BM43THA80C-T2-T-G
BM43THA80C-T2-T-G
    BESTOWMASCOT
    TO-46-4
    温湿度传感器 TO46 Humidity, Temperature
BM43THA80C-T2-T-G 数据手册
Temperature Sensor BM43THA80C Bestow Mascot Publication Number: BM43THA80C                                  Revision:1.0                              Issue Date:Oct.20,2019  BM43THA80C  Content CONTENT 1. Description .............................................................................................................................................. 1 1.1 General Description ....................................................................................................................... 1 1.2 Features ......................................................................................................................................... 1 1.3 Applications .................................................................................................................................... 1 1.4 Package ......................................................................................................................................... 1 2 Pin Descriptions ................................................................................................................................... 2 3 Characteristics ..................................................................................................................................... 3 3.1 Thermopile Parameter.................................................................................................................... 3 3.2 NTC Temperature VS Resistance Table ........................................................................................ 4 3.3 Filter Transmission Curve .............................................................................................................. 7 3.4 Sensitivity Output Curve ................................................................................................................. 7 3.5 Typical Reliability Test Items........................................................................................................... 8 4. Ordering Information ............................................................................................................................... 9 4.1 Naming Scheme ............................................................................................................................. 9 4.2 Order Information ......................................................................................................................... 10 4.3 TO Package Type2 Outline Information (in mm) ........................................................................... 11 4.4 TO Package Type3 Outline Information (in mm) .......................................................................... 12 4.5 Packing Information ..................................................................................................................... 13 5. Notice .................................................................................................................................................... 14 6. Revision History .................................................................................................................................... 18   BM43THA80C  Description 1. Description 1.1 General Description The BM43THA80C is a CMOS compatible thermopile temperature sensor based on MEMS (microelectromechanical systems) technology. This thermopile detector consists of thermopile MEMS chip, 514um infrared band pass filter, a NTC thermistor for temperature compensation and a small size TO Package. 1.2 Features  Non-contact surface temperature measuring  TO housing with an 5-14um infrared filter  Using NTC thermistor for ambient temperature compensation  High sensitivity  Fast response time  Wide working temperature: -40℃+120℃(Temperature range can be extended to +1000℃by using specific infrared lens) 1.3 Applications  Non-contact human body temperature infrared thermometer  Microwave oven  Automatic induction equipment  Heating, Ventilation and Air Conditioning(HVAC)  Appliance 1.4 Package   1/18 BM43THA80C  Pin Description 2 Pin Descriptions Table1 Pin Descriptions   Pin Function Description 1 GND Thermistor 2 Thermopile- Output DC voltage- pin. 3 Thermistor Ambient temperature compensation resistance+ pin. 4 Thermopile+ Ambient temperature compensation resistance- pin and GND. Output DC voltage+ pin. 2/18 BM43THA80C  Specification 3 Characteristics 3.1 Thermopile Parameter Table 2 Thermopile Parameter Parameter Specification Unit Condition Chip Size 1.28X1.28 mm - Active Area 0.9X0.9 mm - Responsivity 135 V/W Black body=500K,1HZ @temp=25℃ Detectivity 6.3E07 cm·Hz1/2/W Black body=500K,1HZ @temp=25℃ Thermopile Res 225±10 k @temp=25℃ Time Constant 15 ms - Field of View(FOV) 0 Operating Temp -40~120 ℃ - Storage Temp -40~150 ℃ - ° Degree at 50% signal level Thermistor for Temperature Compensation Thermistor Resistance TC of Thermistor(B)   100 k +2% tolerance, @temp=25℃ 3950 K ±1% tolerance, Defined at 25/50℃ 3/18 BM43THA80C  Specification 3.2 NTC Temperature VS Resistance Table Table 3 NTC Temperature VS Resistance Table Temp.(℃)   Rmax(kΩ) Temp.(℃) Rmin(kΩ) Rnor(kΩ) Rmin(kΩ) Rnor(kΩ) Rmax(kΩ) -40 3062.1 3235.1 3416.6 43 45.920 47.210 48.517 -39 2869.0 3029.1 3196.9 44 44.112 45.369 46.644 -38 2689.3 2837.6 2992.8 45 42.384 43.609 44.852 -37 2522.1 2659.4 2803.1 46 40.731 41.925 43.137 -36 2366.4 2493.6 2626.6 47 39.150 40.314 41.496 -35 2221.4 2339.3 2462.5 48 37.638 38.772 39.924 -34 2086.2 2195.5 2309.7 49 36.191 37.295 38.418 -33 1960.1 2061.5 2167.4 50 34.806 35.882 36.977 -32 1842.5 1936.6 2034.8 51 33.479 34.527 35.594 -31 1732.6 1820.1 1911.1 52 32.208 33.229 34.269 -30 1630.1 1711.3 1795.8 53 30.991 31.986 32.999 -29 1534.3 1609.7 1688.2 54 29.825 30.794 31.782 -28 1444.7 1514.8 1587.7 55 28.708 29.652 30.615 -27 1360.9 1426.1 1493.8 56 27.638 28.557 29.496 -26 1282.6 1343.2 1406.1 57 26.612 27.508 28.422 -25 1209.2 1265.6 1324.1 58 25.628 26.501 27.392 -24 1140.5 1193.0 1247.4 59 24.685 25.535 26.404 -23 1076.1 1125.0 1175.6 60 23.781 24.609 25.455 -22 1015.8 1061.3 1108.4 61 22.913 23.720 24.545 -21 959.19 1001.6 1045.4 62 22.081 22.867 23.671 -20 906.11 945.61 986.44 63 21.283 22.048 22.831 -19 856.11 892.92 930.94 64 20.516 21.262 22.025 -18 809.19 843.50 878.91 65 19.781 20.507 21.251 -17 765.13 797.12 830.11 66 19.074 19.781 20.507 -16 723.74 753.58 784.33 67 18.396 19.085 19.792 -15 684.85 712.69 741.36 68 17.745 18.416 19.105 -14 648.29 674.27 701.01 69 17.119 17.773 18.444 -13 613.91 638.16 663.10 70 16.518 17.155 17.809 -12 581.56 604.20 627.47 71 15.940 16.561 17.199 -11 551.12 572.26 593.98 72 15.385 15.990 16.611 -10 522.45 542.20 562.48 73 14.852 15.441 16.047 4/18 BM43THA80C  Specification Temp.(℃)   Rmax(kΩ) Temp.(℃) Rmin(kΩ) Rnor(kΩ) Rmin(kΩ) Rnor(kΩ) Rmax(kΩ) -9 495.45 513.91 532.84 74 14.339 14.913 15.503 -8 470.01 487.26 504.94 75 13.846 14.405 14.980 -7 446.03 462.15 478.67 76 13.371 13.916 14.477 -6 423.41 438.49 453.92 77 12.915 13.446 13.993 -5 402.08 416.18 430.60 78 12.476 12.993 13.526 -4 381.95 395.13 408.61 79 12.054 12.558 13.078 -3 362.94 375.28 387.88 80 11.648 12.139 12.645 -2 345.00 356.54 368.32 81 11.261 11.740 12.234 -1 328.04 338.85 349.87 82 10.890 11.356 11.838 0 312.02 322.13 332.44 83 10.532 10.987 11.457 1 296.93 306.40 316.05 84 10.187 10.631 11.089 2 282.65 291.52 300.55 85 9.855 10.288 10.735 3 269.14 277.45 285.90 86 9.535 9.957 10.393 4 256.35 264.13 272.04 87 9.227 9.639 10.064 5 244.23 251.52 258.93 88 8.931 9.332 9.747 6 232.75 239.59 246.52 89 8.645 9.036 9.441 7 221.88 228.28 234.78 90 8.369 8.750 9.145 8 211.57 217.57 223.65 91 8.103 8.475 8.861 9 201.79 207.42 213.11 92 7.847 8.210 8.586 10 192.52 197.79 203.13 93 7.600 7.954 8.321 11 183.72 188.66 193.66 94 7.361 7.707 8.065 12 175.37 180.00 184.69 95 7.132 7.468 7.818 13 167.44 171.79 176.17 96 6.910 7.238 7.580 14 159.92 163.99 168.10 97 6.696 7.016 7.349 15 152.77 156.58 160.43 98 6.489 6.802 7.127 16 145.97 149.55 153.16 99 6.290 6.595 6.913 17 139.52 142.87 146.25 100 6.098 6.395 6.705 18 133.38 136.52 139.69 101 5.912 6.202 6.505 19 127.54 130.49 133.46 102 5.732 6.016 6.311 20 121.99 124.76 127.53 103 5.559 5.836 6.124 21 116.71 119.30 121.90 104 5.392 5.662 5.944 22 111.68 114.11 116.55 105 5.230 5.494 5.769 23 106.90 109.17 111.45 106 5.074 5.332 5.600 24 102.34 104.47 106.61 107 4.923 5.175 5.437 5/18 BM43THA80C  Specification Temp.(℃) Rmax(kΩ) Temp.(℃) Rmin(kΩ) Rnor(kΩ) Rmin(kΩ) Rnor(kΩ) Rmax(kΩ) 25 98.000 100.00 102.00 108 4.777 5.023 5.279 26 93.784 95.740 97.697 109 4.636 4.876 5.126 27 89.770 91.682 93.597 110 4.500 4.734 4.978 28 85.948 87.816 89.688 111 4.368 4.597 4.835 29 82.306 84.131 85.962 112 4.241 4.464 4.697 30 78.837 80.620 82.409 113 4.118 4.336 4.563 31 75.531 77.271 79.020 114 3.999 4.211 4.434 32 72.379 74.078 75.787 115 3.883 4.091 4.309 33 69.374 71.032 72.701 116 3.772 3.975 4.187 34 66.507 68.126 69.755 117 3.664 3.862 4.070 35 63.773 65.352 66.943 118 3.560 3.753 3.956 36 61.164 62.704 64.258 119 3.459 3.648 3.846 37 58.674 60.176 61.692 120 3.361 3.546 3.739 38 56.297 57.762 59.242 121 3.266 3.447 3.636 39 54.027 55.456 56.899 122 3.174 3.351 3.536 40 51.860 53.252 54.661 123 3.086 3.258 3.439 41 49.789 51.147 52.521 124 3.000 3.168 3.345 42 47.810 49.134 50.474 125 2.916 3.081 3.254 Note: B=3950K,R(25℃)=100KΩ.   6/18 BM43THA80C  Specification 3.3 Filter Transmission Curve Figure 1 Filter Transmission Curve 3.4 Sensitivity Output Curve     7/18 BM43THA80C  Specification 3.5 Typical Reliability Test Items No. Tested Item Condition Result (N/F1) 1 High Humidity Test +85±2℃, 85±2%RH 120h 20/0 2 Low Temperature -40±3℃ 200h 20/0 3 High Temperature +105±3℃ 200h 20/0 4 Thermal Shock (-40℃→+85℃)×20Cycle 2h 20/0 Frequency sweep: 10~55Hz/min  2h 5 Vibration Direction : X, Y, X (1.5mm distance for each direction) Note1: N for amount of sample, F for amount of failure after test   8/18 20/0 BM43THA80C  Ordering Information 4. Ordering Information 4.1 Naming Scheme BM 43 Company Prefix Bestow Mascot Technology Ltd. Series Name 43: Temperature Sensor Measure Type T-Thermopile IR Performance H-High N-Normal Signal Type A-Analogy D-Digital FOV Value Version Operating Temperature Range A-High B-Middle C-Low Package T2-TO Package Type2 T3- TO Package Type3 Packing T-Tube A-Tray Plating Technology Blank-Standard SnPb Plating R-RoHS compliant G-Green (REACH compliant)   9/18 T H A 80 C -X -X -X -G BM43THA80C  Ordering Information 4.2 Order Information Temperature Range Package Packaging HSF Order Code Tube Green BM43THA80C-B-T2-T-G Tray Green BM43THA80C-B-T2-A-G Tube Green BM43THA80C-B-T3-T-G Tray Green BM43THA80C-B-T3-A-G Tube Green BM43THA80C-C-T2-T-G Tray Green BM43THA80C-C-T2-A-G Tube Green BM43THA80C-C-T3-T-G Tray Green BM43THA80C-C-T3-A-G T2 Middle T3 T2 Low T3   10/18 BM43THA80C  Ordering Information 4.3 TO Package Type2 Outline Information (in mm) TOP 5 .0 0 +0 0.1 - 40 5. 55 3. ±0.0 5 5 .0 5 +0 0.0 - 2.50 4. 70 1. 02 + - 0 0.0 .1 3 0 + - 0 0.0 .0 5 5 R0.20 Bottom Front +0.05 TND 0.25 0.38Max Thermopile- +0.05 - 0.05 5.40 - 0.10 +0.03 4.70 - 0.10 45° Thermister Thermopile+ 0.45   11/18 +0.03 - 0.04 16.85 14 +1 -1 +1 -1 2.54 BM43THA80C  Ordering Information 4.4 TO Package Type3 Outline Information (in mm) 5 .0 0 +0 0.1 - 2. 50 ±0 .0 40 5. 5 TOP 3 .0 +0 0.10 - 70 4. Bottom Front +0.05 0.25 ±0.05 4 2.5 Thermister Thermopile+ 0.45   12/18 +0.03 - 0.04 16.85 14 +1 -1 +1 -1 TND 0.38Max Thermopile- 2.60 ±0.05 5.40 - 0.10 +0.03 4.70 - 0.10 BM43THA80C  Ordering Information 4.5 Packing Information Container Tray Quantity 1000 pcs Direction of feed Direction of products is fixed in a container tray 100pcs per tray 10 tray per box MOQ=1000pcs Container Tube Quantity 2000 pcs Direction of feed Direction of products is fixed in a container tray 40 tube per box 50pcs per tube MOQ=2000pcs   13/18 BM43THA80C  Notice 5. Notice ●General Precaution 1) Before you use our Products, you are requested to carefully read this document and fully understand its contents. BM shall not be in any way responsible or liable for failure, malfunction or accident arising from the use of any BM’s Products against warning, caution or note contained in this document. 2) All information contained in this document is current as of the issuing date and subject to change without any prior notice. Before purchasing or using BM’s Products, please confirm the latest information with a BM sales representative. ●Precaution on using BM Products 1) Our Products are designed and manufactured for application in ordinary electronic equipments (such as AV equipment, OA equipment, telecommunication equipment, home electronic appliances, amusement equipment, etc.). If you intend to use our Products in devices requiring extremely high reliability (such as medical equipment, transport equipment, traffic equipment, aircraft/spacecraft, nuclear power controllers, fuel controllers, car equipment including car accessories, safety devices, etc.) and whose malfunction or failure may cause loss of human life, bodily injury or serious damage to property (“Specific Applications”), please consult with the BM sales representative in advance. Unless otherwise agreed in writing by BM in advance, BM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of any BM’s Products for Specific Applications. 2) BM designs and manufactures its Products subject to strict quality control system. However, semiconductor products can fail or malfunction at a certain rate. Please be sure to implement, at your own responsibilities, adequate safety measures including but not limited to fail-safe design against the physical injury, damage to any property, which a failure or malfunction of our Products may cause. The following are examples of safety measures: [a] Installation of protection circuits or other protective devices to improve system safety [b] Installation of redundant circuits to reduce the impact of single or multiple circuit failure 3) Our Products are designed and manufactured for use under standard conditions and not under any special or extraordinary environments or conditions, as exemplified below. Accordingly, BM shall not be in any way responsible or liable for any damages, expenses or losses arising from the use of any BM’s Products under any special or extraordinary environments or conditions. If you intend to use our Products under any special or extraordinary environments or conditions (as exemplified below), your independent verification and confirmation of product performance, reliability, etc, prior to use, must be necessary: [a] Use of our Products in any types of liquid, including water, oils, chemicals, and organic solvents   14/18 BM43THA80C  Notice [b] Use of our Products outdoors or in places where the Products are exposed to direct sunlight or dust [c] Use of our Products in places where the Products are exposed to sea wind or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [d] Use of our Products in places where the Products are exposed to static electricity or electromagnetic waves [e] Use of our Products in proximity to heat-producing components, plastic cords, or other flammable items [f] Sealing or coating our Products with resin or other coating materials [g] Use of our Products without cleaning residue of flux (even if you use no-clean type fluxes, cleaning residue of flux is recommended); or Washing our Products by using water or water-soluble cleaning agents for cleaning residue after soldering [h] Use of the Products in places subject to dew condensation 4) The Products are not subject to radiation-proof design. 5) Please verify and confirm characteristics of the final or mounted products in using the Products. 6) In particular, if a transient load (a large amount of load applied in a short period of time, such as pulse) is applied, confirmation of performance characteristics after on-board mounting is strongly recommended. Avoid applying power exceeding normal rated power; exceeding the power rating under steady-state loading condition may negatively affect product performance and reliability. 7) De-rate Power Dissipation (Pd) depending on Ambient temperature (Ta). When used in sealed area, confirm the actual ambient temperature. 8) Confirm that operation temperature is within the specified range described in the product specification. 9) BM shall not be in any way responsible or liable for failure induced under deviant condition from what is defined in this document. ●Precaution for Mounting / Circuit board design 1) When a highly active halogen us (chlorine, bromine, etc.) flux is used, the residue of flux may negatively affect product performance and reliability. 2) In principle, the reflow soldering method must be used; if flow soldering method is preferred, please consult with the BM representative in advance. For details, please refer to BM Mounting specification ●Precautions Regarding Application Examples and External Circuits 1) If change is made to the constant of an external circuit, please allow a sufficient margin considering variations of the characteristics of the Products and external components,   15/18 BM43THA80C  Notice including transient characteristics, as well as static characteristics. 2) You agree that application notes, reference designs, and associated data and information contained in this document are presented only as guidance for Products use. Therefore, in case you use such information, you are solely responsible for it and you must exercise your own independent verification and judgment in the use of such information contained in this document. BM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of such information. ●Precaution for Electrostatic This Product is electrostatic sensitive product, which may be damaged due to electrostatic discharge. Please take proper caution in your manufacturing process and storage so that voltage exceeding the Products maximum rating will not be applied to Products. Please take special care under dry condition (e.g. Grounding of human body / equipment / solder iron, isolation from charged objects, setting of Ionizer, friction prevention and temperature / humidity control). ●Precaution for Storage / Transportation 1) Product performance and soldered connections may deteriorate if the Products are stored in the places where: [a] the Products are exposed to sea winds or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [b] the temperature or humidity exceeds those recommended by BM [c] the Products are exposed to direct sunshine or condensation [d] the Products are exposed to high Electrostatic 2) Even under BM recommended storage condition, solder ability of products out of recommended storage time period may be degraded. It is strongly recommended to confirm solder ability before using Products of which storage time is exceeding the recommended storage time period. 3) Store / transport cartons in the correct direction, which is indicated on a carton with a symbol. Otherwise bent leads may occur due to excessive stress applied when dropping of a carton. 4) Use Products within the specified time after opening a humidity barrier bag. Baking is required before using Products of which storage time is exceeding the recommended storage time period. ●Precaution for Product Label QR code printed on BM Products label is for BM’s internal use only.   16/18 BM43THA80C  Notice ●Precaution for Disposition When disposing Products please dispose them properly using an authorized industry waste company. ●Precaution for Foreign Exchange and Foreign Trade act Since our Products might fall under controlled goods prescribed by the applicable foreign exchange and foreign trade act, please consult with BM representative in case of export. ●Precaution Regarding Intellectual Property Rights 1) All information and data including but not limited to application example contained in this document is for reference only. BM does not warrant that foregoing information or data will not infringe any intellectual property rights or any other rights of any third party regarding such information or data. BM shall not be in any way responsible or liable for infringement of any intellectual property rights or other damages arising from use of such information or data. 2) No license, expressly or implied, is granted hereby under any intellectual property rights or other rights of BM or any third parties with respect to the information contained in this document. ●Other Precaution 1) The information contained in this document is provided on an “as is” basis and BM does not warrant that all information contained in this document is accurate and/or errorfree. BM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties resulting from inaccuracy or errors of or concerning such information. 2) This document may not be reprinted or reproduced, in whole or in part, without prior written consent of BM. 3) The Products may not be disassembled, converted, modified, reproduced or otherwise changed without prior written consent of BM. 4) In no event shall you use in any way whatsoever the Products and the related technical information contained in the Products or this document for any military purposes, including but not limited to, the development of mass-destruction weapons. 5) The proper names of companies or products described in this document are trademarks or registered trademarks of BM, its affiliated companies or third parties.   17/18 BM43THA80C  Revision History 6. Revision History   Version Publication date Pages Revise Description 1.0 Oct.2019 18 Initial Document Release 18/18
BM43THA80C-T2-T-G 价格&库存
很抱歉,暂时无法提供与“BM43THA80C-T2-T-G”相匹配的价格&库存,您可以联系我们找货
BM43THA80C-T2-T-G
  • 1+10.15002
  • 30+9.80002
  • 100+9.10001
  • 500+8.40001
  • 1000+8.05001
