LM741
LM741 Operational Amplifier
General Description
The LM741 series are general purpose operational amplifiers which feature improved performance over industry standards like the LM709. They are direct, plug-in replacements
for the 709C, LM201, MC1439 and 748 in most applications.
The amplifiers offer many features which make their application nearly foolproof: overload protection on the input and
output, no latch-up when the common mode range is exceeded, as well as freedom from oscillations.
The LM741C/LM741E are identical to the LM741/LM741A
except that the LM741C/LM741E have their performance
guaranteed over a 0˚C to +70˚C temperature range, instead
of −55˚C to +125˚C.
Schematic Diagram
DS009341-1
Offset Nulling Circuit
DS009341-7
http://www.hgsemi.com.cn
1
2018 AUG
LM741
Absolute Maximum Ratings (Note 1)
If Military/Aerospace specified devices are required, please contact the National Semiconductor Sales Office/
Distributors for availability and specifications.
(Note 6)
LM741A
LM741E
LM741
LM741C
± 22V
± 22V
± 22V
± 18V
Supply Voltage
Power Dissipation (Note 2)
500 mW
500 mW
500 mW
500 mW
± 30V
± 30V
± 30V
± 30V
Differential Input Voltage
± 15V
± 15V
± 15V
± 15V
Input Voltage (Note 3)
Output Short Circuit Duration
Continuous
Continuous
Continuous
Continuous
Operating Temperature Range
−55˚C to +125˚C
0˚C to +70˚C
−55˚C to +125˚C
0˚C to +70˚C
Storage Temperature Range
−65˚C to +150˚C
−65˚C to +150˚C
−65˚C to +150˚C
−65˚C to +150˚C
Junction Temperature
150˚C
100˚C
150˚C
100˚C
Soldering Information
N-Package (10 seconds)
260˚C
260˚C
260˚C
260˚C
J- or H-Package (10 seconds)
300˚C
300˚C
300˚C
300˚C
M-Package
Vapor Phase (60 seconds)
215˚C
215˚C
215˚C
215˚C
Infrared (15 seconds)
215˚C
215˚C
215˚C
215˚C
See AN-450 “Surface Mounting Methods and Their Effect on Product Reliability” for other methods of soldering
surface mount devices.
ESD Tolerance (Note 7)
400V
400V
400V
400V
Electrical Characteristics (Note 4)
Parameter
Conditions
LM741A/LM741E
Min
Input Offset Voltage
Typ
Max
0.8
3.0
LM741
Min
LM741C
Typ
Max
1.0
5.0
Min
Units
Typ
Max
2.0
6.0
TA = 25˚C
RS ≤ 10 kΩ
RS ≤ 50Ω
mV
mV
TAMIN ≤ TA ≤ TAMAX
RS ≤ 50Ω
4.0
mV
RS ≤ 10 kΩ
6.0
Average Input Offset
7.5
15
mV
µV/˚C
Voltage Drift
TA = 25˚C, VS = ± 20V
± 10
± 15
± 15
mV
Adjustment Range
Input Offset Current
TA = 25˚C
3.0
TAMIN ≤ TA ≤ TAMAX
30
70
85
500
nA
300
nA
0.5
nA/˚C
Current Drift
Input Bias Current
TA = 25˚C
Input Resistance
TAMIN ≤ TA ≤ TAMAX
TAMIN ≤ TA ≤ TAMAX,
VS = ± 20V
Input Voltage Range
30
1.0
80
6.0
500
80
1.5
0.3
2.0
0.3
2.0
0.5
500
nA
0.8
µA
MΩ
MΩ
± 12
TA = 25˚C
TAMIN ≤ TA ≤ TAMAX
80
0.210
± 12
2
± 13
± 13
V
V
2018 AUG
LM741
Parameter
(Continued)
Conditions
LM741A/LM741E
Min
Large Signal Voltage Gain
TA = 25˚C, RL ≥ 2 kΩ
VS = ± 20V, VO = ± 15V
VS = ± 15V, VO = ± 10V
Typ
Max
LM741
Min
Typ
50
200
LM741C
Max
Min
Typ
Units
Max
50
V/mV
V/mV
TAMIN ≤ TA ≤ TAMAX,
RL ≥ 2 kΩ,
VS = ± 5V, VO = ± 2V
Output Voltage Swing
32
V/mV
25
RL ≥ 10 kΩ
10
V/mV
± 16
± 15
V
V
RL ≥ 10 kΩ
± 12
± 10
RL ≥ 2 kΩ
TA = 25˚C
10
Current
TAMIN ≤ TA ≤ TAMAX
10
Common-Mode
TAMIN ≤ TA ≤ TAMAX
RS ≤ 10 kΩ, VCM = ± 12V
Rejection Ratio
RS ≤ 50Ω, VCM = ± 12V
Supply Voltage Rejection
Ratio
25
35
± 14
± 13
± 12
± 10
25
± 14
± 13
V
25
mA
40
mA
70
80
95
86
96
90
70
90
dB
RS ≤ 10 kΩ
TA = 25˚C, Unity Gain
77
96
77
96
dB
µs
0.25
0.8
0.3
0.3
Overshoot
6.0
5
Slew Rate
Supply Current
Power Consumption
LM741A
LM741E
LM741
dB
dB
Rise Time
Bandwidth (Note 5)
V
TAMIN ≤ TA ≤ TAMAX,
VS = ± 20V to VS = ± 5V
RS ≤ 50Ω
Transient Response
V/mV
VS = ± 20V
RL ≥ 2 kΩ
VS = ± 15V
15
TA = 25˚C
TA = 25˚C
0.437
1.5
0.3
0.7
TA = 25˚C
VS = ± 20V
VS = ± 15V
80
MHz
0.5
0.5
V/µs
1.7
2.8
1.7
2.8
50
85
50
85
150
mA
mW
mW
VS = ± 20V
TA = TAMIN
TA = TAMAX
165
mW
135
mW
VS = ± 20V
TA = TAMIN
TA = TAMAX
150
mW
150
mW
VS = ± 15V
TA = TAMIN
TA = TAMAX
60
100
mW
45
75
mW
Note 1: “Absolute Maximum Ratings” indicate limits beyond which damage to the device may occur. Operating Ratings indicate conditions for which the device is
functional, but do not guarantee specific performance limits.
3
2018 AUG
LM741
(Continued)
Note 2: For operation at elevated temperatures, these devices must be derated based on thermal resistance, and Tj max. (listed under “Absolute Maximum Ratings”). Tj = TA + (θjA PD).
Thermal Resistance
θjA (Junction to Ambient)
θjC (Junction to Case)
Cerdip (J)
DIP (N)
HO8 (H)
SO-8 (M)
100˚C/W
100˚C/W
170˚C/W
195˚C/W
N/A
N/A
25˚C/W
N/A
Note 3: For supply voltages less than ± 15V, the absolute maximum input voltage is equal to the supply voltage.
Note 4: Unless otherwise specified, these specifications apply for VS = ± 15V, −55˚C ≤ TA ≤ +125˚C (LM741/LM741A). For the LM741C/LM741E, these specifications are limited to 0˚C ≤ TA ≤ +70˚C.
Note 5: Calculated value from: BW (MHz) = 0.35/Rise Time(µs).
Note 6: For military specifications see RETS741X for LM741 and RETS741AX for LM741A.
Note 7: Human body model, 1.5 kΩ in series with 100 pF.
Connection Diagram
Metal Can Package
Ceramic Dual-In-Line Package
DS009341-2
Note 8: LM741H is available per JM38510/10101
DS009341-5
Order Number LM741H, LM741H/883 (Note 8),
LM741AH/883 or LM741CH
See NS Package Number H08C
Note 9: also available per JM38510/10101
Note 10: also available per JM38510/10102
Order Number LM741J-14/883 (Note 9),
LM741AJ-14/883 (Note 10)
See NS Package Number J14A
Dual-In-Line or S.O. Package
Ceramic Flatpak
DS009341-6
DS009341-3
Order Number LM741W/883
See NS Package Number W10A
Order Number LM741J, LM741J/883,
LM741CM, LM741CN or LM741EN
See NS Package Number J08A, M08A or N08E
4
2018 AUG
很抱歉,暂时无法提供与“LM741M/TR”相匹配的价格&库存,您可以联系我们找货
