RS3005-5.0YE3
RS3005-5.0YE3
    RUNIC(润石)
    SOT89-3
    输出类型:固定 输出极性:正 最大输入电压:36V 输出电压:5V 输出电流:150mA
RS3005-5.0YE3 数据手册
RS3005 150mA, Low Power Consumption, High Voltage CMOS LDO Regulator DESCRIPTION FEATURES • Low Power Consumption • 150mA Nominal Output Current • Low Dropout Voltage • Low Temperature Coefficient • High Input Voltage (up to 36V) • Output Voltage Accuracy: ±2.5% • Operating Temperature Range: -40°C to +85°C • Micro SIZE PACKAGES: SOT23-3、 The RS3005 series is a set of low power high voltage regulators implemented in CMOS technology. It can operate from 2.5V to 36V. which can provide 150mA output current. The device allows input voltage as high as 36V. The RS3005 series is available in several fixed output voltages. CMOS technology ensures low dropout voltage and low quiescent current. The RS3005 is available in Green SOT23-3 and SOT89-3L packages. It operates over an ambient temperature range of -40°C to +85°C. SOT89-3L and SOT89-3L(L-Type) Function Block Diagram APPLICATIONS • Audio/Video Equipment • Communication Equipment • Battery-Powered Equipment • Laptop, Palmtops, Notebook Computers RevA.2 1 www.run-ic.com RS3005 PIN CONFIGURATIONS VOUT SCXX GND 1 2 3 VIN SOT23-3 GND VIN SCXX SCXXL 1 2 3 1 2 3 VOUT GND VIN GND VIN VOUT SOT89-3L SOT89-3L(L-Type) NOTE: XX indicate Output Voltage For example: SC33 (VOUT=3.3V) PIN DESCRIPTION PIN NAME FUNCTION SOT23-3 SOT89-3L SOT89-3L (L-Type) GND 1 2 1 Ground. VIN 3 3 2 Regulator Input. Up to 36V input voltage. At least 1μF supply bypass capacitor is recommended. VOUT 2 1 3 Regulator Output. Recommended output capacitor range:1μF to 10μF. RevA.2 2 www.run-ic.com RS3005 ABSOLUTE MAXIMUM RATINGS (1) VIN to GND.........................................................-0.3 to 40V VOUT to GND......................... -0.3V to Min (VIN + 0.3V,7V) Power Dissipation, PD @ TA = 25°C SOT23-3 ……….……………………………………..…0.31W SOT89-3L ……….………………………………………. 1.3W SOT89-3L(L-Type) ……….………………………….…. 0.6W Junction Temperature..............................................+150°C Operating Temperature Range ...................-40°C to +85°C Package Thermal Resistance @ TA = 25°C SOT23-3………………….…………………….…….320°C/W SOT89-3L……….…………......................................75°C/W SOT89-3L(L-Type) ……….…………………...…….165°C/W Storage Temperature Range......................-65°C to +150°C Lead Temperature (Soldering, 10s) …………….........260°C ESD Susceptibility HBM ….......................................................................1000V MM ……………………….........………………...……….100V ESD SENSITIVITY CAUTION ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. (1) Stresses above these ratings may cause permanent damage. Exposure to absolute maximum conditions for extended periods may degrade device reliability. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those specified is not implied. PACKAGE/ORDERING INFORMATION PRODUCT RS3005-3.3 RS3005-5.0 ORDERING NUMBER VOUT(V) PACKAGE LEAD PACKAGE MARKING PACKAGE OPTION RS3005-3.3YF3 3.3 SOT23-3 SC33 XXXX Tape and Reel,3000 RS3005-3.3YE3 3.3 SOT89-3L SC33 XXXX Tape and Reel,1000 RS3005-3.3YE3L 3.3 SOT89-3L (L-Type) SC33L XXXX Tape and Reel,1000 RS3005-5.0YF3 5.0 SOT23-3 SC50 XXXX Tape and Reel,3000 RS3005-5.0YE3 5.0 SOT89-3L SC50 XXXX Tape and Reel,1000 RS3005-5.0YE3L 5.0 SOT89-3L (L-Type) SC50L XXXX Tape and Reel,1000 NOTE: XXXX = Date Code and Vendor Code. 3 www.run-ic.com RS3005 ELECTRICAL CHARACTERISTICS (VIN = VOUT + 2V, CIN = COUT = 1μF, Full = -40°C to +85°C, typical values are at TA = +25°C, unless otherwise noted.) PARAMETER Input Voltage SYMBOL VIN Output Voltage Accuracy CONDITIONS MIN VOUT = 3.3V +25°C 2.5(1) IOUT = 1mA +25°C No load Ground Pin Current TEMP -2.5 VIN = VOUT + 2V VIN = 36V +25°C IOUT = 50mA Line Regulation Load Regulation Power Supply Rejection Ratio Output Voltage Temperature Coefficient (4) +25°C VDROP IOUT = 150mA ΔVOUT VIN = VOUT + 2V to 36V, IOUT = 1mA ΔVIN × VOUT ΔVOUT PSRR VIN =VOUT+2V, IOUT = 1mA to150mA VOUT = 3.3V, IOUT = 10mA MAX UNITS 36 V 0 2.5 % 11 18 16 25 μA 11 Maximum Output Current (2) Dropout Voltage (3) TYP f = 217Hz f = 1KHz ΔVOUT IOUT = 1mA ΔTA × VOUT 150 mA +25°C 1300 1800 mV +25°C 0.005 0.012 %/V +25°C +25°C FULL 10 65 63 25 mV dB 70 ppm/°C 120 °C THERMAL PROTECTION Thermal Shutdown Temperature TSHDN NOTES: 1. VIN = VOUT (NOMINAL) or 2.5V, whichever is greater. 2. Maximum output current is affected by the PCB layout, size of metal trace, the thermal conduction path between metal layers, ambient temperature and the other environment factors of system. Attention should be paid to the dropout voltage when VIN < VOUT + VDROP. 3. The dropout voltage is defined as VIN - VOUT, when VOUT is 100mV below the value of VOUT for VIN = VOUT (NOMINAL) + 2V. 4. Output voltage temperature coefficient is defined as the worst-case voltage change divided by the total temperature range. 4 www.run-ic.com RS3005 TYPICAL CHARACTERISTICS VIN = 5.3V, VOUT = 3.3V, CIN = COUT = 1μF, TA = 25°C unless otherwise noted. Line-Transient Response Load-Transient Response IOUT=10mA to 100mA VVININ=4.4V =5.3Vto to5.4V,I 6.3V,IOUT OUT =50mA =50mA 100mA/div IOUT VIN 1V/div 100mV/div 100mV/div VOUT VOUT Time(2ms/div) Time(2ms/div) Power-Up/Power-Down Output Waveform Output Short Waveform VOUT 2V/div 2V/div VIN 100mA/div 2V/div VOUT VIN=0 to 3.4V,IOUT=50mA IOUT Time(1ms/div) Time(2ms/div) Dropout Voltage vs. Temperature Dropout Voltage vs. Output Current 600 1600 IOUT=50mA Dropout Voltage(mV) 550 Dropout Voltage(mV) 1200 500 450 400 350 300 800 400 0 -50 -25 0 25 50 75 100 0 Temperature(℃) 25 50 75 100 125 150 Output Current(mA) 5 www.run-ic.com RS3005 APPLICATION NOTES Input Capacitor and Output Capacitor For proper operation, using a ceramic capacitor (CIN) between 1μF and 10μF between the input pin and ground. The input capacitor must be located a distance of not more than 0.5 inch from the input pin of the IC and returned to a clean analog ground. The capacitor with larger value and lower ESR (equivalent series resistance) provides better PSRR and line-transient response. The output capacitor must meet both requirements for minimum amount of capacitance and ESR in all LDOs application for stable operation, use a ceramic capacitor (COUT) between 1μF and 10μF. Larger values in this range will help improve load transient response and reduce noise. Output capacitors of other dielectric types may be used, but are not recommended as their capacitance can deviate greatly from their rated value over temperature. Thermal Considerations When the junction temperature is too high, the thermal protection circuitry sends a signal to the control logic that will shut down the IC. The IC will restart when the temperature has sufficiently cooled down. The maximum power dissipation is dependent on the thermal resistance of the case and the circuit board, the temperature difference between the die junction and the ambient air, and the rate of air flow. The GND pin must be connected to the ground plane for proper dissipation. VIN VIN CIN 1μF VOUT RS3005 VOUT COUT 1μF GND Typical Application Circuit 6 www.run-ic.com RS3005 PACKAGE OUTLINE DIMENSIONS SOT23-3 D 1.90 b 2.59 E1 E 0.99 0.95 0.69 e e1 RECOMMENDED LAND PATTERN (Unit: mm) 0.2 A A2 L A1 Symbol c θ Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0° 8° 0° 8° 7 www.run-ic.com RS3005 SOT89-3L D 2.0 A D1 3.0 E E1 0.7 45° b1 L e 1.5 b c 1.5 e1 1.0 RECOMMENDED LAND PATTERN (Unit: mm) Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.400 1.600 0.055 0.063 b 0.320 0.520 0.013 0.020 b1 0.400 0.580 0.016 0.023 c 0.350 0.440 0.014 0.017 D 4.400 4.600 0.173 0.181 D1 1.550 REF 0.061 REF E 2.300 2.600 0.091 0.102 E1 3.940 4.250 0.155 0.167 e 1.500 BSC 0.060 BSC e1 3.000 BSC 0.118 BSC L 0.900 1.200 8 0.035 0.047 www.run-ic.com
RS3005-5.0YE3 价格&库存
很抱歉,暂时无法提供与“RS3005-5.0YE3”相匹配的价格&库存,您可以联系我们找货
RS3005-5.0YE3
  • 5+0.71820
  • 50+0.53676
  • 150+0.44604
  • 1000+0.37800
库存:3511
RS3005-5.0YE3
  • 5+0.42500
  • 20+0.38750
  • 100+0.35000
  • 500+0.31250
  • 1000+0.29500
  • 2000+0.28250
