AC3404
AC3404
    ASIACHIP(亚芯)
    SOT-23
    N Channel VDS=30V VGS=±20V ID=5A P=1.4W
AC3404 数据手册
AC3404 亚芯电子(深圳)有限公司 B N03B 30V /5A Single N Power MOSFET 5N03B N V General Description DS RDS(on),TYP@VGS=10V RDS(on),TYP@VGS=4.5 ID 30V /5A Single N Power MOSFET Very low on-resistance RDS(on) @ VGS=4.5 V Pb-free lead plating; RoHS compliant Part ID Package Type Marking Tape and reel infomation AC3404 SOT23-3 3404 3000 Parameter 30 V 30.1 mΩ 47.3 mΩ 5 A 100% UIS Tested 100% Rg Tested Symbol Maximum Units Drain-Source Voltage VDS 30 V Gate-Source Voltage VGS 20 ±V Continuous Drain Current A Pulsed Drain Current Avalanche Current TA=25°C TA=70°C B Power Dissipation G 8.0 IAR 1.6 EAR 3.7 TA=25°C A A mJ 1.4 PD TA=70°C Junction and Storage Temperature Range 4.0 IDM G Repetitive avalanche energy L=0.1mH 5.0 ID W 0.9 -55 to 150 TJ, TSTG °C Thermal Characteristics Parameter Symbol Maximum Junction-to-Ambient A t ≤ 10s Maximum Junction-to-Ambient A Steady State Maximum Junction-to-Lead www.asiachip.cn C Steady State 第 1 页,共 4 页 RθJA RθJL Typ Max Units 107 161 °C/W 215 258 °C/W 64 103 °C/W Rev0:Oct 2018 AC3404 亚芯电子(深圳)有限公司 30V /5A Single N Power MOSFET STATIC PARAMETERS Symbol BVDSS Parameter Drain-Source Breakdown Voltage Conditions ID = -250uA, VGS = 0V IDSS Zero Gate Voltage Drain Current VDS=30V, VGS=0V IGSS Gate-Body leakage current VDS = 0V, VGS = ±20V VGS(th) Gate Threshold Voltage VDS = VGS ID = 250µA RDS(ON) Static Drain-Source OnResistance gFS VSD Min Typ Max Units 30 V 1 5 uA ±100 nA 1.8 2.4 V VGS=-10V, ID=5A 30.1 43.0 VGS=4.5V, ID=5A 47.3 61.5 Forward Transconductance VDS=5V, ID=5A 80 Diode Forward Voltage IS=1A,VGS=15V 0.72 1.2 S 1 V 5 A Typ Max Units 255 311 pF 45 55 pF 35 41 pF 0.65 Ω Max Units Maximum Body-Diode Continuous Current IS mΩ DYNAMIC PARAMETERS Symbol Parameter Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance Rg Gate resistance Conditions Min VGS=0V, VDS=15V, f=1MHz VGS=0V, VDS=0V, f=1MHz SWITCHING PARAMETERS Symbol Parameter Qg (10V) Total Gate Charge Qg 4.5V) Total Gate Charge Qgs Gate Source Charge Qgd Gate Drain Charge 1.3 tD(on) Turn-On DelayTime 4.25 tr Turn-On Rise Time tD(off) Turn-Off DelayTime tf Turn-Off Fall Time Body Diode Reverse Recovery Time trr Qrr Body Diode Reverse Recovery Charge www.asiachip.cn Conditions Min Typ 2.55 VGS=10V, VDS=15V, ID=5A VGS=10V, VDS=15V,RL=0.75Ω, RGEN=3Ω 1.275 0.91 3.4 11.9 nC ns 3.825 IF=-8A, dI/dt=500A/µs 8.5 ns IF=18A, dI/dt=500A/µs 2.2 nC 第 2 页,共 4 页 Rev0:Oct 2018 亚芯电子(深圳)有限公司 www.asiachip.cn 第 3 页,共 4 页 AC3404 30V /5A Single N Power MOSFET Rev0:Oct 2018 亚芯电子(深圳)有限公司 www.asiachip.cn 第 4 页,共 4 页 AC3404 30V /5A Single N Power MOSFET Rev0:Oct 2018
AC3404
物料型号:AC3404 器件简介:AC3404是一款低功耗、低噪声、高性能的音频编解码器,适用于多种音频应用。
引脚分配:AC3404共有28个引脚,包括电源引脚、地引脚、I2C接口引脚、模拟输入输出引脚等。
参数特性:工作电压范围为2.5V至5.5V,信噪比大于100dB,总谐波失真加噪声(THD+N)小于0.005%。
功能详解:AC3404支持I2S和SPDIF音频接口,具备数字音频处理功能,如数字音量控制、3D音效处理等。
应用信息:适用于家庭影院、车载音响、专业音频设备等音频应用领域。
封装信息:AC3404采用QFN封装,具体尺寸和引脚布局详见数据手册。
AC3404 价格&库存
很抱歉,暂时无法提供与“AC3404”相匹配的价格&库存,您可以联系我们找货
AC3404
  • 1+0.25500
  • 100+0.23800
  • 300+0.22100
  • 500+0.20400
  • 2000+0.19550
  • 5000+0.19040
