THICK FILM NETWORK RESISTOR
BRIEF INTRODUCTION
Miniature, high density assembly.
Stable electrical capability, high reliability.
Combinations of different ohmic
value are available
R oHS
RoHS compliant
ORDER
08
A
H
Circuits
Code
Power Rating
4
7
Resistance
Value Code
Pins
(E
A
B
C
D
E
F
G
H
T
Code
Power
No
Mark
1/8W
H
1/4W
2
24
J
Code of
pin distance
Resistance
Value Code
A
B
C
D
E
F
H
T
G
2.54mm
No
mark
04~14
Three digits (E-24
series):
The first two digits
are significant figures and the third
one denotes number of zeros.
Y
1
When it is the type of A,
B,C, D or G, there is no
mark.
When it is the type of E,
F,H or T, the expression
is same as Resistance
Value Codel .
1.778mm
Lead-free Level
Resistance
Tolerance Code
Code
F
1%
G
2%
J
5%
J(
Jumper)
No Contained
Lead
mark
Tolerance
P
Termination
Lead-free
50m
Outer coating
Conductor
Ceramic substrate
CONSTRUCTION AND DIMENSIONS
unit:mm
Code
a
b
Normal dimension
2.54
(n-1)+2.50max
A B C D
E F G H
Type
T
Type
5.08max
8.50max
A 472
Resistance/
Protection coating
Special dimension
1.778
(n-1)+3.20max
A B C D
E F G H
Type
T
Type
5.08max
Lead pin
Note: The white dot means the first pin.
8.50max
a
c
3.00max
3.00max
d
0.50
0.1
0.50
0.1
e
3.50
0.5
3.50
0.5
f
0.25
0.1
0.30
0.1
g
2.54
(n-1)
p
2.54
0.1
0.3
1.778
(n-1)
1.778
0.1
c
A 472J
b
0.3
f
d
e
1
p
n
g
81
EQUIVALENT CIRCUIT
Type
Type
Equivalent Circuit
R1
Equivalent Circuit
R1
Rn
R2
B
A
1
2
3
R1=R2=
R1
Rn
D
C
n
2
R1
1
2
R1
_n
2 +1
2
R2
4
R2
1
2
3
=Rn
R2
R1
2
n
1
R1
R2
n
R1
R2
R1
3
R1
n+1
R1=R2
R2
2 3
4 5
R1=R2 R1 R2
R2
1
3
R2
1
n+2
n+1
R1=R2=
R1
R2
Rn
H
T
R1
R1=R2 R1 R2
G
2
n+1
=Rn
R2
R2
1n
n
5
F
R1
1
n
R1
R1
R1=R2 R1 R2
R1
Rn
n+1
R1
R2
3
=Rn
=Rn
R2
E
2n
Rn-1
R2
R1=R2=
R1=R2=
1
4
3
=Rn
R2
1
2
Rn
n+1
R1=R2=
R1
1
R2
R1 R2
REFERENCE STANDARD
GB/T 15654-1995
GB/T 2828.1-2003
GB/T 2829-2002
82
n n+1
IEC E-24
IEC E-24 Series Resistance Cross-reference List
E-24
unit:1
10
E-24 Series (
100
1K
10
10K
n
100K
1M
1.0
1.5
2.2
3.3
4.7
6.8
1.1
1.6
2.4
3.6
5.1
7.5
1.2
1.8
2.7
3.9
5.6
8.2
1.3
2.0
3.0
4.3
6.2
9.1
DERATING CURVE
Pe r c e n t r a t e d l o a d
-55
70
100
Operating
75
Temperature Range
-55 ~125
50
25
-75
-50
-25
50
100
75
Ambient temperature(
125
150
70
For resistors operated in ambient over 70 , rated load (power rating or current rating) shall be
derated in accordance with above figure.
RATINGS
Specification
Item
1/8W
Power Rating
200V
Max. Working Voltage
280V
Max. Overload Voltage
2A
Jumper Rated Current
Resistance Temperature
Coefficient
Resistance Tolerance
1/4w
10
1
R 1M
R 10
,1M
2%,
5%,
1%,
Resistance Range
R 10M
250ppm/
Jumper:
Jumper
E 24
55
Operating Temperature Range
100ppm/
1.0
50m
~10M
~125
70
Rated Temperature
Note: Rated Voltage= Power Rating Resistance Value or Max. Working Voltage, whichever is lower.
83
CHARACTERISTICS
GB/T 15654-1995
Item
Specifications
T. C. R
Within the specified T.C.R
Test Methods
55
No mechanical damage
Short Time Overload
R
100M
Coating Insulation Resistane
Coating Insulation Withstand
Voltage
(2.0%R 0.05
Jumper R 50m
2.5
Rated voltage or Max. Overload
Voltage, choose the lower , for 5 seconds
Apply 500V DC
1min
Apply 500V DC 1min
95%
260
5
2
0.5
95%Cover Min
260
5
2
0.5S
(1.0%R 0.05
~125
5
500V DC
R
55
2.5
10
Resistance to Solvent
~125
measure between
500V DC
Min
No arc, inflammation and damage
Solderability
GB/T 15654-1995
Jumper R 50m
1
23
2
Dip in isopropyl alcohol solution of 10h
the solution temperature of 23
2
1h
, No mechanical damage
Pin strength
R
1.0%R+0.05
Jumper
10mm/s
R 50m
500g
Speed:10mm/s, pull strength:500g.
0.5kg,
90 ,
5s
2
Force with 0.5kg on the terminal pin,between the
Bending strength
resistor and the terminal pin is 90 degree,duration:
5s for 1 cycle
total 2 cycles
Resistance to Soldering Heat
R
1.0%R+0.05
Jumper R 50m
Temperature Cycling
R
1.0%R+0.05
Jumper R 50m
84
-55
270
5
10
270
5
10s 1s
30
30
-55
30min
2~3min
1
2~3
~125
5
~normal temperature
~125
30min
5cycles
GB/T 15654-1995
Specifications
Item
Test Methods
R
Steady state humidity
40
3.0%R+0.1
Jumper R 100m
Load Life(70
R
R
temperature
90%~95%RH1000h
2 ,1000
1.5
0.5
70
2 ,1000h,Rated Voltage or Max. Working
Voltage , whichever is lower. 1.5h on/0.5h off
3.0%R+0.1
Jumper R 100m
Endurance at upper
90%~95%RH1000
2
70
70
2
40
GB/T 15654-1995
125
3.0%R+0.1
125
Jumper R 100m
2
1000
2
1000h
PACKAGING
Packaging style
Label
200pcs
Plactics Bag
Label
(4/5/10) /
(4/5/10)Bags/Box
25
25Boxes/Case
Label
Packaging quantity
Box
Bag
Case
4
Bag
200pcs
5
6~11
Pins
10 Bags
Pins
5 Bags
85
12
14
Pins
4 Bags
25 boxes Max.
很抱歉,暂时无法提供与“A09-512JP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.65535
- 50+0.52726
- 150+0.46322
- 国内价格
- 100+0.54580
- 1000+0.45470
- 5000+0.38980
- 10000+0.36380
- 20000+0.34110
- 国内价格
- 5+1.19520
- 20+0.71300
- 100+0.49910
- 200+0.35650
- 400+0.33870
- 2000+0.31370
- 国内价格
- 1+0.39000
- 100+0.36500
- 300+0.34000
- 500+0.31500
- 2000+0.30250
- 5000+0.29500
