S10M
S10M
    MDD(辰达半导体)
    SMC(DO-214AB)
    表面安装通用整流器Vr:1kV Io:10A Vf:1.2V Ir:10μA SMC
S10M 数据手册
S10A THRU S10M SURFACE MOUNT GENERAL RECTIFIER Reverse Voltage - 50 to 1000 Volts FEATURES DO-214AB/SMC The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 For surface mounted applications Low reverse leakage Built-in strain relief,ideal for automated placement High forward surge current capability High temperature soldering guaranteed: 250 C/10 seconds at terminals 0.245(6.22) 0.220(5.59) 0.126 (3.20) 0.114 (2.90) Forward Current - 10.0 Amperes 0.280(7.11) 0.260(6.60) 0.012(0.305) 0.006(0.152) MECHANICAL DATA 0.103(2.62) 0.079(2.06) 0.060(1.52) 0.030(0.76) Case: JEDEC DO-214AB molded plastic body Terminals: Solder plated, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight:0.007 ounce, 0.25grams 0.008(0.203)MAX. 0.320(8.13) 0.305(7.75) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. MDD Catalog Number Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL=75 C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 10.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) Operating junction and storage temperature range SYMBOLS VRRM VRMS VDC S10A S10B 50 35 50 100 70 100 S10D S10G S10J S10K S10M UNITS 200 140 200 600 420 600 800 560 800 1000 700 1000 VOLTS VOLTS VOLTS 400 280 400 I(AV) 10.0 Amps IFSM 200.0 Amps VF 1.2 Volts IR 10.0 100.0 µA CJ RθJA TJ,TSTG 60.0 10.0 -55 to +150 pF C/W C *Pulse test: Pulse width 200 sec, Duty cycle 2% Note: 1. High Temperature Solder Exemptions Applied, see EU Directive Annex 7. 2014-03 01版 http://www.microdiode.com RATINGS AND CHARACTERISTIC CURVES S10A THRU S10M Figure 1 Typical Forward Characteristics 100 Figure 2 Forward Derating Curve 60 12 40 10 20 10 8 6 6 4 Amps 2 4 25C Amps 1 2 Single Phase, Half Wave 60Hz Resistive or Inductive Load .6 .4 0 40 60 80 100 120 140 160 .2 C .1 Average Forward Rectified Current - Amperes versus Case Temperature - C .06 .04 .02 .01 .5 .9 .7 1.1 1.3 1.7 1.5 Volts Instantaneous Forward Current - Amperes versus Instantaneous Forward Voltage - Volts Figure 3 Junction Capacitance 1000 600 400 200 pF TJ=25C 100 60 40 20 10 .1 .2 .4 1 Volts 2 4 10 20 40 100 200 400 1000 Junction Capacitance - pF versus Reverse Voltage - Volts 2014-03 01版 http://www.microdiode.com RATINGS AND CHARACTERISTIC CURVES S10A THRU S10M Figure 4 Typical Reverse Characteristics 1000 600 400 Figure 5 Peak Forward Surge Current 300 200 250 100 200 60 150 40 Amps 100 20 50 Amps 10 0 6 1 2 4 6 8 10 20 40 60 80 100 Cycles 4 Peak Forward Surge Current - Amperes versus Number Of Cycles At 60Hz - Cycles 2 1 .6 .4 TA=25C .2 .1 20 40 60 80 100 120 140 Volts Instantaneous Reverse Leakage Current - MicroAmperes versus Percent Of Rated Peak Reverse Voltage - Volts 2014-03 01版 http://www.microdiode.com
很抱歉,暂时无法提供与“S10M”相匹配的价格&库存,您可以联系我们找货
