ATS1-46
ATS1-46
    BESTAR
    TO-46
    温度传感器 湿度、温度 TO46
ATS1-46 数据手册
AUI SPECIFICATION For Thermopile Temperature Sensor TOTAL PAGE 07 www.auimems.com Customer Model Name ATS1-46 Customer P/N Product No. 19**** Date 11 Nov.2017 Issue No. Page 01 of 09 Issue Date RoHS BS/TEM01.***A 2017.11.11 Approval: 1.Descriptions 2.Features 3.Applications 4.Drawing 5.Parameter 6.Packing 7.History change record Drawn by Checked by Approved by Customer approved Audio Unlimited Incorporation CO.,LTD No.11 qingyang north road, tianning district, changzhou,JiangSu Province,P.R.China Tel: +86 519 68191786 Fax: +86 519 88222551 E-mail:wu@auimems.com http:// www.auimems.com AUI 6 5 4 3 2 1 H H ATS1-46 G G 1. Descriptions This print and information there in are proprietary to Audio Unlimited Incorporation Co., Ltd. and shall not be used in whole or in part without its written content F F The ATS1-46 is a thermopile temperature sensor based on MEMS (Micro-ElectroMechanical Systems) technology. This thermopile detector consists of a thermopile MEMS chip, a F5.5 infrared band pass filter, a NTC thermistor for temperature compensation and a small size TO-46 package. E E 2. Features Non-contact surface temperature measuring TO housing with an F5.5 infrared filter Using NTC thermistor for ambient temperature compensation Suitable for human body temperature detecting and Industrial temperature measurement Fast response time High sensitivity D D 3.Applications Non-contact infrared thermometer Microwave oven Automatic induction equipment Heating, Ventilation and Air Conditioning(HVAC) Appliance C C B B 2017.11.11 Date: A A 2017.11.11 Date Rev. 王焕焕 Drawn Note Drawn by: 王焕焕 Checked by: 徐 Approved by: 徐金国 波 www.auimems.com wu@auimems.com 6 文件号:BS/QDTE045B 5 4 ATS1-46 3 Sensor DRG NO: BS/TEM01.***A 2 A Page:2 of 7 1 AUI 6 H 5 4 2 3 1 H ATS1-46 4.Drawing 1.3±0.05 0 1-0.07 G 14 2.4±0.05 Ø2.5±0.05 2.85±0.05 G F F Ø4.6+0.02 -0.03 1.8 Unit: mm E E 45° Ø2.54±0.05 Description Pin No. 2(TH) D 3(TP-) 1(TP+) 4(NC) 2(TH) 6.26±0.1 This print and information there in are proprietary to Audio Unlimited Incorporation Co., Ltd. and shall not be used in whole or in part without its written content 2-Ø0.45±0.03 Ø5.5±0.05 3(TP-) 1(TP+) 4(NC) Thermopile+(TP+) Thermistor(TH) 1 2 3 Thermopile-(TP-) 4 GND D Bottom C C Pin Function Description 1 Thermopile+(TP+) : Thermopile Output DC Voltage+ pin. 2 Thermistor(TH): Ambient Temperature Compensation Resistance+ pin. 3 Thermopile-(TP-): Thermopile Output DC Voltage- pin. 4 GND: Ambient Temperature Compensation Resistance- pin and GND. B B Notes Tolerance±0.15mm unless otherwise specified. 2017.11.11 Date: Drawn by: A A 2017.11.11 Date Rev. 王焕焕 Drawn Note Checked by: 徐 Approved by: 徐金国 波 www.auimems.com wu@auimems.com 6 文件号:BS/QDTE045B 5 4 ATS1-46 王焕焕 3 Sensor DRG NO: BS/TEM01.***A 2 Page:3 of 7 1 A AUI 6 H 5 4 2 3 1 H ATS1-46 5. Parameter 5.1 Thermopile parameter G This print and information there in are proprietary to Audio Unlimited Incorporation Co., Ltd. and shall not be used in whole or in part without its written content F E Specification Condition Min. Typ. Max. Chip Size 1.85*1.85 Active Area 0.7X0.7 Responsivity Black body=500K,1HZ @temp=25℃ 63 Detectivity Black body=500K,1HZ @temp=25℃ 1.21E08 NEP Black body=500K,1HZ @temp=25℃ 0.56 Voltage Response Black body=500K,1HZ @temp=25℃ 29 Thermopile Res @temp=25℃ 65 75 85 TC of Thermopile -0.11 Noise Voltage @temp=25℃ 33 35 37 Time Constant 16 Field of View(FOV) Degree at 50% signal level 83 Operating Temp -40~120 Storage Temp -40~120 Thermistor Resistance @temp=25 100 +1.5% TC of Thermistor(B) Defined at 25/50℃ 3950 ±1% G Unit mm² mm² V/W cm·Hz½ /W nW·Hz½ V·mm²/W kΩ %/℃ nV/Hz½ ms ° ℃ ℃ kΩ K F E  5.2. NT Temperature VS Resistance Table Rmin(kΩ) 3073.524 1644.113 912.905 524.122 311.198 191.179 120.819 97.000 77.949 51.246 34.450 23.673 16.576 11.812 8.546 6.275 4.671 3.523 Temp.( ) -40 -30 -20 -10 0 10 20 25 30 40 50 60 70 80 90 100 110 120 D C B Drawn by: A 2017.11.11 Date Rev. 王焕焕 Drawn Note Checked by: 徐 Approved by: 徐金国 文件号:BS/QDTE045B 5 4 波 3 D C B ATS1-46 王焕焕 www.auimems.com wu@auimems.com 6 Rmax(kΩ) 3499.634 1848.539 1014.286 575.836 338.322 205.806 128.863 103.000 83.130 55.108 37.339 25.850 18.229 13.076 9.522 7.034 5.267 3.995 2017.11.11 Date: A Rnor(kΩ) 3281.143 1744.117 962.695 549.618 324.623 198.447 124.832 100.000 80.534 53.166 35.882 24.749 17.391 12.433 9.024 6.647 4.963 3.753 Sensor DRG NO: BS/TEM01.***A 2 A Page:4 of 7 1 AUI 6 5 4 3 2 1 ATS1-46 H H 5.3 Filter Transmission Curve transmittance % G F F E E μm 5.4 Sensitivity Output Curve D D output mv This print and information there in are proprietary to Audio Unlimited Incorporation Co., Ltd. and shall not be used in whole or in part without its written content G C C B B Temperature( ) Object Temperature(℃)@Tamb.=25℃ 2017.11.11 Date: Drawn by: A A 2017.11.11 Date Rev. 王焕焕 Drawn Note Checked by: 徐 Approved by: 徐金国 波 www.auimems.com wu@auimems.com 6 文件号:BS/QDTE045B 5 4 ATS1-46 王焕焕 3 Sensor DRG NO: BS/TEM01.***A 2 A Page:5 of 7 1 AUI 6 5 4 3 2 1 ATS1-46 H H This print and information there in are proprietary to Audio Unlimited Incorporation Co., Ltd. and shall not be used in whole or in part without its written content 6.Packing G G F F TBD E E D D C C B B Notes All dimensions are in millimeter(mm). 2017.11.11 Date: Drawn by: A A 2017.11.11 Date Rev. 王焕焕 Drawn Note Checked by: 徐 Approved by: 徐金国 波 www.auimems.com wu@auimems.com 6 文件号:BS/QDTE045B 5 4 ATS1-46 王焕焕 3 Sensor DRG NO: BS/TEM01.***A 2 A Page:6 of 7 1 AUI 6 4 5 2 3 1 ATS1-46 H H 7. History change record version No. Change Items Date G This print and information there in are proprietary to Audio Unlimited Incorporation Co., Ltd. and shall not be used in whole or in part without its written content Drawn Approved After Before 2017.11.11 王焕焕 G 徐金国 F F E E D D C C B B 2017.11.11 Date: Drawn by: A A 2017.11.11 Date Rev. 王焕焕 Drawn Note Checked by: 徐 Approved by: 徐金国 波 www.auimems.com wu@auimems.com 6 文件号:BS/QDTE045B 5 4 ATS1-46 王焕焕 3 Sensor DRG NO: BS/TEM01.***A 2 A Page:7 of 7 1
ATS1-46 价格&库存
很抱歉,暂时无法提供与“ATS1-46”相匹配的价格&库存,您可以联系我们找货
ATS1-46
    • 1+6.67001
    • 30+6.44001
    • 100+5.98001
    • 500+5.52000
    • 1000+5.29000
