BAT-HLD-012-THM
BAT-HLD-012-THM
    LINXTECHNOLOGIES(灵思)
    BATT-BASE_13.5X9.5MM_TM
    DIP 4PINS
BAT-HLD-012-THM 数据手册
8 5 6 7 4 2 3 1 REVISIONS REV DESCRIPTION DATE APPV 2-FEB-12 SAH 10-AUG-16 SAH A INITIAL RELEASE OF INTERNAL DOCUMENT B UPDATED DIMENSIONS; ADDED THROUGH HOLE PIN LENGTH DIMENSION D D RECOMMENDED FOOTPRINT C .53 13.5 .14 3.6 .07 1.7 C .13 3.2 .26 6.6 .12 3 4X .06 1.6 .04 1 4X .03 0.8 .12 3.1 .26 6.6 .23 5.8 .37 9.5 B 4X 4X.08 2 .13 3.4 .06 1.6 .09 2.3 .40 10.2 B NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. WARNING: THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. A MATERIAL: PHOSPHOR BRONZE #C-5191 FINISH: NICKEL PLATE 8 7 6 5 4 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5. 32 TITLE: A CR1216,1225 HOLDER OUTLINE PROJECTION: THROUGH HOLE MOUNT SURFACE FINISH: ANGLES: 1 TOLERANCES: .X .1 .XX .01 .XXX .005 DRAWN: B.MURPHY DT: 2-FEB-12 ENGR: S.HOGAN DT: 2-FEB-12 3 159 ORT LANE MERLIN, OR 97532 SIZE DWG. NO. B BAT-HLD-012-THM-OTL SCALE: 4:1 2 REV B SHEET 1 OF 1 DO NOT SCALE DRAWING 1 LDCFDFB_C
BAT-HLD-012-THM 价格&库存
很抱歉,暂时无法提供与“BAT-HLD-012-THM”相匹配的价格&库存,您可以联系我们找货
