Transient
Voltage
Suppressors
SMBJ3.3A Series
Circuit Protection
System
Revision:DEC-16
Please refer to http://www.ruilon.com.cn for current information.
Transient Voltage Suppressors - SMBJ3.3A Series
Features
• Very fast response time
• Halogen free and RoHS compliant
• Low incremental surge resistance
• Optimized for LAN protection applications
• Matte tin lead–free Plated
• Halogen ree and RoHS compliant
• For surface mounted applications to optimize board space
• ESD protection of data lines in accordance with IEC 61000-4-2 (IEC801-2)
• EFT protection of data lines in accordance with IEC 61000-4-4 (IEC801-4)
• High temperature soldering : 260°C/ 40 seconds at terminals
Cathode
Anode
Description
The SMBJ3.3A series is designed specifically to protect sensitive electronic equipment from voltage transients induced by
lightning and other transient voltage events.
Mechanical Characteristics
Rating
Peak Pulse Power Dissipation at TA=25ºC by 10/1000µs
Waveform (Fig.2)(Note 1), (Note 2)
Forward voltage IF=0.2A
Operating junction and Storage Temperature Range.
Symbol
Value
Units
PPPM
300
Watts
VF
1.2
V
TJ,TSTG
-55°C to 150°C
°C
Notes:
1. Non-repetitive current pulse, per Fig.4 and derated above TA=25ºC per Fig. 3.
2. Mounted on 5.0x5.0mm copper pad to each terminal.
3. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional device only.
4. VF< 3.5V for VBR _< 200V and VF< 6.5V for VBR >_ 201V
Circuit Protection
System
Revision:DEC-16
Page:1
Electriacl Characteristics
Type Number
Reverse
Stand-Off
Device Marking
Voltage
Code
VRWM(V) VBR MIN.(V)
SMBJ3.3A
KC
Test
Current
Maximum
Clamping
Voltage@IPP
Peak Pulse
Current
Reverse
Leakage
@VRWM
(V)
IT(mA)
VC(V)
IPP(A)
IR(µA)
6.0
1
7.2
42
10
Breakdown
Voltage@IT
3.3
4.00
I-VI-VCurve
Characteristics
Curve Characteristics
BR V
VBR
Vc V
VRR
Vc
Bi-directional
I
pp
IIpp
BR V
VBR
Vc V
VRR
Vc
V
V
IIRR V
VFF
IITT
IITT
IIRR
IIRR
IITT
VRRV
BR Vc
VBR
Vc
V
V
V
pp
IIpp
pp
IIpp
PP
Peak Pulse Power Dissipation -- Max power dissipation
PPM
PPM
PPM Peak Pulse Power Dissipation -- Max power dissipation
VV
Stand-off
Voltage -- Maximum voltage that can be applied to the TVS without operation
RR
R Stand-off Voltage -- Maximum voltage that can be applied to the TVS without operation
VV
Breakdown
Voltage -- Maximum voltage that flows thoughthe TVS at a specified test current (ITT)
BR
BR
test current (IT)
BR Breakdown Voltage -- Maximum voltage that flows though the TVS at a specified
VV
Clamping
Voltage
-- Peak--voltage
across the suppressor
a specified
Ippm (peakIppm
impulse
current)
CC C
Clamping Voltage
Peak measured
voltage measured
across theat TVS
at a specified
(peak
impulse current)
Leakage
Current
-- Current
at VRR
IRIRR Reverse
Reverse
Leakage
Current
-- measured
Current measured
at VR
VV
Forward
Voltage
Drop Drop
for Uni-directional
Forward
Voltage
for Uni-directional
FF F
Ratings and Characteristic Curves
(TAA=25°C
=25°C unless
unless otherwise
otherwise noted)
noted)
(T
Figure 1 - TVS Transients Clamping Waveform
Figure 2 - Peak Pulse Power Rating
1000
1000
-Peak Pulse Power (kW)
PPPM
PPM
Voltage Transients
Transients
Voltage
Voltage Across
Across TVS
TVS
Voltage
Voltage or Current
P6KESeries
Series
P6KE
Uni-directional
Current Through
Through TVS
TVS
Current
100
100
10
10
11
0.1
0.1
0.000001
0.000001
Time
Time
Circuit Protection
System
0.00001
0.00001
0.0001
0.0001
0.001
0.001
-Pulse Width
Width (Sec.)
(Sec.)
ttdd-Pulse
Revision:DEC-16
Please refer to http://www.ruilon.com.cn for current information. Page:2
Ratings and Characteristic Curves (TA=25°C unless otherwise noted)
Figure 3 - Pulse Derating Curve
Figure 4 - Pulse Waveform
150
IPPM - Peak Pulse Cur rent, % IRSM
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
100
80
60
40
50
75
100
125
150
tr=10µsec
Half Value
IPPM IPPM
2
50
TA-Ambient temperature (ºC)
10/1000µsec. Waveform
as defined by R.E.A
td
1.0
3.0
4.0
t-Time (ms)
Figure 5 - Typical Junction Capacitance
Figure 6 - Steady State Power Dissipation Derating Curve
10000
PM(AV), Steady State Power Dissipation
(W)
6
Bi-directional V=0V
1000
Cj (pF)
Peak Value
IPPM
100
175
T J =25°C
Pulse Width(td) is defined
as the point where the peak
current decays to 50% of IPPM
Uni-directional V=0V
Uni-directional @VR
100
Bi-directional @VR
10
Tj=25C
f=1.0MHz
Vsig=50mVp-p
1
1.0
10.0
100.0
VBR - Reverse Breakdown Voltage (V)
1000.0
5
4
3
2
1
50
75
100
125
150
175
TA - Ambient Temperature (ºC)
Figure 7 - Maximum Non-Repetitive Peak Forward
Surge Current Uni-Directional Only
IFSM - Peak Forward Surge Current (A)
120
100
80
60
40
10
100
Number of Cycles at 60 Hz
Circuit Protection
System
Revision:DEC-16
Page:3
Soldering Parameters
Pre Heat
150°C
200°C
60-180 secs
Average ramp up rate (Liquidus Temp (TA)
to peak
3°C/second max
TS(max) to TA - Ramp-up Rate
3°C/second max
- Temperature (T A)
(Liquidus)
- Time (min to max) (t s)
TL
tL
Ts(max)
Ramp-down
Ts(min)
ts
Preheat
Time (t)
217°C
60-150 seconds
260+0/-5 °C
Peak Temperature (T P)
Time within 5°C of actual peak
Temperature (t p)
Critical Z one
TL to TP
Ramp-up
- Temperature Min (T
s(min))
- Temperature Max (T
s(min))
Reflow
tp
TP
Lead-free assembly
Temperature (T)
Reflow Condition
20-40 seconds
Ramp-down Rate
6°C/second max
Time 25°C to peak Temperature (T P)
8 minutes Max.
Do not exceed
280°C
Physical Specifications
Environmental Specifications
High Temp. Storage
JESD22-A103
HTRB
JESD22-A108
Temperature Cycling
JESD22-A104
MSL
JEDEC-J-STD-020, Level 1
H3TRB
JESD22-A101
RSH
JESD22-A111
Flow/Wave Soldering
Weight
0.003 ounce, 0.093 grams
Case
JEDEC DO-214AA Molded Plastic over
Polarity
glass passivated junction
Termina
Matte Tin axial leads, solderable per JESD22-B102D.
Peak Temperature :
265°C
Dipping Time :
10 seconds
Soldering :
1 time
Dimensions DO-214AA/SMB
Inches
DIM
A
B
C
D
E
F
G
H
I
J
K
L
Circuit Protection
System
Millimeters
Min
Max
Min
Max
0.077
0.160
0.130
0.084
0.030
0.205
0.006
0.089
0.085
0.085
0.086
0.180
0.155
0.096
0.060
0.008
0.220
0.012
0.107
1.950
4.060
3.300
2.130
0.760
5.210
0.152
2.260
2.160
2.160
2.200
4.570
3.940
2.440
1.520
0.203
5.590
0.305
2.740
Revision:DEC-16
Please refer to http://www.ruilon.com.cn for current information. Page:4
0.157
(4.0)
Cathode
0.31
(8.0)
0.157
(4.0)
0.059 DIA
(1.5)
Cover tape
Transient
13.0 (330)
Dimensions are in inches
(and millimeters).
0.80 (20.2)
Arbor Hole Dia.
Product Name
Direction of Feed
0.33
(8.5)
S
M
B
J
x
x
DC Spark-over
Voltage
Series code
0.157
(4.0)
x
Part Marking System
Cathode band
(for Uni-directional products only)
A
XX
XXXX
5% Voltage
Tolerance
Marking code
Date code
Cathode
0.47
(12.0)
0.157
(4.0)
Packaging
0.059 DIA
(1.5)
13.0 (330)
Component
Package
0.80
Part(20.2)
Number
Arbor Hole Dia.
SMBJ3.3A
DO-214AC
0.49
(12.5
Cover tape
(and millimeters).
Quantity
Packaging Option
Packaging Specification
500
Tape & Reel
EIA RS-481
Direction of Feed
Tape and Reel Specification
0.157
(4.0)
Cathode
0.47
(12.0)
0.315
(8.0)
13.0 (330)
0.80 (20.2)
Arbor Hole Dia.
0.059 DIA
(1.5)
Cover tape
(and millimeters).
Direction of Feed
0.49
(12.5)
0.157
(4.0)
Cathode
0.63
(16.0)
0.315
(8.0)
13.0 (330)
0.80 (20.2)
Arbor Hole Dia.
Circuit Protection
System
0.059 DIA
(1.5)
Cover tape
(and millimeters).
Revision:DEC-16
Page:5
很抱歉,暂时无法提供与“SMBJ3.3A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.99394
- 50+0.79861
- 100+0.78663
- 200+0.70104
- 500+0.62777
- 2500+0.54706
- 国内价格
- 5+0.80346
- 50+0.71380
- 150+0.66896
- 500+0.63530
- 3000+0.58410
- 6000+0.57056
- 国内价格
- 1+0.70599
- 200+0.48783
- 1500+0.44238
- 3000+0.41309
