74HC74PW,118
74HC74PW,118
    NEXPERIA(安世)
    TSSOP-14
    IC FF D-TYPE DUAL 1BIT 14TSSOP
74HC74PW,118 数据手册
74HC74; 74HCT74 Dual D-type flip-flop with set and reset; positive edge-trigger Rev. 5 — 3 December 2015 Product data sheet 1. General description The 74HC74 and 74HCT74 are dual positive edge triggered D-type flip-flop. They have individual data (nD), clock (nCP), set (nSD) and reset (nRD) inputs, and complementary nQ and nQ outputs. Data at the nD-input, that meets the set-up and hold time requirements on the LOW-to-HIGH clock transition, is stored in the flip-flop and appears at the nQ output. Schmitt-trigger action in the clock input, makes the circuit highly tolerant to slower clock rise and fall times. Inputs include clamp diodes that enable the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Input levels:  For 74HC74: CMOS level  For 74HCT74: TTL level  Symmetrical output impedance  Low power dissipation  High noise immunity  Balanced propagation delays  Specified in compliance with JEDEC standard no. 7A  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number 74HC74D Package Temperature range Name Description Version 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 40 C to +125 C SSOP14 plastic shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 74HCT74D 74HC74DB 74HCT74DB 74HC74; 74HCT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger Table 1. Ordering information …continued Type number 74HC74PW Package Temperature range Name Description Version 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 40 C to +125 C DHVQFN14 plastic dual in-line compatible thermal enhanced very SOT762-1 thin quad flat package; no leads; 14 terminals; body 2.5  3  0.85 mm 74HCT74PW 74HC74BQ 74HCT74BQ 4. Functional diagram    6' ' &3 6' 4 ' 4   6' 6'      6' ' ' ' &3 &3 &3 4 4 4     )) 4 5' 4 4      5' 5'   Fig 1. Logic symbol Fig 2. 6   & '    5' 6' 5  6   & ' &3 6' ' 4 4  &3 )) ' 4  4  5' 5  IEC logic symbol Fig 3. 5' PQD Functional diagram 4 & & 4 5' PQD PQD  &3 ))   4 & & & & ' 4 & & 5' 6' &3 PQD & & Fig 4. Logic diagram for one flip-flop 74HC_HCT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 2 of 20 74HC74; 74HCT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 5. Pinning information 5.1 Pinning 5' WHUPLQDO LQGH[DUHD  +& +&7 &3   ' 6'   &3 4   6' 4   4 *1'   4   5'   ' 6'   &3 4  4  *1'   6'    ' &3  '  9&&  5' 4  *1' 5'  9&& +& +&7 4 DDD 7UDQVSDUHQWWRSYLHZ DDD (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Fig 5. Pin configuration for SO14 and (T)SSOP14 Fig 6. Pin configuration for DHVQFN14 5.2 Pin description Table 2. Pin description Symbol Pin Description 1RD 1 asynchronous reset-direct input (active LOW) 1D 2 data input 1CP 3 clock input (LOW-to-HIGH, edge-triggered) 1SD 4 asynchronous set-direct input (active LOW) 1Q 5 output 1Q 6 complement output GND 7 ground (0 V) 2Q 8 complement output 2Q 9 output 2SD 10 asynchronous set-direct input (active LOW) 2CP 11 clock input (LOW-to-HIGH, edge-triggered) 2D 12 data input 2RD 13 asynchronous reset-direct input (active LOW) VCC 14 supply voltage 74HC_HCT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 3 of 20 74HC74; 74HCT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 6. Functional description Table 3. Function table[1] Input Output nSD nRD nCP nD nQ nQ L H X X H L H L X X L H L L X X H H [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. Table 4. Function table[1] Input Output nSD nRD nCP nD nQn+1 nQn+1 H H  L L H H H  H H L [1] H = HIGH voltage level; L = LOW voltage level;  = LOW-to-HIGH transition; Qn+1 = state after the next LOW-to-HIGH CP transition; X = don’t care. 7. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage 0.5 +7 V IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V - 20 mA IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V - 20 mA IO output current VO = 0.5 V to (VCC + 0.5 V) - 25 mA ICC supply current - +100 mA IGND ground current 100 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot [1] Conditions SO14, (T)SSOP14 and DHVQFN14 packages Min [1] Max Unit For SO14 package: Ptot derates linearly with 8 mW/K above 70 C. For (T)SSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C. For DHVQFN14 packages: Ptot derates linearly with 4.5 mW/K above 60 C. 74HC_HCT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 4 of 20 74HC74; 74HCT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 8. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC74 Min Typ 74HCT74 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature 40 +25 +125 40 +25 +125 C t/V input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 9. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 40 C to +85 C Conditions Tamb = 40 C to +125 C Unit Min Typ[1] Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 V IO = 4.0 mA; VCC = 4.5 V 3.84 4.32 - 3.7 - V IO = 5.2 mA; VCC = 6.0 V 5.34 5.81 - 5.2 - V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.33 - 0.4 V 74HC74 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - 1.0 - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 40 - 80 A CI input capacitance - 3.5 - - - pF 74HC_HCT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 5 of 20 74HC74; 74HCT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 40 C to +85 C Conditions Tamb = 40 C to +125 C Min Typ[1] Max Min Max Unit 74HCT74 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V 3.84 4.32 - 3.7 - V LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 4.0 mA - 0.15 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 1.0 - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 40 - 80 A ICC additional supply current VI = VCC  2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A per input pin; nD, nRD inputs - 70 315 - 343 A per input pin; nSD, nCP input - 80 360 - 392 A - 3.5 - - - pF VOL input capacitance CI [1] IO = 4 mA All typical values are measured at Tamb = 25 C. 74HC_HCT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 6 of 20 74HC74; 74HCT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 10. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 9. Symbol Parameter Tamb = 40 C to +85 C Conditions Tamb = 40 C to +125 C Unit Min Typ[1] Max Min Max - 47 220 - 265 ns 74HC74 tpd propagation delay nCP to nQ, nQ; see Figure 7 [2] VCC = 2.0 V VCC = 4.5 V - 17 44 - 53 ns VCC = 5 V; CL = 15 pF - 14 - - - ns - 14 37 - 45 ns VCC = 2.0 V - 50 250 - 300 ns VCC = 4.5 V - 18 50 - 60 ns VCC = 5 V; CL = 15 pF - 15 - - - ns - 14 43 - 51 ns - 52 250 - 300 ns VCC = 6.0 V nSD to nQ, nQ; see Figure 8 [2] VCC = 6.0 V nRD to nQ, nQ; see Figure 8 [2] VCC = 2.0 V VCC = 4.5 V - 19 50 - 60 ns VCC = 5 V; CL = 15 pF - 16 - - - ns - 15 43 - 51 ns VCC = 6.0 V tt tW transition time pulse width nQ, nQ; see Figure 7 [3] VCC = 2.0 V - 19 95 - 110 ns VCC = 4.5 V - 7 19 - 22 ns VCC = 6.0 V - 6 16 - 19 ns VCC = 2.0 V 100 19 - 120 - ns VCC = 4.5 V 20 7 - 24 - ns VCC = 6.0 V 17 6 - 20 - ns VCC = 2.0 V 100 19 - 120 - ns VCC = 4.5 V 20 7 - 24 - ns VCC = 6.0 V 17 6 - 20 - ns VCC = 2.0 V 40 3 - 45 - ns VCC = 4.5 V 8 1 - 9 - ns VCC = 6.0 V 7 1 - 8 - ns nCP HIGH or LOW; see Figure 7 nSD, nRD LOW; see Figure 8 trec recovery time 74HC_HCT74 Product data sheet nSD, nRD; see Figure 8 All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 7 of 20 74HC74; 74HCT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 9. Symbol Parameter tsu th fmax set-up time hold time maximum frequency Tamb = 40 C to +85 C Conditions Min Max Min Max VCC = 2.0 V 75 6 - 90 - ns VCC = 4.5 V 15 2 - 18 - ns VCC = 6.0 V 13 2 - 15 - ns VCC = 2.0 V 3 6 - 3 - ns VCC = 4.5 V 3 2 - 3 - ns VCC = 6.0 V 3 2 - 3 - ns VCC = 2.0 V 4.8 23 - 4.0 - MHz VCC = 4.5 V 24 69 - 20 - MHz - 76 - - - MHz 28 82 - 24 - MHz - 24 - - - pF - 18 44 - 53 ns - 15 - - - ns - 23 50 - 60 ns - 18 - - - ns - 24 50 - 60 ns - 18 - - - ns - 7 19 - 22 ns 23 9 - 27 - ns 20 9 - 24 - ns 8 1 - 9 - ns 15 5 - 18 - ns nD to nCP; see Figure 7 nD to nCP; see Figure 7 nCP; see Figure 7 VCC = 5 V; CL = 15 pF VCC = 6.0 V CPD Tamb = 40 C to +125 C Unit Typ[1] power dissipation capacitance CL = 50 pF; f = 1 MHz; VI = GND to VCC [4] propagation delay nCP to nQ, nQ; see Figure 7 [2] 74HCT74 tpd VCC = 4.5 V VCC = 5 V; CL = 15 pF nSD to nQ, nQ; see Figure 8 [2] VCC = 4.5 V VCC = 5 V; CL = 15 pF nRD to nQ, nQ; see Figure 8 [2] VCC = 4.5 V VCC = 5 V; CL = 15 pF tt tW transition time nQ, nQ; see Figure 7 pulse width nCP HIGH or LOW; see Figure 7 VCC = 4.5 V VCC = 4.5 V [3] nSD, nRD LOW; see Figure 8 VCC = 4.5 V trec tsu recovery time nSD, nRD; see Figure 8 set-up time nD to nCP; see Figure 7 VCC = 4.5 V VCC = 4.5 V 74HC_HCT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 8 of 20 74HC74; 74HCT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 9. Symbol Parameter Tamb = 40 C to +85 C Conditions th hold time nD to nCP; see Figure 7 fmax maximum frequency nCP; see Figure 7 VCC = 4.5 V VCC = 4.5 V VCC = 5 V; CL = 15 pF power dissipation capacitance CPD [4] CL = 50 pF; f = 1 MHz; VI = GND to VCC - 1.5 V [1] All typical values are measured at Tamb = 25 C. [2] tpd is the same as tPLH and tPHL. Tamb = 40 C to +125 C Unit Min Typ[1] Max Min Max 3 3 - 3 - ns 22 54 - 18 - MHz - 59 - - - MHz - 29 - - - pF [3] tt is the same as tTHL and tTLH. [4] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74HC_HCT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 9 of 20 74HC74; 74HCT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 11. Waveforms 9, Q'LQSXW 90 *1' WK WK WVX WVX IPD[ 9, Q&3LQSXW 90 *1' W: W3+/ W3/+ 92+ 90 Q4RXWSXW 92/ W3/+ W3+/ 92+  Q4RXWSXW  90  92/  W7/+ W7+/ DDD Measurement points are given in Table 9. VOL and VOH are typical voltage output levels that occur with the output load. Fig 7. Input to output propagation delay, output transition time, clock input pulse width and maximum frequency 74HC_HCT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 10 of 20 74HC74; 74HCT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 9, 90 Q&3LQSXW *1' W UHF 9, 90 Q6'LQSXW *1' W: W: 9, 90 Q5'LQSXW *1' W 3/+ W 3+/ 92+ Q4RXWSXW 90 92/ 92+ 90 Q4RXWSXW 92/ W 3+/ W 3/+ PQD Measurement points are given in Table 9. VOL and VOH are typical voltage output levels that occur with the output load. Fig 8. Table 9. Set and reset propogation delays, pulse widths and recovery time Measurement points Type Input Output VM VM 74HC74 0.5VCC 0.5VCC 74HCT74 1.3 V 1.3 V 74HC_HCT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 11 of 20 74HC74; 74HCT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger W: 9, QHJDWLYH SXOVH  90 90  *1' WI 9, WI  SRVLWLYH SXOVH *1' WU WU 90 90  W: 9&& * 9, 92 '87 57 &/ DDK  Test data is given in Table 10. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig 9. Table 10. Test circuit for measuring switching times Test data Type Input VI tr, tf CL RL 74HC74 VCC 6 ns 15 pF, 50 pF 1 k tPLH, tPHL 74HCT74 3V 6 ns 15 pF, 50 pF 1 k tPLH, tPHL 74HC_HCT74 Product data sheet Load All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 December 2015 Test © Nexperia B.V. 2017. All rights reserved 12 of 20 74HC74; 74HCT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 12. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV        ș R R  1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 10. Package outline SOT108-1 (SO14) 74HC_HCT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 13 of 20 74HC74; 74HCT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 6623SODVWLFVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S /   GHWDLO; Z 0 ES H   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 11. Package outline SOT337-1 (SSOP14) 74HC_HCT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 14 of 20 74HC74; 74HCT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 12. Package outline SOT402-1 (TSSOP14) 74HC_HCT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 15 of 20 74HC74; 74HCT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger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ig 13. Package outline SOT762-1 (DHVQFN14) 74HC_HCT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 16 of 20 74HC74; 74HCT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 13. Abbreviations Table 11. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT74 v.5 20151203 Product data sheet - 74HC_HCT74 v.4 Modifications: 74HC_HCT74 v.4 Modifications: • Type numbers 74HC74N and 74HCT74N (SOT27-1) removed. 20120827 Product data sheet - 74HC_HCT74 v.3 • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • Legal texts have been adapted to the new company name where appropriate. 74HC_HCT74 v.3 20030710 Product data sheet - 74HC_HCT74_CNV v.2 74HC_HCT74_CNV v.2 19980223 Product specification - - 74HC_HCT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 17 of 20 74HC74; 74HCT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT74 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 18 of 20 74HC74; 74HCT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC_HCT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 December 2015 © Nexperia B.V. 2017. All rights reserved 19 of 20 74HC74; 74HCT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 17 Legal information. . . . . . . . . . . . . . . . . . . . . . . 18 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 18 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Contact information. . . . . . . . . . . . . . . . . . . . . 19 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 03 December 2015
74HC74PW,118
物料型号:74HC74 和 74HCT74
器件简介:74HC74 和 74HCT74 是双触发器,具有独立的时钟输入和清除输入。74HC74 是高速CMOS版本,而74HCT74 是CMOS与TTL电平兼容版本。
引脚分配:引脚1为清除,引脚2为时钟1,引脚3为数据输入1,引脚4为集电极,引脚5为集电极,引脚6为时钟2,引脚7为数据输入2,引脚8为Vcc,引脚14为GND。
参数特性:包括电源电压范围、功耗、工作温度范围、输入电压范围等。
功能详解:该器件具有两个独立的触发器,每个触发器可以存储一位二进制信息。触发器在时钟信号的上升沿或下降沿锁定数据。
应用信息:它们可以用于各种数字电路,如计数器、分频器、寄存器、脉冲整形等。
74HC74PW,118 价格&库存
很抱歉,暂时无法提供与“74HC74PW,118”相匹配的价格&库存,您可以联系我们找货
74HC74PW,118
  • 1+1.09340
  • 100+0.84150
  • 1250+0.71170
  • 2500+0.66000
库存:1
74HC74PW,118
  • 5+0.60624
  • 20+0.55275
  • 100+0.49925
  • 500+0.44576
  • 1000+0.42080
  • 2000+0.40297
