FS98O25
FS98O25
    FORTUNE(富晶)
    QFN100_20X14MM
    带8k程序EPROM的8位MCU QFN100_20X14MM
FS98O25 数据手册
FS98O25-DS-15_EN OCT 2009 Datasheet F P r R ro SC ef pe ’ er rti en es ce O nl y REV. 1.5 FS98O25 Fo 8-bit MCU with 8k program EPROM, 256-byte RAM, 2 low noise OPAMP, 8-ch 14-bit ADC, 4 × 32 LCD driver and RTC FS98O25 Fo F P r R ro SC ef pe ’ er rti en es ce O nl y Fortune Semiconductor Corporation 富晶電子股份有限公司 28F., No.27, Sec. 2, Zhongzheng E. Rd., Danshui Town, Taipei County 251, Taiwan Tel.:886-2-28094742 Fax:886-2-28094874 www.ic-fortune.com This manual contains new product information. Fortune Semiconductor Corporation reserves the rights to modify the product specification without further notice. No liability is assumed by Fortune Semiconductor Corporation as a result of the use of this product. No rights under any patent accompany the sale of the product. Rev. 1.5 2/142 FS98O25 Contents DEVICE OVERVIEW ................................................................................................................................ 10 High Performance RISC CPU ..................................................................................................... 10 1.2 Peripheral Features..................................................................................................................... 10 1.3 Analog Features .......................................................................................................................... 10 1.4 Special Microcontroller Features ............................................................................................... 10 1.5 CMOS Technology ...................................................................................................................... 10 1.6 Applications................................................................................................................................. 10 1.7 1.8 1.9 y 1.1 F P r R ro SC ef pe ’ er rti en es ce O nl 1. Pin Configuration ........................................................................................................................ 12 Pin Description ............................................................................................................................ 13 1.10 Functional Block Diagram .......................................................................................................... 14 1.11 CPU Core ..................................................................................................................................... 16 1.12 2. Ordering Information .................................................................................................................. 11 Clocking Scheme/Instruction Cycle .......................................................................................... 18 ELECTRICAL CHARACTERISTICS ........................................................................................................ 19 2.1 2.2 2.3 2.4 Absolute Maximum Ratings ....................................................................................................... 19 DC Characteristics (VDD=3V, TA=25℃, unless otherwise noted) ............................................ 19 ADC Characteristics (VDD=3V, TA=25℃, unless otherwise noted) ......................................... 20 OPAMP Characteristics (VDD=3V, TA=25℃, unless otherwise noted) .................................... 20 2.5 Temperature Characteristics(VDD=3V) ........................................................................................... 20 3. MEMORY ORGANIZATION ...................................................................................................................... 21 3.1 3.2 3.3 Program Memory Structure ........................................................................................................ 21 Data Memory Structure ............................................................................................................... 21 System Special Registers........................................................................................................... 22 3.3.1 3.3.2 3.3.3 3.3.4 3.4 Peripheral Special Registers ...................................................................................................... 27 POWER SYSTEM ..................................................................................................................................... 29 Fo 4. Special Register Contents after External Reset (Power On Reset) and WDT Reset . 23 IND and FSR Registers ................................................................................................... 23 STATUS Register ............................................................................................................. 24 INTE and INTF registers.................................................................................................. 25 4.1 Voltage Doubler ........................................................................................................................... 33 4.2 Voltage Regulator ........................................................................................................................ 34 4.3 Analog Bias Circuit ..................................................................................................................... 35 4.4 Analog Common Voltage Generator .......................................................................................... 36 4.5 Low Battery Comparator ............................................................................................................ 37 Rev. 1.5 3/142 FS98O25 4.6 6. CLOCK SYSTEM ..................................................................................................................................... 39 Oscillator State ............................................................................................................................ 40 5.2 CPU Instruction Cycle ................................................................................................................ 41 5.3 ADC Sample Frequency ............................................................................................................. 42 5.4 Beeper Clock ............................................................................................................................... 42 5.5 Voltage Doubler Operation Frequency ...................................................................................... 43 5.6 Chopper Operation Amplifier Input Control Signal .................................................................. 43 5.7 TMCLK -- Timer and LCD Module Input Clock .......................................................................... 44 y 5.1 F P r R ro SC ef pe ’ er rti en es ce O nl 5. Bandgap Voltage and Temperature Sensor .............................................................................. 38 TIMER MODULE, WATCH DOG TIMER AND PROGRAMMABLE COUNTER ................................................................................................................................................ 45 6.1 Timer Module ............................................................................................................................... 50 6.1.1 6.1.2 6.2 6.3 7. Timer module interrupt ................................................................................................... 51 Using Timer with External/Internal Clock ...................................................................... 52 Watch Dog Timer ......................................................................................................................... 54 Dual 16-bit Programmable Counter ........................................................................................... 55 I/O PORT .................................................................................................................................................. 59 7.1 7.2 7.3 7.4 7.5 7.6 Digital I/O Port with Analog Input Channel Shared: PT1[7:0] .................................................. 72 Digital I/O Port and External Interrupt Input : PT2[0], PT2[1], PT3[0], PT3[1]......................... 73 Digital I/O Port or PDM Output : PT2[2] and PT2[5] .................................................................. 76 Digital I/O Port or I2C Serial Port : PT2[3]/SDA, PT2[4]/SCL .................................................... 77 Digital I/O Port : PT2[6] ............................................................................................................... 79 Digital I/O Port or Buzzer Output : PT2[7] ................................................................................. 81 8. PDM (PULSE DENSITY MODULATOR) MODULE .................................................................................. 83 9. I2C MODULE (SLAVE MODE ONLY) ...................................................................................................... 90 10. ANALOG FUNCTION NETWORK ........................................................................................................... 96 10.1 Analog to Digital Converter (ADC) :......................................................................................... 105 10.2 OPAMP : OP1 and OP2 ............................................................................................................. 109 11. ADC APPLICATION GUIDE ................................................................................................................... 112 11.1 11.2 ADC Linear Range..................................................................................................................... 112 ADC Output Rate and Settling Time ........................................................................................ 112 Fo 11.3 ADC Output Format .................................................................................................................. 112 11.4 ADC Input Offset ....................................................................................................................... 112 11.5 ADC Digital Output .................................................................................................................... 113 11.6 ADC Resolution ......................................................................................................................... 113 12. LOW NOISE OPERATION AMPLIFIER GUIDE ..................................................................................... 114 Rev. 1.5 4/142 FS98O25 12.1 Single End Amplifier Application ............................................................................................. 114 12.2 Differential Amplifier ................................................................................................................. 115 13. LCD DRIVER .......................................................................................................................................... 116 14. HALT AND SLEEP MODES ................................................................................................................... 128 15. INSTRUCTION SET ............................................................................................................................... 129 15.1 Instruction Set Summary .......................................................................................................... 129 15.2 Instruction Description ............................................................................................................. 131 Package Outline ........................................................................................................................ 142 F P r R ro SC ef pe ’ er rti en es ce O nl 16.1 y 16. PACKAGE INFORMATION .................................................................................................................... 142 Fo 17. REVISION HISTORY .............................................................................................................................. 142 Rev. 1.5 5/142 FS98O25 Figure List Fo F P r R ro SC ef pe ’ er rti en es ce O nl y Figure 1-1 FS98O25 pin configuration ......................................................................................... 12 Figure 1-2 FS98O25 function block .............................................................................................. 14 Figure 1-3 FS98O25 CPU core function block ............................................................................. 16 Figure 1-4 FS98O25 instruction cycle .......................................................................................... 18 Figure 2-1 VDDA vs Temp @ VDD=3V Figure 2-2 VREF vs Temp @ VDD=3V....................... 20 Figure2-3LVR vs Temp @ VDD=3V20 Figure 3-1 FS98O25 program memory structure ......................................................................... 21 Figure 3-2 IND & FSR function description .................................................................................. 23 Figure 4-1 FS98O25 power system block .................................................................................... 29 Figure 4-2 Voltage Doubler ............................................................................................................ 33 Figure 4-3 Voltage regulator .......................................................................................................... 34 Figure 4-4 analog bias circuit ....................................................................................................... 35 Figure 4-5 analog common voltage generator............................................................................. 36 Figure 4-6 low battery comparator function block ...................................................................... 37 Figure 4-7 Bandgap voltage and temperature sensor function block ....................................... 38 Figure 5-1 FS98O25 clock system function block ....................................................................... 39 Figure 5-2 FS98O25 oscillator state block ................................................................................... 40 Figure 6-1 FS98O25 timer module function block ....................................................................... 50 Figure 6-2 watch dog timer function block .................................................................................. 54 Figure 6-3 Programmable Counter Working block diagram ....................................................... 55 Figure 6-4 Programmable Counter Counter mode ...................................................................... 56 Figure 6-5 Programmable Counter Pulse Width Measurement mode ....................................... 57 Figure 6-6 Programmable Counter Frequency Measurement mode.......................................... 58 Figure 7-1 PT1[7:0] function block ............................................................................................... 72 Figure 7-2 PT2[0] PT2[1] PT3[0] PT3[1] function block ............................................................... 73 Figure 7-3 PT2[2] function block................................................................................................... 76 Figure 7-4 PT2[3] PT2[4] function block ....................................................................................... 77 Figure 7-5 PT2[6] function block................................................................................................... 79 Figure 7-6 PT2[7] function block................................................................................................... 81 Figure 8-1 FS98O25 PDM module function block........................................................................ 83 Figure 8-2 PDM module signal generation ................................................................................... 84 Figure 9-1 FS98O25 I2C module communication ........................................................................ 90 Figure 9-2 I2C module function block .......................................................................................... 90 Figure 9-3 I2C waveform for reception ......................................................................................... 94 Figure 9-4 I2C waveforms for transmission ................................................................................. 95 Figure 10-1 FS98O25 analog function network ........................................................................... 96 Figure 10-2 FS98O25 ADC function block.................................................................................. 105 Figure 12-1 single end amplifier application example ............................................................... 114 Figure 12-2 differential amplifier example .................................................................................. 115 Figure 13-1 LCD driver control block .......................................................................................... 116 Figure 13-2 LCD control mode ..................................................................................................... 116 Figure 13-3 LCD duty mode working cycle ................................................................................. 118 Figure 13-4 1/3 bias LCD power system circuit connection example....................................... 119 Figure 13-5 1/3 bias LCD power system clock ........................................................................... 119 Figure 13-6 1/2 bias LCD power system circuit connection example...................................... 120 Figure 13-7 1/2 bias LCD power system clock .......................................................................... 120 Figure 16-1 FS98O25 package outline ........................................................................................ 142 Rev. 1.5 6/142 FS98O25 Table List Fo F P r R ro SC ef pe ’ er rti en es ce O nl y Table 1-1 Ordering Information ...................................................................................................... 11 Table 1-2 FS98O25 pin description ............................................................................................... 13 Table 1-3 FS98O25 main function description table.................................................................... 15 Table 1-4 FS98O25 CPU core block diagram description table .................................................. 17 Table 2-1 FS98O25 absolute maximum rating table .................................................................... 19 Table 2-2 FS98O25 DC characteristics ......................................................................................... 19 Table 2-3 FS98O25 ADC characteristics ....................................................................................... 20 Table 2-4 FS98O25 OPAMP characteristics ................................................................................. 20 Table 3-1 FS98O25 Data memory structure ................................................................................. 21 Table 3-2 system register table ..................................................................................................... 22 Table 3-3 special register reset table ............................................................................................ 23 Table 3-4 peripheral special registers table ................................................................................. 27 Table 4-1 FS98O25 power system register table ......................................................................... 30 Table 4-2 Voltage Doubler register table ...................................................................................... 33 Table 4-3 Voltage Doubler operation frequency selection table ................................................. 34 Table 4-4 voltage regulator register table .................................................................................... 34 Table 4-5 analog bias circuit register table .................................................................................. 35 Table 4-6 analog common voltage generator register table ....................................................... 36 Table 4-7 low battery comparator register table .......................................................................... 37 Table 4-8 low battery comparator voltage detection selection table ......................................... 37 Table 4-9 bandgap voltage and temperature sensor register table ........................................... 38 Table 5-1 FS98O25 clock system register table ........................................................................... 39 Table 5-2 FS98O25 clock system register table ........................................................................... 40 Table 5-3 MCK selection table ....................................................................................................... 40 Table 5-4 CLK selection table ........................................................................................................ 40 Table 5-5 oscillator state selection table ...................................................................................... 41 Table 5-6 FS98O25 CPU instruction cycle register table ............................................................ 41 Table 5-7 MCK selection table ....................................................................................................... 41 Table 5-8 instruction cycle selection table ................................................................................... 41 Table 5-9 ADC sample frequency selection table ........................................................................ 42 Table 5-10 beeper clock register table.......................................................................................... 42 Table 5-11 MCK selection table ..................................................................................................... 42 Table 5-12 CLK selection table ...................................................................................................... 42 Table 5-13 beeper clock selection table ....................................................................................... 42 Table 5-14 register and the beeper clock selection table ........................................................... 43 Table 5-15 MCK selection table ..................................................................................................... 43 Table 5-16 Voltage Doubler operation frequency selection table ............................................... 43 Table 5-17 CLK selection table ...................................................................................................... 44 Table 5-18 MCK selection table ..................................................................................................... 44 Table 5-19 chopper control signal selection table ...................................................................... 44 Table 5-20 TMCLK selection table................................................................................................. 44 Table 6-1 Timer module and watch dog timer register table ...................................................... 45 Table 6-2 timer module interrupt register table ........................................................................... 51 Table 6-3 timer selection table ...................................................................................................... 51 Table 6-4 external timer setup register table ............................................................................... 52 Table 6-5 CLK selection table ........................................................................................................ 52 Table 6-6 MCK selection table ....................................................................................................... 52 Table 6-7 TMCLK selection table .................................................................................................. 52 Table 6-8 registers and timer selection table ............................................................................... 53 Table 6-9 watch dog timer register table ...................................................................................... 54 Table 6-10 Programmable Counter working mode selection table ............................................ 55 Table 6-11 Programmable Counter Clock signal selection table ............................................... 56 Table 7-1 FS98O25 I/O port register table .................................................................................... 59 Table 7-2 PT1 register table ........................................................................................................... 73 Table 7-3 PT2 register table ........................................................................................................... 75 Table 7-4 PT2 register table ........................................................................................................... 77 Table 7-5 PT2 register table ........................................................................................................... 78 Table 7-6 PT2 register table ........................................................................................................... 80 Table 7-7 PT2[7] register table ...................................................................................................... 82 Rev. 1.5 7/142 FS98O25 Fo F P r R ro SC ef pe ’ er rti en es ce O nl y Table 8-1 PDM module register table ............................................................................................ 85 Table 8-2 PMD register table ......................................................................................................... 89 Table 8-3 PDM CLK selection table ............................................................................................... 89 Table 9-1 I2C module register table .............................................................................................. 91 Table 9-2 I2C register table ............................................................................................................ 94 Table 10-1 analog function network register table ...................................................................... 97 Table 10-2 ADC function register table ....................................................................................... 106 Table 10-3 FTIN selection table ................................................................................................... 106 Table 10-4 FTB selection table .................................................................................................... 106 Table 10-5 INH selection table ..................................................................................................... 107 Table 10-6 INL selection table ..................................................................................................... 107 Table 10-7 ADG selection table ................................................................................................... 107 Table 10-8 VRH selection table ................................................................................................... 107 Table 10-9 SVRL selection table.................................................................................................. 108 Table 10-10 ADC output rate selection table .............................................................................. 108 Table 10-11 ADC sample frequency selection table .................................................................. 108 Table 10-12 FS98O25 OPAMP register table .............................................................................. 109 Table 10-13 SOP1P selection table ............................................................................................. 109 Table 10-14 SOP1N selection table ............................................................................................. 109 Table 10-15 chopper mode selection table ................................................................................. 110 Table 10-16 FS98O25 OPAMP register table ............................................................................... 110 Table 10-17 SOP2P selection table .............................................................................................. 110 Table 10-18 SOP2N selection table .............................................................................................. 111 Table 10-19 chopper mode selection table ................................................................................. 111 Table 11-1 ADC rolling counts versus ADM ................................................................................ 113 Table 11-2 ADC rolling counts versus VR ................................................................................... 113 Table 13-1 LCD frame frequency selection table ........................................................................ 117 Table 13-2 LCD duty selection table ............................................................................................ 117 Table 13-3 FS98O25 LCD driver register table ........................................................................... 121 Table 13-4 LCD driver register table ........................................................................................... 126 Table 13-5 CLK selection table .................................................................................................... 126 Table 13-6 MCK selection table ................................................................................................... 126 Table 13-7 TMCLK selection table............................................................................................... 127 Table 13-8 LCD frame frequency selection table ....................................................................... 127 Table 13-9 LCD duty control mode selection table.................................................................... 127 Table 15-1 FS98O25 instruction set table................................................................................... 129 Rev. 1.5 8/142 FS98O25 Register List Fo F P r R ro SC ef pe ’ er rti en es ce O nl y Register STATUS at address 04H .................................................................................................. 24 Register INTE at address 07H ........................................................................................................ 25 Register INTF at address 06H ........................................................................................................ 26 Register PCK at address 15H ......................................................................................................... 30 Register NETE at address 1CH ...................................................................................................... 31 Register NETF at address 1DH ...................................................................................................... 32 Register SVD at address 1FH ......................................................................................................... 32 Register CTAH at address 08H....................................................................................................... 45 Register CTAL at address 09H ....................................................................................................... 45 Register CTBH at address 0AH ...................................................................................................... 46 Register CTBL at address 0BH ...................................................................................................... 46 Register CTCON at address 0CH ................................................................................................... 47 Register WDTCON at address 0DH................................................................................................ 48 Register TMOUT at address 0EH ................................................................................................... 49 Register TMCON at address 0FH ................................................................................................... 49 Register PT1 at address 20H .......................................................................................................... 60 Register PT1EN at address 21H ..................................................................................................... 60 Register PT1PU at address 22H ..................................................................................................... 61 Register AIENB1 at address 23H ................................................................................................... 62 Register PT2 at address 24H .......................................................................................................... 63 Register PT2EN at address 25H ..................................................................................................... 64 Register PT2PU at address 26H ..................................................................................................... 65 Register PT2MR at address 27H .................................................................................................... 66 Register PT3 at address 28H .......................................................................................................... 67 Register PT3EN at address 29H ..................................................................................................... 68 Register PT3PU at address 2AH .................................................................................................... 69 Register PT3MR at address 2BH.................................................................................................... 70 Register PT2OCB at address 37H .................................................................................................. 79 Register PT2MR at address 27H .................................................................................................... 85 Register PMD1H at address 30H .................................................................................................... 86 Register PMD1L at address 31H .................................................................................................... 86 Register PMD2H at address 32H .................................................................................................... 87 Register PMD2L at address 33H .................................................................................................... 87 Register PMCON at address 36H ................................................................................................... 88 Register I2CCON at address 57H ................................................................................................... 91 Register I2CSTA at address 58H .................................................................................................... 92 Register I2CADD at address 59H ................................................................................................... 92 Register I2CBUF at address 5AH ................................................................................................... 93 Register ADOH at address 10H ...................................................................................................... 98 Register ADOL at address 11H ...................................................................................................... 98 Register ADOLL at address 12H .................................................................................................... 99 Register ADCON at address 13H ................................................................................................... 99 Register PCK at address 15H ....................................................................................................... 100 Register NETA at address 18H ..................................................................................................... 101 Register NETB at address 19H .................................................................................................... 102 Register NETC at address 1AH .................................................................................................... 103 Register NETD at address 1BH .................................................................................................... 104 Register LCD1 at address 40H ..................................................................................................... 121 Register LCD2 at address 41H ..................................................................................................... 122 Register LCD3 at address 42H ..................................................................................................... 122 Register LCD4 at address 43H ..................................................................................................... 123 Register LCD5 at address 44H ..................................................................................................... 123 Register LCD6 at address 45H ..................................................................................................... 124 Register LCDENR at address 54H ............................................................................................... 125 Rev. 1.5 9/142 FS98O25 1. Device Overview The FS98O25 is a CMOS 8-bit single chip microcontroller(MCU) with embedded a 8kx16 bits one-time programmable (OTP) ROM, a 8-channel 14-bit fully differential input analog to digital converter, low noise amplifier, and 4 x 32 LCD driver. The FS98O25 is best suited for applications such as electrical scale, meter, and sensor or transducer measurement application etc. 8-bit single chip microcontroller(MCU). Embedded 8k x 16 bits program memory with one-time programmable (OTP) ROM. 256-byte data memory (RAM). Only 37 single word instructions to learn 8-level memory stacks. F P r R ro SC ef pe ’ er rti en es ce O nl      y High Performance RISC CPU Peripheral Features        20-bit bi-directional I/O port. Two PDM (Pulse Density Modulator) output. Buzzer output. I2C serial I/O port (slave mode only). 4 x 32 LCD drivers. One 8-channel 14-bit fully differential input analog to digital converter(ADC) Two low noise amplifier Analog Features   8-channel Sigma-Delta ADC with programmable output rate and resolution. Low noise (1μV Vpp without chopper, 0.5μV Vpp with chopper, 0.1Hz~1Hz) OPAMP with chopper controller. Special Microcontroller Features          External 32768Hz crystal oscillator (RTC). Embedded Low Voltage Reset (LVR) and Low Voltage Detector (LVD). Embedded charge pump (Voltage Doubler) and voltage regulator (3.6V regulated output). Embedded bandgap voltage reference (typical 1.16V±50mV, 150ppm/°C). 8 Interrupt sources (external: 5, internal: 3). Internal silicon temperature sensor. Watchdog timer (WDT). Embedded 1.0 MHz oscillator. Package: 82-pin dice form, 100-pin LQFP.   Fo CMOS Technology Voltage operation ranges from 2.2V to 3.6V. Operation current is less than 4 mA; sleep mode current is about 3μA. Applications  Sensor or transducer measurement applications. Rev. 1.5 10/142 FS98O25   Electronic kitchen scale, personal scale. Digital meter. Ordering Information Table 1-1 Ordering Information F P r R ro SC ef pe ’ er rti en es ce O nl y Product Number Description Package Type FS98O25 MCU with OTP ROM; The customer has to 82-pin Dice form, 100-pin QFP program the compiled hex code into OTP ROM. FS98O25-nnnV MCU with program type; FSC programs the 82-pin Dice form, 100-pin QFP customer‟s compiled hex code into EPROM at factory before shipping. FS98O251 6K ROM version of FS98O25 82-pin Dice form, 100-pin QFP FS98O251-nnnV 6K ROM version of FS98O25 with program 82-pin Dice form, 100-pin QFP type Note1: Code number (nnnV) is assigned for customer. Fo Note2: Code number (nnn = 001~999); Version (V = A~Z). Rev. 1.5 11/142 FS98O25 F P r R ro SC ef pe ’ er rti en es ce O nl y Pin Configuration Fo Figure 1-1 FS98O25 pin configuration Rev. 1.5 12/142 FS98O25 Pin Description Table 1-2 FS98O25 pin description I/O I/O I/O I/O I/O I/O I/O I/O Pin No 1 4 5 6 7, 8 9 10 11~18 19~20 34~35 21,24 22 23 26 36 37 25 54~74 38~48 75~78 82 83 84~86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 Description Programming Power Supply OPAMP 2 Output OPAMP 1 Output Band gap Reference Output ADC Pre-Filter Capacitor Connection Analog Circuit Bias Current Input Analog Ground Digital I/O Port or Analog input channel Digital I/O Port and External Interrupt input y In/Out I I/O I/O O I/O I I/O I/O Digital I/O Port or PDM output Digital I/O Port or I2C serial Bi-Directional data line Digital I/O Port or I2C clock input Digital I/O Port or Buzzer Output Digital I/O Port or Programmable Frequency Input Digital I/O Port or Programmable Frequency Output Digital I/O Port F P r R ro SC ef pe ’ er rti en es ce O nl Name VPP OP2O OP1O REFO FTB, FTC VB AGND PT1/AIN0~7 PT2/INT0~1, PT3/INT2~3 PT2/PDM1,2 PT2/SDA PT2/SCL PT2/BZ PT3/PFI PT3/PFO PT2 O COM4~COM1 LCA LCB V3,V2,V1 VDDA VS VGG NC VSSP CB CA VDDP VDD VSS XOUT XIN TST RST O I/O I/O I/O I/O I/O I/O I I/O I/O I I I O I I I LCD Segment Driver Output LCD Common Driver Output LCD Charge Pump Capacitor Positive Connection LCD Charge Pump Capacitor Negative Connection LCD Bias Analog Power Output Voltage Source from VDDA Charge Pump Voltage No Connection Charge Pump Negative Power Supply Charge Pump Capacitor Negative Connection Charge Pump Capacitor Positive Connection Charge Pump Positive Power Supply Positive Power Supply Negative Power Supply (Ground) 32768Hz Oscillator Output 32768Hz Oscillator Input Testing Mode CPU Reset Fo SEG32~SEG1 Rev. 1.5 13/142 FS98O25 F P r R ro SC ef pe ’ er rti en es ce O nl y Functional Block Diagram Fo Figure 1-2 FS98O25 function block Rev. 1.5 14/142 FS98O25 There are 5 kinds of functional blocks in the Function Block Diagram, described as table 1-3: Table 1-3 FS98O25 main function description table Sub Item FS98O25 CPU Core OTP Program Memory Data Memory Clock sys Timer Module LCD Module I2C F P r R ro SC ef pe ’ er rti en es ce O nl Digital Function Description Please refer to Chapter 1.11 for detailed description OTP: One Time Programmable 16k bytes is used for 8k line programming instructions FS98O25 has 384 bytes Data Memory embedded in it. (128 bytes registers, 256 bytes general data memory) There are two clock sources in FS98O25. One is the internal clock which generates 1M HZ for CPU works, and the other is an external one which provide 32768 HZ clock signal to the chip. Clock Counter for Time out interrupt and Watch dog Timer Embedded 4 X 32 LCD driver Embedded Serial Port for Communication, It support I2C protocol which is designed by Philips Similar to PWM function User should connect a Buzzer to the embedded buzzer port to receive the warning or reminding signal. FS98O25 embeds Dual 16-bit Programmable Counter which could be used to do three kinds of processes: Counter, Pulse Width Measurement and Frequency Measurement. FS98O25 support 2 External Interrupt port An embedded Sigma-Delta Analog to Digital Converter which converts the analog signal of the sensor to a digital number. FS98O25 has an embedded low noise OP amplifier for pre-processing the signal, which is connected to the ADC to get a better A/D resolution or amplify the signal to fit the ADC Input range. FS98O25 has a special power system. The power system can supply a fixed voltage for CPU and ADC. The input voltage of the chip can be within a certain range and floating. The PT1 port has 8 bits. User can define these 8 bits for general purpose or special assignment as ADC input. The PT2 port has 8 bits. User can define these 8 bits for general purpose or some special function as External Interrupt, I2C, PDM and the Buzzer. y Item CPU Kernel PDM Buzzer Programmable Counter Analog Function Ext. INT ADC OP Amplifier Power Function Power Module General Purpose I/O PT1 Fo PT2 Rev. 1.5 15/142 FS98O25 F P r R ro SC ef pe ’ er rti en es ce O nl y CPU Core Figure 1-3 FS98O25 CPU core function block Fo The “CPU Core Block Diagram” shown in Section 1.11 mainly includes 7 important registers and 2 memory units. Please see the Figure 1-3 and the Table 1-4 for detailed information. Rev. 1.5 16/142 FS98O25 Table 1-4 FS98O25 CPU core block diagram description table Sub Items Program Counter Description This Register plays an important role in all the CPU working cycle. It records the pointer of the instruction that the CPU processes every cycle in the Program Memory. In a general CPU cycle, Program Counter pushes the Program Memory Address (13bits), instruction pointer, into the Program Memory and then increments for the next cycle. Stack Register Stack Register is used for recording the program return instruction pointer. When the program calls function, Program Counter will push the instruction pointer into the Stack Register. After finish this function, Stack Register pushes the instruction pointer back to the Program Counter to resume the original program process. F P r R ro SC ef pe ’ er rti en es ce O nl y Items Registers Instruction Register After Program Counter pushes the instruction pointer (Program Memory Address) into the Program Memory, Program Memory pushes the Program Memory Data (16bits), instruction, into Instruction Register for reference. FS98O25 instruction has 16 bits, and contains 3 kinds of information as Direct Address, Direct Data and Control Information. CPU could push the Direct Data into Work Register or do some process for the register stored in the Data Memory pointed by the Direct Address by Control Information.    Instruction Decoder Instruction Register pushes the Control Information to the Instruction Decoder to decode and then sends the decoded information to related registers. File Select Register In FS98O25 Instruction Sets, FSR (File Select Register) is used for indirect data process. User could fill the FSR with the Data Memory Address of some register, and then process this register by IND Register. CPU will fill the IND Register with the data address in the Data Memory as FSR. Work Register Work Register is used for buffering the data which is stored in some memory address of Data Memory. While CPU processes some register data by ALU, the following status may change as follows: PD, TO, DC, C and Z. Please refer to Section 3.3.2 for detailed introduction. Status Register Program Memory Fo Memory Data Memory Rev. 1.5 Direct Address (8bits) It is the Data Memory Address. CPU can use this address to process the Data Memory. Direct Data (8bits) It is the value which CPU used for processing Work Register by the ALU (arithmetic and logic unit). Control Information It records the information for the ALU to process. FS98O25 has an embedded 16k bytes OTP (One Time Programmable) ROM as Program Memory. Because the OPCODE of the instruction is 16 bits, user could program 8k instructions in FS98O25 at most. Program Memory Address Bus is 13 bits, and the Data Bus is 16bits. FS98O25 has an embedded 384 bytes Data Memory. The Data Memory Address Bus is 9 bits, and Data Bus is 8 bits. 17/142 FS98O25 Clocking Scheme/Instruction Cycle F P r R ro SC ef pe ’ er rti en es ce O nl y One Instruction cycle (CPU cycle) includes 4 steps and the CPU could process 2 steps per CPU Clock. Users can setup the MCK Register to decide the step timing. Please refer to Chapter 5 for related information. For Example, if the MCK Register is filled with 0x04H (MCK = ICK, Instruction Cycle = MCK / 2, ICK = 1MHZ), the step timing is 500k HZ, and one instruction cycle needs 4us (2 x 1/500k sec) to complete. The 4 steps are described as follows. Please refer to the CPU core (Section 1.11) to understand these 4 steps. 1. Fetch Program Counter pushes the Instruction Pointer into Program Memory, and the pointed Data in the Program Memory is stored in the Instruction Register. 2. Decode The Instruction Register pushes the Direct Address to Address MUX, or pushes the Direct Data to Data MUX, and pushes the Control Information into Instruction Decoder to decode the OPCODE. 3. Execute ALU executes the process based on the decoded Control Information. 4. Write Back Push the ALU result to Work Register or Assigned Data Memory Address. Because one OPCODE can only have either Direct Address or Direct Data, sometimes user needs 2 instructions to complete one simple job. For example, if user want to fill Data Memory address 0x55h with data 0xFF, user needs to process 【movlw 0xFFH】 to filled Work Register with 0xFFH, and then process 【movwf 0x55H】to fill Data Memory 0x55H with Work Register content. For the same reason, CPU needs 2 instruction cycles to complete some kinds of instructions such as call, goto…etc. Please see the Figure 1-4. Fo Figure 1-4 FS98O25 instruction cycle Rev. 1.5 18/142 FS98O25 2. Electrical Characteristics Absolute Maximum Ratings Table 2-1 FS98O25 absolute maximum rating table Unit V V C C y Parameter Rating Supply Voltage to Ground Potential for any port -0.3 to 5.5 Applied Input/Output Voltage -0.3 to VDD+0.3 Ambient Operating Temperature 0* to +70 Storage Temperature -55 to +150 Soldering Temperature, Time 260C, 10 Sec * FS98O25 passed 0C LTOL (Low Temperature Operating Life) test (VDD=3V) F P r R ro SC ef pe ’ er rti en es ce O nl DC Characteristics (VDD=3V, TA=25℃, unless otherwise noted) Table 2-2 FS98O25 DC characteristics Symbol VDD IDD1 IDD2 IPO VIH VIL VIHSH VIHSL IPU IOH IOL VDDA IREG VCVDDA AGND VREF TCREF VLBAT Supply Current 1 Supply Current 2 Sleep Mode Supply Current Digital Input High Voltage Digital Input Low Voltage Input Hys. High Voltage Input Hys. Low Voltage Pull up Current High Level Output Current Low Level Output Current Analog Power VDDA Regulator Output Current VDDA Voltage Coefficient Analog Ground Voltage Build in Reference Voltage Build in Reference Voltage Temperature Coefficient Low Battery Detection Voltage VS Switch Resistor Internal RC oscillator Internal WDT Clock Test Conditions MCK=1MHz, CPUCLK=MCK/2, Charge Pump, ADC,OPAMP ON Internal Oscillator Off, MCK=32768Hz LCD ON. Sleep Instruction PT1, Reset PT1, Reset Schmitt-trigger port Schmitt-trigger port Vin=0 VOH=VDD-0.3 V VOL=0.3 V VDD=3V Internal Voltage Double VDDA=0.95*VDDA(unload) Min. 2.2 Typ. Max. 3.6 4 8 0.7 mA 15 3 0.45 0.20 20 7 5 3.6 0.3 6 -2 To AGND VDDA/2 1.18 Ta=0~50℃ 100 S_LB [1:0]=00 S_LB [1:0]=01 2.3 3.5 10 1.0 2.1 0.7 Unit V μA μA VDD VDD VDD VDD μA mA mA V mA 2 %/V V V ppm/ ℃ V 1.3 Ω MHz kHz Fo VSR FRC FWDT Parameter Recommended Operation Power Voltage Rev. 1.5 19/142 FS98O25 ADC Characteristics (VDD=3V, TA=25℃, unless otherwise noted) Table 2-3 FS98O25 ADC characteristics Symbol Parameter VACIN ADC Common Mode Input Range VADIN ADC Differential Mode Input Range Resolution ADC Linearity Error ADC Input Offset Voltage With Zero Cancellation Test Conditions INH,INL,VRH,VRL to VSS (INH,INL), (VRH,VRL) Min. 0.6 Typ. 0 VRFIN=0.44V VRFIN=0.44V VAIN=0 -0.1 15625 0 Max. 2.3 0.6 312501 +0.1 0 Unit V V Counts mV V Table 2-4 FS98O25 OPAMP characteristics Parameter Input Offset Input Offset Voltage with Chopper Input Reference Noise Input Reference Noise with Chopper Input Bias Current Input Bias Current with Chopper Input Common Mode Range Output Voltage Range Chopper Clock Frequency Capacitor Load Test Conditions Min. Typ. 1.5 20 1.0 0.5 10 100 Max. Unit mV F P r R ro SC ef pe ’ er rti en es ce O nl Symbol y OPAMP Characteristics (VDD=3V, TA=25℃, unless otherwise noted) 0.5 0.5 S_CHCK[1:0]=11 1k 50 30 300 2.4 2.4 100 pA pA V V Hz pF Temperature Characteristics(VDD=3V) 4 3.8 3.6 3.4 3.2 3 V RE F Temperature C oeffi ci ent (A V G) V R E F ( V ) VDDA(V) VDDA Temperature Coefficient(AVG) 1.3 1.25 1.2 1.15 1.1 - 5 0- 4 0- 3 0- 2 0- 1 0 0 10 20 30 40 50 60 70 80 90 100 110 120 130 140 150 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 100 110 120 130 140 150 Temperature (Deg) Temperature (D eg) Figure 2-1 VDDA vs Temp @ VDD=3V Figure 2-2 VREF vs Temp @ VDD=3V LVR Temperature Coefficient (AVG) LVR(V) 2.5 2 1.5 1 0 10 Fo -50 -40 -30 -20 -10 20 30 40 50 60 Temperature (Deg) Figure 2-3 LVR vs Temp @ VDD=3V 1 Use ADOH, ADOL and ADOLL (Extra ADC output register) three register (24 bits ADC output) Rev. 1.5 20/142 FS98O25 3. Memory Organization Program Memory Structure F P r R ro SC ef pe ’ er rti en es ce O nl y FS98O25 has an 13bits Program Counter which is capable of addressing a 8k x 16bits program memory space and a 8 level depth 13bits Stack Register. The Start up/Reset Vector is at 0x0000H. When FS98O25 is started or its program is reset, the Program Counter will point to Reset Vector. The Interrupt Vector is at 0x0004H. No matter what ISR is processed, the Program Counter will point to Interrupt Vector. Please see Figure 3-1. Figure 3-1 FS98O25 program memory structure Data Memory Structure FS98O25 has a 384-byte Data Memory. The data memory is partitioned into three parts. The area with address 00h~07h is reserved for system special registers, such as indirect address, indirect address pointer, status register, working register, interrupt flag, interrupt control register. The address 08h~7Fh areas are peripheral special registers, such as I/O ports, timer, ADC, signal conditional network control register, LCD driver. The address 80h~17Fh areas are general data memory. Please see Table 3-1. Table 3-1 FS98O25 Data memory structure End Address Data Memory 0X00H 0X07H System Special Registers 0X08H 0X7FH Peripheral Special Registers 0X80H 0X17FH General Data Memory(256 bytes) Fo Start Address Rev. 1.5 21/142 FS98O25 System Special Registers The System Special Registers are designed to complete CPU Core functions, and consists of indirect address, indirect address pointer, status register, work register, interrupt flag, and interrupt control register. Please see Section 1.11 for related CPU work flow chart. Table 3-2 system register table Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Use contents of FSR0 to address data memory Use contents of FSR1 to address data memory Indirect data memory address pointer 0 Indirect data memory address pointer 1 IRP1 IRP0 PD TO DC C WORK register TMIF I2CIF ADIF E1IF GIE TMIE I2CIE ADIE E1IE CTIF E3IF CTIE E3IE Bit 0 Z E0IF E0IE E2IF E2IE Value on Power on Reset2 uuuuuuuu uuuuuuuu uuuuuuuu uuuuuuuu 00u00uuu uuuuuuuu 00000000 00000000 00000000 00000000 Fo F P r R ro SC ef pe ’ er rti en es ce O nl 00H 01H 02H 03H 04H 05H 06H 07H 16H 17H Referenced Section IND0 027 IND1 3.4.1 FSR0 1.11/3.4.1 FSR1 1.11/3.4.1 STATUS 1.11/3.4.2 WORK 1.11 INTF 3/6/7/9/10/11 INTE 3/6/7/9/10/11 INTF2 6/7 INTE2 6/7 Name y Address 2 u mean unknown or unchanged Rev. 1.5 22/142 FS98O25 3..1 Special Register Contents after External Reset (Power On Reset) and WDT Reset Register Name STATUS WDTCON PT1 PT1EN PT1PU AIENB1 PT2 PT2EN PT2PU PT2MR PT3 PT3EN PT3PU PT3MR PT2OC I2CCON STA I2CADD I2CBUF Register Content External Reset WDT Reset 00u00uuu uuuu1uuu 00000000 uuuuuuuu 00000000 uuuuuuuu 00000000 uuuuuuuu 00000000 uuuuuuuu 00000000 uuuuuuuu 00000000 uuuuuuuu 00000000 uuuuuuuu 00000000 uuuuuuuu 00000000 uuuuuuuu 00000000 uuuuuuuu 00000000 uuuuuuuu 00000000 uuuuuuuu 00000000 uuuuuuuu uuu11uuu uuuuuuuu 0001uuuu uuuuuuuu uu0000u0 uuuuuuuu 00000000 uuuuuuuu 00000000 uuuuuuuu F P r R ro SC ef pe ’ er rti en es ce O nl Register Address 04H 0DH 20H 21H 22H 23H 24H 25H 26H 27H 28H 29H 2AH 2BH 37H 57H 58H 59H 5AH y Table 3-3 special register reset table 3..2 IND and FSR Registers Fo The IND (Indirect Addressing) register is not a physical register, but indirect addressing needs the IND register. Any instruction using the IND register actually accesses the register pointed by the FSR (File Select Register). While user reads data from the IND register, the CPU gets the data from the Data Memory at the address stored in FSR. While user writes the data into IND register, CPU actually saves the data into Data Memory at the address stored in FSR. Please see Figure 3-2. Figure 3-2 IND & FSR function description Rev. 1.5 23/142 FS98O25 3..3 STATUS Register The STATUS register contains the arithmetic status of ALU and the RESET status. The STATUS register is similar to other registers, and can be the destination for any instruction. If the STATUS register is the destination for an instruction that affects the Z, DC or C bit, then the writing to these three bits is disabled. These bits are set or cleared according to the device logic. The TO and PD bits are not writable. Register STATUS at address 04H R/W-0 R/W-0 STATUS IRP1 IRP0 U-X R-0 R-0 R/W-X R/W-X R/W-X PD TO DC C Z Bit0 F P r R ro SC ef pe ’ er rti en es ce O nl Bit7 y property Bit 7 IRP1: Indirect address 1 page select 1 = Indirect address 1 extend memory address is set (Memory 1XXH) 0 = Indirect address 1 extend memory address is Not set (Memory 0XXH) Bit 6 IRP0: Indirect address 0 page select 1 = Indirect address 0 extend memory address is set (Memory 1XXH) 0 = Indirect address 0 extend memory address is Not set (Memory 0XXH) Bit 4 PD: Power down Flag. 1 = By execution of SLEEP instruction 0 = After power-on reset Bit 3 TO: Watch Dog Time Out Flag. Cleared by writing 0 and Set by Watch Dog Time Out 1 = A Watch Dog Timer time-out occurred 0 = After power-on reset Bit 2 DC: Digit Carry Flag/borrow Flag, for ADDWF(C) and SUBWF(C) (for borrow the polarity is reversed) 1 = If there is a carry out from the 4th bit of the result 0 = No carry out from the 4th bit of the result Bit 1 C: Carry Flag/borrow Flag (~Borrow) (for borrow the polarity is reversed) 1 = If there is a carry out from the Most Significant bit of the result 0 = No carry out from the most significant bit of the result Bit 0 Z: Zero Flag 1 = The result of an arithmetic or logic operation is zero Fo 0 = The result of an arithmetic or logic operation is NOT zero Rev. 1.5 24/142 FS98O25 3..4 INTE and INTF registers The INTE and INTF registers are readable and writable registers, and contain enable and flag bits for interrupt devices. Register INTE at address 07H property R/W-0 INTE GIE U-0 U-0 R/W-0 R/W-0 R/W-0 R/W-0 R/W-0 TMIE I2CIE ADIE E1IE E0IE GIE: Global Interrupt Enable flag F P r R ro SC ef pe ’ er rti en es ce O nl Bit 7 Bit0 y Bit7 1 = Enable all unmasked interrupts 0 = Disable all interrupts Bit 4 TMIE: 8-bit Timer Interrupt Enable flag 1 = Enable Timer interrupt 0 = Disable Timer interrupt Bit 3 I2CIE: I2C Interface Interrupt Enable flag 1 = Enable I2C interface interrupt 0 = Disable I2C interface interrupt Bit 2 ADIE: Analog to Digital converter Interrupt Enable flag 1 = Enable analog to digital converter interrupt 0 = Disable analog to digital converter interrupt Bit 1 E1IE: PT2.1 External Interrupt Enable flag 1 = Enable PT2.1 external interrupt 0 = Disable PT2.1 external interrupt Bit 0 E0IE: PT2.0 External Interrupt Enable flag 1 = Enable PT2.0 external interrupt 0 = Disable PT2.0 external interrupt property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 25/142 FS98O25 Register INTF at address 06H property U-0 U-0 U-0 R/W-0 R/W-0 R/W-0 R/W-0 R/W-0 TMIF I2CIF ADIF E1IF E0IF INTF Bit7 Bit 4 Bit0 TMIF: 8-bit Timer Interrupt Flag y 1 = Timer interrupt occurred (must be cleared in software) 0 = No Timer interrupt I2CIF: I2C Interface Interrupt Flag F P r R ro SC ef pe ’ er rti en es ce O nl Bit 3 1 = I2C Interface interrupt occurred (must be cleared in software) 0 = No I2C Interface interrupt Bit 2 ADIF: Analog to digital converter Interrupt Flag 1 = Analog to digital converter Interrupt occurred (must be cleared in software) 0 = No Analog to digital converter Interrupt Bit 1 E1IF: PT2.1 External Interrupt Flag 1 = PT2.1 External Interrupt occurred (must be cleared in software) 0 = No PT2.1 External Interrupt Bit 0 E0IF: PT2.0 External Interrupt Flag 1 = PT2.0 External Interrupt occurred (must be cleared in software) 0 = No PT2.0 External Interrupt property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 26/142 FS98O25 Peripheral Special Registers The Peripheral Special Registers are designed for Peripheral functions, such as I/O ports, timer, ADC, signal conditional network control register, LCD driver. Please see Table 3-4 and the following Chapters for detailed description of these peripheral functions. Table 3-4 peripheral special registers table Name 08H 09H 0AH 0BH 0CH 0DH 0EH 0FH 10H 11H 12H 13H 14H CTAH CTAL CTBH CTBL CTCON 18H 19H 1AH 1BH 1CH 1DH 1FH 20H 21H 22H 23H 24H 25H 26H 27H 28H 29H 2AH 2BH 30H 31H 32H 33H 36H 37H TON WTDTEN PCK 10/11 5 4/5/7.5/10 NETA NETB NETC NETD NETE NETF 10/11 10/11 10/11 10/11 4/10/11 SVD PT1 PT1EN PT1PU AIENB1 PT2 PT2EN PT2PU PT2MR PT3 PT3EN PT3PU PT3MR PMD1H PMD1L PMD2H PMD2L PMCON PT2OC B LCD1 LCD2 LCD3 LCD4 LCD5 LCD6 LCD7 LCD8 LCD9 LCD10 LCD1 4.5 7 7 7 7 7 7 7 7.2/7.5/8 7 7 7 7 8 8 4/10/11 8 TRST Rev. 1.5 Bit 6 Bit 5 Bit 4 Bit 3 CTA[15:8] CTA[7:0] CTB[15:8] CTB[7:0] MUXSEL[2:0] TE Bit 2 Bit 1 Bit 0 FQTMB OVAB WTS [2:0] TMOUT [7:0] TMEN ADO [15:8] ADO [7:0] Extra ADC output register ADRST 9 13 13 13 13 13 13 13 13 13 13 13 INS [2:0] ADM [2:0] M1_C M7_CK M6_CK M5_CK M3_CK M2_CK M0_CK K S_BE ENPUMP S_CH2CK [1:0] S_CH1CK [1:0] S_PCK EP SINL[1:0] SINH[2:0] SFTA[2:0] SOP2N[1:0] SOP1N[1:0] SVRL[1:0] SVRH[1:0] SREFO ADG[1:0] ADEN AZ OP2EN SOP2P[2:0] OP1EN SOP1P[2:0] ENVS SILB[1:0] ENLB ENVDD ENAG ENBAND ENVB A ND LBOUT PT1 [7:0] PT1EN [7:0] PT1PU [7:0] AIENB[7:6] AIENB[5:0] PT2 [7:0] PT2EN [7:0] PT2PU [7:0] BZEN PM2EN PM1EN E1M[1:0] E0M[1:0] PT3 [3:0] PT3EN [3:0] PT3PU [3:0] PFOEN E3M[1:0] E2M[1:0] PMD1[15:8] PMD1[7:0] PDMD2[15:8] PDMD2[7:0] PDMEN PMCS[2:0] Fo 40H 41H 42H 43H 44H 45H 46H 47H 48H 49H 4AH TMOUT TMCON ADOH ADOL ADOLL ADCON MCK 6.3 6.3 6.3 6.3 6.3 6.2 6.1 6.1 10/11 10/11 Bit 7 Value on Power on Reset uuuuuuuu uuuuuuuu uuuuuuuu uuuuuuuu 0000000u 0uuuu000 00000000 1uuu0000 00000000 00000000 00000000 uuuu0000 00000000 F P r R ro SC ef pe ’ er rti en es ce O nl 15H WDTCON Referenced Section y Address PT2OC[4:3] SEG2 [3:0]] SEG4 [3:0] SEG6 [3:0] SEG8 [3:0] SEG10 [3:0] SEG12 [3:0] SEG14 [3:0] SEG16 [3:0] SEG18 [3:0] SEG20 [3:0] SEG22 [3:0]] SEG1 [3:0] SEG3 [3:0] SEG5 [3:0] SEG7 [3:0] SEG9 [3:0] SEG11 [3:0] SEG13 [3:0] SEG15 [3:0] SEG17 [3:0] SEG19 [3:0] SEG21 [3:0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 uuuuuuuu uuuuuuuu 00000000 00000000 00000000 uuuuuuuu 00000000 00000000 00000000 uuuuuuuu 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 uuu11uuu uuuuuuuu uuuuuuuu uuuuuuuu uuuuuuuu uuuuuuuu uuuuuuuu uuuuuuuu uuuuuuuu uuuuuuuu uuuuuuuu uuuuuuuu 27/142 FS98O25 Name 4BH 4CH 4DH 4EH 4FH 54H LCD2 LCD3 LCD4 LCD5 LCD6 LCDEN R I2CCON I2CSTA I2CADD I2CBUF Bit 7 13 13 13 13 13 13 9 9 9 9 Bit 6 Bit 5 Bit 4 Bit 3 SEG24 [3:0] SEG26 [3:0] SEG28 [3:0] SEG30 [3:0] SEG32 [3:0] LCDCKS [1:0] WCOL I2COV LCDEN I2CEN DA Bit 2 Bit 1 SEG23 [3:0] SEG25 [3:0] SEG27 [3:0] SEG29 [3:0] SEG31 [3:0] LEVEL LCD_DUTY[1:0] CKP P S I2CADD [7:0] I2CBUF [7:0] RW Bit 0 ENPMP L BF Value on Power on Reset uuuuuuuu uuuuuuuu uuuuuuuu uuuuuuuu uuuuuuuu 00000000 0001uuuu uu0000u0 00000000 00000000 Fo F P r R ro SC ef pe ’ er rti en es ce O nl 57H 58H 59H 5AH Referenced Section y Address Rev. 1.5 28/142 FS98O25 4. Power System FS98O25 has a special power system that can supply a fixed voltage (3.6V) for CPU and ADC. FS98O25 could work when the supply voltage is within a specified range, fixed or floating. The power system has 6 function engines as Voltage Doubler, Voltage Regulator, Analog Bias Circuit, Common Voltage Generator Low Battery Comparator and Band gap Voltage / Temperature Sensor. Through the first 4 function engines, the system can generate 3 Voltage level as VGG = 2VDDP, VDDA = 3.6V, AGND = 1.8V. Please see Figure 4-1. Voltage Doubler The acceptable VDD range for FS98O25 is from 2.2V to 3.6V. Voltage Doubler raises the voltage of VGG 3 to 2 times of VDDP . VGG is used as the input of Voltage Regulator. It is from 4.4V to 7.2V. Please see Section 4.1 for detailed register setting. 2. Voltage Regulator The fixed voltage is important when the Analog function is working. Voltage Regulator raises the voltage of VDDA to fixed 3.6V. Although the input voltage of Voltage Regulator, VGG, is from 4.4V to 7.2V (It depends on the voltage of VDD), the minimum possible voltage is still higher than 3.6V, so Voltage Regulator could surely supply VDDA as 3.6V. Please refer to Section 4.2 for detailed register setting. 3. Analog Bias Circuit Analog Bias Circuit is used to set VB to 3.6V. VB is used for FS98O25 Analog Function Network. The user needs to enable Analog Bias Circuit, and then the Analog Functions such as ADC or OPAMP can work correctly. Please refer to Section 4.3 for detailed register setting. 4. Common Voltage Generator FS98O25 sets the analog ground to half VDDA. Please refer to Section 4.4 for detailed register setting. F P r R ro SC ef pe ’ er rti en es ce O nl y 1. VGG = 2 VDDP (4.4V~7.2V) VDDA / VB (fixed 3.6V) VDD / VDDP (2.2V~3.6V) AGND = 1/2VDDA (fixed 1.8V) VSS / VSSP (GND) Voltage Doubler Voltage Regulator Analog Bias Circuit Common Voltage Generator Fo Figure 4-1 FS98O25 power system block 3 VDDP means the VDD for Charge Pump (Voltage Doubler). User usually connects the VDDP to VDD. VSSP means the VSS for Charge Pump (Voltage Doubler). User usually connects the VSSP to VSS. Rev. 1.5 29/142 FS98O25 Table 4-1 FS98O25 power system register table Address Name 15H 1CH 1DH 1FH PCK NETE NETF SVD Referenced Bit 7 Bit 6 Bit 5 Bit 4 Section ENPUMP 4/5/7.5/10 4/10/11 ENVS ENBAND ENVDDA 4/10/11 4.5 Bit 3 Bit 2 -SILB[1:0] ENVB LBOUT Value on Power on Reset 00000000 00000000 00000000 uuuuuuuu U-0 R/W-0 -- S_PCK Bit 1 Bit 0 -ENLB S_PCK ENAGND property U-0 U-0 U-0 U-0 ENPUMP U-0 -- F P r R ro SC ef pe ’ er rti en es ce O nl PCK R/W-0 Bit7 Bit 6 y Register PCK at address 15H Bit0 ENPUMP: Voltage Doubler enabled flag 1 = Voltage Doubler is enabled 0 = Voltage Doubler is disabled Bit 0 S_PCK: Voltage Doubler operation frequency selector 1 = Voltage Doubler Operation Frequency = MCK/100 (Please see Chapter 5) 0 = Voltage Doubler Operation Frequency = MCK/200 (Please see Chapter 5) property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 30/142 FS98O25 Register NETE at address 1CH property U-0 U-0 U-0 NETE R/W-0 R/W-0 ENVS R/W-0 SILB[1:0] R/W-0 U-0 ENLB Bit7 ENVS: VDDA Voltage Source enable flag (Please read Section 4.2 for detailed description) 1 = VDDA is connected to VS. VS could be used as a voltage source. 0 = VDDA and VS are disconnected. y Bit 4 Bit0 F P r R ro SC ef pe ’ er rti en es ce O nl Bit 3-2 SILB[1:0]: Low Battery Comparator Input Selector (Please refer to Section 4.5 for detailed description) 11 = No definition. The Low Battery Comparator Input is floating. 10 = Low Battery Comparator Input is selected as external analog input AIN4 01 = Low Battery Comparator Input is selected as 3.65V 00 = Low Battery Comparator Input is selected as 2.45V Bit 1 ENLB: Low Battery Comparator enable flag (Please refer to Section 4.5 for detailed description) 1 = Low Battery Comparator is enabled 0 = Low Battery Comparator is disabled property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 31/142 FS98O25 Register NETF at address 1DH property U-0 NETF R/W-0 R/W-0 ENBAND ENVDDA U-0 U-0 U-0 R/W-0 R/W-0 ENAGND ENVB Bit7 Bit 6 Bit0 ENBAND: Band gap Voltage enable flag (Please refer to Section 4.6 for detailed description) y 1 = The Band gap Voltage and Temperature Sensor are enabled, REFO to AGND is about 1.16V 0 = The Band gap Voltage and Temperature Sensor are disabled ENVDDA: Voltage Regulator enable flag (Please refer to Section 4.5 for detailed description) F P r R ro SC ef pe ’ er rti en es ce O nl Bit 5 1 = Voltage Regulator is enabled, VDDA is 3.6V 0 = Voltage Regulator is disabled. VDDA can be from external power supply. Bit 1 ENAGND: Analog Common Voltage Generator enable flag (Please see Section 4.4 for detailed description) 1 = Analog Common Voltage Generator is enabled. AGND = 1/2 VDDA 0 = Analog Common Voltage Generator is disabled. AGND is floating. Bit 0 ENVB: Analog Bias Circuit enable flag (Please see Section 4.3 for detailed description) 1 = Analog Bias Circuit is enabled. Analog system (ADC and OPAMP) can work correctly. 0 = Analog Bias Circuit is disabled. Analog system can NOT work Register SVD at address 1FH property SVD U-X U-X U-X U-X U-X U-X R-X LBOUT Bit7 Bit 0 U-X Bit0 LBOUT: Low Battery Comparator output (Please refer to Section 4.5 for detailed description) 1 = The Voltage selected by SILB[1:0] is higher than 1.2V. 0 = The Voltage selected by SILB[1:0] is lower than 1.2V property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 32/142 FS98O25 Voltage Doubler F P r R ro SC ef pe ’ er rti en es ce O nl y C1 10uF Figure 4-2 Voltage Doubler 4 Voltage Doubler is used for generating VGG which provide input for VDDA Voltage Regulator. The inputs of Voltage Doubler are VDDP, VSSP, CA and CB. The related registers are S_PCK and ENPUMP. The Output is VGG. Please see Figure 4-2. Table 4-2 Voltage Doubler register table Address Name 14H 15H MCK PCK Referenced Section 5 4/5/7.5/10 Bit 7 M7_CK Bit 6 Bit 5 M6_CK M5_CK ENPUMP Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 M3_CK M2_CK M1_CK M0_CK --S_PCK Value on Power on Reset 00000000 00000000 Operations: 1. 2. 3. Fo 4. 5. Connect the pins VDDP and VSSP to VDD (2.2V~3.6V) and VSS (system ground). Put a 10uF capacitance between CA and CB. 5 Select the Voltage Doubler Operation frequency by setting S_PCK and M0_CK according to the following table Set the ENPUMP flag. The output, VGG, will be 2 times of VDDP. 4 5 Please refer to Section 4.2 for detailed description about VDDA and Voltage regulator. M0_CK is the 1st bit of the MCK register. Please refer to Section 5.0 Rev. 1.5 33/142 FS98O25 Table 4-3 Voltage Doubler operation frequency selection table M0_CK S_PCK Voltage Doubler Operation Frequency 0 0 MCK/200 0 1 MCK/100 1 X ECK/32 y If the user doesn‟t want the VGG to be generated from the Voltage Doubler, then the ENPUMP should be set to disable the voltage Doubler, and input the VGG pin a voltage as voltage regulator power supply. F P r R ro SC ef pe ’ er rti en es ce O nl Voltage Regulator Figure 4-3 Voltage regulator Voltage Regulator is used for generating VDDA (3.6V). The input is VGG which is generated by Voltage Doubler (please see the Section 4.1). The control Register flags are ENVDDA and ENVS. The Outputs are VDDA and VS. Please see Figure 4-3. Table 4-4 voltage regulator register table Referenced Section NETE 4/10/11 NETF 4/10/11 Address Name 1CH 1DH Bit 7 Bit 6 Bit 5 ENBAND ENVDDA Bit 4 ENVS Bit 3 Bit 2 SILB[1:0] Bit 1 ENLB Bit 0 ENAGND ENVB Value on Power on Reset 00000000 00000000 Operations Operate as Section 4.1 to get the VGG (2 times of VDD or external Power Supply). Set the ENVDDA flag. The output, VDDA, is 3.6V. If the user wants VDDA as output voltage source, then the ENVS flag should be set. VS will be the same as VDDA. Fo 1. 2. 3. 4. Rev. 1.5 34/142 FS98O25 F P r R ro SC ef pe ’ er rti en es ce O nl y Analog Bias Circuit Figure 4-4 analog bias circuit Analog Bias Circuit is used to activate VB (reference VDDA) as the power supply voltage for analog circuit (include ADC, OPAMP, Low Battery Comparator) and LCD driver. The Control register flag is ENVB. Please see Figure 4-4. Table 4-5 analog bias circuit register table Address 1DH Name NETF Referenced Section 4/10/11 Bit 7 Bit 6 Bit 5 ENBAND ENVDDA Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 ENAGND ENVB Value on Power on Reset 00000000 Operation: 1. 2. 3. Fo 4. Operate as Section 4.1 to get the VGG (2 times of VDD or external Power Supply). Operate as Section 4.2 to get the VDDA (3.6V). Set the ENVB flag. The VB will be 3.6V (same as VDDA) and the analog function network and the LCD driver can be activate correctly. Note that Pin VB must be connected with a 10nF capacitor to VSS for reducing Voltage Doubler noise. Rev. 1.5 35/142 FS98O25 F P r R ro SC ef pe ’ er rti en es ce O nl y Analog Common Voltage Generator Figure 4-5 analog common voltage generator 6 Analog Common Voltage Generator is used to provide a voltage at the halt of AGND as 1/2 VDDA . The Control register is ENAGND and the output is AGND. Please see Figure 4-5. Table 4-6 analog common voltage generator register table Reference Bit 7 Bit 6 Bit 5 Bit 4 d Section ENBAND ENVDDA NETF 4/10/11 Address Name 1DH Bit 3 Bit 2 Bit 1 Bit 0 ENAGND ENVB Value on Power on Reset 00000000 Operation: Operate following the steps Chapter 4.1 to get the VGG (2 times VDD or external Power Supply). Operate as Section 4.2 to get the VDDA (3.6V) Operate as Section 4.3 to activate the Analog Bias Circuit Set the ENAGND register flag. The output, AGND, will be 1/2 VDDA Fo 1. 2. 3. 4. 5. 6 When VDDA is 3.6V, AGND would be 1.8V Rev. 1.5 36/142 FS98O25 Low Battery Comparator y Figure 4-6 low battery comparator function block F P r R ro SC ef pe ’ er rti en es ce O nl Low Battery Comparator is used for VDD low voltage detection. FS98O25 embeds a voltage divider which can generate 1/2 VDD and the 1/3 VDD. A multiplexer is used to connect the voltage divides to component input. The multiplexer‟s output is compares with 1.2V. The Control register flags are SILB[1:0] and the ENLB. The Output flag is LBOUT which is for read only. Please see Figure 4-6. Table 4-7 low battery comparator register table Referenced Section NETE 4/10/11 SVD 4.5 Address Name 1CH 1FH Bit 7 Bit 6 Bit 5 Bit 4 ENVS Bit 3 Bit 2 SILB[1:0] Bit 1 ENLB Bit 0 Value on Power on Reset LBOUT 00000000 uuuuuuuu Operation: 1. 2. 3. 4. Operate as Section 4.1 to get the VGG (2 times VDD or external Power Supply). Operate as Section 4.2 to get the VDDA (3.6V) Operate as Section 4.3 to active the Analog Bias Circuit Set SILB to choose the Comparator input. Please see Table 4-8 Table 4-8 low battery comparator voltage detection selection table Detection Voltage if LBOUT = 1 00 1/2 VDD VDD > 2.3 volt 01 1/3 VDD VDD > 3.5 volt 10 AIN4 AIN > 1.2 volt Set the ENLB register flag, and the Low Battery Comparator is enabled. The output, LBOUT, is the result of the comparator. Fo 5. 6. SILB [1:0] Rev. 1.5 37/142 FS98O25 Bandgap Voltage and Temperature Sensor REFO TEMPH Bandgap Voltage Reference and Temperature Sensor F P r R ro SC ef pe ’ er rti en es ce O nl y To Function Network TEMPL ENBAND Figure 4-7 Bandgap voltage and temperature sensor function block REFO is low temperature coefficient bandgap voltage reference output. Its voltage to AGND is 1.16V, and the typical temperature coefficient is 150ppm/C. FS98O25 embeds a Temperature Sensor to measure the IC temperature from the differential voltage between TEMPH and TEMPL (typically 550μV50μV/C). Its working range is 100 ~ 200 mV. User can connect the TEMPH and TEMPL to an ADC to get the IC temperature. Please refer to Chapter 10 and Chapter 11 for detailed instruction of ADC. Both the bandgap Voltage Reference and the Temperature sensor are controlled by ENBAND register flag. Please see Figure 4-7. Table 4-9 bandgap voltage and temperature sensor register table Referenced Section NETF 4/10/11 Address Name 1DH Bit 7 Bit 6 Bit 5 ENBAND ENVDDA Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 ENAGND ENVB Value on Power on Reset 00000000 Operation: Operate as Section 4.1 to get the VGG (2 times VDD or external Power Supply). Operate as Section 4.2 to get the VDDA (3.6V) Operate as Section 4.3 to enable the Analog Bias Circuit Set the ENBAND register flag. Check REFO. Its value with respect to AGND should be about 1.16V The output, TEMPH and TEMPL, will show the IC temperature as the differential voltage. Fo 1. 2. 3. 4. 5. 6. Rev. 1.5 38/142 FS98O25 5. Clock System Table 5-1 FS98O25 clock system register table Name Referenced Section 14H 15H MCK PCK 5 4/5/7.5/10 Bit 7 Bit 6 Bit 5 M7_CK M6_CK M5_CK ENPUMP Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 M3_CK M2_CK M1_CK M0_CK S_CH1CK [1:0] S_BEEP S_PCK Value on Power on Reset 00000000 00000000 F P r R ro SC ef pe ’ er rti en es ce O nl y Address Figure 5-1 FS98O25 clock system function block Fo The clock system provides clock signals for the following 7 function blocks: Voltage Doubler, ADC, CPU core, OPAMP, Buzzer, Timer module and LCD. Users could use 10 register flags to generate all kinds of clock signals for the above 7 function blocks. These 10 register flags are M0_CK, M1_CK, M2_CK, M3_CK, M5_CK, M6_CK, M7_CK, S_PCK, S_CH1CK[1:0] and S_BEEP. The detailed setup will be illustrated in following sections. Please see Figure 5-1. Rev. 1.5 39/142 FS98O25 F P r R ro SC ef pe ’ er rti en es ce O nl y Oscillator State Figure 5-2 FS98O25 oscillator state block Table 5-2 FS98O25 clock system register table Referenced Bit 7 Bit 6 Bit 5 Section MCK 5 M7_CK M6_CK M5_CK Address Name 14H Bit 4 Value on Power on Reset M3_CK M2_CK M1_CK M0_CK 00000000 Bit 3 Bit 2 Bit 1 Bit 0 There are two clock sources in FS98O25. One is the internal clock which generates 1 MHZ for CPU, and the other is an external one which provides 32768 HZ clock signal to the Chip. Users should choose one clock to use as MCK. Please see Figure 5-2. There are 2 clock signals working in FS98O25: MCK and CLK. Users should use Table 5-2 and 5-3 to setup MCK and CLK based on the M0_CK, M1_CK and M3_CK. Table 5-3 MCK selection table M3_CK M0_CK MCK X 0 ICK 0 1 ECK 1 1 ECK/2 Fo Table 5-4 CLK selection table M1_CK CLK 0 MCK 1 MCK/4 To enable the internal and external oscillators, users need to set the right values for M7_CK and M6_CK as shown in Table 5-4. If users execute the sleep instruction to make FS98O25 enter the SLEEP mode, both the internal oscillators and the external oscillator will be disabled. Rev. 1.5 40/142 FS98O25 Table 5-5 oscillator state selection table Input Oscillator State Sleep instruction M7_CK M6_CK Internal External 1 X X Disable Disable 0 0 0 Enable Enable 0 0 1 Enable Disable 0 1 0 Disable Enable 0 1 1 Enable Disable F P r R ro SC ef pe ’ er rti en es ce O nl y 7 CPU Instruction Cycle Table 5-6 FS98O25 CPU instruction cycle register table Referenced Bit 7 Bit 6 Bit 5 Section MCK 5 M7_CK M6_CK M5_CK Address Name 14H Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 M3_CK M2_CK M1_CK M0_CK Value on Power on Reset 00000000 8 User can setup M0_CK, M1_CK, M2_CK and M3_CK to select the instruction cycle . In order to maintain a stable ADC output, user could clear M2_CK to make CPU have a different operation clock cycle from ADC. In the applications where a resolution of ADC is more than 13 bits, M2_CK should be set to zero. Table 5-7 MCK selection table M3_CK M0_CK MCK X 0 ICK (1MHZ) 0 1 ECK (32768 HZ) 1 1 ECK/2 (16384HZ) Table 5-8 instruction cycle selection table M1_CK Instruction Cycle 0 0 MCK/6.5 0 1 MCK/12.5 1 0 MCK/2 1 1 MCK/4 Fo 7 M2_CK X means “don‟t care” Users must make sure that switching from one oscillator to the other can be made only after the oscillator ‟s output is stabilized. An NOP command should be added after the switching. 8 Rev. 1.5 41/142 FS98O25 ADC Sample Frequency FS98O25 embeds one sigma delta ADC which needs clock input to generate digital output. When users want N ADC have N bits resolution digital output, ADC needs 2 clocks cycles input. (Please refer to Chapter 10 and Chapter 11 for detailed description) User should setup the M1_CK to decide the ADC sample frequency. Please see Table 5-9. Table 5-9 ADC sample frequency selection table ADC sample Frequency (ADCF) 0 MCK/25 1 MCK/50 F P r R ro SC ef pe ’ er rti en es ce O nl y M1_CK Beeper Clock Table 5-10 beeper clock register table Address Name 14H 15H MCK PCK Referenced Section 5 4/5/7.5/10 Bit 7 M7_CK Bit 6 Bit 5 M6_CK M5_CK Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 M3_CK M2_CK M1_CK M0_CK S_CH1CK [1:0] S_BEEP S_PCK ENPUMP Value on Power on Reset 00000000 00000000 FS98O25 has a Beeper Clock which is used as the buzzer source. (Please refer to Section 7.5 for how to use Buzzer) User could change the Beeper clock frequency by setting M0_CK, M1_CK, M3_CK and S_BEEP register flags according to Table 5-11, Table 5-12 and Table 5-13. Table 5-11 MCK selection table M3_CK M0_CK MCK X 0 ICK 0 1 ECK 1 1 ECK/2 Table 5-12 CLK selection table M1_CK CLK 0 MCK 1 MCK/4 Table 5-13 beeper clock selection table S_BEEP Beeper Clock X 0 CLK/250 0 1 CLK/375 1 1 ECK/8 Fo M0_CK Rev. 1.5 42/142 FS98O25 Table 5-14 shows the relation between clock signals and the register flags. Please see Table 5-14) Table 5-14 register and the beeper clock selection table M1_CK M3_CK S_BEEP MCK CLK beep clock 1 1 1 1 0 0 0 0 0 0 0 0 1 1 1 1 0 0 1 1 0 0 0 0 1 1 1 1 0 0 1 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 1 1 1 1 0 0 1 1 0 0 1 1 0 0 0 0 32768 16384 32768 16384 1000000 1000000 1000000 1000000 1000000 1000000 1000000 1000000 32768 16384 32768 16384 32768 16384 8192 4096 1000000 1000000 1000000 1000000 250000 250000 250000 250000 32768 16384 8192 4096 4096 4096 4096 4096 4000 4000 2666.6667 2666.6667 1000 1000 666.6667 666.6667 131.072 65.536 32.768 16.384 F P r R ro SC ef pe ’ er rti en es ce O nl y M0_CK Voltage Doubler Operation Frequency FS98O25 embeds a switching voltage regulator. Users can use M0_CK and S_PCK register flags to decide the operation frequency as in Table 5-15 and Table 5-16. Table 5-15 MCK selection table M3_CK M0_CK MCK X 0 ICK 0 1 ECK 1 1 ECK/2 Table 5-16 Voltage Doubler operation frequency selection table M0_CK S_PCK Voltage Doubler Operation Frequency 0 0 MCK/200 0 1 MCK/100 1 X ECK/32 (1024 HZ) Fo Chopper Operation Amplifier Input Control Signal The OPAMP embedded in FS98O25 has a chopper function to cancel the inverting and non-inverting sides voltage bias offsets. After the Chopper operation, OPAMP input voltage bias is removed. Users could setup the S_CH1CK[1:0] to choose the Chopper Control Signal. (Please see Table 5-17, Table 5-18 and Table 5-19) Rev. 1.5 43/142 FS98O25 Table 5-17 CLK selection table M1_CK CLK 0 MCK 1 MCK/4 M0_CK MCK X 0 ICK 0 1 ECK 1 1 ECK/2 F P r R ro SC ef pe ’ er rti en es ce O nl M3_CK y Table 5-18 MCK selection table Table 5-19 chopper control signal selection table S_CH1CK [1] S_CH1CK [0] Chopper Control Signal 0 0 0 0 1 1 1 0 CLK/500 1 1 CLK/1000 TMCLK -- Timer and LCD Module Input Clock TMCLK is the clock for FS98O25 Timer and LCD Module. Users can use Table 5-20 to choose TMCLK frequency by setting the right values for M5_CK. Table 5-20 TMCLK selection table TMCLK (Timer and LCD Module input Clock) 0 CLK/1000 1 ECK/32 Fo M5_CK Rev. 1.5 44/142 FS98O25 6. Timer Module, Watch Dog Timer and Programmable Counter Table 6-1 Timer module and watch dog timer register table Value on Power on Reset 00u00uuu 00000000 00000000 uuuuuuuu uuuuuuuu uuuuuuuu uuuuuuuu 0000000u 0uuuu000 00000000 1uuu0000 F P r R ro SC ef pe ’ er rti en es ce O nl 04H 06H 07H 08H 09H 0AH 0BH 0CH 0DH 0EH 0FH Referenced Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Section STATUS 1.11/3.4.2 -TO ---INTF 3/6/7/9/10/11 TMIF ----INTE 3/6/7/9/10/11 GIE TMIE ----CTAH 6.3 CTA[15:8] CTAL 6.3 CTA[7:0] CTBH 6.3 CTB[15:8] CTBL 6.3 CTB[7:0] CTCON 6.3 TON MUXSEL[2:0] TE FQTMB OVAB WDTCO 6.2 WDTEN WTS [2:0] N TMOUT 6.1 TMOUT [7:0] TMCON 6.1 TRST TMEN INS [2:0] Name y Address The Registers are described as follows. Register CTAH at address 08H property CTAH R -X R-X R-X R-X R-X R-X R-X R-X CTA[15:8] Bit7 Bit0 Register CTAL at address 09H property CTAL R-X R-X R-X R-X R-X R-X property R-X CTA[7:0] Bit7 Bit 15-0 R-X Bit0 CTA[15:0]: Programmable Counter 16-bit Counter A register (Please refer to Section 6.3 for detail) W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 45/142 FS98O25 Register CTBH at address 0AH property R/W-X R/W-X R/W-X CTBH R/W-X R/W-X R/W-X R/W-X R/W-X CTB[15:8] Bit7 Bit0 Register CTBL at address 0BH R/W-X R/W-X R/W-X R/W-X R/W-X CTB[7:0] Bit7 Bit 15-0 property R/W-X R/W-X y CTBL R/W-X F P r R ro SC ef pe ’ er rti en es ce O nl property Bit0 CTB[15:0]: Programmable Counter 16-bit Counter B register (Please refer to Section 6.3 for detail) W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 46/142 FS98O25 Register CTCON at address 0CH property R/W-0 CTCON TON R/W-0 R/W-0 R/W-0 MUXSEL[2:0] R/W-0 R/W-0 R/W-0 R/W-X TE FQTMB OVAB -- Bit7 TON: 16-bit Counter input signal switch (Please refer to Section 6.2 for detail) 1 = The 16-bit Counter input signal switch is ON. 0 = The 16-bit Counter input signal switch is OFF. MUXSEL[2]: Programmable Counter Counter/Pulse Width measurement mode selector. F P r R ro SC ef pe ’ er rti en es ce O nl Bit 6 y Bit 7 Bit0 1 = Programmable Counter is used as Pulse Width measurement. 0 = Programmable Counter is used as General Counter. Bit 5-4 MUXSEL[1:0]: Counter A clock source select multiplexer 1. 11 = PFI, GPIO 3 port 2. 10 = ECK, External Clock (32768HZ) 01 = Instruction clock, please see Section 5.2 00 = ICK, Internal Clock (1MHZ) Bit 3 TE: PFI signal inverting register 1 = PFI signal is inverted 0 = PFI signal is NOT inverted Bit 2 FQTMB: Programmable Counter Frequency measurement mode enabled register flag. 1 = Programmable Counter is used as Frequency measurement. 0 = Programmable Counter is used as General Counter or Pulse Width measurement. Bit 1 OVAB: Programmable Counter interrupt source selector 1 = Programmable Counter interrupt source is Counter A. 0 = Programmable Counter interrupt source is Counter B. property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 47/142 FS98O25 Register WDTCON at address 0DH property R/W-0 WDTCON U-X U-X U-X U-X R/W-0 WDTEN R/W-0 WTS [2:0] Bit7 Bit 7 R/W-0 Bit0 WDTEN: Watch Dog Timer enable flag (Please refer to Section 6.2 for detail) y 1 = Watch Dog Timer is enabled. 0 = Watch Dog Timer is disabled WTS [2:0]: Watch Dog Timer counter 2 Input Selector (Please refer to Chapter 6.2 for details) F P r R ro SC ef pe ’ er rti en es ce O nl Bit 2-0 111 = Watch Dog Timer Counter 2 Input is WDTA[0] 110 = Watch Dog Timer Counter 2 Input is WDTA[1] 101 = Watch Dog Timer Counter 2 Input is WDTA[2] 100 = Watch Dog Timer Counter 2 Input is WDTA[3] 011 = Watch Dog Timer Counter 2 Input is WDTA[4] 010 = Watch Dog Timer Counter 2 Input is WDTA[5] 001 = Watch Dog Timer Counter 2 Input is WDTA[6] 000 = Watch Dog Timer Counter 2 Input is WDTA[7] property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 48/142 FS98O25 Register TMOUT at address 0EH property R-0 R-0 R-0 R-0 TMOUT R-0 R-0 R-0 TMOUT [7:0] Bit7 Bit0 TMOUT [7:0]: Timer module 8-bit counter output (Please refer to Section 6.1 for detail) y Bit 7-0 F P r R ro SC ef pe ’ er rti en es ce O nl Register TMCON at address 0FH property R/W-1 TMCON TRST U-X U-X U-X R/W-0 R/W-0 TMEN R/W-0 R/W-0 INS [2:0] Bit7 Bit 7 R-0 Bit0 TRST: Timer Module reset flag (Please refer to Section 6.1 for detail) 1 = Timer Module Counter works normally. 0 = Timer Module Counter is reset.(After resetting the Counter, TRST will reset itself) Bit 3 TMEN: Timer Module enable flag (Please refer to Section 6.1 for detail) 1 = Timer Module Counter will active. 0 = Timer Module Counter will be disabled. Bit 2-0 INS [2:0]: Timer Module interrupt Signal Selector (Please refer to Chapter 6.1 for detail) 111 = TMOUT[7] is selected as Timer Module interrupt Signal 110 = TMOUT[6] is selected as Timer Module interrupt Signal 101 = TMOUT[5] is selected as Timer Module interrupt Signal 100 = TMOUT[4] is selected as Timer Module interrupt Signal 011 = TMOUT[3] is selected as Timer Module interrupt Signal 010 = TMOUT[2] is selected as Timer Module interrupt Signal 001 = TMOUT[1] is selected as Timer Module interrupt Signal 000 = TMOUT[0] is selected as Timer Module interrupt Signal property W = Writable bit Fo R = Readable bit - n = Value at Power On Reset „1‟ = Bit is Set U = unimplemented bit „0‟ = Bit is Cleared X = Bit is unknown There are two timers in FS98O25: Timer Module and Watch Dog Timer. Please see the following sections for detail. Rev. 1.5 49/142 FS98O25 Timer Module The Timer module has the following features: 8-bit Timer Counter Internal (1 MHZ) or External (32768HZ) clock selection Time out Interrupt Signal selection TMOUT[7:0] TMEN EN Out 8 to 1 Mux F P r R ro SC ef pe ’ er rti en es ce O nl 8 bits Counter Timer Interrupt Signal y    TMCLK Frequency Divider TMCLK/4 CK Reset TMRST Figure 6-1 FS98O25 timer module function block Fo Please see Figure 6-1. The input of Timer Module is TMCLK. (Please refer to Section 5.7 for the detailed setting) FS98O25 embeds a Frequency Divider in the Timer Module to divide the TMCLK by 4, and treats the divided clock signal as 8-bit counter input clock. When a user sets the Timer Module enable flag, the 8-bit counter will activate, and the TMOUT[7:0] will increase from 0x00H to 0xFFH. User needs to setup INS (Timer Module interrupt Signal Selector) to select the time out interrupt signal. When timer out event happens, the interrupt Flag will set itself and the program counter will jump to 0x04H for ISR (Interrupt Service Routine) Rev. 1.5 50/142 FS98O25 6..1 Timer module interrupt Table 6-2 timer module interrupt register table Address 06H 07H 0EH 0FH Referenced Bit 7 Section INTF 3/6/7/9/10/11 INTE 3/6/7/9/10/11 GIE TMOUT 6.1 TMCON 6.1 TRST Name Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 --- --- --- TMIF -TMIE -TMOUT [7:0] TMEN INS [2:0] Value on Power on Reset 00000000 00000000 00000000 1uuu0000 Operate as Section 5.7 to setup the TMCLK for Timer module input Setup the INS[2:0] to select timer interrupt source. Please see Table 6-3. Set the TMIE and GIE register flags to enable the Timer interrupt. Set the TMEN register flag to enable Timer module 8-bit counter. Clear the TRST register flag to reset the Timer module 8-bit counter When time out event happens, TMIF register flag will reset itself, and the program counter will reset to 0x04H F P r R ro SC ef pe ’ er rti en es ce O nl 1. 2. 3. 4. 5. 6. y Operation: Table 6-3 timer selection table interrupt source Time at TMCLK=1024Hz (ECK/32) 000 TMOUT[0] 1/128 sec. 001 TMOUT[1] 1/64 sec. 010 TMOUT[2] 1/32 sec. 011 TMOUT[3] 1/16 sec. 100 TMOUT[4] 1/8 sec. 101 TMOUT[5] 1/4 sec. 110 TMOUT[6] 1/2 sec. 111 TMOUT[7] 1 sec. Fo INS[2:0] Rev. 1.5 51/142 FS98O25 6..2 Using Timer with External/Internal Clock The user could see the Table 6-4, 6-5, 6-6 and 6-7 to setup related registers to decide the clock source. Table 6-4 external timer setup register table Detail on Bit 7 Bit 6 Bit 5 Chapter MCK 5 M7_CK M6_CK M5_CK Address Name 14H Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 M3_CK M2_CK M1_CK M0_CK Value on Power on Reset 00000000 CLK 0 MCK 1 MCK/4 F P r R ro SC ef pe ’ er rti en es ce O nl M1_CK y Table 6-5 CLK selection table Table 6-6 MCK selection table M3_CK M0_CK MCK X 0 ICK 0 1 ECK 1 1 ECK/2 Table 6-7 TMCLK selection table TMCLK (Timer and LCD Module input Clock) 0 CLK/1000 1 ECK/32 Fo M5_CK Rev. 1.5 52/142 FS98O25 Users can use Table 6-8 to select TMCLK clock source based on M0_CK, M1_CK, M3_CK and M5_CK register flag. M1_CK M3_CK M5_CK MCK CLK TMCLK 0 0 0 1 1000000 1000000 1024 0 0 1 1 1000000 1000000 1024 0 1 0 1 1000000 500000 1024 0 1 1 1 1000000 500000 1024 1 0 0 1 32768 32768 1024 1 1 0 1 32768 16384 1024 1 0 1 1 16384 16384 1024 1 1 1 1 16384 8192 1024 0 0 0 0 1000000 1000000 1000 0 0 1 0 1000000 1000000 1000 0 1 0 0 1000000 500000 500 0 1 1 0 1000000 500000 500 1 0 0 0 32768 32768 32.768 1 1 0 0 32768 16384 16.384 1 0 1 0 16384 16384 16.384 1 1 1 0 16384 8192 8.192 Fo F P r R ro SC ef pe ’ er rti en es ce O nl M0_CK y Table 6-8 registers and timer selection table Rev. 1.5 53/142 FS98O25 Watch Dog Timer WDTEN Watch Dog Timer Oscillator WDTA[7:0] 8 bits Counter1 Multiplex 8 bits Counter2 WDTOUT F P r R ro SC ef pe ’ er rti en es ce O nl CLRWDT y WDTS[2:0] Figure 6-2 watch dog timer function block Please see Figure 6-2. WDT (Watch Dog Timer) is used to prevent the program from being out of control by any uncertain reason. When WDT is active, it will reset the CPU when the WDT timeout. Generally, the program run in FS98O25 needs to reset the WDT before the WDT times out every time to reset the CPU. When some trouble happens, the program will be reset to the general situation by WDT and the program won‟t reset the WDT in that situation. The input of Watch Dog Timer is WDTEN and WDTS[2:0] register flags. The output of Watch Dog Timer is TO register flag. When a user sets the WDTEN, the embedded Watch Dog Timer Oscillator (3 KHZ) will become active, and the generated clock will be pushed into the “8-bit counter 1” as shown in Figure 6-2. The output of the “8-bit counter 1”, WDTA[7:0], is a virtual signal which is sent to one multiplexer. The multiplexer is controlled by the register flags, WDTS[2:0]. The output signal is used as the “8-bit Counter 2” clock input. When “8-bit Counter 2” overflows, it will send WDTOUT to reset the CPU (Program Counter will jump to 0x00H to reset the program) and set TO flag. Users could reset the WDT by the instruction – CLRWDT. Table 6-9 watch dog timer register table Address 04H 0DH Referenced Bit 7 Bit 6 Section STATUS 1.11/3.4.2 WDTCON 6.3 WDTEN Name Bit 5 Bit 4 Bit 3 Bit 2 -- TO -- Bit 1 Bit 0 --WDTS [2:0] Value on Power on Reset 00u00uuu 0uuuu000 Operation: Setup the WDTS[2:0] to decide the WDT timeout frequency. 2. Set WDTEN register flag to enable the WDT. 3. Process the CLRWDT instruction to reset the WDT in the program. Fo 1. Rev. 1.5 54/142 FS98O25 Dual 16-bit Programmable Counter Content ( u mean unknown or unchanged) CTIF CTIE CTA[15:8] CTA[7:0] CTB[15:8] CTB[7:0] MUXSEL[2:0] TE FQTMB OVAB PFOEN - GIE TON Reset State 00000000 00000000 00000000 uuuuuuuu uuuuuuuu uuuuuuuu uuuuuuuu 0000000u 00000000 - F P r R ro SC ef pe ’ er rti en es ce O nl y Address Name 07H INTE 16H INTF2 17H INTE2 08H CTAH 09H CTAL 0AH CTBH 0BH CTBL 0CH CTCON 2BH PT3MR Data Bus Internal RC Oscillator Instruction clock External RTC Oscillator MAXSEL[1:0 ] ICK (00) Q1 (01) MUXSEL[2]=0 CTA_CLK ECK (10) PFII (11) 16 bit counter A (CTA) Overflow INT MUXSEL[2]=1 Pulse Width Measurement Control D OVAB=0 TON OVAB=1 PT3/PFI TE CTB_CLK FQTMB 16 bit counter B (CTB) Q PT3/PFO __ Q Reset PFOEN Overflow Figure 6-3 Programmable Counter Working block diagram FS98O25 embeds Dual 16-bit Programmable Counter. It could be used under three working modes: Counter mode, Pulse Width Measurement mode and Frequency Measurement mode. Users could setup MUXSEL[2] and FQTMB register flags to decide the working mode. Table 6-10 Programmable Counter working mode selection table MUXSEL[2] 0 1 0 1 FQTMB 0 0 1 1 Fo Working mode Counter mode Pulse Width Measurement mode Frequency Measurement mode NONE Rev. 1.5 55/142 FS98O25  Counter mode: There are two 16-bit counters (CTA and CTB) in Programmable Counter unit. Operation: 1. 2. Clear FQTMB and MUXSEL[2] register flags to make the Programmable Counter work as Counter. Setup MUXSEL[1:0] to decide the input clock signal. Table 6-11 Programmable Counter Clock signal selection table 3. 4. 5. 6. 7. 8. 9. y Clock signal PFI ECK Instruction Cycle ICK F P r R ro SC ef pe ’ er rti en es ce O nl MUXSEL[1:0] 11 10 01 00 If PFI is assigned to be the Clock signal, users could set TE to invert the PFI voltage level. Clear OVAB register flag to set the CTA as the working counter. When CTA counter overflows, the interrupt (CTIE) will be triggered. Clear CTIF and set the CTIE and GIE register flag to enable the Programmable Counter interrupt. Setup CTB[15:0]. CTA[15:0] will be filled with the same value as CTB[15:0]. When CTA[15:0] overflows, it will be filled with the same value again. User could decide CTA timeout by setting up CTB[15:0] register. Set TON to start the counter. When CTA counter overflows, the interrupt will be triggered. Users could clear TON register flag to stop the counting process. CLK TON Software Set Software Clear CTA_CLK CTA XXXX FFF9 CTB XXXX FFF9 FFFA FFFB FFFC FFFD FFFE FFFF FFF9 FFFA X FFFC FFFD FFFE FFFF FFFA FFFB FFFC FFFD FFFE FFFF FFFA FFFB FFFC FFFA Software Write into CTB (CTA same as CTB) INT FFFB Software Write into CTB 1 0 1 CTIF When CTIE=1 Software Clear Software no Clear Fo Figure 6-4 Programmable Counter/TimerCounter Mode Counter mode Rev. 1.5 56/142 FS98O25  Pulse Width Measurement mode: Programmable Counter could be used to measure the time when a signal holds its voltage level in high or low. Operation: 4. 5. 6. 7. 8. 9. y 2. 3. Clear FQTMB and clear MUXSEL[2] register flags to make the Programmable Counter work as Pulse Width Measurement. Setup MUXSEL[1:0] to decide the input clock signal. PFI is the signal which is ready to measure the pulse width. Users could set TE to invert the PFI voltage level. Clear OVAB register flag to set the CTA as the working counter. When CTA counter overflows, the interrupt (CTIE) will be triggered. Clear CTIF and set the CTIE and GIE register flag to enable the Programmable Counter interrupt. Setup CTB[15:0]. CTA[15:0] will be filled with the same value as CTB[15:0]. When CTA[15:0] overflows, it will be filled with the same value again. User could decide CTA timeout by setting up CTB[15:0] register. Set TON to start the Pulse Width Measurement. When PFI signal is from high to low, CTA counter will stop counting and clear TON register flag. Interrupt will be triggered at the same time. Users could read the CTA counter value to know the pulse width of PFI. If CTA counter overflows, and the PFI signal is still high, the interrupt will be triggered, but CTA will count again. CLK TON F P r R ro SC ef pe ’ er rti en es ce O nl 1. Software Set PFII CTA_CLK CTA XXXX 0000 0001 0002 0003 0004 0005 0006 0007 0008 0009 Software Write into CTB (CTA same as CTB) INT CTIF X 1 When CTIE=1 Fo Figure 6-5 Programmable Counter Pulse Width Measurement mode Pulse Width Measurement Mode Rev. 1.5 57/142 FS98O25  Frequency Measurement mode: Programmable Counter could be used to measure a signal frequency. Operation: 4. 5. 6. 7. 8. 9. y 2. 3. Set FQTMB and clear MUXSEL[2] register flags to make the Programmable Counter work as Frequency Measurement. Setup MUXSEL[1:0] to decide the input clock signal. PFI is the signal which is ready to measure the frequency. Users could set TE to invert the PFI voltage level. Clear OVAB register flag to set the CTA as the working counter. When CTA counter overflows, the interrupt (CTIE) will be triggered. Clear CTIF and set the CTIE and GIE register flags to enable the Programmable Counter interrupt. Setup CTB[15:0]. CTA[15:0] will be filled with the same value as CTB[15:0]. When CTA[15:0] overflows, it will be filled with the same value again. User could decide CTA timeout by setting up CTB[15:0] register. Set TON to start the Frequency Measurement. When CTA counter overflows, the interrupt will be triggered. TON register flag will be clear automatically. Users could read the CTB value to know the PFI signal frequency. F P r R ro SC ef pe ’ er rti en es ce O nl 1. CLK PFII TON Software Set CTA_CLK CTB_CLK FQTMB CTA XXXX FFEA CTB XXXX FFEA FFEB FFEC FFED FFEE FFEB FFEF FFEC FFF0 FFF1 FFF2 FFED FFF3 FFF4 FFEE FFF5 FFF6 FFF7 FFEF FFF8 FFF9 FFF0 FFFA FFFB FFFC FFFD FFF1 FFFE FFFF 0000 FFF2 Software Write into CTB (CTA same as CTB) INT X 1 CTIF When CTIE=1 Fo Frequency Measurement ModeMeasurement mode Figure 6-6 Programmable Counter Frequency Rev. 1.5 58/142 FS98O25 7. I/O Port Table 7-1 FS98O25 I/O port register table 06H 07H 16H 17H 20H 21H 22H 23H 24H 25H 26H 27H 28H 29H 2AH 2BH 37H INTF INTE INTF2 INTE2 PT1 PT1EN PT1PU AIENB1 PT2 PT2EN PT2PU PT2MR PT3 PT3EN PT3PU PT3MR PT2OCB Detail on Bit 7 Bit 6 Chapter 3/6/7/9/10/11 3/6/7/9/10/11 GIE 6/7 6/7 7 7 7 7 AIENB[7:6] 7 7 7 7.2/7.5/8 BZEN Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 --- I2CIF I2CIE --- E1IF E1IE E3IF E3IE E0IF E0IE E2IF E2IE PT1 [7:0] PT1EN [7:0] PT1PU [7:0] AIENB[5:0] PT2 [7:0] PT2EN [7:0] PT2PU [7:0] PM1EN E1M[1:0] E0M[1:0] PT3 [3:0] PT3 [3:0] PT3 [3:0] PFOEN E3M[1:0] E2M[1:0] PT2OC[4:3] Value on Power on Reset 00000000 00000000 00000000 00000000 uuuuuuuu 00000000 00000000 00000000 uuuuuuuu 00000000 00000000 00000000 uuuuuuuu 00000000 00000000 00000000 uuu11uuu y Name F P r R ro SC ef pe ’ er rti en es ce O nl Address 9 Fo The GPIO (General Purpose Input Output) in a micro-controller is used for general purpose input or output function. Users could use these ports to get digital signal or transmit data to any other digital device. Some GPIOs in FS98O25 are also defined for other special functions. In this Chapter, the GPIO will be illustrated as the GPIO function. The special functions defined in the GPIO will be illustrated in the following Chapters. Rev. 1.5 59/142 FS98O25 Register PT1 at address 20H property R/W-X R/W-X R/W-X PT1 R/W-X R/W-X R/W-X R/W-X R/W-X PT1 [7:0] Bit7 Bit 7-0 Bit0 PT1[7:0]: GPIO Port 1 data flag (Please refer to Section 7.1 for detail) y PT1[7] = GPIO Port 1 bit 7 data flag PT1[6] = GPIO Port 1 bit 6 data flag F P r R ro SC ef pe ’ er rti en es ce O nl PT1[5] = GPIO Port 1 bit 5 data flag PT1[4] = GPIO Port 1 bit 4 data flag PT1[3] = GPIO Port 1 bit 3 data flag PT1[2] = GPIO Port 1 bit 2 data flag PT1[1] = GPIO Port 1 bit 1 data flag PT1[0] = GPIO Port 1 bit 0 data flag Register PT1EN at address 21H property R/W-0 R/W-0 R/W-0 PT1EN R/W-0 R/W-0 R/W-0 R/W-0 R/W-0 PT1EN [7:0] Bit7 Bit 7-0 Bit0 PT1EN [7:0]: GPIO Port 1 Input / Output control flag (Please refer to Section 7.1 for detail) PT1EN[7] = GPIO Port 1 bit 7 I/O control flag ; 0 = defined as input port, 1 = defined as output port PT1EN[6] = GPIO Port 1 bit 6 I/O control flag ; 0 = defined as input port, 1 = defined as output port PT1EN[5] = GPIO Port 1 bit 5 I/O control flag ; 0 = defined as input port, 1 = defined as output port PT1EN[4] = GPIO Port 1 bit 4 I/O control flag ; 0 = defined as input port, 1 = defined as output port PT1EN[3] = GPIO Port 1 bit 3 I/O control flag ; 0 = defined as input port, 1 = defined as output port PT1EN[2] = GPIO Port 1 bit 2 I/O control flag ; 0 = defined as input port, 1 = defined as output port PT1EN[1] = GPIO Port 1 bit 1 I/O control flag ; 0 = defined as input port, 1 = defined as output port PT1EN[0] = GPIO Port 1 bit 0 I/O control flag ; 0 = defined as input port, 1 = defined as output port property W = Writable bit Fo R = Readable bit - n = Value at Power On Reset Rev. 1.5 „1‟ = Bit is Set U = unimplemented bit „0‟ = Bit is Cleared X = Bit is unknown 60/142 FS98O25 Register PT1PU at address 22H property R/W-0 R/W-0 R/W-0 PT1PU R/W-0 R/W-0 R/W-0 resistor resistor resistor resistor resistor resistor property PT1PU [7:0]: GPIO Port 1 Pull up resistor enable flag (Please refer to Section 7.1 for detail) PT1EN[7] = GPIO Port 1 bit 7 control flag ; 0 = Pull up resistor is disconnected, 1 = with Pull up y resistor Bit0 PT1EN[6] = GPIO Port 1 bit 6 control flag ; 0 = Pull up resistor is disconnected, 1 = with Pull up F P r R ro SC ef pe ’ er rti en es ce O nl resistor R/W-0 PT1PU [7:0] Bit7 Bit 7-0 R/W-0 PT1EN[5] = GPIO Port 1 bit 5 control flag ; 0 = Pull up resistor is disconnected, 1 = with Pull up PT1EN[4] = GPIO Port 1 bit 4 control flag ; 0 = Pull up resistor is disconnected, 1 = with Pull up PT1EN[3] = GPIO Port 1 bit 3 control flag ; 0 = Pull up resistor is disconnected, 1 = with Pull up PT1EN[2] = GPIO Port 1 bit 2 control flag ; 0 = Pull up resistor is disconnected, 1 = with Pull up PT1EN[1] = GPIO Port 1 bit 1 control flag ; 0 = Pull up resistor is disconnected, 1 = with Pull up PT1EN[0] = GPIO Port 1 bit 0 control flag ; 0 = Pull up resistor is disconnected, 1 = with Pull up W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 61/142 FS98O25 Register AIENB1 at address 23H property R/W-0 R/W-0 R/W-0 AIENB1 R/W-0 R/W-0 R/W-0 R/W-0 R/W-0 AIENB[7:0] Bit7 channel AIENB[7] = GPIO Port 1 bit 7 D/A flag ; 0 = defined as Analog channel, 1 = defined as Digital y channel AIENB[7:0]: GPIO Port 1 Analog / Digital control flag (Please refer to Section 7.1 for detail) AIENB[6] = GPIO Port 1 bit 6 D/A flag ; 0 = defined as Analog channel, 1 = defined as Digital F P r R ro SC ef pe ’ er rti en es ce O nl Bit 7-0 Bit0 AIENB[5] = GPIO Port 1 bit 5 D/A flag ; 0 = defined as Analog channel, 1 = defined as Digital channel channel channel channel channel channel property AIENB[4] = GPIO Port 1 bit 4 D/A flag ; 0 = defined as Analog channel, 1 = defined as Digital AIENB[3] = GPIO Port 1 bit 3 D/A flag ; 0 = defined as Analog channel, 1 = defined as Digital AIENB[2] = GPIO Port 1 bit 2 D/A flag ; 0 = defined as Analog channel, 1 = defined as Digital AIENB[1] = GPIO Port 1 bit 1 D/A flag ; 0 = defined as Analog channel, 1 = defined as Digital AIENB[0] = GPIO Port 1 bit 0 D/A flag ; 0 = defined as Analog channel, 1 = defined as Digital W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 62/142 FS98O25 Register PT2 at address 24H property R/W-X R/W-X R/W-X PT2 R/W-X R/W-X R/W-X R/W-X PT2 [7:0] Bit7 Bit 7-0 R/W-X Bit0 PT2[7:0]: GPIO Port 2 data flag y PT2[7] = GPIO Port 2 bit 7 data flag PT2[6] = GPIO Port 2 bit 6 data flag F P r R ro SC ef pe ’ er rti en es ce O nl PT2[5] = GPIO Port 2 bit 5 data flag PT2[4] = GPIO Port 2 bit 4 data flag PT2[3] = GPIO Port 2 bit 3 data flag PT2[2] = GPIO Port 2 bit 2 data flag PT2[1] = GPIO Port 2 bit 1 data flag PT2[0] = GPIO Port 2 bit 0 data flag property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 63/142 FS98O25 Register PT2EN at address 25H property R/W-0 R/W-0 R/W-0 PT2EN R/W-0 R/W-0 R/W-0 R/W-0 PT2EN [7:0] Bit7 Bit 7-0 R/W-0 Bit0 PT2EN [7:0]: GPIO Port 2 Input / Output control flag PT2EN[7] = GPIO Port 2 bit 7 I/O control flag ; 0 = defined as input port, 1 = defined as output port y PT2EN[6] = GPIO Port 2 bit 6 I/O control flag ; 0 = defined as input port, 1 = defined as output port F P r R ro SC ef pe ’ er rti en es ce O nl PT2EN[5] = GPIO Port 2 bit 5 I/O control flag ; 0 = defined as input port, 1 = defined as output port PT2EN[4] = GPIO Port 2 bit 4 I/O control flag ; 0 = defined as input port, 1 = defined as output port PT2EN[3] = GPIO Port 2 bit 3 I/O control flag ; 0 = defined as input port, 1 = defined as output port PT2EN[2] = GPIO Port 2 bit 2 I/O control flag ; 0 = defined as input port, 1 = defined as output port PT2EN[1] = GPIO Port 2 bit 1 I/O control flag ; 0 = defined as input port, 1 = defined as output port PT2EN[0] = GPIO Port 2 bit 0 I/O control flag ; 0 = defined as input port, 1 = defined as output port property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 64/142 FS98O25 Register PT2PU at address 26H R/W-0 R/W-0 R/W-0 PT2PU R/W-0 R/W-0 R/W-0 resistor resistor resistor resistor resistor resistor property PT2PU [7:0]: GPIO Port 2 Pull up resistor enable flag PT2PU[7] = GPIO Port 2 bit 7 control flag ; 0 = Pull up resistor is disconnect, 1 = with Pull up y resistor Bit0 PT2PU[6] = GPIO Port 2 bit 6 control flag ; 0 = Pull up resistor is disconnect, 1 = with Pull up F P r R ro SC ef pe ’ er rti en es ce O nl resistor R/W-0 PT2PU [7:0] Bit7 Bit 7-0 R/W-0 PT2PU[5] = GPIO Port 2 bit 5 control flag ; 0 = Pull up resistor is disconnect, 1 = with Pull up PT2PU[4] = GPIO Port 2 bit 4 control flag ; 0 = Pull up resistor is disconnect, 1 = with Pull up PT2PU[3] = GPIO Port 2 bit 3 control flag ; 0 = Pull up resistor is disconnect, 1 = with Pull up PT2PU[2] = GPIO Port 2 bit 2 control flag ; 0 = Pull up resistor is disconnect, 1 = with Pull up PT2PU[1] = GPIO Port 2 bit 1 control flag ; 0 = Pull up resistor is disconnect, 1 = with Pull up PT2PU[0] = GPIO Port 2 bit 0 control flag ; 0 = Pull up resistor is disconnect, 1 = with Pull up W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 65/142 FS98O25 Register PT2MR at address 27H property R/W-0 PT2MR BZEN U-0 U-0 R/W-0 PM1EN R/W-0 R/W-0 E1M[1:0] R/W-0 E0M[1:0] Bit7 Bit 7 R/W-0 Bit0 BZEN: Buzzer enable flag (Please refer to Section 7.5 for detail) 1 = Buzzer function is enabled, GPIO Port 2 bit 7 is defined as Buzzer output. PM1EN: PDM Module enable flag (Please refer to Chapter 8 for detail) F P r R ro SC ef pe ’ er rti en es ce O nl Bit 4 y 0 = Buzzer function is disabled, GPIO Port 2 bit 7 is defined as GPIO. 1 = PDM Module is enabled, GPIO Port 2 bit 2 is defined as PDM output. 0 = PDM Module is disabled, GPIO Port 2 bit 2 is defined as GPIO. Bit 3-2 E1M[1:0]: GPIO Port 2 bit 1 interrupt trigger mode (Please refer to Section 7.2 for detail) 11 = External Interrupt 1 (GPIO Port 2 bit 1) is triggered at state change 10 = External Interrupt 1 (GPIO Port 2 bit 1) is triggered at state change 01 = External Interrupt 1 (GPIO Port 2 bit 1) is triggered at positive edge 00 = External Interrupt 1 (GPIO Port 2 bit 1) is triggered at negative edge Bit 1-0 E0M[1:0]: GPIO Port 2 bit 0 interrupt trigger mode (Please refer to Section 7.2 for detail) 11 = External Interrupt 0 (GPIO Port 2 bit 0) is triggered at state change 10 = External Interrupt 0 (GPIO Port 2 bit 0) is triggered at state change 01 = External Interrupt 0 (GPIO Port 2 bit 0) is triggered at positive edge 00 = External Interrupt 0 (GPIO Port 2 bit 0) is triggered at negative edge property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 66/142 FS98O25 Register PT3 at address 28H property U-X U-X U-X U-X R/W-X R/W-X PT3 R/W-X PT3 [3:0] Bit7 Bit 3-0 R/W-X Bit0 PT3[3:0]: GPIO Port 3 data flag y PT3[3] = GPIO Port 3 bit 3 data flag PT3[2] = GPIO Port 3 bit 2 data flag F P r R ro SC ef pe ’ er rti en es ce O nl PT3[1] = GPIO Port 3 bit 1 data flag PT3[0] = GPIO Port 3 bit 0 data flag property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 67/142 FS98O25 Register PT3EN at address 29H property U-0 U-0 U-0 U-0 R/W-0 R/W-0 PT3EN R/W-0 PT3EN [3:0] Bit7 Bit 3-0 R/W-0 Bit0 PT3EN [3:0]: GPIO Port 3 Input / Output control flag PT3EN[3] = GPIO Port 3 bit 3 I/O control flag ; 0 = defined as input port, 1 = defined as output port y PT3EN[2] = GPIO Port 3 bit 2 I/O control flag ; 0 = defined as input port, 1 = defined as output port F P r R ro SC ef pe ’ er rti en es ce O nl PT3EN[1] = GPIO Port 3 bit 1 I/O control flag ; 0 = defined as input port, 1 = defined as output port PT3EN[0] = GPIO Port 3 bit 0 I/O control flag ; 0 = defined as input port, 1 = defined as output port property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 68/142 FS98O25 Register PT3PU at address 2AH U-0 U-0 U-0 U-0 R/W-0 R/W-0 PT3PU resistor resistor property PT3PU [3:0]: GPIO Port 3 Pull up resistor enable flag PT3PU[3] = GPIO Port 3 bit 3 control flag ; 0 = Pull up resistor is disconnected, 1 = with Pull up y resistor Bit0 PT3PU[2] = GPIO Port 3 bit 2 control flag ; 0 = Pull up resistor is disconnected, 1 = with Pull up F P r R ro SC ef pe ’ er rti en es ce O nl resistor R/W-0 PT3PU [3:0] Bit7 Bit 3-0 R/W-0 PT3PU[1] = GPIO Port 3 bit 1 control flag ; 0 = Pull up resistor is disconnected, 1 = with Pull up PT3PU[0] = GPIO Port 3 bit 0 control flag ; 0 = Pull up resistor is disconnected, 1 = with Pull up W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 69/142 FS98O25 Register PT3MR at address 2BH property U-0 U-0 U-0 PT3MR R/W-0 R/W-0 PFOEN R/W-0 E3M[1:0] R/W-0 E2M[1:0] Bit7 Bit 4 R/W-0 Bit0 PFOEN: Programmable Counter Enabled register flag 0 = Programmable Counter is disabled E3M[1:0]: GPIO Port 3 bit 1 interrupt trigger mode (Please refer to Section 7.2 for detail) F P r R ro SC ef pe ’ er rti en es ce O nl Bit 3-2 y 1 = Programmable Counter is enabled 11 = External Interrupt 4 (GPIO Port 3 bit 1) is triggered at state change 10 = External Interrupt 4 (GPIO Port 3 bit 1) is triggered at state change 01 = External Interrupt 4 (GPIO Port 3 bit 1) is triggered at positive edge 00 = External Interrupt 4 (GPIO Port 3 bit 1) is triggered at negative edge Bit 1-0 E2M[1:0]: GPIO Port 3 bit 0 interrupt trigger mode (Please refer to Section 7.2 for detail) 11 = External Interrupt 3 (GPIO Port 3 bit 0) is triggered at state change 10 = External Interrupt 3 (GPIO Port 3 bit 0) is triggered at state change 01 = External Interrupt 3 (GPIO Port 3 bit 0) is triggered at positive edge 00 = External Interrupt 3 (GPIO Port 3 bit 0) is triggered at negative edge property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 70/142 FS98O25 Register PT2OCB at address 37H property U-X U-X U-X PT2OCB R/W-1 R/W-1 U-X property PT2OC[4:3]: GPIO Port 2 Open Drain control flag PT2OC[4] = GPIO Port 2 bit 4 Open Drain control flag ; 0 = normal digital I/O, 1 = Open Drain y Control Bit0 PT2OC[3] = GPIO Port 2 bit 3 Open Drain control flag ; 0 = normal digital I/O, 1 = Open Drain F P r R ro SC ef pe ’ er rti en es ce O nl Control U-X PT2OC[4:3] Bit7 Bit 4-3 U-X W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 71/142 FS98O25 F P r R ro SC ef pe ’ er rti en es ce O nl y Digital I/O Port with Analog Input Channel Shared: PT1[7:0] Figure 7-1 PT1[7:0] function block GPIO Port 1 (PT1[7:0]) function block is shown in Figure 7-1. The main function of the GPIO is for data exchange between the Data bus and the ports. Users could control the PT1EN[7:0] register flags to decide the input and output direction. The input and output function and the related functions are explained as follows:  Input: GPIO Port 1 Bit0 to Bit7 (PT1[7:0]) could be used to get both the digital signal and the analog signal. User should control the AIENB[11:0] register flags to decide the input type. If user sets the AIENB, the AND gate embedded in the GPIO Port1 will allow the digital data to connect to the data bus. Otherwise, the Input signals will be defined as analog signals and sent to the related function blocks (ADC, OPAMP…etc)  Output FS98O25 sends the digital data out by an embedded D Flip Flop. When the program sends data out through PT1 , the data will be sent to data bus first, and then the D Flip Flop will latch the signal for PT1 and output while the Write signal and AR (FS98O25 internal device address pointer) is pointed to PT1 and .  Pull up resistor 9 Fo FS98O25 embeds an internal pull up resistor function in PT1 with about 1000k ohm resistor . Users could control the PT1PU[7:0] register flags to decide the connections to pull up resistor. When a port is connected to the pull up resistor, the input data is, by default, assigned to high (data 1). 9 The pull up current is about 10uA. Remember to disable PT1PU before program falls into Sleep mode. Rev. 1.5 72/142 FS98O25 Table 7-2 PT1 register table Address Name 20H 21H 22H 23H PT1 PT1EN PT1PU AIENB1 Detail on Chapter 7 7 7 7 Bit 7 Bit 6 AIENB[7:6] Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 PT1 [7:0] PT1EN [7:0] PT1PU [7:0] AIENB[5:0] Value on Power on Reset uuuuuuuu 00000000 00000000 00000000 Read data Operation 6. 10 y Clear the PT1EN[n] register flags. The PT1[n] will be defined as an input port. Set the PT1PU[n] register as required. The PT1[n] will be connected to an internal pull up resistor. Set the AIENB[n] register flags if the input signals are analog signals.(n = 11 to 0) 11 Clear the AIENB[n] register flags if the input signals are analog signals. (n = 11 to 0 ) The VDDA Regulator must be enabled first, and then the AIN0~AIN7 can work correctly. (Please refer to Chapter 4) After the signal input from outside, users can get the data through PT1[n] F P r R ro SC ef pe ’ er rti en es ce O nl 1. 2. 3. 4. 5. Write data Operation 1. 2. 3. Set the PT1EN[n] register flags. The PT1[n] will be defined as an output port. Set the PT1PU[n] register as required. The PT1[n]] will be connected to an internal pull up resistor. Set the PT1[n] to output the data. The embedded D Flip Flop will latch the data till PT1[n] is changed. Notice Operation 1. 2. To keep low operation current in SLEEP mode, set AIENB[11:0] to let the PT1 be floating. Parallel a small resistor (about 10k ohm) between ports and VDD to increase the possible output current when the PT1PU[n] is set. Fo Digital I/O Port and External Interrupt Input : PT2[0], PT2[1], PT3[0], PT3[1] Figure 7-2 PT2[0] PT2[1] PT3[0] PT3[1] function block 10 11 n means the bits indexes user want to control PT1 bit6 and bit7 could only be defined as digital signal input. Rev. 1.5 73/142 FS98O25 GPIO Port 2 Bit1 and Bit 0 (PT2[1:0])and Port 3 Bit1 and Bit 0 (PT3[1:0]) function block is shown in Figure 7-2. The main function of the GPIO is input and output data between the Data bus and the ports. Users could control the PT2EN[1:0] and PT3EN[1:0] register flags to decide the input output direction. The input and output function and the related functions are explained as follows:  Input: GPIO Port 2 Bit1 and Bit0 (PT2[1:0]) could be the external interrupt ports as INT1 and INT0 or be the general I/O ports. User should control INTE register E0IE and E1IE flags to decide if the interrupt is enabled. The interrupt trigger mode is selected by E0M[1:0] and E1M[1:0] register flags. The input port has a Schmitt trigger in it, and the up/down trigger voltage level is 0.45VDD/0.2VDD. Output F P r R ro SC ef pe ’ er rti en es ce O nl  y GPIO Port 3 Bit1 and Bit0 (PT3[1:0]) could be the external interrupt ports as INT3 and INT2 or be the general I/O ports. User should control INTE register E2IE and E3IE flags to decide if the interrupt is enabled. The interrupt trigger mode is selected by E2M[1:0] and E3M[1:0] register flags. The input port has a Schmitt trigger in it, and the up/down trigger voltage level is 0.45VDD/0.2VDD. FS98O25 sends the digital data out by an embedded D Flip Flop. When the program sends data out through PT2 or PT3, the data will be sent to data bus first, and then the D Flip Flop will latch the signal for PT2/PT3 output while the Write signal and AR (FS98O25 internal device address pointer) is pointed to PT2/PT3.  Pull up resistor 12 Fo FS98O25 embeds an internal pull up resistor function in PT2 with about 1000k ohm resistor . Users could control the PT2PU[1:0] register flags to decide the connections to pull up resistor. When a port is connected to the pull up resistor, the input data is, by default, assigned to high (data 1). 12 The pull up current is about 10uA. Remember to disable PT1PU before program falls into Sleep mode. Rev. 1.5 74/142 FS98O25 Table 7-3 PT2 register table 06H 07H 24H 25H 26H 27H 28H 29H 2AH 2BH Referenced Section INTF 3/6/7/9/10/11 INTE 3/6/7/9/10/11 PT2 7 PT2EN 7 PT2PU 7 PT2MR 7.2/7.5/8 PT3 PT3EN PT3PU PT3MR Name Bit 7 Bit 6 Bit 5 GIE -- Bit 4 Bit 3 Bit 0 Value on Power on Reset 00000000 00000000 uuuuuuuu 00000000 00000000 00000000 uuuuuuuu 00000000 00000000 00000000 F P r R ro SC ef pe ’ er rti en es ce O nl 3. Bit 1 --E1IF E0IF --E1IE E0IE PT2 [7:0] PT2EN [7:0] PT2PU [7:0] -E1M[1:0] E0M[1:0] PT3 [3:0] PT3EN [3:0] PT3PU [3:0] PFOEN E3M[1:0] E2M[1:0] Read data Operation 1. 2. Bit 2 y Address 13 Clear the PT2EN[n] /PT3EN[n] register flags. The PT2[n]/PT3[n] will be defined as an input port. Set the PT2PU[n]/PT3PU[n] register as required. The PT2[n]/PT3[n] will be connected to an internal pull up resistor. After the signal input from outside, user could get the data through PT2[n]/PT3[n] Write data Operation 1. 2. 3. Set the PT2EN[n]/PT3EN[n] register flags. The PT2[n]/PT3[n] will be defined as an output port. Set the PT2PU[n]/PT3PU[n] register as required. The PT2[n]/PT3[n] will be connected to an internal pull up resistor. Set the PT2[n]/PT3[n] to output the data. The embedded D Flip Flop will latch the data till PT2[n]/PT3[n] is changed. External Interrupt Operation (negative edge trigger for example) 1. 2. 3. 4. 5. 6. Clear the PT2EN[n]/PT3EN[n] register flags. The PT2[n]/PT3[n] will be defined as an input port. Set the PT2PU[n]/PT3PU[n] register. The PT2[n]/PT3[n] will be connected to an internal pull up resistor. Set the E0M[1:0] as 00 to define INT0 interrupt trigger mode as “negative edge trigger”. Set the E1M[1:0] as 00 to define INT1 interrupt trigger mode as “negative edge trigger”. Set the E2M[1:0] as 00 to define INT2 interrupt trigger mode as “negative edge trigger”. Set the E3M[1:0] as 00 to define INT3 interrupt trigger mode as “negative edge trigger”. Notice Operation Parallel a small resistor (about 10k ohm) between ports and VDD to increase the possible output current when the PT2PU[n]/PT3PU[n] is set. Fo 1. 13 n means the bits indexes user want to control Rev. 1.5 75/142 FS98O25 F P r R ro SC ef pe ’ er rti en es ce O nl y Digital I/O Port or PDM Output : PT2[2] and PT2[5] Figure 7-3 PT2[2] function block GPIO Port 2 Bit2 (PT2[2]) and GPIO Port 2 Bit5 (PT2[5]) function block is shown in Figure 7-3. The main function of the GPIO is input and output data between the Data bus and the ports. User could control the PT2EN[2]/ PT2EN[5] register flags to decide the input output direction. The input and output function and the related functions are explained as follows:  Input: GPIO Port 2 Bit2 (PT1[2]) and GPIO Port 2 Bit5 (PT1[5]) could be the PDM (Pulse Density Modulator) output port or be the general I/O port. User should setup PM1EN/ PM2EN register flag to decide if the PDM is enabled. The detailed PDM usage is described in Chapter 8. The input port has a Schmitt trigger in it, and the up/down trigger voltage level is 0.45VDD/0.2VDD.  Output FS98O25 sends the digital data out by an embedded D Flip Flop. When the program sends data out through PT2, the data will be sent to data bus first, and then the D Flip Flop will latch the signal for PT2 output while the Write signal and AR (FS98O25 internal device address pointer) is pointed to PT2.  Pull up resistor 14 Fo FS98O25 embeds an internal pull up resistor function in PT2 with about 1000k ohm resistor . Users could control the PT2PU[2]/PT2PU[5] register flags to decide the connection to pull up resistor. When a port is connected to the pull up resistor, the input data is, by default, assigned to high (data 1). 14 The pull up current is about 10uA. Remember to disable PT1PU before program falls into Sleep mode. Rev. 1.5 76/142 FS98O25 Table 7-4 PT2 register table Address 24H 25H 26H 27H Detail on Bit 7 Chapter PT2 7 PT2EN 7 PT2PU 7 PT2MR 7.2/7.5/8 -Name Bit 6 Bit 5 PM2EN Bit 4 Bit 3 Bit 2 Bit 1 PT2 [7:0] PT2EN [7:0] PT2PU [7:0] PM1EN -- Bit 0 -- Value on Power on Reset uuuuuuuu 00000000 00000000 00000000 Read data Operation 15 y Clear the PT2EN[n] register flags. The PT2[n] will be defined as an input port. Set the PT2PU[n] register as required. The PT2[n] will be connected to an internal pull up resistor. After the signal input from outside, user could get the data through PT2[n] F P r R ro SC ef pe ’ er rti en es ce O nl 1. 2. 3. Write data Operation 1. 2. 3. Set the PT2EN[n] register flags. The PT2[n] will be defined as an output port. Set the PT2PU[n] register as required. The PT2[n] will be connected to an internal pull up resistor. Set the PT2[n] to output the data. The embedded D Flip Flop will latch the data till user change PT2[n]. Notice Operation 1. Parallel a small resistor (about 10k ohm) between ports and VDD to increase the possible output current when the PT2PU[n] is set. Fo Digital I/O Port or I2C Serial Port : PT2[3]/SDA, PT2[4]/SCL Figure 7-4 PT2[3] PT2[4] function block 15 n means the bits indexes user want to control Rev. 1.5 77/142 FS98O25 GPIO Port 2 Bit4 and Bit 3 (PT2[4:3]) function block is shown in Figure 7-4. The main function of the GPIO is input and output data between the Data bus and the ports. Users could control the PT2EN[4:3] register flags to decide the input output direction. The input and output function and the related functions are explained as follows:  Input: GPIO Port 2 Bit4 and Bit3 (PT2[4:3]) could be the I2C Module SCL and SDA ports or be the general I/O ports. User should setup I2CEN register flag to decide the I2C Module is enabled or not. The detailed I2C Module usage is described in Chapter 9. Output F P r R ro SC ef pe ’ er rti en es ce O nl  y The input port has a Schmitt trigger in it, and the up/down trigger voltage level is 0.45VDD/0.2VDD. FS98O25 sends the digital data out by an embedded D Flip Flop. When the program sends data out through PT2, the data will be sent to data bus first, and then the D Flip Flop will latch the signal for PT2 output while the Write signal and AR (FS98O25 internal device address pointer) is pointed to PT2.  Pull up resistor 16 FS98O25 embeds an internal pull up resistor function in PT2 with about 1000k ohm resistor . User could control the PT2PU[4:3] register flags to decide the connections to pull up resistor. When a port is connected to the pull up resistor, the input data is, by default, assigned to high (data 1).  Open Drain Control FS98O25 embeds an internal Open Drain Control function in PT2[4:3]. Users could control the PT2OC[4:3] register flags to decide if the Open Drain Control function is enabled. When the user assigns these 2 ports to be SCL and SDA, PT2OC[4:3] should be set. Please refer to Chapter 9. Table 7-5 PT2 register table Address 24H 25H 26H 37H Referenced Bit 7 Section PT2 7 PT2EN 7 PT2PU 7 PT2OCB 9 Name Bit 6 Bit 5 Bit 4 Bit 3 PT2 [7:0] PT2EN [7:0] PT2PU [7:0] PT2OC[4:3] Bit 2 Bit 1 Bit 0 Value on Power on Reset uuuuuuuu 00000000 00000000 uuu11uuu Read data Operation 1. 2. 3. 4. 17 Clear the PT2EN[n] register flags. The PT2[n] will be defined as an input port. Set the PT2PU[n] register as required. The PT2[n] will be connected to an internal pull up resistor. Set the PT2OC[n] register as required. The PT2[n] will be connected to an internal pull low resistor. After the signal input from outside, user could get the data through PT2[n] Write data Operation 4. 16 17 Set the PT2EN[n] register flags. The PT2[n] will be defined as an output port. Set the PT2PU[n] register as required. The PT2[n] will be connected to an internal pull up resistor. Set the PT2OC[n] register as required. The PT2[n] will be connected to an internal pull low resistor. Set the PT2[n] to output the data. The embedded D Flip Flop will latch the data till PT2[n] is changed. Fo 1. 2. 3. The pull up current is about 10uA. Remember to disable PT1PU before program falls into Sleep mode. n means the bit index that a user want to control Rev. 1.5 78/142 FS98O25 Notice Operation 1. 2. Parallel a small resistor (about 10k ohm) between ports and VDD to enlarge the possible output current when the PT2PU[n] is set. The Pull up resistor function and the Open drain control function should NOT be enabled at the same time. F P r R ro SC ef pe ’ er rti en es ce O nl y Digital I/O Port : PT2[6] Figure 7-5 PT2[6] function block GPIO Port 2 Bit 6 (PT2[6]) is shown in Figure 7-5. The main function of the GPIO is input and output data between the Data bus and the ports. Users could control the PT2EN[6] register flags to decide the input output direction. The input and output function are explained as follows:  Input: GPIO Port 2 Bit 6 (PT2[6]) could only be the general I/O ports. The input port has a Schmitt trigger in it, and the up/down trigger voltage level is 0.45VDD/0.2VDD.  Output  Fo FS98O25 sends the digital data out by an embedded D Flip Flop. When the program sends data out through PT2, the data will be sent to data bus first, and then the D Flip Flop will latch the signal for PT2 output while the Write signal and AR (FS98O25 internal device address pointer) is pointed to PT2. Pull up resistor 18 FS98O25 embeds an internal pull up resistor function in PT2 with about 1000k ohm resistor . User could control the PT2PU[6] register flags to set the connections to pull up resistor. When a port is connected to the pull up resistor, the input data is, by default, assigned to high (data 1). 18 The pull up current is about 10uA. Remember to disable PT1PU before program falls into Sleep mode. Rev. 1.5 79/142 FS98O25 Table 7-6 PT2 register table Referenced Bit 7 Section PT2 7 PT2EN 7 PT2PU 7 PT2MR 7.2/7.5/8 BZEN Address Name 24H 25H 26H 27H Bit 6 Bit 5 Bit 4 Bit 3 PT2 [7:0] PT2EN [7:0] PT2PU [7:0] --- Bit 2 Bit 1 Bit 0 -- Value on Power on Reset uuuuuuuu 00000000 00000000 00000000 Read data Operation 19 y Clear the PT2EN[n] register flags. The PT2[n] will be defined as an input port. Set the PT2PU[n] register as required. The PT2[n] will be connected to an internal pull up resistor. After the signal input from outside, user could get the data through PT2[n] F P r R ro SC ef pe ’ er rti en es ce O nl 1. 2. 3. Write data Operation 1. 2. 3. Set the PT2EN[n] register flags. The PT2[n] will be defined as an output port. Set the PT2PU[n] register as required. The PT2[n] will be connected to an internal pull up resistor. Set the PT2[n] to output the data. The embedded D Flip Flop will latch the data till PT2[n] is changed. Notice Operation Parallel a small resistor (about 10k ohm) between ports and VDD to increase the possible output current when the PT2PU[n] is set. Fo 1. 19 n means the bits indexes user want to control Rev. 1.5 80/142 FS98O25 F P r R ro SC ef pe ’ er rti en es ce O nl y Digital I/O Port or Buzzer Output : PT2[7] Figure 7-6 PT2[7] function block GPIO Port 2 Bit2 (PT2[2]) function block is shown in Figure 7-6. The main function of the GPIO is input and output data between the Data bus and the ports. Users could control the PT2EN[2] register flags to decide the input output direction. The input and output function and the related functions are explained as follows:  Input: GPIO Port 2 Bit2 (PT1[2]) could be the Buzzer output port or be the general I/O port. User should setup BZEN register flag to decide if the Buzzer output is enabled. The detailed Buzzer usage is described in Section 5.4.  Output FS98O25 sends the digital data out by an embedded D Flip Flop. When the program sends data out through PT2, the data will be sent to data bus first, and then the D Flip Flop will latch the signal for PT2 output while the Write signal and AR (FS98O25 internal device address pointer) is pointed to PT2.  Pull up resistor 20 Fo FS98O25 embeds an internal pull up resistor function in PT2 with about 1000k ohm resistor . User could control the PT2PU[2] register flags to set the connection to pull up resistor. When a port is connected to the pull up resistor, the input data is, by default, assigned to high (data 1). 20 The pull up current is about 10uA. Remember to disable PT1PU before program falls into Sleep mode. Rev. 1.5 81/142 FS98O25 Table 7-7 PT2[7] register table Address 24H 25H 26H Referenced Bit 7 Section PT2 7 PT2EN 7 PT2PU 7 Name Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 PT2 [7:0] PT2EN [7:0] PT2PU [7:0] Value on Power on Reset uuuuuuuu 00000000 00000000 Read data Operation 21 y Clear the PT2EN[n] register flags. The PT2[n] will be defined as an input port. Set the PT2PU[n] register as required. The PT2[n] will be connected to an internal pull up resistor. After the signal input from outside, user could get the data through PT2[n] F P r R ro SC ef pe ’ er rti en es ce O nl 1. 2. 3. Write data Operation 1. 2. 3. Set the PT2EN[n] register flags. The PT2[n] will be defined as an output port. Set the PT2PU[n] register as required. The PT2[n] will be connected to an internal pull up resistor. Set the PT2[n] to output the data. The embedded D Flip Flop will latch the data till PT2[n] is changed. Buzzer Output Operation 1. 2. 3. 4. Set the PT2EN[7] register flags. The PT2[7] will be defined as an output port. Please refer to Section 5.4 for the Buzzer Clock setting. Set the BZEN register flag. The PT2[7] will become the buzzer output port. Connect a buzzer to PT2 bit7. The Buzzer will work correctly. Notice Operation Parallel a small resistor (about 10k ohm) between ports and VDD to increase the possible output current when the PT2PU[n] is set. Fo 1. 21 n means the bits indexes user want to control Rev. 1.5 82/142 FS98O25 8. PDM (Pulse Density Modulator) Module F P r R ro SC ef pe ’ er rti en es ce O nl y Please see Figure 8-1 and Figure 8-2. The GPIO port 2 bit 2 (PT2[2]) could be defined as either PDM module output or General purpose I/O. User could control the PDMEN register flags to decide the definition. The PDM module is the function FS98O25 uses for implementing the PWM (Pulse Width Modulation). Its working flowchart and usage will be described in this Chapter. First of all, a user needs to setup the PMCS register flag 22 to decide the PDM CLK which is generated by a Frequency divider from the MCK . Then, the PDM CLK will be divided into 16 internal clock signals named PDM15, PDM14,…, PDM0. Finally, the user should control the PMD1 (PMD1H and PMD1L) register flag to do the combination of these 16 internal clock signals. For example, if the PMD1 is set as 0x1228H, the output signal is assigned to be the combination of PDM12, PDM9, PDM5 and PDM3. If the PMD1 is set as 0x6000H, the output signal is assigned to be the combination of PDM14 and PDM13 (please refer to the following figure).The PMD1 value could be assigned from 0 to 65535, and the 23 output signal duty cycle could be from 0 to 65535/65536 . For example, when user sets the PMD1 as 0x6000H (24576), the equivalent PWM duty cycle is 24576/65536. 22 Fo Figure 8-1 FS98O25 PDM module function block Please refer to Chapter 5 for MCK detailed information. The PDM couldn‟t generate signal as duty cycle 1, user needs to define the port as General purpose I/O and keep it at high voltage level (data 1) manually to represent Duty Cycle 1. 23 Rev. 1.5 83/142 F P r R ro SC ef pe ’ er rti en es ce O nl y FS98O25 Fo Figure 8-2 PDM module signal generation Rev. 1.5 84/142 FS98O25 Table 8-1 PDM module register table Referenced Section PT2MR 7.2/7.5/8 PMD1H 8 PMD1L 8 PMD2H PMD2L PMCON 8 Address Name 27H 30H 31H 32H 33H 36H Bit 7 Bit 6 -- PM2EN Bit 5 Bit 4 Bit 3 Bit 2 PM1EN -PMD1[15:8] PMD1[7:0] PDMD2[15:8] PDMD2[7:0] PDMEN Bit 1 Bit 0 -- PMCS[2:0] Value on Power on Reset 00000000 00000000 00000000 00000000 00000000 00000000 U-0 R/W-0 PT2MR -- PM2EN U-0 R/W-0 U-0 PM1EN U-0 -- Bit7 Bit 6 U-0 U-0 -- F P r R ro SC ef pe ’ er rti en es ce O nl property y Register PT2MR at address 27H Bit0 PM2EN: PT2[5] output multiplexer (Please refer to Section 7.3 for details) 1 = GPIO Port 2 bit 5 (PT2[5]) is defined as PDM output. 0 = GPIO Port 2 bit 5 (PT2[5]) is defined as GPIO. Bit 4 PM1EN: PT2[2] output multiplexer (Please refer to Section 7.3 for details) 1 = GPIO Port 2 bit 2 (PT2[2]) is defined as PDM output. 0 = GPIO Port 2 bit 2 (PT2[2]) is defined as GPIO. property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 85/142 FS98O25 Register PMD1H at address 30H property R/W-0 R/W-0 R/W-0 PMD1H R/W-0 R/W-0 R/W-0 R/W-0 R/W-0 PMD1[15:8] Bit7 Bit0 Register PMD1L at address 31H R/W-0 R/W-0 R/W-0 R/W-0 R/W-0 PMD1[7:0] R/W-0 R/W-0 F P r R ro SC ef pe ’ er rti en es ce O nl PMD1L R/W-0 y property Bit7 Bit 15-0 Bit0 PMD1[15:0]: PDM Module Data output Control Register 1 PMD1[15] = PDM15 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 2 PMD1[14] = PDM14 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 3 PMD1[13] = PDM13 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 4 PMD1[12] = PDM12 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 5 PMD1[11] = PDM11 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 6 PMD1[10] = PDM10 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 7 PMD1[9] = PDM9 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 8 PMD1[8] = PDM8 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 9 PMD1[7] = PDM7 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 10 PMD1[6] = PDM6 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 11 PMD1[5] = PDM5 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 12 PMD1[4] = PDM4 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 13 PMD1[3] = PDM3 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 14 PMD1[2] = PDM2 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 15 PMD1[1] = PDM1 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 16 PMD1[0] = PDM0 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 86/142 FS98O25 Register PMD2H at address 32H property R/W-0 R/W-0 R/W-0 PMD2H R/W-0 R/W-0 R/W-0 R/W-0 R/W-0 PMD2[15:8] Bit7 Bit0 Register PMD2L at address 33H R/W-0 R/W-0 R/W-0 R/W-0 PMD2[7:0] R/W-0 R/W-0 R/W-0 F P r R ro SC ef pe ’ er rti en es ce O nl PMD2L R/W-0 y property Bit7 Bit 15-0 Bit0 PMD2[15:0]: PDM Module Data output Control Register 1 PMD2[15] = PDM15 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 2 PMD2[14] = PDM14 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 3 PMD2[13] = PDM13 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 4 PMD2[12] = PDM12 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 5 PMD2[11] = PDM11 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 6 PMD2[10] = PDM10 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 7 PMD2[9] = PDM9 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 8 PMD2[8] = PDM8 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 9 PMD2[7] = PDM7 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 10 PMD2[6] = PDM6 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 11 PMD2[5] = PDM5 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 12 PMD2[4] = PDM4 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 13 PMD2[3] = PDM3 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 14 PMD2[2] = PDM2 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 15 PMD2[1] = PDM1 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable 16 Fo PMD2[0] = PDM0 (PDM CLK/2 )Signal Combination enable flag. 0 = Enable ; 1 = Disable Rev. 1.5 87/142 FS98O25 Register PMCON at address 36H property U-0 U-0 U-0 PMCON R/W-0 U-0 R/W-0 PDMEN R/W-0 PMCS[2:0] Bit7 Bit 4 R/W-0 Bit0 PDMEN: PDM Module enable flag (Please refer to Chapter 8 for details) 0 = PDM Module is disabled, GPIO Port 2 bit 2 could be defined as GPIO. PMCS[2:0]: PDM CLK frequency Selector F P r R ro SC ef pe ’ er rti en es ce O nl Bit 2-0 y 1 = PDM Module is enabled, GPIO Port 2 bit 2 could be defined as PDM output. 111 = PDM CLK frequency is as MCK/128 110 = PDM CLK frequency is as MCK/64 101 = PDM CLK frequency is as MCK/32 100 = PDM CLK frequency is as MCK/16 011 = PDM CLK frequency is as MCK/8 010 = PDM CLK frequency is as MCK/4 001 = PDM CLK frequency is as MCK/2 000 = PDM CLK frequency is the same as MCK property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 88/142 FS98O25 Table 8-2 PMD register table Address Name 14H 25H 27H 30H 31H 36H MCK PT2EN PT2MR PMD1H PMD1L PMCON Detail on Value on Power Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Chapter on Reset 5 M7_CK M6_CK M5_CK M3_CK M2_CK M1_CK M0_CK 00000000 7 PT2EN [7:0] 00000000 7.2/7.5/8 -PM1EN --00000000 8 PMD1[15:8] 00000000 8 PMD1[7:0] 00000000 8 PDMEN PMCS[2:0] 00000000 Setup M0_CK, M3_CK to decide the MCK.(Please refer to Section 5.1 for detailed instruction for setup) Set PDMEN to enable the PDM Module. Setup PMCS[2:0] to decide the PDM CLK frequency. Setup PMD1[15:0] to decide the PDM output signal. Set PT2EN[2] to assign the PT2[2] to be an output port. Set PM1EN to assign the PT2[2] to be PDM Module output. F P r R ro SC ef pe ’ er rti en es ce O nl 1. 2. 3. 4. 5. 6. y PDM Operation Table 8-3 PDM CLK selection table PDM CLK frequency 000 MCK 001 MCK/2 010 MCK/4 011 MCK/8 100 MCK/16 101 MCK/32 110 MCK/64 111 MCK/128 Fo PWCS Rev. 1.5 89/142 FS98O25 9. I2C Module (slave mode only) FS98O25 embeds a slave mode I2C module. The two pins, SCL and SDA, are used to perform the I2C system. The pin SCL is assigned to be the clock pin, and the pin SDA is assigned to be the data pin in the I2C module. In an I2C system, there are master side and slave side. Master side would send the clock, slave ID and the commands to slave side. One master could connect to several slave sides with different IDs. First of all, the slave side would check if the ID sent by master side is the same as itself. If the ID matched, slave side would check the following bit from master. If the bit was low, it means that master side want to transfer some data or command to slave, so slave side should sent back an acknowledgement signal and then receive the data from master side. On the other hand, if the bit was high, it means that master side want to receive the data from slave side, so slave side should sent back an acknowledgement signal and then transmit the data back.( Please see Figure 9-1) Slave to master …. start slave ID R ack data ack start slave ID W ack Data1 ack stop F P r R ro SC ef pe ’ er rti en es ce O nl Master y Master to slave receive data Master transmit …. stop data Figure 9-1 FS98O25 I2C module communication Fo In the I2C module embedded in FS98O25, there are 5 register flags shown in following figure. The SCL and SDA signal is connected to I2CSR and the Start and stop bit detector. The I2CSR is assigned to be the data buffer. When some signal is sent from master, the Start and stop bit detector will respond to the situation, and the Match detector will determine if the input data is matched with the slave ID. If it matches the ID, the user should send back the acknowledgement (data low) to respond to the master side. No matter whether the I2C module sends the data or receives the data, the I2CBUF is assigned to be the buffer. When the module receives the data, the data signals will be stored in the I2CSR, and send the whole data to I2CBUF after the data is sent completely. Rev. 1.5 Figure 9-2 I2C module function block 90/142 FS98O25 Table 9-1 I2C module register table Address Name 57H 58H 59H 5AH I2CCON I2CSTA I2CADD I2CBUF Referenced Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Section 9 WCOL I2COV I2CEN CKP 9 DA P S 9 I2CADD [7:0] 9 I2CBUF [7:0] Bit 2 Bit 1 RW Bit 0 BF Value on Power on Reset 0001uuuu uu0000u0 00000000 00000000 Register I2CCON at address 57H R/W-0 R/W-0 R/W-1 I2CCON WCOL I2COV I2CEN CKP U-X U-X U-X Bit7 Bit 7 U-X y R/W-0 F P r R ro SC ef pe ’ er rti en es ce O nl property Bit0 WCOL: Write collision detector register flag. 1 = The I2CBUF register is written while it is still transmitting the previous data. 0 = No write collision is happened. This register should be clear in software. Bit 6 I2COV: Receive overflow detector register flag 1 = A byte is received while the I2CBUF is still holding the previous data. 0 = No receive overflow is happened. This register should be clear in software Bit 5 I2CEN: I2C module enable flag 1 = I2C module is enabled. 0 = I2C module is disabled. Bit 4 CKP: SCK signal control register 1 = SCK pin is enabled. 0 = SCK pin is disabled and hold to low. property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 91/142 FS98O25 Register I2CSTA at address 58H property U-X U-X I2CSTA R/W-0 R/W-0 R/W-0 R/W-0 DA P S RW U-X BF Bit7 Bit 5 R/W-0 Bit0 DA: Data / Address bit register flag. y 1 = The last received byte is data. 0 = The last received byte is address. P: Stop bit register flag F P r R ro SC ef pe ’ er rti en es ce O nl Bit 4 1 = A stop bit is detected. 0 = No stop bit is detected. When the I2C module is disabled, this bit would be clear. Bit 3 S: Start bit register flag 1 = A start bit is detected. 0 = No start bit is detected. When the I2C module is disabled, this bit would be clear. Bit 2 RW: Read / Write register flag 1 = Read command is detected. 0 = Write command is detected. Bit 0 BF: I2CBUF full register flag. 1 = I2CBUF is full. The user could get data from I2CBUF register. 0 = I2CBUF is empty. Register I2CADD at address 59H property R/W-0 R/W-0 R/W-0 I2CADD R/W-0 R/W-0 R/W-0 property Bit0 I2CADD[7:0]: I2C module slave mode ID buffer register. W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared Fo R = Readable bit Rev. 1.5 R/W-0 I2CADD [7:0] Bit7 Bit 7-0 R/W-0 X = Bit is unknown 92/142 FS98O25 Register I2CBUF at address 5AH property R/W-0 R/W-0 R/W-0 I2CBUF R/W-0 R/W-0 R/W-0 R/W-0 I2CBUF [7:0] Bit7 Bit0 I2CBUF[7:0]: I2C module Data buffer register. property F P r R ro SC ef pe ’ er rti en es ce O nl y Bit 7-0 R/W-0 W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 93/142 FS98O25 Table 9-2 I2C register table Name 06H 07H 37H 57H 58H 59H 5AH INTF INTE PT2OCB I2CCON I2CSTA I2CADD I2CBUF Referenced Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Section 3/6/7/9/10/11 -I2CIF 3/6/7/9/10/11 GIE -I2CIE 9 PT2OC[4:3] 9 WCOL I2COV I2CEN CKP 9 DA P S 9 I2CADD [7:0] 9 I2CBUF [7:0] Bit 2 Bit 1 Bit 0 --- --- --- RW Value on Power on Reset 00000000 00000000 uuu11uuu 0001uuuu uu0000u0 00000000 00000000 BF y Address 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. F P r R ro SC ef pe ’ er rti en es ce O nl I2C data receive operation: (master to slave) Configure SCL and SDA pins as open-drain through the PTOCB[4:3] Set I2CEN register flag to enable the I2C module. Clear I2CIF to reset the I2C interrupt. Set I2CIE and GIE to enable the I2C interrupt. Wait for the interrupt. When the I2C master device sends data to slave side, the data (ID) transmitted from the master device will be sent to I2CBUF, and the BF register flag will be set. If the RW register flag is clear,(low) the I2C module will enter the receive mode. The acknowledgement signal will be sent automatically and an interrupt will occur. Clear the I2CIF and reset the interrupt to wait for the interrupt happened again. When an interrupt occurs, read the I2CBUF for receiving the data transmitted from master side. The acknowledgement signal will be sent automatically. If the user doesn‟t read the data from I2CBUF, the BF register flag will be held high. When the data is sent to slave again, the I2COV register flag will be set, and the interrupt will NOT happen. __ R/W = 0 Receiving Address SDA SCL S A7 A6 A5 A4 A3 A2 A1 1 2 3 4 5 6 7 8 ____ ACK 9 Receiving Data ____ ACK Receiving Data D7 D6 D5 D4 D3 D2 D1 D0 ____ ACK D7 D6 D5 D4 D3 D2 D1 D0 1 2 3 4 5 6 7 8 9 1 2 3 4 5 6 7 8 I2CIF (INTF) 9 P Bus Master terminates transfer Cleared in software BF (I2CSTA) I2CBUF is read I2COV (I2CCON) I2C Waveforms for Reception I2COV is set Because ____ I2CBUF is still full. ACK is not sent. Fo Figure 9-3 I2C waveform for reception Rev. 1.5 94/142 FS98O25 I2C data transmit operation: (slave to master) 1. 2. 3. 4. 5. 6. Configure SCL and SDA pins as open-drain through the PTOCB[4:3]. Set I2CEN register flag to enable the I2C module. Clear I2CIF to reset the I2C interrupt. Set I2CIE and GIE to enable the I2C interrupt. Wait for the interrupt. When the I2C master device sends data to slave side, the data (ID) transmitted from the master device will be sent to I2CBUF, and the BF register flag will be set. If the RW register flag is set,(high) the I2C module will enter the transmit mode. The acknowledgement signal will be sent automatically and the interrupt will happen. Set the CKP register flag to hold the SCK to low, and then write the data, which is ready to send to master side, to I2CBUF. Clear the I2CIF and reset the interrupt to wait for the interrupt to happen again. Clear the CKP register flag to enable the SCK pin. The master side will start to get the data. When interrupt happen, the master side has already finished the transmission, the acknowledgement has been sent back to salve side, and the BF register flag has been clear. 10. 11. 12. F P r R ro SC ef pe ’ er rti en es ce O nl y 7. 8. 9. __ R/W = 1 Receiving Address SDA SCL S A7 A6 A5 A4 A3 A2 A1 1 2 3 4 5 6 7 8 ____ ACK Transmitting Data ____ ACK 9 D7 D6 D5 D4 D3 D2 D1 D0 1 2 3 4 5 6 7 8 SCL held low while CPU responds to I2CIF Data in sampled 9 P I2CIF (INTF) BF (I2CSTA) Cleared in software I2CBUF is written in software } From I2CIF interrupt service routine I2COV (I2CCON) I2CBUF is read Fo I2C Waveforms for Transmission Figure 9-4 I2C waveforms for transmission Rev. 1.5 95/142 FS98O25 10. Analog Function Network Please see Figure 10-1. FS98O25 Analog Function Network has 2 main functions: Low Noise OP Amplifier (OPAMP) and Sigma Delta Analog to Digital Converter (ADC). OPAMP is used to amplify the input analog signal for ADC. ADC is used to convert the analog signal to digital signal. The OPAMP has 2 input ports as inverting side and non-inverting side. Users could setup SOP1P[2:0] and SOP1N[1:0] to choose the input signals. S_CH1CK[1:0] and OP1EN register flags are used to control OPAMP and OP1O is the OPAMP output port. The detailed operations will be described in Section 10.2. Fo F P r R ro SC ef pe ’ er rti en es ce O nl y The embedded ADC contains sigma delta modulator and digital comb filter. It is a fully differential input system. User could give 2 signals for differential reference and 2 signals for differential input. ADC will convert the ratio of differential input to differential reference to 14-bit digital output. The related control instructions will be illustrated in Section 10.1. Figure 10-1 FS98O25 analog function network Rev. 1.5 96/142 FS98O25 Table 10-1 analog function network register table Value on Power on Reset 00000000 00000000 00000000 00000000 00000000 uuuu0000 00000000 00000000 00000000 00000000 00000000 Fo F P r R ro SC ef pe ’ er rti en es ce O nl 06H 07H 10H 11H 12H 13H 15H 18H 19H 1AH 1BH Referenced Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Section INTF 3/6/7/9/10/11 --ADIF --INTE 3/6/7/9/10/11 GIE --ADIE --ADOH 10/11 ADO [15:8] ADOL 10/11 ADO [7:0] ADOLL 10/11 Extra ADC output register ADCON 10/11 ADRST ADM [2:0] PCK 4/5/7.5/10 -S_CH1CK [1:0] --NETA 10/11 SINL[1:0] SINH[2:0] SFTA[2:0] NETB 10/11 SOP2N[1:0] SOP1N[1:0] SVRL[1:0] SVRH[1:0] NETC 10/11 SREFO ADG[1:0] ADEN AZ NETD 10/11 OP2EN SOP2P[2:0] OP1EN SOP1P[2:0] Name y Address Rev. 1.5 97/142 FS98O25 Register ADOH at address 10H Property R-0 R-0 R-0 R-0 ADOH R-0 R-0 R-0 R-0 ADO [15:8] Bit7 Bit0 Register ADOL at address 11H R-0 R-0 R-0 R-0 R-0 R-0 ADO [7:0] Bit7 Bit 15-0 R-0 F P r R ro SC ef pe ’ er rti en es ce O nl ADOL R-0 y property Bit0 ADO [15:0]: ADC Digital Output ADO[15] = ADC Digital Output sign bit. 0 = Output is positive; 1 = Output is negative. ADO[14] = ADC Digital Output sign bit. 0 = Output is positive; 1 = Output is negative. ADO[13] = ADC Digital Output Data bit 13. ADO[12] = ADC Digital Output Data bit 12. ADO[11] = ADC Digital Output Data bit 11. ADO[10] = ADC Digital Output Data bit 10. ADO[9] = ADC Digital Output Data bit 9. ADO[8] = ADC Digital Output Data bit 8. ADO[7] = ADC Digital Output Data bit 7. ADO[6] = ADC Digital Output Data bit 6. ADO[5] = ADC Digital Output Data bit 5. ADO[4] = ADC Digital Output Data bit 4. ADO[3] = ADC Digital Output Data bit 3. ADO[2] = ADC Digital Output Data bit 2. ADO[1] = ADC Digital Output Data bit 1. ADO[0] = ADC Digital Output Data bit 0. property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared Fo R = Readable bit Rev. 1.5 X = Bit is unknown 98/142 FS98O25 Register ADOLL at address 12H property R-0 R-0 R-0 ADOLL R-0 R-0 R-0 R-0 R-0 Extra ADC output register Bit7 Bit0 Users could take the value of 3 registers, ADOH, ADOL and ADOLL as 24 bits ADC output. U-X U-X U-X U-X R/W-0 R/W-0 R/W-0 ADCON ADRST ADM [2:0] Bit7 Bit 3 R/W-0 F P r R ro SC ef pe ’ er rti en es ce O nl property y Register ADCON at address 13H Bit0 ADRST: ADC comb filter enable register (Please refer to Section 10.1 for detail) 1 = ADC comb filter is enabled, ADC could work correctly. 0 = ADC comb filter is disabled, ADC digital output will be zero. Bit 2-0 ADM [2:0]: ADC output rate selector 111 = ADC output rate is ADCF/8000 24 110 = ADC output rate is ADCF/8000 101 = ADC output rate is ADCF/4000 100 = ADC output rate is ADCF/2000 011 = ADC output rate is ADCF/1000 010 = ADC output rate is ADCF/500 001 = ADC output rate is ADCF/250 000 = ADC output rate is ADCF/125 property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit 24 Please refer to Section 5.3 for ADCF information. Rev. 1.5 99/142 FS98O25 Register PCK at address 15H property U-0 PCK U-0 U-0 -- U-0 R/W-0 R/W-0 S_CH1CK [1:0] U-0 U-0 -- -- Bit7 Bit 3-2 Bit0 S_CH1CK [1:0]: OPAMP Control Register (Please refer to Section 10.2) 10 = The OPAMP Chopper mode is enabled, and the Chopper frequency is CLK/500 y 11 = The OPAMP Chopper mode is enabled, and the Chopper frequency is CLK/1000 F P r R ro SC ef pe ’ er rti en es ce O nl 01 = The OPAMP Chopper mode is disabled. OPAMP input operation mode is set to be “-Offset”. 00 = The OPAMP Chopper mode is disabled. OPAMP input operation mode is set to be “+Offset”. property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 100/142 FS98O25 Register NETA at address 18H property R/W-0 NETA R/W-0 R/W-0 SINL[1:0] R/W-0 R/W-0 R/W-0 SINH[2:0] R/W-0 R/W-0 SFTA[2:0] Bit7 Bit 7-6 Bit0 SINL[1:0]: ADC negative input port signal multiplexer (Please refer to Section 10.1) y 11 = The ADC negative input port is connected to TEMPL. (Please refer to Section 4.6) 10 = The ADC negative input port is connected to AIN3 (PT1[3]). F P r R ro SC ef pe ’ er rti en es ce O nl 01 = The ADC negative input port is connected to AIN2 (PT1[2]). 00 = The ADC negative input port is connected to AIN1 (PT1[1]). Bit 5-3 10.1) SINH[2:0]: Embedded ADC Low Pass Filter input port signal multiplexer (Please refer to Section 111 = The ADC Low Pass Filter input port is connected to OP2P. (Please refer to Section 4.4) 110 = The ADC Low Pass Filter input port is connected to OP2O (PT1[4]). 101 = The ADC Low Pass Filter input port is connected to AIN5 (PT1[5]). 100 = The ADC Low Pass Filter input port is connected to TEMPH. (Please refer to Section 4.6) input). input). 011 = The ADC Low Pass Filter input port is connected to VRL (ADC referenced voltage negative 010 = The ADC Low Pass Filter input port is connected to VRH (ADC referenced voltage positive 001 = The ADC Low Pass Filter input port is connected to OP1P (OPAMP non-inverting input port). 000 = The ADC Low Pass Filter input port is connected to OP1O (OPAMP output port). Bit 2 SFTA [2]: FTIN and FTB connector ( ADC Low Pass Filter enable flag) 1 = FTIN and FTB is short. ADC Low Pass Filter is enabled. 0 = FTIN and FTB is open. ADC Low Pass Filter is disabled. Bit 1-0 SFTA [1:0]: ADC positive input port signal multiplexer (Please refer to Section 10.1) 11 = The ADC positive input port is connected to AIN3 (PT1[3]). 10 = The ADC positive input port is connected to AIN2 (PT1[2]). 01 = The ADC positive input port is connected to FTIN (SINH[2:0] multiplexer output port). 00 = The ADC positive input port is connected to FTB (FTIN output signal after Low Pass filter). property W = Writable bit Fo R = Readable bit - n = Value at Power On Reset Rev. 1.5 „1‟ = Bit is Set U = unimplemented bit „0‟ = Bit is Cleared X = Bit is unknown 101/142 FS98O25 Register NETB at address 19H property R/W-0 R/W-0 SOP2N[1:0] NETB R/W-0 R/W-0 SOP1N[1:0] R/W-0 R/W-0 R/W-0 SVRL[1:0] SVRH[1:0] Bit7 Bit 7-6 R/W-0 Bit0 SOP2N: OPAMP inverting input port signal multiplexer (Please refer to Section 10.2) y 00 = The OPAMP inverting input port is connected to OP2O (OPAMP output port). 01 = The OPAMP inverting input port is connected to AIN7 (PT1[7]). F P r R ro SC ef pe ’ er rti en es ce O nl 10 = Not available 11 = Not available Bit 5-4 SOP1N[1:0]: OPAMP inverting input port signal multiplexer (Please refer to Section 10.2) 11 = The OPAMP inverting input port is connected to AIN3 (PT1[3]). 10 = The OPAMP inverting input port is connected to AIN5 (PT1[5]). 01 = The OPAMP inverting input port is connected to AIN4 (PT1[4]). 00 = The OPAMP inverting input port is connected to OP1O (OPAMP output port). Bit 3-2 10.1) SVRL[1:0]: ADC reference voltage negative input port signal multiplexer (Please refer to Section 25 11 = The ADC negative referenced input port is connected to VR2P (1/5 REFO ). 10 = The ADC negative referenced input port is connected to AIN2 (PT1[2]). 01 = The ADC negative referenced input port is connected to AIN1 (PT1[1]). 00 = The ADC negative referenced input port is connected to AGND (Please refer to Section 4.4). Bit 1-0 10.1) SVRH[1:0]: ADC reference voltage positive input port signal multiplexer (Please refer to Section 11 = The ADC negative referenced input port is connected to VR2P (1/5 REFO). 10 = The ADC negative referenced input port is connected to VR1P (2/5 REFO). 01 = The ADC negative referenced input port is connected to AIN3 (PT1[3]). 00 = The ADC negative referenced input port is connected to AIN0 (PT1[0]). property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit 25 Please refer to Section 4.6 for REFO detailed information Rev. 1.5 102/142 FS98O25 Register NETC at address 1AH property R/W-0 NETC SREFO U-0 U-0 U-0 R/W-0 R/W-0 ADG[1:0] R/W-0 R/W-0 ADEN AZ Bit7 SREFO: Internal Reference Voltage enable flag. (Please refer to Section 10.1) 1 = Internal Reference Voltage is enabled. VR1P = 2/5 REFO, VR2P = 1/5 REFO 0 = Internal Reference Voltage is disabled. VR1P and VR2P are floating. ADG[1:0]: Internal ADC input gain. (Please refer to Section 10.1) F P r R ro SC ef pe ’ er rti en es ce O nl Bit 3-2 y Bit 7 Bit0 11 = Internal ADC input gain is 7/3 10 = Internal ADC input gain is 2 01 = Internal ADC input gain is 1 00 = Internal ADC input gain is 2/3 Bit 1 ADEN: ADC enable flag. (Please refer to Section 10.1) 1 = ADC is enabled. 0 = ADC is disabled. Bit 0 AZ: ADC differential input ports short controller. (Please refer to Section 10.1) 1 = ADC differential input ports are short and both connect to INL 26 (SINL output). 0 = ADC differential input ports are NOT short. The 2 ports connect to INH and INL. property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit 26 That means the ADC input differential voltage is zero. ADC output should be zero counts. User could measure ADC offset counts when the AZ register flag is set. Rev. 1.5 103/142 FS98O25 Register NETD at address 1BH property R/W-0 NETD OP2EN R/W-0 R/W-0 SOP2P[2:0] R/W-0 R/W-0 R/W-0 OP1EN Bit7 Bit 7 R/W-0 R/W-0 SOP1P[2:0] Bit0 OP2EN: OPAMP enable flag. (Please refer to Section 10.2) 1 = OPAMP2 is enabled. Bit 6-4 y 0 = OPAMP2 is disabled. SOP2P[2:0]: OPAMP non-inverting input port signal multiplexer (Please refer to Section 10.2) F P r R ro SC ef pe ’ er rti en es ce O nl 111 = Not available 110 = Not available 101 = Not available 100 = Not available 011 = The OPAMP non-inverting input port is connected to AIN7 (PT1[7]). 010 = The OPAMP non-inverting input port is connected to AIN6 (PT1[6]). 001 = The OPAMP non-inverting input port is connected to AIN5 (PT1[5]). 000 = The OPAMP non-inverting input port is connected to AIN4 (PT1[4]). Bit 3 OP1EN: OPAMP enable flag. (Please refer to Section 10.2) 1 = OPAMP is enabled. 0 = OPAMP is disabled. Bit 2-0 SOP1P[2:0]: OPAMP non-inverting input port signal multiplexer (Please refer to Section 10.2) 111 = The OPAMP non-inverting input port is connected to AIN7 (PT1[7]) 110 = The OPAMP non-inverting input port is connected to AIN6 (PT1[6]) 101 = The OPAMP non-inverting input port is connected to AIN5 (PT1[5]). 100 = The OPAMP non-inverting input port is connected to AIN4 (PT1[4]). 011 = The OPAMP non-inverting input port is connected to AIN3 (PT1[3]). 010 = The OPAMP non-inverting input port is connected to AIN2 (PT1[2]). 001 = The OPAMP non-inverting input port is connected to AIN1 (PT1[1]). Fo 000 = The OPAMP non-inverting input port is connected to AIN0 (PT1[0]). Rev. 1.5 104/142 FS98O25 Analog to Digital Converter (ADC) : F P r R ro SC ef pe ’ er rti en es ce O nl y Please see Figure 10-2. ADC Module contains 3 main functions – Low Pass Filter, Sigma Delta Modulator and Comb Filter. Before doing the AD conversion, User could reduce the low frequency noise by the embedded Low Pass Filter. The SINH[2:0] register flags are used to choose the input signal. SFTA[2] flag is used to enable the Filter. Sigma Delta Modulator and Comb Filter are used to complete the AD Converter. First of all the Modulator will output serial bits to show the ratio of the difference between INH and INL to the difference between VRH and VRL. For example, if the ratio of VRH and VRL to INH and INL is 7/10, the output bit series will be 7 „bit1‟ every 10 bits in average. Comb Filter is used to increase the SNR(signal-noise ratio) and the real ADC output, ADO, will be 14-bit precision in FS98O25. Fo Figure 10-2 FS98O25 ADC function block Rev. 1.5 105/142 FS98O25 Table 10-2 ADC function register table Name 06H 07H 10H 11H 13H 14H 18H 19H 1AH INTF INTE ADOH ADOL ADCON MCK NETA NETB NETC Referenced Bit 7 Bit 6 Section 3/6/7/9/10/11 3/6/7/9/10/11 GIE 10/11 10/11 10/11 5 --10/11 SINL[1:0] 10/11 -10/11 SREFO Bit 5 -- Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 --ADIF ----ADIE --ADO [15:8] ADO [7:0] ADRST ADM [2:0] ---M1_CK -SINH[2:0] SFTA[2:0] -SVRL[1:0] SVRH[1:0] ADG[1:0] ADEN AZ F P r R ro SC ef pe ’ er rti en es ce O nl ADC Operation 1. 2. 3. 4. Value on Power on Reset 00000000 00000000 00000000 00000000 uuuu0000 00000000 00000000 00000000 00000000 y Address Operate as in Section 4.1 to get the VGG (2 times VDD or external Power Supply). Operate as in Section 4.2 to get the VDDA (3.6V) Operate as in Section 4.3 to enable the Analog Bias Circuit Set SINH[2:0] and SFTA[2:0] to decide the ADC positive input port signal.(Table 10-3, 10-4 and 10-5) Table 10-3 FTIN selection table SINH[2:0] FTIN 000 OP1O 001 OP1P 010 VRH 011 VRL 100 TEMPH 101 AIN5 110 AIN4 111 AGND Table 10-4 FTB selection table 27 SFTA[2] FTB ADC Low Pass Filter is disabled 1 ADC Low Pass Filter is enabled Fo 0 27 The input of ADC Low Pass Filter is FTIN, and the output is FTB Rev. 1.5 106/142 FS98O25 5. SFTA[1:0] INH (ADC positive input port signal) 00 FTB 01 FTIN 10 AIN2 11 AIN3 Set SINL[1:0] to decide the ADC negative input port signal. (Table 10-6) 6. F P r R ro SC ef pe ’ er rti en es ce O nl Table 10-6 INL selection table y Table 10-5 INH selection table SINL[1:0] INL (ADC negative input port signal) 00 AIN1 01 AIN2 10 AIN3 11 TEMPL Set ADG[1:0] to decide the ADC input gain. (Table 10-7) Table 10-7 ADG selection table 7. 8. ADG[1:0] ADC input gain 00 2/3 01 1 10 2 11 7/3 Set SREFO register flag to enable the VR1P and VR2P if needed. (VR1P = 2/5 REFO, VR2P = 1/5 REFO) Set SVRH[1:0] to decide the ADC reference voltage positive input port signal. (Table 10-8) Table 10-8 VRH selection table VRH (ADC reference voltage positive input) 00 AIN0 01 AIN3 10 VR1P 11 VR2P Fo 9. SVRH[1:0] Set SVRL[1:0] to decide the ADC reference voltage negative input port signal. (Table 10-9) Rev. 1.5 107/142 FS98O25 10. SVRL[1:0] VRL (ADC reference voltage negative input) 00 AGND 01 AIN1 10 AIN2 11 VR2P Set ADM[2:0] to decide the ADC output rate. (Table 10-10 and 10-11) F P r R ro SC ef pe ’ er rti en es ce O nl Table 10-10 ADC output rate selection table y Table 10-9 SVRL selection table ADM[2:0] ADC Output Rate 000 ADCF/125 001 ADCF/250 010 ADCF/500 011 ADCF/1000 100 ADCF/2000 101 ADCF/4000 110 ADCF/8000 111 ADCF/8000 Table 10-11 ADC sample frequency selection table 16. ADC sample Frequency (ADCF) 0 MCK/25 1 MCK/50 Set ADIE and GIE register flags to enable the ADC interrupt Set ADEN register flag, the embedded - modulator will be enabled. Set ADRST register flag, the comb filter will be enabled. When the ADC interrupt happen, read the ADO[15:0] to get the ADC output.(ADO[15:14] are signed bits) Set AZ register flag to make the ADC positive and negative input port be internally short. Read the ADO[15:0] to get the ADC offset (The ADO should be zero if the offset is zero) Clear AZ register flag to make the ADC work normally. Fo 11. 12. 13. 14. 15. M1_CK Rev. 1.5 108/142 FS98O25 OPAMP : OP1 and OP2 Table 10-12 FS98O25 OPAMP register table Referenced Bit 7 Bit 6 Bit 5 Bit 4 Section PCK 4/5/7.5/10 -S_CH2CK [1:0] NETB 10/11 SOP2N[1:0] SOP1N[1:0] NETD 10/11 OP2EN SOP2P[2:0] Address Name 15H 19H 1BH Bit 3 Bit 2 Bit 1 Bit 0 S_CH1CK [1:0] ----OP1EN SOP1P[2:0] Value on Power on Reset 00000000 00000000 00000000 OPAMP1 Operation Set SOP1P[2:0] to decide the OPAMP non-inverting input port signal. (Table 10-13) 2. F P r R ro SC ef pe ’ er rti en es ce O nl Table 10-13 SOP1P selection table y 1. SOP1P[2:0] OP1P (OPAMP non-inverting input) 000 AIN0 001 AIN1 010 AIN2 011 AIN3 100 AIN4 101 AIN5 110 AIN6 111 AIN7 Set SOP1N[1:0] to decide the OPAMP inverting input port signal. (Table 10-14) Table 10-14 SOP1N selection table OP1N (OPAMP inverting input) 00 OP1O 01 AIN4 10 AIN5 11 AIN6 Fo 3. SOP1N[1:0] Set S_CH1CK[1:0] to decide the OPAMP chopper mode.(Please see Section 3.6 for details) Rev. 1.5 109/142 FS98O25 Table 10-15 chopper mode selection table 00 +Offset 01 -Offset 10 CLK/500 chopper frequency 11 CLK/1000 chopper frequency y OPAMP chopper mode (input operation) Set OP1EN to enable the OPAMP. F P r R ro SC ef pe ’ er rti en es ce O nl 4. S_CH1CK[1:0] Table 10-16 FS98O25 OPAMP register table Address 15H 19H 1BH Referenced Value on Power on Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Section Reset PCK 4/5/7.5/10 -S_CH2CK [1:0] S_CH1CK [1:0] --00000000 NETB 10/11 SOP2N[1:0] SOP1N[1:0] --00000000 NETD 10/11 OP2EN SOP2P[2:0] OP1EN SOP1P[2:0] 00000000 Name OPAMP2 Operation 1. Set SOP2P[2:0] to decide the OPAMP non-inverting input port signal. (Table 10-16) Table 10-17 SOP2P selection table OP2P (OPAMP non-inverting input) 000 AIN4 001 AIN5 010 AIN6 011 AIN7 100 Not available 101 Not available 110 Not available 111 Not available Fo 2. SOP2P[2:0] Set SOP2N[1:0] to decide the OPAMP inverting input port signal. (Table 10-17) Rev. 1.5 110/142 FS98O25 OP2N (OPAMP inverting input) 00 OP2O 01 AIN7 10 Not available 11 Not available Set S_CH2CK[1:0] to decide the OPAMP chopper mode.(Please see Section 3.6 for details) F P r R ro SC ef pe ’ er rti en es ce O nl 3. SOP2N[1:0] y Table 10-18 SOP2N selection table Table 10-19 chopper mode selection table OPAMP chopper mode (input operation) 00 +Offset 01 -Offset 10 CLK/500 chopper frequency 11 CLK/1000 chopper frequency Set OP2EN to enable the OPAMP. Fo 4. S_CH2CK[1:0] Rev. 1.5 111/142 FS98O25 11. ADC Application Guide The ADC used in FS98O25 is a - ADC with fully differential inputs and fully differential reference voltage inputs. Its maximum output is 15625. The conversion equation is as follows: Dout  15625 * G * y       G is ADC input gain. (refer to Section 10.1 ADC operation step 6) VIH is ADC’s positive input voltage VIL is ADC’s negative input voltage Vio is ADC’s offset on the input terminals (Vio could be measured by using AZ register flag. See Section 11.4) VRH is the voltage at the positive input of Reference Voltage VRL is the voltage at the negative input of Reference Voltage Vro is the offset on the input terminals of Reference Voltage (Generally speaking, Vro could be ignored) The value (VRH-VRL+Vro) should be positive. When G * (VIH-VIL+Vio) / (VRH-VRL+Vro)  1, Dout=15625 When G * (VIH-VIL+Vio) / (VRH-VRL+Vro)  -1, Dout=-15625 F P r R ro SC ef pe ’ er rti en es ce O nl     VIH - VIL  Vio VRH - VRL  Vro ADC Output Format CPU can read ADO[14:0] as ADC‟s 15-bit output. Note that the output is in 2‟s complement format. The 14th bit of ADO[14:0] is sign bit. When the sign bit is cleared, the ADC output denotes a positive number, When the sign bit is set, the ADC output denotes a negative number. Example: ADO[15:0] = 0X257FH, then Dout = 9599. ADO[15:0] = 0XE2F7H, then Dout = - (not (E2F7H) +1) = -7433. ADC Linear Range ADC is close to saturation when G * (VIH-VIL+Vio) / (VRH-VRL+Vro) is close to 1, and has good linearity in the range of 0.95. ADC Output Rate and Settling Time ADC output is the results of sigma delta modulator and the comb filter. The analog input signal needs to be 28 sampled N times and processed by the ADC and then the user could get one digital output. Generally speaking, the more times ADC samples the analog input signal, the more precise the digital output is. When the user decides the sampling frequency and sampling counts, and then enables the ADC module, ADC module will send out a 15-bit signed digital output data every sampling N times and trigger the ADC interrupt. In fact, every ADC output includes previous 2*N times sampling results. Generally speaking, if ADC inputs, reference voltage, ADG, AZ are switched, the previous two ADC digital outputs are normally unstable ones, the third output and beyond are stable. Fo ADC Input Offset ADC Input Offset Vio is NOT a constant. It drifts with temperature and common mode voltage at the inputs. To get a correct ADC result, Doff(ADC input offset digital output) should be deducted from the Dout. The instruction is as follows: 28 „N times‟ could be decided by setting ADM register flag (Please refer to Section 10.1). FS98O25 ADC sampling frequency is decided by M1_CK( Please refer to Section 5.3). Rev. 1.5 112/142 FS98O25 1. 2. 3. 4. Set AZ bit, and VIH and VIL will short. Dout will be 15625 *G * (Vio) / (VRH-VRL+Vro). It‟s called Doff. Save Doff in memory, and then Clear AZ bit to restart the ADC module. Pass the first 2 ADC interrupts for ignoring the unstable ADC result. When measuring analog signal, Doff should be deducted. ADC Digital Output The ADC digital output deducted by Doff is ADC Gain. The ADC Gain doesn‟t change as VDD changes. The suggested values for common mode voltages at ADC input and reference voltage are 1V~2V. y ADC input gain could be set by ADG[1:0] register flag. Please see Section 10.1 for detail. ADC Resolution  F P r R ro SC ef pe ’ er rti en es ce O nl ADC resolution is mainly affected by the ADC sampling counts and the ADC reference voltage. Generally speaking, the more times ADC samples the analog input signal, the more precise the digital output is. The ADC sampling counts could be decided by ADM[2:0] register flag. The ADC digital output rolling counts versus ADM[2:0] and Reference voltage table are shown as follows: (VRH, VRL) =0.4V, (VIH, VIL) =0.2V, VRL=VIL=AGND. G=1 Table 11-1 ADC rolling counts versus ADM  ADM 000 001 010 011 100 101 110 Rolling counts 10 6 4 3 3 2 1 (VRH, VRL) =VR, (VIH, VIL) =1/2 VR, VRL=VIL=AGND. G=1 ADM=101 Table 11-2 ADC rolling counts versus VR VR 0.1 0.2 0.3 0.4 0.6 0.8 1.0 31 15 5 3 2 2 4 9 Fo Rolling counts 0.05 Rev. 1.5 113/142 FS98O25 12. Low Noise Operation Amplifier Guide The input noise of CMOS OPAMP is generally much larger than the one of a Bipolar OPAMP. Moreover, the flick noise (1/f noise) of CMOS is a killer for low frequency small signal measurement. But the need for input bias current in Bipolar OPAMP causes that some transducers can not be used. In general, bipolar process is not good for highly integrated ICs. FS98O25 use special CMOS low noise circuit design, and under normal conditions, the input noise is controlled under 1μVpp (0.1Hz~1Hz). FS98O25 is good for transducer applications because there is no need to consider input bias current. Most of the input noise in CMOS OPAMP comes from input differential amplification. S_CHCK can be set to switch the differential amplification: 00 for positive Offset Voltage, 01 for negative Offset voltage. When using one clock pulse to switch input differential amplification, that is called chopper mode. In general, chopper frequency is set between 1 kHz and 2 KHz. F P r R ro SC ef pe ’ er rti en es ce O nl y Under chopper mode, the input noise peak-to-peak voltage in FS98O25 is less than 0.5μV (0.1Hz~1Hz). But an equivalent input current of less than 100pA is generated, due to the effect of switching. Single End Amplifier Application Measurement of small signal usually takes consideration of the drifting of an OPAMP offset voltage. In the Figure below, the negative input is connected to AGND. It is also possible to measure the ADC‟s negative input and deduct this value; in order to correct the error caused by the Amplifier‟s offset voltage drifting. Because AGND provides current output in applications, AIN1 is used as negative input measurement point to avoid unnecessary voltage error. OPAMP input offset is amplified by an amplifier then inputted to ADC. Too much amplification can cause OPAMP output move beyond ADC linear operation range. Hence, under normal conditions, OPAMP amplification should be less than 50 times. Please see Figure 12-1 for example. Fo Figure 12-1 single end amplifier application example Rev. 1.5 114/142 FS98O25 Differential Amplifier Measurement of differential signal is often used in bridge sensor applications. As shown in the differential amplifier below, VS Pin is used as power input for bridge sensor, ADC reference voltage is also from VS Pin after voltage division. When there is a small change in VS, ADC output does not change. Connecting AIN2 to ADC negative input can adjust the zero point of bridge sensor. When starting chopper mode, the amplification should be less than 100 times. F P r R ro SC ef pe ’ er rti en es ce O nl y Please see Figure 12-2 for example. Fo Figure 12-2 differential amplifier example Rev. 1.5 115/142 FS98O25 13. LCD Driver FS98O25 embeds a LCD driver. The control signal are COM1~COM4 and SEG1~SEG32. The user could set the SEG register flags to drive a static or multiplexed LCD panel. FS98O25 LCD driver could drive up to 32 segments multiplexed with up to 4 commons. Please see Figure 13-1. COM1~COM4 y 4x32 LCD F P r R ro SC ef pe ’ er rti en es ce O nl FS98O25 SEG1 ~ SEG32 Figure 13-1 LCD driver control block Fo FS98O25 LCD driver has 4 kinds of control mode: static, 1/2 duty, 1/3 duty and 1/4 duty. The control mode depends on the LCD panel The user could setup LCD_DUTY[1:0] register flags to choose one. Take a 1/4 duty control mode number LCD for example, if the user wants to show number 9 in LCD, the SEG 1 includes 4 commons as [1,0,1,1] and the SEG2 include 4 commons as [1,1,1,1]. Please see Figure 13-2. Static mode Rev. 1.5 1/2 duty mode 1/3 duty mode 1/4 duty mode Figure 13-2 LCD control mode 116/142 FS98O25 The LCD frame frequency could be setup by setting the LCDCKS[1:0] register flags. FS98O25 divides the LCD Module input clock to get LCDCK. (Please see Table 13-1 and Table 13-2) Table 13-1 LCD frame frequency selection table LCD frame frequency (LCDCK) LCD Input clock Frequency/8 01 LCD Input clock Frequency/16 10 LCD Input clock Frequency/32 11 LCD Input clock Frequency/64 F P r R ro SC ef pe ’ er rti en es ce O nl 00 y LCDCKS [1:0] Table 13-2 LCD duty selection table LCD_DUTY [1:0] Control mode SEG 2, SEG 4, --- SEG 32 SEG 1, SEG 3, --- SEG 31 bit7 bit6 bit5 bit4 bit3 bit2 - - COM2 COM1 - - COM3 COM2 COM1 - 00 static - - 01 1/2 - - 10 1/3 - 11 1/4 COM4 bit1 bit0 COM2 COM1 COM3 COM2 COM1 Fo COM3 COM2 COM1 COM4 COM3 COM2 COM1 Rev. 1.5 117/142 FS98O25 LCDCK COM1 1/4 duty COM2 COM3 COM4 COM1 COM2 y 1/3 duty COM3 F P r R ro SC ef pe ’ er rti en es ce O nl COM4 COM1 1/2 duty COM2 COM3 COM4 COM1 static COM2 COM3 COM4 Fo Figure 13-3 LCD duty mode working cycle Rev. 1.5 118/142 FS98O25 FS98O25 LCD driver has 3 voltage bias ports, such as V1, V2 and V3, and 2 kinds of power mode: 1/3 bias and 1/2 bias. Please see the following description to setup the LCD power system. 1/3 bias power system (Please see Figure 13-4 and 13-5) F P r R ro SC ef pe ’ er rti en es ce O nl y  Figure 13-4 1/3 bias LCD power system circuit connection example 1/4 duty, 1/3 bias 1/3duty, 1/3bias Fo Figure 13-5 1/3 bias LCD power system clock Rev. 1.5 119/142 FS98O25 1/2 bias power system (Please see Figure 13-6 and 13-17) F P r R ro SC ef pe ’ er rti en es ce O nl Figure 13-6 1/2 bias LCD power system circuit connection example y  1/4 duty, 1/2 bias 1/3duty, 1/2bias Fo Figure 13-7 1/2 bias LCD power system clock Rev. 1.5 120/142 FS98O25 Table 13-3 FS98O25 LCD driver register table Bit 7 Bit 6 Bit 5 Bit 4 SEG2 [3:0] SEG4 [3:0] SEG6 [3:0] SEG8 [3:0] SEG10 [3:0] SEG12 [3:0] SEG14 [3:0] SEG16 [3:0] SEG18 [3:0] SEG20 [3:0] LCDCKS [1:0] LCDEN Value on Power on Reset SEG1 [3:0] uuuuuuuu SEG3 [3:0] uuuuuuuu SEG5 [3:0] uuuuuuuu SEG7 [3:0] uuuuuuuu SEG9 [3:0] uuuuuuuu SEG11 [3:0] uuuuuuuu SEG13 [3:0] uuuuuuuu SEG15 [3:0] uuuuuuuu SEG17 [3:0] uuuuuuuu SEG19 [3:0] uuuuuuuu LEVEL LCD_DUTY[1:0] ENPMPL 00000000 Bit 3 Bit 2 Bit 1 Bit 0 y 40H 41H 42H 43H 44H 45H 46H 47H 48H 49H 54H Referenced Section LCD1 13 LCD2 13 LCD3 13 LCD4 13 LCD5 13 LCD6 13 LCD7 13 LCD8 13 LCD9 13 LCD10 13 LCDENR 13 Name F P r R ro SC ef pe ’ er rti en es ce O nl Address Register LCD1 at address 40H property LCD1 R/W-X R/W-X R/W-X R/W-X R/W-X R/W-X SEG2 [3:0] R/W-X SEG1 [3:0] Bit7 Bit 7-4 R/W-X Bit0 SEG2[3]: LCD driver control signal: SEG2 with COM4 data. SEG2[2]: LCD driver control signal: SEG2 with COM3 data. SEG2[1]: LCD driver control signal: SEG2 with COM2 data. SEG2[0]: LCD driver control signal: SEG2 with COM1 data. Bit 3-0 SEG1[3]: LCD driver control signal: SEG1 with COM4 data. SEG1[2]: LCD driver control signal: SEG1 with COM3 data. SEG1[1]: LCD driver control signal: SEG1 with COM2 data. SEG1[0]: LCD driver control signal: SEG1 with COM1 data. property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 121/142 FS98O25 Register LCD2 at address 41H property R/W-X R/W-X LCD2 R/W-X R/W-X R/W-X R/W-X SEG4 [3:0] R/W-X SEG3 [3:0] Bit7 Bit 7-4 R/W-X Bit0 SEG4[3]: LCD driver control signal: SEG4 with COM4 data. y SEG4[2]: LCD driver control signal: SEG4 with COM3 data. SEG4[1]: LCD driver control signal: SEG4 with COM2 data. Bit 3-0 F P r R ro SC ef pe ’ er rti en es ce O nl SEG4[0]: LCD driver control signal: SEG4 with COM1 data. SEG3[3]: LCD driver control signal: SEG3 with COM4 data. SEG3[2]: LCD driver control signal: SEG3 with COM3 data. SEG3[1]: LCD driver control signal: SEG3 with COM2 data. SEG3[0]: LCD driver control signal: SEG3 with COM1 data. Register LCD3 at address 42H property LCD3 R/W-X R/W-X R/W-X R/W-X R/W-X R/W-X SEG6 [3:0] R/W-X SEG5 [3:0] Bit7 Bit 7-4 R/W-X Bit0 SEG6[3]: LCD driver control signal: SEG6 with COM4 data. SEG6[2]: LCD driver control signal: SEG6 with COM3 data. SEG6[1]: LCD driver control signal: SEG6 with COM2 data. SEG6[0]: LCD driver control signal: SEG6 with COM1 data. Bit 3-0 SEG5[3]: LCD driver control signal: SEG5 with COM4 data. SEG5[2]: LCD driver control signal: SEG5 with COM3 data. SEG5[1]: LCD driver control signal: SEG5 with COM2 data. SEG5[0]: LCD driver control signal: SEG5 with COM1 data. property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared Fo R = Readable bit Rev. 1.5 X = Bit is unknown 122/142 FS98O25 Register LCD4 at address 43H property R/W-X R/W-X LCD4 R/W-X R/W-X R/W-X SEG8 [3:0] R/W-X R/W-X SEG7 [3:0] Bit7 Bit 7-4 Bit0 SEG8[3]: LCD driver control signal: SEG8 with COM4 data. y SEG8[2]: LCD driver control signal: SEG8 with COM3 data. SEG8[1]: LCD driver control signal: SEG8 with COM2 data. F P r R ro SC ef pe ’ er rti en es ce O nl SEG8[0]: LCD driver control signal: SEG8 with COM1 data. Bit 3-0 R/W-X SEG7[3]: LCD driver control signal: SEG7 with COM4 data. SEG7[2]: LCD driver control signal: SEG7 with COM3 data. SEG7[1]: LCD driver control signal: SEG7 with COM2 data. SEG7[0]: LCD driver control signal: SEG7 with COM1 data. Register LCD5 at address 44H property LCD5 R/W-X R/W-X R/W-X R/W-X R/W-X SEG10 [3:0] R/W-X R/W-X SEG9 [3:0] Bit7 Bit 7-4 R/W-X Bit0 SEG10[3]: LCD driver control signal: SEG10 with COM4 data. SEG10[2]: LCD driver control signal: SEG10 with COM3 data. SEG10[1]: LCD driver control signal: SEG10 with COM2 data. SEG10[0]: LCD driver control signal: SEG10 with COM1 data. Bit 3-0 SEG9[3]: LCD driver control signal: SEG9 with COM4 data. SEG9[2]: LCD driver control signal: SEG9 with COM3 data. SEG9[1]: LCD driver control signal: SEG9 with COM2 data. SEG9[0]: LCD driver control signal: SEG9 with COM1 data. property W = Writable bit Fo R = Readable bit - n = Value at Power On Reset Rev. 1.5 „1‟ = Bit is Set U = unimplemented bit „0‟ = Bit is Cleared X = Bit is unknown 123/142 FS98O25 Register LCD6 at address 45H property R/W-X R/W-X LCD6 R/W-X R/W-X R/W-X R/W-X SEG12 [3:0] R/W-X SEG11 [3:0] Bit7 Bit0 SEG12[3]: LCD driver control signal: SEG12 with COM4 data. SEG12[2]: LCD driver control signal: SEG12 with COM3 data. F P r R ro SC ef pe ’ er rti en es ce O nl SEG12[1]: LCD driver control signal: SEG12 with COM2 data. y Bit 7-4 R/W-X SEG12[0]: LCD driver control signal: SEG12 with COM1 data. Bit 3-0 SEG11[3]: LCD driver control signal: SEG11 with COM4 data. SEG11[2]: LCD driver control signal: SEG11 with COM3 data. SEG11[1]: LCD driver control signal: SEG11 with COM2 data. SEG11[0]: LCD driver control signal: SEG11 with COM1 data. property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 124/142 FS98O25 Register LCDENR at address 54H property LCDENR R/W-0 R/W-0 LCDCKS [1:0] R/W-0 U-0 R/W-0 LCDEN LEVEL R/W-0 LCD_DUTY[1:0] Bit7 Bit 7-6 R/W-0 R/W-0 ENPMPL Bit0 LCDCKS[1:0]: LCD frame frequency selector 10 = LCD frame frequency is assigned to be LCD input clock frequency/16 F P r R ro SC ef pe ’ er rti en es ce O nl 01 = LCD frame frequency is assigned to be LCD input clock frequency/32 y 11 = LCD frame frequency is assigned to be LCD input clock frequency/8 00 = LCD frame frequency is assigned to be LCD input clock frequency/64 Bit 5 LCDEN: LCD driver enable register flag 1 = The LCD driver is enabled. LCD clock is started 0 = The LCD driver is disabled. LCD clock is stopped Bit 3 LEVEL: LCD driver voltage bias selector. 0 = LCD driver voltage bias is assigned to be 1/3 bias. 1 = LCD driver voltage bias is assigned to be 1/2 bias. Bit 2-1 LCD_DUTY[1:0]: LCD driver control mode (SEG duty cycle) 11 = LCD driver control mode is assigned to be 1/4 duty cycle mode. 10 = LCD driver control mode is assigned to be 1/3 duty cycle mode. 01 = LCD driver control mode is assigned to be 1/2 duty cycle mode. 00 = LCD driver control mode is assigned to be static mode Bit 0 ENPMPL: LCD driver charge pump enable register flag 1 = LCD driver charge pump is enabled. 0 = LCD driver charge pump is disabled. property W = Writable bit U = unimplemented bit - n = Value at Power On Reset „1‟ = Bit is Set „0‟ = Bit is Cleared X = Bit is unknown Fo R = Readable bit Rev. 1.5 125/142 FS98O25 Table 13-4 LCD driver register table 14H 40H 41H 42H 43H 44H 45H 46H 47H 48H 49H 4AH 4BH 4CH 4DH 4EH 4FH 54H MCK LCD1 LCD2 LCD3 LCD4 LCD5 LCD6 LCD7 LCD8 LCD9 LCD10 LCD11 LCD12 LCD13 LCD14 LCD15 LCD16 LCDENR Referenced Bit 7 Bit 6 Bit 5 Section 5 --M5_CK 13 SEG2 [3:0] 13 SEG4 [3:0] 13 SEG6 [3:0] 13 SEG8 [3:0] 13 SEG10 [3:0] 13 SEG12 [3:0] 13 SEG14 [3:0] 13 SEG16 [3:0] 13 SEG18 [3:0] 13 SEG20 [3:0] 13 SEG22 [3:0]] 13 SEG24 [3:0] 13 SEG26 [3:0] 13 SEG28 [3:0] 13 SEG30 [3:0] 13 SEG32 [3:0] 13 LCDCKS [1:0] LCDEN Bit 4 Value on Power on Reset M3_CK -M1_CK M0_CK 00000000 SEG1 [3:0] uuuuuuuu SEG3 [3:0] uuuuuuuu SEG5 [3:0] uuuuuuuu SEG7 [3:0] uuuuuuuu SEG9 [3:0] uuuuuuuu SEG11 [3:0] uuuuuuuu SEG13 [3:0] uuuuuuuu SEG15 [3:0] uuuuuuuu SEG17 [3:0] uuuuuuuu SEG19 [3:0] uuuuuuuu SEG21 [3:0] uuuuuuuu SEG23 [3:0] uuuuuuuu SEG25 [3:0] uuuuuuuu SEG27 [3:0] uuuuuuuu SEG29 [3:0] uuuuuuuu SEG31 [3:0] uuuuuuuu LEVEL LCD_DUTY[1:0] ENPMPL 00000000 Bit 3 Bit 2 Bit 1 Bit 0 y Name F P r R ro SC ef pe ’ er rti en es ce O nl Address LCD operation 1. 2. 3. 4. Connect the 32 segment ports and 4 common ports to LCD panel. Setup LEVEL register flag to decide the LCD driver power system. (0 = 1/3 bias, 1 = 1/2 bias) Set ENPMPL to enable the LCD charge pump. Setup M0_CK,M1_CK,M3_CK and M5_CK to decide the LCD input clock frequency.(Refer to Section 5.7) Table 13-5 CLK selection table M1_CK CLK 0 MCK 1 MCK/4 Table 13-6 MCK selection table M0_CK MCK X 0 ICK 0 1 ECK 1 1 ECK/2 Fo M3_CK Rev. 1.5 126/142 FS98O25 Table 13-7 TMCLK selection table 5. M5_CK TMCLK (Timer and LCD Module input Clock) 0 CLK/1000 1 ECK/32 Setup LCDCKS[1:0] register flags to decide the LCD Clock frequency. 6. LCD frame frequency (LCDCK) F P r R ro SC ef pe ’ er rti en es ce O nl LCDCKS [1:0] y Table 13-8 LCD frame frequency selection table 00 LCD Input clock Frequency/8 01 LCD Input clock Frequency/16 10 LCD Input clock Frequency/32 11 LCD Input clock Frequency/64 Setup LCD_DUTY[1:0] register flag to decide the control mode.(SEG duty cycle) Table 13-9 LCD duty control mode selection table Control mode 00 static 01 1/2 10 1/3 11 1/4 Set LCDEN to enable the LCD driver. Fo 7. LCD_DUTY [1:0] Rev. 1.5 127/142 FS98O25 14. Halt and Sleep Modes FS98O25 supports low power working mode. When the user want FS98O25 to do nothing and just stand by, FS98O25 could be set to Halt mode or Sleep mode to reduce the power consumption by stopping the CPU core working. The two modes will be described below.  Halt Mode  y After CPU executes a Halt command, CPU Program Counter (PC) stops counting until an interrupt command is issued. To avoid program errors caused by Interrupt Return, it is suggested to add a NOP command after Halt to guarantee the program‟s normal execution when turning back. Sleep Mode F P r R ro SC ef pe ’ er rti en es ce O nl After CPU executes Sleep command, all oscillators stop working until an external interrupt command is issued or the CPU is reset. To avoid program errors caused by Interrupt return, it is suggested to add a NOP command after Sleep to guarantee the program‟s normal execution. The sleep mode power consumption is about 3 uA. To make sure that CPU consumes minimum power in Sleep mode, it is necessary to close all power blocks and analog circuits before issuing the Sleep command, and make sure that all I/O Ports are in VDD or VSS voltage levels. It is recommended that users execute the following program before issuing the Sleep command: CLRF NETA ; As Reset state CLRF NETB ; As Reset state CLRF NETC ; As Reset state CLRF NETD ; As Reset state CLRF NETE ; As Reset state CLRF NETF ; As Reset state CLRF PT1PU ; Pull up resistor is disconnected CLRF PT1EN ; PT1[7:0] is assigned to be input ports. CLRF AINENB ; Set PT1 as Analog Input Pin MOVLW MOVWF interrupt) 01h PT2PU MOVLW 0FEh MOVWF PT2EN ; PT2 ports are assigned to be output ports except port 0 CLRF PT2 ; Set PT2 [7:1] Output Low CLRF INTF ; Clear the interrupt flags MOVLW 081h MOVWF INTE Fo SLEEP NOP wakes up. Rev. 1.5 ; PT2 Pull up resistor is disconnected except port 0(external ; Enable the external interrupt ; Set the FS98O25 into Sleep mode ; Guarantee that the program works normally when CPU 128/142 FS98O25 15. Instruction Set The FS9XXX instruction set consists of 37 instructions. Each instruction could be converted to 16-bit OPCODE. The detailed descriptions are shown in the following sections. Instruction Set Summary Operation [W]  [W] + k [PC]  [PC] + 1 + [W] [Destination]  [f] + [W] [Destination]  [f] + [W] + C [W]  [W] AND k [Destination]  [W] AND [f] [f]  0 [f]  1 Skip if [f] = 0 Skip if [f] = 1 Push PC + 1 and GOTO k [f]  0 Clear watch dog timer [f]  NOT([f]) [Destination]  [f] -1 [Destination]  [f] -1, skip if the result is zero PC  k CPU Stop [Destination]  [f] +1 [Destination]  [f] + 1, skip if the result is zero [W]  [W] | k [Destination]  [W] | [f] [W]  [f] [W]  k [f]  [W] No operation Pop PC and GIE = 1 RETURN and W = k Pop PC [Destination]  [f] [Destination]  [f] Stop OSC [W]  k – [W] [Destination]  [f] – [W] ‧ [Destination]  [f] – [W] –C [W]  [W] XOR k [Destination]  [W] XOR [f] Cycle 1 2 1 1 1 1 1 1 1, 2 1, 2 2 1 1 1 1 1, 2 2 1 1 1, 2 Flag C, DC, Z None C, DC, Z C, DC, Z Z Z None None None None None Z None Z Z None None None Z None F P r R ro SC ef pe ’ er rti en es ce O nl Instruction ADDLW k ADDPCW ADDWF f, d ADDWFC f, d ANDLW k ANDWF f, d BCF f, b BSF f, b BTFSC f, b BTFSS f, b CALL k CLRF f CLRWDT COMF f, d DECF f, d DECFSZ f, d GOTO k HALT INCF f, d INCFSZ f, d y Table 15-1 FS98O25 instruction set table IORLW k IORWF f, d MOVFW f MOVLW k MOVWF f NOP RETFIE RETLW k RETURN RLF f, d RRF f, d SLEEP SUBLW k SUBWF f, d SUBWFC f, d Fo XORLW k XORWF f, d Rev. 1.5 1 1 1 1 1 1 2 2 2 1 1 1 1 1 1 Z Z None None None None None None None C,Z C, Z PD C, DC, Z C, DC, Z C, DC, Z 1 1 Z Z 129/142              f: memory address (00h ~ 7Fh). W: work register. k: literal field, constant data or label. d: destination select: d=0 store result in W, d=1: store result in memory address f. b: bit select (0~7). [f]: the content of memory address f. PC: program counter. C: Carry flag DC: Digit carry flag Z: Zero flag PD: power down flag TO: watchdog time out flag WDT: watchdog timer counter Fo F P r R ro SC ef pe ’ er rti en es ce O nl Note: y FS98O25 Rev. 1.5 130/142 FS98O25 Instruction Description ADDLW Syntax F P r R ro SC ef pe ’ er rti en es ce O nl Operation Flag Affected Description Cycle Example: ADDLW 08h Add Literal to W ADDLW k 0  k  FFh [W]  [W] + k C, DC, Z The content of Work register add literal “k” in Work register 1 Before instruction: W = 08h After instruction: W = 10h y (By alphabetically) ADDPCW Syntax Operation Flag Affected Description Cycle Example 1: ADDPCW Example 2: ADDPCW Example 3: ADDPCW Add W to PC ADDPCW [PC]  [PC] + 1 + [W], [W] < 79h [PC]  [PC] + 1 + ([W] – 100h), otherwise None The relative address PC + 1 + W are loaded into PC. 2 Before instruction: W = 7Fh, PC = 0212h After instruction: PC = 0292h Before instruction: W = 80h, PC = 0212h After instruction: PC = 0193h Before instruction: W = FEh, PC = 0212h After instruction: PC = 0211h Add W to f ADDWF f, d 0  f  FFh d  [0,1] Operation [Destination]  [f] + [W] Flag Affected C, CD, Z Description Add the content of the W register and [f]. If d is 0, the result is stored in the W register. If d is 1, the result is stored back in f. Cycle 1 Example 1: Before instruction: ADDWF OPERAND, 0 OPERAND = C2h W = 17h After instruction: OPERAND = C2h W = D9h Example 2: Before instruction: ADDWF OPERAND, 1 OPERAND = C2h W = 17h After instruction: OPERAND = D9h W = 17h Fo ADDWF Syntax Rev. 1.5 131/142 FS98O25 Add W, f and Carry ADDWFC f, d 0  f  FFh d  [0,1] Operation [Destination]  [f] + [W] + C Flag Affected C, DC, Z Description Add the content of the W register, [f] and Carry bit. If d is 0, the result is stored in the W register. If d is 1, the result is stored back in f. Cycle 1 Example Before instruction: ADDWFC OPERAND,1 C = 1 OPERAND = 02h W = 4Dh ANDLW Syntax F P r R ro SC ef pe ’ er rti en es ce O nl After instruction: C=0 OPERAND = 50h W = 4Dh Operation Flag Affected Description Cycle Example: ANDLW 5Fh ANDWF Syntax y ADDWFC Syntax Operation Flag Affected Description Cycle Example 1: ANDWF OPERAND,0 AND W and f ANDWF f, d 0  f  FFh d  [0,1] [Destination]  [W] AND [f] Z AND the content of the W register with [f]. If d is 0, the result is stored in the W register. If d is 1, the result is stored back in f. 1 Before instruction: W = 0Fh, OPERAND = 88h After instruction: W = 08h, OPERAND = 88h Before instruction: W = 0Fh, OPERAND = 88h After instruction: W = 88h, OPERAND = 08h Fo Example 2: ANDWF OPERAND,1 AND literal with W ANDLW k 0  k  FFh [W]  [W] AND k Z AND the content of the W register with the eight-bit literal "k". The result is stored in the W register. 1 Before instruction: W = A3h After instruction: W = 03h Rev. 1.5 132/142 FS98O25 Operation Flag Affected Description Cycle Example: BCF FLAG, 2 Bit Set f BSF f, b 0  f  FFh 0b7 [f]  1 None Bit b in [f] is set to 1. 1 Before instruction: FLAG = 89h After instruction: FLAG = 8Dh F P r R ro SC ef pe ’ er rti en es ce O nl BSF Syntax Bit Clear f BCF f, b 0  f  FFh 0b7 [f]  0 None Bit b in [f] is reset to 0. 1 Before instruction: FLAG = 8Dh After instruction: FLAG = 89h y BCF Syntax Operation Flag Affected Description Cycle Example: BSF FLAG, 2 Bit Test skip if Clear BTFSC f, b 0  f  FFh 0b7 Operation Skip if [f] = 0 Flag Affected None Description If bit 'b' in [f] is 0, the next fetched instruction is discarded and a NOP is executed instead making it a two-cycle instruction. Cycle 1, 2 Example: Before instruction: Node BTFSC FLAG, PC = address (Node) 2 After instruction: OP1 : If FLAG = 0 OP2 : PC = address(OP2) If FLAG = 1 PC = address(OP1) BTFSC Syntax Bit Test skip if Set BTFSS f, b 0  f  FFh 0b7 Operation Skip if [f] = 1 Flag Affected None Description If bit 'b' in [f] is 1, the next fetched instruction is discarded and a NOP is executed instead making it a two-cycle instruction. Cycle 1, 2 Example: Before instruction: Node BTFSS FLAG, PC = address (Node) 2 After instruction: OP1 : If FLAG = 0 OP2 : PC = address(OP1) If FLAG = 1 PC = address(OP2) Fo BTFSS Syntax Rev. 1.5 133/142 FS98O25 Operation Flag Affected Description Cycle CLRF Syntax Clear f CLRF f 0  f  255 [f]  0 None Reset the content of memory address f 1 Before instruction: WORK = 5Ah After instruction: WORK = 00h F P r R ro SC ef pe ’ er rti en es ce O nl Operation Flag Affected Description Cycle Example: CLRF WORK Subroutine CALL CALL k 0  k  1FFFh Push Stack [Top Stack]  PC + 1 PC  k None Subroutine Call. First, return address PC + 1 is pushed onto the stack. The immediate address is loaded into PC. 2 y CALL Syntax CLRWDT Syntax Operation Flag Affected Description Cycle Example: CLRWDT Clear watch dog timer CLRWDT Watch dog timer counter will be reset None CLRWDT instruction will reset watch dog timer counter. 1 After instruction: WDT = 0 COMF Syntax Complement f COMF f, d 0  f  255 d  [0,1] [f]  NOT([f]) Z [f] is complemented. If d is 0, the result is stored in the W register. If d is 1, the result is stored back in [f] 1 Before instruction: W = 88h, OPERAND = 23h After instruction: W = DCh, OPERAND = 23h Before instruction: W = 88h, OPERAND = 23h After instruction: W = 88h, OPERAND = DCh Operation Flag Affected Description Cycle Example 1: COMF OPERAND,0 Fo Example 2: COMF OPERAND,1 Rev. 1.5 134/142 FS98O25 Operation Flag Affected Description Cycle Example 1: DECF OPERAND,0 F P r R ro SC ef pe ’ er rti en es ce O nl Example 2: DECF OPERAND,1 Decrement f DECF f, d 0  f  255 d  [0,1] [Destination]  [f] -1 Z [f] is decremented. If d is 0, the result is stored in the W register. If d is 1, the result is stored back in [f]. 1 Before instruction: W = 88h, OPERAND = 23h After instruction: W = 22h, OPERAND = 23h Before instruction: W = 88h, OPERAND = 23h After instruction: W = 88h, OPERAND = 22h y DECF Syntax Decrement f, skip if zero DECFSZ f, d 0  f  FFh d  [0,1] Operation [Destination]  [f] -1, skip if the result is zero Flag Affected None Description [f] is decremented. If d is 0, the result is stored in the W register. If d is 1, the result is stored back in [f]. If the result is 0, then the next fetched instruction is discarded and a NOP is executed instead making it a two-cycle instruction. Cycle 1, 2 Example: Before instruction: Node DECFSZ PC = address (Node) FLAG, 1 After instruction: OP1 : [FLAG] = [FLAG] - 1 OP2 : If [FLAG] = 0 PC = address(OP1) If [FLAG]  0 PC = address(OP2) DECFSZ Syntax GOTO Syntax Operation Flag Affected Description Cycle Stop CPU Core Clock HALT CPU Stop None CPU clock is stopped. Oscillator is running. CPU can be waked up by internal and external interrupt sources. 1 Fo HALT Syntax Operation Flag Affected Description Unconditional Branch GOTO k 0  k  1FFFh PC  k None The immediate address is loaded into PC. 2 Cycle Rev. 1.5 135/142 FS98O25 Operation Flag Affected Description Cycle Example 1: INCF OPERAND,0 F P r R ro SC ef pe ’ er rti en es ce O nl Example 2: INCF OPERAND,1 Increment f INCF f, d 0  f  FFh d  [0,1] [Destination]  [f] +1 Z [f] is incremented. If d is 0, the result is stored in the W register. If d is 1, the result is stored back in [f]. 1 Before instruction: W = 88h, OPERAND = 23h After instruction: W = 24h, OPERAND = 23h Before instruction: W = 88h, OPERAND = 23h After instruction: W = 88h, OPERAND = 24h y INCF Syntax Increment f, skip if zero INCFSZ f, d 0  f  FFh d  [0,1] Operation [Destination]  [f] + 1, skip if the result is zero Flag Affected None Description [f] is incremented. If d is 0, the result is stored in the W register. If d is 1, the result is stored back in [f]. If the result is 0, then the next fetched instruction is discarded and a NOP is executed instead making it a two-cycle instruction. Cycle 1, 2 Example: Before instruction: Node INCFSZ FLAG, PC = address (Node) 1 After instruction: OP1 : [FLAG] = [FLAG] + 1 OP2 : If [FLAG] = 0 PC = address(OP2) If [FLAG]  0 PC = address(OP1) INCFSZ Syntax IORLW Syntax Operation Flag Affected Description 85h Fo Cycle Example: IORLW Inclusive OR literal with W IORLW k 0  k  FFh [W]  [W] | k Z Inclusive OR the content of the W register and the eight-bit literal "k". The result is stored in the W register. 1 Before instruction: W = 69h After instruction: W = EDh Rev. 1.5 136/142 FS98O25 Inclusive OR W with f IORWF f, d 0  f  FFh d  [0,1] Operation [Destination]  [W] | [f] Flag Affected Z Description Inclusive OR the content of the W register and [f]. If d is 0, the result is stored in the W register. If d is 1, the result is stored back in [f]. Cycle 1 Example: Before instruction: IORWF OPERAND,1 W = 88h, OPERAND = 23h After instruction: W = 88h, OPERAND = ABh MOVLW Syntax F P r R ro SC ef pe ’ er rti en es ce O nl Move f to W MOVFW f 0  f  FFh Operation [W]  [f] Flag Affected None Description Move data from [f] to the W register. Cycle 1 Example: Before instruction: MOVFW OPERAND W = 88h, OPERAND = 23h After instruction: W = 23h, OPERAND = 23h MOVFW Syntax y IORWF Syntax Operation Flag Affected Description Cycle Example: MOVLW 23h Move literal to W MOVLW k 0  k  FFh [W]  k None Move the eight-bit literal "k" to the content of the W register. 1 Before instruction: W = 88h After instruction: W = 23h Move W to f MOVWF f 0  f  FFh Operation [f]  [W] Flag Affected None Description Move data from the W register to [f]. Cycle 1 Example: Before instruction: MOVWF OPERAND W = 88h, OPERAND = 23h After instruction: W = 88h, OPERAND = 88h MOVWF Syntax No Operation NOP No Operation None No operation. NOP is used for one instruction cycle delay. 1 Fo NOP Syntax Operation Flag Affected Description Cycle Rev. 1.5 137/142 FS98O25 Flag Affected Description Cycle RETLW Syntax Flag Affected Description Cycle Return Syntax Operation Flag Affected Description Cycle RLF Syntax Return and move literal to W RETLW k 0  k  FFh [W]  k [Top Stack] => PC Pop Stack None Move the eight-bit literal "k" to the content of the W register. The program counter is loaded from the top stack, then pop stack. 2 F P r R ro SC ef pe ’ er rti en es ce O nl Operation Return from Interrupt RETFIE [Top Stack] => PC Pop Stack 1 => GIE None The program counter is loaded from the top stack, then pop stack. Setting the GIE bit enables interrupts. 2 y RETFIE Syntax Operation Return from Subroutine RETURN [Top Stack] => PC Pop Stack None The program counter is loaded from the top stack, then pop stack. 2 Operation Flag Affected Description Fo Cycle Example: RLF OPERAND, 1 Rev. 1.5 Rotate left [f] through Carry RLF f, d 0  f  FFh d  [0,1] [Destination]  [f] [Destination]  C C  [f] C, Z [f] is rotated one bit to the left through the Carry bit. If d is 0, the result is stored in the W register. If d is 1, the result is stored back in [f]. 1 Before instruction: C=0 W = 88h, OPERAND = E6h After instruction: C=1 W = 88h, OPERAND = CCh 138/142 FS98O25 Rotate right [f] through Carry RRF f, d 0  f  FFh d  [0,1] [Destination]  [f] [Destination]  C C  [f] C [f] is rotated one bit to the right through the Carry bit. If d is 0, the result is stored in the W register. If d is 1, the result is stored back in [f]. RRF Syntax Operation F P r R ro SC ef pe ’ er rti en es ce O nl y Flag Affected Description Cycle Example: RRF OPERAND, 0 1 Before instruction: C=0 OPERAND = 95h After instruction: C=1 W = 4Ah, OPERAND = 95h SLEEP Syntax Operation Flag Affected Description Cycle Oscillator stop SLEEP CPU oscillator is stopped PD 29 CPU oscillator is stopped. CPU can be waked up by external interrupt sources. 1 SUBLW Syntax Subtract W from literal SUBLW k 0  k  FFh [W]  k – [W] C, DC, Z Subtract the content of the W register from the eight-bit literal "k". The result is stored in the W register. 1 Before instruction: W = 01h After instruction: W = 01h C=1 Z=0 Before instruction: W = 02h After instruction: W = 00h C=1 Z=1 Before instruction: W = 03h After instruction: W = FFh C=0 Z=0 Operation Flag Affected Description Cycle Example 1: SUBLW 02h Example 2: SUBLW 02h Fo Example 3: SUBLW 02h 29 Please make sure all interrupt flags are cleared before running SLEEP; "NOP" command must follow HALT and SLEEP commands. Rev. 1.5 139/142 FS98O25 Subtract W from f SUBWF f, d 0  f  FFh d  [0,1] Operation [Destination]  [f] – [W] Flag Affected C, DC, Z Description Subtract the content of the W register from [f]. If d is 0, the result is stored in the W register. If d is 1, the result is stored back in [f], Cycle 1 Example 1: Before instruction: SUBWF OPERAND, OPERAND = 33h, W = 01h 1 After instruction: OPERAND = 32h C=1 Z=0 Example 2: Before instruction: SUBWF OPERAND, OPERAND = 01h, W = 01h 1 After instruction: OPERAND = 00h C=1 Z=1 Example 3: Before instruction: SUBWF OPERAND, OPERAND = 04h, W = 05h 1 After instruction: OPERAND = FFh C=0 Z=0 F P r R ro SC ef pe ’ er rti en es ce O nl y SUBWF Syntax SUBWFC Syntax Operation Flag Affected Description Cycle Example 1: SUBWFC OPERAND, 1 Example 2: SUBWFC OPERAND, 1 Fo Example 3: SUBWFC OPERAND, 1 Subtract W and Carry from f SUBWFC f, d 0  f  FFh d  [0,1] ‧ [Destination]  [f] – [W] –C C, DC, Z Subtract the content of the W register from [f]. If d is 0, the result is stored in the W register. If d is 1, the result is stored back in [f]. 1 Before instruction: OPERAND = 33h, W = 01h C=1 After instruction: OPERAND = 32h, C = 1, Z = 0 Before instruction: OPERAND = 02h, W = 01h C=0 After instruction: OPERAND = 00h, C = 1, Z = 1 Before instruction: OPERAND = 04h, W = 05h C=0 After instruction: OPERAND = FEh, C = 0, Z = 0 Rev. 1.5 140/142 FS98O25 Operation Flag Affected Description 5Fh 1 Before instruction: W = ACh After instruction: W = F3h F P r R ro SC ef pe ’ er rti en es ce O nl Cycle Example: XORLW Exclusive OR literal with W XORLW k 0  k  FFh [W]  [W] XOR k Z Exclusive OR the content of the W register and the eight-bit literal "k". The result is stored in the W register. y XORLW Syntax Exclusive OR W and f XORWF f, d 0  f  FFh d  [0,1] Operation [Destination]  [W] XOR [f] Flag Affected Z Description Exclusive OR the content of the W register and [f]. If d is 0, the result is stored in the W register. If d is 1, the result is stored back in [f]. Cycle 1 Example: Before instruction: XORWF OPERAND, OPERAND = 5Fh, W = ACh 1 After instruction: OPERAND = F3h Fo XORWF Syntax Rev. 1.5 141/142 FS98O25 16. Package Information F P r R ro SC ef pe ’ er rti en es ce O nl y Package Outline Figure 16-1 FS98O25 package outline 17. Revision History 1.5 Date 2008/04/23 2008/10/9 2008/11/10 2008/12/30 2009/07/08 Page All 13-14 12 34 20 2009/10/27 20 21 Fo Ver. 1.0 1.1 1.2 1.3 1.4 Rev. 1.5 Description Initial release. Move VSSP~RST PIN from 90~99 to 91~100 Add FS98O251 (6K ROM version) in ordering information Low Battery Comparator Input Selector Correct Revise Ambient Operating Temperature from -10~85 C to 0~70 C and add LTOL test condition description Revise Sleep Current Unit:μA Revise Input Offset TYP:1.5mV 142/142
FS98O25 价格&库存
很抱歉,暂时无法提供与“FS98O25”相匹配的价格&库存,您可以联系我们找货
