1 μA O hFE(1 VCE= 1V, IC= 100mA 100 ) hFE(2 VCE= 1V, IC= 500mA 40 Collector-emitter saturation voltage VCE)(sat) IC= 500mA, IB= 50mA 0.7 V Base-emitter saturation voltage VBE(sat) IC= 500mA, IB= 50mA 1.2 V Base-emitter voltage VB VCE= 1 V, IC= 500mA 1.2 V Collecter capactiance CEob VCB=10V ,f=1MHz Transition frequency fT DC current gain 600 10 pF VCE= 5 V, IC= 10mA CLASSIFICATION OF Rank Range 100 f=100MHz MHz hFE 6A 100-250 GUANGDONG HOTTECH 6B 160-400 INDUSTRIAL CO., LTD 6C 250-600 Page:P2-P1 Plastic-Encapsulate Transistors BC817-16 BC817-25 BC817-40 Typical Characteristics GUANGDONG HOTTECH INDUSTRIAL CO., LTD Page:P2-P2
BC817-40
PDF文档中包含如下信息:
1. 物料型号:BC817 2. 器件简介:BC817 是一款硅 NPN 双极型晶体管,常用于开关和放大电路。
3. 引脚分配:BC817 有 3 个引脚,分别为发射极(E)、基极(B)和集电极(C)。
4. 参数特性:BC817 的主要参数包括电流增益(hFE)范围为 100 至 300,最大集电极电流(IC)为 500 mA,最大集电极-发射极电压(VCEO)为 45V。
5. 功能详解:BC817 可用于低功耗开关和信号放大,适用于各种电子设备。
6. 应用信息:广泛应用于音频和电源放大器、开关电路、温度控制器等。
7. 封装信息:BC817 通常采用 SOT-23 或 TO-92 封装。
BC817-40 价格&库存
很抱歉,暂时无法提供与“BC817-40”相匹配的价格&库存,您可以联系我们找货
BC817-40
    • 1+0.04160
    • 100+0.03770
    库存:5364
    BC817-40
    • 1+0.06190
    • 3000+0.04900
    库存:9608
    BC817-40
    • 5+0.08520
    BC817-40
    • 5+0.14200
    • 50+0.11510
    • 150+0.09950
    • 500+0.09050
    • 3000+0.07950
    • 6000+0.07540
    库存:7174
    BC817-40
    • 5+0.14683
    • 50+0.11932
    • 150+0.10414
    • 500+0.09490
    • 3000+0.08352
    • 6000+0.07921
    库存:290595
