DW01A-G
DW01A-G
    FORTUNE(富晶)
    SOT23-6
    SOT23-6 3.9V 3μA 1
DW01A-G 数据手册
DW01x-DS-17_EN May 2014 FO Fo P R r R ro TU ef pe NE er rti ' en es ce O nl y REV. 1.7 7 Datasheet DW01x One Cell Lithium-ion/Polymer Battery Protection IC DW01x Fortune Semiconductor Corporation 富晶電子股份有限公司 23F., No.29-5,Sec. 2, Zhongzheng E. Rd., FO Fo P R r R ro TU ef pe NE er rti ' en es ce O nl y Danshui Dist, New Taipei City 251, Taiwan Tel.:886-2-28094742 Fax:886-2-28094874 www.ic-fortune.com This manual contains new product information. Fortune Semiconductor Corporation reserves the rights to modify the product specification without further notice. No liability is assumed by Fortune Semiconductor Corporation as a result of the use of this product. No rights under any patent accompany the sale of the product. Rev. 1.7 2/19 DW01x 1. General Description Ordering Information DW01x-x Serial code form G Serial code form - & + Serial code from A to C&E、F * PACKAGE TYPE SOT-23-6 (Green-Package) Refer to the product name list on the next page FO Fo P R r R ro TU ef pe NE er rti ' en es ce O nl y The DW01 series battery protection IC is designed to protect lithium-ion/polymer battery from damage or degrading the lifetime due to overcharge, overdischarge, and/or overcurrent for one-cell lithium-ion/polymer battery powered systems, such as cellular phones. The ultra-small package and less required external components make it ideal to integrate the DW01 series into the limited space of battery pack. The accurate ±50mV overcharging detection voltage ensures safe and full utilization charging. The very low standby current drains little current from the cell while in storage. 3. 2. 4. z Applications Protection IC for One-Cell Lithium-Ion / Lithium-Polymer Battery Pack Features z Reduction in Board Size due to Miniature Package SOT-23-6. z Ultra-Low Quiescent Current at 3μA (Vcc=3.9V). z Ultra-Low Power-Down Current at 0.1μA or Overdischarge Current at 3.5μA (Vcc=2.0V). z Precision Overcharge Protection Voltage 4.25V~4.35, accuracy of ± 50mV. z 0V battery change function are selectable. z Power-down fuction are selectable. z Load Detection Function during Overcharge Mode. z Two Detection Levels for Overcurrent Protection. z Delay times are generated by internal circuits. No external capacitors required. Rev. 1.7 3/19 DW01x 5. Product Name List Model Overcharge Overcharge Overdischarge Overdischarge Overcurrent detection release detection release detection 0V Stand by voltage voltage voltage voltage voltage charge function Package [VOI1] [VODR] [VODP] [VOCR] [VOCP] function release (V) (V) (mV) DW01+G SOT-23-6 4.300±0.050 4.100±0.050 2.40±0.100 3.0±0.100 150±30 NO - DW01-G SOT-23-6 4.250±0.050 4.050±0.050 2.40±0.100 3.0±0.100 150±30 NO - DW01A-G SOT-23-6 4.300±0.050 4.100±0.050 2.40±0.100 3.0±0.100 150±30 NO AUTO recovery DW01B-G SOT-23-6 4.300±0.050 4.100±0.050 2.40±0.100 3.0±0.100 150±30 YES - 2.980±0.100 150±30 NO AUTO recovery (V) FO Fo P R r R ro TU ef pe NE er rti ' en es ce O nl y (V) DW01C-G SOT-23-6 4.250±0.050 4.050±0.050 2.380±0.100 DW01E-G SOT-23-6 4.280±0.050 4.080±0.050 2.40±0.100 3.0±0.100 150±30 NO AUTO recovery DW01F-G SOT-23-6 4.350±0.050 4.150±0.050 2.40±0.100 3.0±0.100 150±30 NO AUTO recovery 6. Pin Configuration and Package Marking Information Pin No. Symbol Description 1 OD MOSFET gate connection pin for discharge control 2 CS Input pin for current sense, charger detect 3 OC MOSFET gate connection pin for charge control 4 TD Test pin for reduce delay time 5 VCC Power supply, through a resistor (R1) 6 GND Ground pin For DW01A~C & E、F X instead of series code A ~C & E、F Top Point:Lot No Bottom Point:Year w : week, A~Z & A ~ Z Rev. 1.7 For DW01+、DW01Top Point:Lot No Bottom Point:Year w : week, A~Z & A ~ Z 4/19 DW01x Functional Block Diagram TD 7. VCC Short circuit Detector VSS VSS Oscillator Control Circuit Overcharge Detector FO Fo P R r R ro TU ef pe NE er rti ' en es ce O nl y Over current Detector Overdischarg e Detector CS Charger Detector GND VSS OD OC Control Logic GND 8. VSS Divider Control Logic Typical Application Circuit Symbol R1 Purpose ESD protection. For power fluctuation. Recommended 470Ω C1 R2 For power fluctuation. Protection for reverse connection of a charger. 0.1μF 1k~2kΩ Rev. 1.7 Remakes Resistance should be as small as possible to avoid lowering of the overcharge detection accuracy caused by VDD pin current. Use 470Ω for better ESD protection. Select a resistance as large as possible to prevent large current when a charge is connected in reverse. 5/19 DW01x 9. Absolute Maximum Ratings (GND=0V, Ta=25°C unless otherwise specified) Symbol Rating Unit Input voltage between VCC and GND * VCC GND-0.3 to GND+10 V OC output pin voltage VOC VCC -24 to VCC +0.3 V OD output pin voltage VOD GND-0.3 to VCC +0.3 V CS input pin voltage VCS VCC -24 to VCC +0.3 V FO Fo P R r R ro TU ef pe NE er rti ' en es ce O nl y Item Operating Temperature Range TOP -40 to +85 °C Storage Temperature Range TST -40 to +125 °C Note: DW01series contains a circuit that will protect it from static discharge; but please take special care that no excessive static electricity or voltage which exceeds the limit of the protection circuit will be applied to it. Rev. 1.7 6/19 DW01x 10. Electrical Characteristics (Ta=25°C unless otherwise specified) 1. DW01+G TEST CONDITIONS SYMBOL Min Typ Max UNIT Supply Current VCC=3.9V ICC 3.0 6.0 μA Power-Down Current VCC=2.0V IPD 0.1 μA Overcharge Protection Voltage DW01+ VOCP 4.25 4.30 4.35 V Overcharge Release Voltage VOCR 4.05 4.10 4.15 V Overdischarge Protection Voltage VODP 2.30 2.40 2.50 V Overdischarge Release Voltage VODR 2.90 3.00 3.10 V Overcurrent Protection Voltage VOIP (VOI1) 120 150 180 mV VSIP (VOI2) 1.00 1.35 1.70 V 1.5 V FO Fo P R r R ro TU ef pe NE er rti ' en es ce O nl y PARAMETER Short Current Protection Voltage VCC=3.6V 0V Battery Charge Inhibition Battery 0V Battery Charging Voltage Unavailable V0INH Overcharge Delay Time TOC 80 200 ms Overdischarge Delay Time VCC=3.6V to 2.0V TOD 40 100 ms Overcurrent Delay Time (1) VCC=3.6V TOI1 10 20 ms Overcurrent Delay Time (2) VCC=3.6V TOI2 5 50 μs -0.7 -0.2 V Charger Detection Threshold Voltage VCHA -1.2 OD Pin Output “H” Voltage VDH VCC-0.1 VCC-0.02 OD Pin Output “L” Voltage VDL OC Pin Output “H” Voltage VCH OC Pin Output “L” Voltage VCL Rev. 1.7 0. 1 V 0.5 VCC-0.1 VCC-0.02 0.1 V V 0.5 V 7/19 DW01x (2)DW01-G TEST CONDITIONS SYMBOL Min Typ Max UNIT Supply Current VCC=3.9V ICC 3.0 6.0 μA Power-Down Current VCC=2.0V IPD 0.1 μA Overcharge Protection Voltage DW01- VOCP 4.20 4.25 4.30 V Overcharge Release Voltage VOCR 4.00 4.05 4.10 V Overdischarge Protection Voltage VODP 2.30 2.40 2.50 V Overdischarge Release Voltage VODR 2.90 3.00 3.10 V Overcurrent Protection Voltage VOIP (VOI1) 120 150 180 mV VSIP (VOI2) 1.00 1.35 1.70 V 1.5 V FO Fo P R r R ro TU ef pe NE er rti ' en es ce O nl y PARAMETER Short Current Protection Voltage VCC=3.6V 0V Battery Charge Inhibition Battery 0V Battery Charging Voltage Unavailable V0INH Overcharge Delay Time TOC 80 200 ms Overdischarge Delay Time VCC=3.6V to 2.0V TOD 40 100 ms Overcurrent Delay Time (1) VCC=3.6V TOI1 10 20 ms Overcurrent Delay Time (2) VCC=3.6V TOI2 5 50 μs -0.7 -0.2 V Charger Detection Threshold Voltage VCHA -1.2 OD Pin Output “H” Voltage VDH VCC-0.1 VCC-0.02 OD Pin Output “L” Voltage VDL OC Pin Output “H” Voltage VCH OC Pin Output “L” Voltage VCL Rev. 1.7 0. 1 V 0.5 VCC-0.1 VCC-0.02 0.1 V V 0.5 V 8/19 DW01x (3)DW01A-G TEST CONDITIONS SYMBOL Supply Current VCC=3.9V Overdischarge Current Overcharge Protection Voltage Min Typ Max UNIT ICC 3.0 6.0 μA VCC=2.0V IOD 1.5 3.5 μA DW01A VOCP 4.25 4.30 4.35 V Overcharge Release Voltage VOCR 4.05 4.10 4.15 V Overdischarge Protection Voltage VODP 2.30 2.40 2.50 V Overdischarge Release Voltage VODR 2.90 3.00 3.10 V Overcurrent Protection Voltage VOIP (VOI1) 120 150 180 mV VSIP (VOI2) 1.00 1.35 1.70 V 1.5 V FO Fo P R r R ro TU ef pe NE er rti ' en es ce O nl y PARAMETER Short Current Protection Voltage VCC=3.6V 0V Battery Charge Inhibition Battery 0V Battery Charging Voltage Unavailable V0INH Overcharge Delay Time TOC 80 200 ms Overdischarge Delay Time VCC=3.6V to 2.0V TOD 40 100 ms Overcurrent Delay Time (1) VCC=3.6V TOI1 10 20 ms Overcurrent Delay Time (2) VCC=3.6V TOI2 5 50 μs -0.7 -0.2 V Charger Detection Threshold Voltage VCHA -1.2 OD Pin Output “H” Voltage VDH VCC-0.1 VCC-0.02 OD Pin Output “L” Voltage VDL OC Pin Output “H” Voltage VCH OC Pin Output “L” Voltage VCL Rev. 1.7 0. 1 V 0.5 VCC-0.1 VCC-0.02 0.1 V V 0.5 V 9/19 DW01x (4)DW01B-G TEST CONDITIONS SYMBOL Min Typ Max UNIT Supply Current VCC=3.9V ICC 3.0 6.0 μA Power-Down Current VCC=2.0V IPD 0.1 μA Overcharge Protection Voltage DW01B VOCP 4.25 4.30 4.35 V Overcharge Release Voltage VOCR 4.05 4.10 4.15 V Overdischarge Protection Voltage VODP 2.30 2.40 2.50 V Overdischarge Release Voltage VODR 2.90 3.00 3.10 V Overcurrent Protection Voltage VOIP 120 (VOI1) 150 180 mV VSIP 1.00 (VOI2) 1.35 1.70 V FO Fo P R r R ro TU ef pe NE er rti ' en es ce O nl y PARAMETER Short Current Protection Voltage VCC=3.6V 0V Battery Charger Starting Charge 0V Battery Charging Voltage Available V0CHA Overcharge Delay Time TOC 80 200 ms 1.5 V Overdischarge Delay Time VCC=3.6V to 2.0V TOD 40 100 ms Overcurrent Delay Time (1) VCC=3.6V TOI1 10 20 ms Overcurrent Delay Time (2) VCC=3.6V TOI2 5 50 μs -0.7 -0.2 V Charger Detection Threshold Voltage VCHA -1.2 OD Pin Output “H” Voltage VDH VCC-0.1 VCC-0.02 OD Pin Output “L” Voltage VDL OC Pin Output “H” Voltage VCH OC Pin Output “L” Voltage VCL 0. 1 V 0.5 VCC-0.1 VCC-0.02 0.1 V V 0.5 V Note: The V0CHA is defined as the voltage between VCC and VCS (VCC-VCS>1.5V) at which OC pin goes “H” when the voltage VCC is gradually increased to the VCC=1V and VCS=-0.5V. Rev. 1.7 10/19 DW01x (5)DW01C-G TEST CONDITIONS SYMBOL Supply Current VCC=3.9V Overdischarge Current Overcharge Protection Voltage Min Typ Max UNIT ICC 3.0 6.0 μA VCC=2.0V IOD 1.5 3.5 μA DW01C VOCP 4.25 4.30 V 4.20 FO Fo P R r R ro TU ef pe NE er rti ' en es ce O nl y PARAMETER Overcharge Release Voltage VOCR 4.00 4.05 4.10 V Overdischarge Protection Voltage VODP 2.28 2.38 2.48 V Overdischarge Release Voltage VODR 2.880 2.980 3.080 V Overcurrent Protection Voltage VOIP (VOI1) 120 150 180 mV VSIP (VOI2) 1.00 1.35 1.70 V 1.5 V Short Current Protection Voltage VCC=3.6V 0V Battery Charge Inhibition Battery 0V Battery Charging Voltage Unavailable V0INH Overcharge Delay Time TOC 80 200 ms Overdischarge Delay Time VCC=3.6V to 2.0V TOD 40 100 ms Overcurrent Delay Time (1) VCC=3.6V TOI1 10 20 ms Overcurrent Delay Time (2) VCC=3.6V TOI2 5 50 μs -0.7 -0.2 V Charger Detection Threshold Voltage VCHA -1.2 OD Pin Output “H” Voltage VDH VCC-0.1 VCC-0.02 OD Pin Output “L” Voltage VDL OC Pin Output “H” Voltage VCH OC Pin Output “L” Voltage VCL Rev. 1.7 0. 1 V 0.5 VCC-0.1 VCC-0.02 0.1 V V 0.5 V 11/19 DW01x (6)DW01E-G TEST CONDITIONS SYMBOL Supply Current VCC=3.9V Overdischarge Current Overcharge Protection Voltage Min Typ Max UNIT ICC 3.0 6.0 μA VCC=2.0V IOD 1.5 3.5 μA DW01E VOCP 4.28 4.33 V 4.23 FO Fo P R r R ro TU ef pe NE er rti ' en es ce O nl y PARAMETER Overcharge Release Voltage VOCR 4.03 4.08 4.13 V Overdischarge Protection Voltage VODP 2.30 2.40 2.50 V Overdischarge Release Voltage VODR 2.90 3.00 3.10 V Overcurrent Protection Voltage VOIP (VOI1) 120 150 180 mV VSIP (VOI2) 1.00 1.35 1.70 V 1.5 V Short Current Protection Voltage VCC=3.6V 0V Battery Charge Inhibition Battery 0V Battery Charging Voltage Unavailable V0INH Overcharge Delay Time TOC 80 200 ms Overdischarge Delay Time VCC=3.6V to 2.0V TOD 40 100 ms Overcurrent Delay Time (1) VCC=3.6V TOI1 10 20 ms Overcurrent Delay Time (2) VCC=3.6V TOI2 5 50 μs -0.7 -0.2 V Charger Detection Threshold Voltage VCHA -1.2 OD Pin Output “H” Voltage VDH VCC-0.1 VCC-0.02 OD Pin Output “L” Voltage VDL OC Pin Output “H” Voltage VCH OC Pin Output “L” Voltage VCL Rev. 1.7 0. 1 V 0.5 VCC-0.1 VCC-0.02 0.1 V V 0.5 V 12/19 DW01x (7)DW01F-G TEST CONDITIONS SYMBOL Supply Current VCC=3.9V Overdischarge Current Overcharge Protection Voltage Min Typ Max UNIT ICC 3.0 6.0 μA VCC=2.0V IOD 1.5 3.5 μA DW01F VOCP 4.30 4.35 4.40 V Overcharge Release Voltage VOCR 4.10 4.15 4.20 V Overdischarge Protection Voltage VODP 2.30 2.40 2.50 V Overdischarge Release Voltage VODR 2.90 3.00 3.10 V Overcurrent Protection Voltage VOIP (VOI1) 120 150 180 mV VSIP (VOI2) 1.00 1.35 1.70 V 1.5 V FO Fo P R r R ro TU ef pe NE er rti ' en es ce O nl y PARAMETER Short Current Protection Voltage VCC=3.6V 0V Battery Charge Inhibition Battery 0V Battery Charging Voltage Unavailable V0INH Overcharge Delay Time TOC 80 200 ms Overdischarge Delay Time VCC=3.6V to 2.0V TOD 40 100 ms Overcurrent Delay Time (1) VCC=3.6V TOI1 10 20 ms Overcurrent Delay Time (2) VCC=3.6V TOI2 5 50 μs -0.7 -0.2 V Charger Detection Threshold Voltage VCHA -1.2 OD Pin Output “H” Voltage VDH VCC-0.1 VCC-0.02 OD Pin Output “L” Voltage VDL OC Pin Output “H” Voltage VCH OC Pin Output “L” Voltage VCL Rev. 1.7 0. 1 V 0.5 VCC-0.1 VCC-0.02 0.1 V V 0.5 V 13/19 DW01x 11. Description of Operation Normal Condition If VODP
DW01A-G 价格&库存
很抱歉,暂时无法提供与“DW01A-G”相匹配的价格&库存,您可以联系我们找货
DW01A-G
    • 5+0.82603
    • 20+0.75315
    • 100+0.68026
    • 500+0.60737
    • 1000+0.57336
    • 2000+0.54907
