GBJ2510
GBJ2510
    DY(迪一电子)
    GBJ
    单相25安培玻璃钝化桥式整流器
GBJ2510 数据手册
6 GBJ25005 THRU GBJ2510 SINGLE PHASE 25.0 AMP GLASS PASSIVATED BRIDGE RECTIFIER Features GBJ · Glass passivated die construction · Low forward voltage drop · High current capability .189(4.8) .173(4.4) 1.193(30.3) 1.169(29.7) .215(5.2) .196(4.8) .800(20.3) · High surge current capability · Plastic material-UL flammability 94V-0 + ~ .106(2.7) .096(2.3) Mechanical Data .090(2.3) .078(2.0) · Case: Molded plastic, GBJ · Terminals: Plated Leads Solderable per .043(1.1) .035(0.9) .433(11) .354(9.0) · · · · .150(3.8) .134(3.4) MIL-STD-202, Method 208 Polarity: As Marked on Case Mounting Position: Any Marking: Type Number Lead Free: For RoHS / Lead Free Version ~ .787(19.7) .441(11.2) .425(10.8) .165(4.2) .150(3.8) ~ ~ .110(2.8) .094(2.4) .023(0.6) .303(7.7) .287(7.3) .303(7.7) .287(7.3) + .706(18.0) .626(16.0) .184(3.4) .122(3.1) - dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified. Single Phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER SYMBOL Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM RMS Reverse Voltage VRMS Average Rectified Output Current (Note 1)@TC =90 ℃ IF(AV) GBJ GBJ 25005 2501 GBJ GBJ 2502 2504 GBJ GBJ GBJ 2506 2508 2510 UNITS 50 100 200 400 600 800 1000 V 35 70 140 280 420 560 700 V VDC 25.0 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 300 A I2t Rating for Fusing (t < 8.3ms) I 2t 373.5 A2s VFM 1.0 1.1 V IR 5.0 500 uA CJ 85 pF Between junction and ambient, Without heatsink RθJA 22 Between junction and case, With heatsink RθJC 1.0 @IF=15A @IF=30A Forward Voltage per element Peak Reverse Current At Rated DC Blocking Voltage @TA =25 ℃ @TA =125 ℃ Typical Junction Capacitance per leg Operating and Storage Temperature Range TJ,TSTG ℃/W ℃ -55to+150 2 Note:1. Mounted on glass epoxy PC board with 1.3mm solder pad. version:02 1 of 3 www.dyelec.com AVERAGE FORWARD RECTIFIED CURRENT (A) GBJ25005 THRU GBJ2510 32.0 24.0 16.0 8.0 0 150 100 50 200 I (AV), 0 IF, INSTANTANEOUS FORWARD CURRENT (A) Fig. 1 Output Current Derating Curve 400 350 300 250 200 150 TA = 25°C Single Half Sine-Wave Pulse Width = 8.3ms (JEDEC Method) 0 10 1 4 0.4 0.04 0.4 TA = 25 C ° Pulse Width = 300 µs 0.6 0.8 1.0 1.2 1.4 1.6 100 NUMBER OF CYCLES AT 60 Hz Fig. 4 Typical Junction Capacitance INSTANTANEOUS REVERSE CURRENT, MICROAMPERES IFSM, PEAK FORWARD SURGE CURRENT (A) Fig. 3 Maximum Peak Forward Surge Current (per leg) 50 40 VF, INSTANTANEOUS FORWARD VOLTAGE (V) TC , CASE TEMPERATURE( ° C) 100 Fig. 2 Typical Forward Characteristics (per leg) 10 1.0 T A=25°C 0.1 0.01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE FIG.5 TYPICAL REVERSE CHRACTERISTICS INVSTANTANEOUS REVERSE CURRENT (µA) 100 Tj=150℃ 10 1.0 Tj=25℃ 0.1 0.01 0 20 40 60 80 100 PERCENT OF RATED PEAK INVERSE VOLTGE (V) version:02 2 of 3 www.dyelec.com GBJ25005 THRU GBJ2510 Important Notice and Disclaimer •Reproducing and modifying information of the document is prohibited without permission from DIYI. • DIYI reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design, purchase or use. •DIYI disclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially occurred. •DIYI does not assume any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. Applications shown on the here in document are examples of standard use and • operation. Customers are responsible in comprehending the suitable use in particular applications. DIYI makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. •The products shown herein are not designed and authorized for equipments requiring high level of reliability or relating to human life and for any applications concerning life-saving or life-sustaining, such as medical instruments, transportation equipment, aerospace machinery et cetera. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify DIYI for any damages resulting from such improper use or sale. •Since DIYI uses lot number as the tracking base, please provide the lot number for tracking when complaining. version:02 3 of 3 www.dyelec.com
GBJ2510 价格&库存
很抱歉,暂时无法提供与“GBJ2510”相匹配的价格&库存,您可以联系我们找货
