SI2301
-20V P-Channel Enhancement Mode MOSFET
VDS= -20V
RDS(ON), Vgs@-4.5V, Ids@-2.3A
RDS(ON), Vgs@-2.5V, Ids@-2.0A
130mΩ
190mΩ
Features
Advanced trench process technology
High Density Cell Design For Ultra Low On-Resistance
Package Dimensions
D
SOT-23
G
A
B
C
D
E
Millimeter
Min.
Max.
2.80
3.00
2.30
2.50
1.20
1.40
0.30
0.50
F
0.45
REF.
0.55
REF.
S
Millimeter
G
H
K
J
L
Min.
1.80
0.90
0.10
0.35
0.92
Max.
2.00
1.1
0.20
0.70
0.98
M
0°
10°
Maximum Ratings and Thermal Characteristics (TA = 25oC unless otherwise noted)
Parameter
Symbol
Limit
Drain-Source Voltage
VDS
-20
Gate-Source Voltage
VGS
±8
ID
-2.3
IDM
-8
Continuous Drain Current
Pulsed Drain Current
1)
Maximum Power Dissipation
TA = 25o
2)
TA = 75oC
TJ, Tstg
Operating Junction and Storage Temperature Range
Junction-to-Ambient Thermal Resistance (PCB mounted)
PD
2)
RthJA
Junction-to-Ambient Thermal Resistance (PCB mounted) 3)
Unit
V
A
1.25
W
0.8
o
-55 to 150
100
166
C
o
C/W
Notes
1) Pulse width limited by maximum junction temperature.
2) Surface Mounted on FR4 Board, t v 5 sec.
3) Surface Mounted on FR4 Board.
- 1-
2012-7-8
SI2301
ELECTRICAL CHARACTERISTICS
Parameter
Symbol
Test Condition
Min.
VGS = 0V, ID = -250uA
-20
Typ.
Max.
Unit
Static
Drain-Source Breakdown Voltage
BVDSS
1)
Drain-Source On-State Resistance
Gate Threshold Voltage
R DS(on)
VGS(th)
Zero Gate Voltage Drain Current 0
IDSS
VGS = -4.5V, ID = -2.3A
105
130
VGS = -2.5V, ID = -2.0A
145
190
mΩ
VDS =VGS, ID = -250uA
-0.45
Forward Transconductance
1)
V
VDS = -16V, V GS = 0V
-1
uA
o
VDS = -16V, V GS = 0V TJ=55
Gate Body Leakage
V
IGSS
VGS = ± 8V, VDS = 0V
gfs
VDS = -5V, ID = -2.3A
C
-10
±100
6.5
nA
S
Dynamic
Total Gate Charge
Gate-Source Charge
Qg
Qgs
Gate-Drain Charge
Qgd
Turn-On Delay Time
td(on)
5.8
VDS = -6V, ID ^ -2.3A
nC
0.85
VGS = -4.5V
1.7
13
VDD = -6V, RL=6Ω
Turn-On Rise Time
tr
Turn-Off Delay Time
td(off)
Turn-Off Fall Time
tf
Input Capacitance
Ciss
ID ^ -1.A, VGEN = -4.5V
RG = 6 Ω
36
ns
42
34
415
VDS = -6V, VGS = 0V
Output Capacitance
Coss
pF
223
f = 1.0 MHz
Reverse Transfer Capacitance
87
Crss
Source-Drain Diode
Max. Diode Forward Current
Diode Forward Voltage
1)
IS
VSD
IS = -1.0A, VGS = 0V
-0.8
-1.6
A
-1.2
V
Pulse test: pulse width
很抱歉,暂时无法提供与“SI2301”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.15002
- 200+0.11794
- 600+0.10012
- 3000+0.07971
- 国内价格
- 20+0.20272
- 200+0.15898
- 600+0.13468
