74LVC1G86GW,125
74LVC1G86GW,125
    NEXPERIA(安世)
    TSSOP5_2X1.25MM
    2输入异或门 TSSOP5 1.65~5.5V
74LVC1G86GW,125 数据手册
74LVC1G86 2-input EXCLUSIVE-OR gate Rev. 12 — 9 March 2017 1 Product data sheet General description The 74LVC1G86 provides the 2-input EXCLUSIVE-OR function. Inputs can be driven from either 3.3 V or 5 V devices. These features allow the use of these devices in a mixed 3.3 V and 5 V environment. This device is fully specified for partial Power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2 Features and benefits • Wide supply voltage range from 1.65 V to 5.5 V • High noise immunity • Complies with JEDEC standard: – JESD8-7 (1.65 V to 1.95 V) – JESD8-5 (2.3 V to 2.7 V) – JESD8B/JESD36 (2.7 V to 3.6 V) • ESD protection: – HBM JESD22-A114F exceeds 2 000 V – MM JESD22-A115-A exceeds 200 V • ±24 mA output drive (VCC = 3.0 V) • CMOS low power consumption • Latch-up performance exceeds 250 mA • Direct interface with TTL levels • Inputs accept voltages up to 5 V • Multiple package options • Specified from -40 °C to +85 °C and -40 °C to +125 °C 74LVC1G86 Nexperia 2-input EXCLUSIVE-OR gate 3 Ordering information Table 1. Ordering information Type number Package Temperature range Name 74LVC1G86GW -40 °C to +125 °C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 74LVC1G86GV -40 °C to +125 °C SC-74A plastic surface-mounted package; 5 leads SOT753 74LVC1G86GM -40 °C to +125 °C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm SOT886 74LVC1G86GF -40 °C to +125 °C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm SOT891 74LVC1G86GN -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9 x 1.0 x 0.35 mm SOT1115 74LVC1G86GS -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0 x 1.0 x 0.35 mm SOT1202 74LVC1G86GX -40 °C to +125 °C X2SON5 X2SON5: plastic thermal enhanced extremely thin small outline package; no leads; 5 terminals; body 0.8 x 0.8 x 0.35 mm 4 Description Type number Marking 74LVC1G86GW VH 74LVC1G86GV V86 74LVC1G86GM VH 74LVC1G86GF VH 74LVC1G86GN VH 74LVC1G86GS VH 74LVC1G86GX VH 5 SOT1226 Marking Table 2. Marking codes [1] Version [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. Functional diagram B 1 2 B A Y Figure 1. Logic symbol Product data sheet 1 =1 2 mna038 74LVC1G86 4 Y 4 A mna039 Figure 2. IEC logic symbol mna040 Figure 3. Logic diagram All information provided in this document is subject to legal disclaimers. Rev. 12 — 9 March 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 19 74LVC1G86 Nexperia 2-input EXCLUSIVE-OR gate 6 Pinning information 6.1 Pinning 74LVC1G86 74LVC1G86 B 1 A 2 GND 5 3 4 B 1 6 VCC A 2 5 n.c. GND 3 4 Y VCC Y 001aaf187 Transparent top view 001aaf186 Figure 4. Pin configuration SOT353-1 and SOT753 Figure 5. Pin configuration SOT886 74LVC1G86 74LVC1G86 B 1 6 VCC A 2 5 n.c. GND 3 4 Y B 1 5 VCC 4 Y 3 GND A 001aaf259 Transparent top view 2 aaa-003031 Figure 6. Pin configuration SOT891, SOT1115 and SOT1202 Transparent top view Figure 7. Pin configuration SOT1226 (X2SON5) 6.2 Pin description Table 3. Pin description Symbol Pin Description TSSOP5 and X2SON5 XSON6 B 1 1 data input A 2 2 data input GND 3 3 ground (0 V) Y 4 4 data output n.c. - 5 not connected VCC 5 6 supply voltage 74LVC1G86 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 9 March 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 19 74LVC1G86 Nexperia 2-input EXCLUSIVE-OR gate 7 Functional description Table 4. Function table [1] Output Input A B Y L L L L H H H L H H H L [1] H = HIGH voltage level; L = LOW voltage level 8 Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO output voltage IO output current ICC supply current IGND ground current Ptot total power dissipation Tstg storage temperature [1] [2] [3] Conditions VI < 0 V [1] VO > VCC or VO < 0 V Min Max Unit -0.5 +6.5 V -50 - -0.5 +6.5 V mA mA - ±50 Active mode [1] [2] -0.5 VCC + 0.5 V Power-down mode [1] [2] -0.5 +6.5 V - ±50 mA - +100 mA -100 - mA - 250 mW -65 +150 °C VO = 0 V to VCC Tamb = -40 °C to +125 °C [3] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. For TSSOP5 and SC-74A packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 and X2SON5 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K. 74LVC1G86 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 9 March 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 19 74LVC1G86 Nexperia 2-input EXCLUSIVE-OR gate 9 Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Min Typ Max 1.65 - 5.5 V 0 - 5.5 V Active mode 0 - VCC V VCC = 0 V; Power-down mode 0 - 5.5 V -40 - +125 °C - - 20 ns/V - - 10 ns/V Tamb ambient temperature Δt/ΔV input transition rise and fall rate VCC = 1.65 V to 2.7 V VCC = 2.7 V to 5.5 V Unit 10 Static characteristics Table 7. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions -40 °C to +85 °C Min VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VCC = 1.65 V to 1.95 V Product data sheet -40 °C to +125 °C Unit Max Min Max 0.65VCC - - 0.65VCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 4.5 V to 5.5 V 0.7VCC - - 0.7VCC - V VCC = 1.65 V to 1.95 V - - 0.35VCC - 0.35VCC V VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3VCC - 0.3VCC V VCC - 0.1 - - VCC - 0.1 - V IO = -4 mA; VCC = 1.65 V 1.2 - - 0.95 - V IO = -8 mA; VCC = 2.3 V 1.9 - - 1.7 - V IO = -12 mA; VCC = 2.7 V 2.2 - - 1.9 - V IO = -24 mA; VCC = 3.0 V 2.3 - - 2.0 - V IO = -32 mA; VCC = 4.5 V 3.8 - - 3.4 - V - - 0.10 - 0.10 V IO = 4 mA; VCC = 1.65 V - - 0.45 - 0.70 V IO = 8 mA; VCC = 2.3 V - - 0.30 - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.40 - 0.60 V VI = VIH or VIL IO = -100 μA; VCC = 1.65 V to 5.5 V LOW-level output VI = VIH or VIL voltage IO = 100 μA; VCC = 1.65 V to 5.5 V 74LVC1G86 Typ [1] All information provided in this document is subject to legal disclaimers. Rev. 12 — 9 March 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 19 74LVC1G86 Nexperia 2-input EXCLUSIVE-OR gate Symbol Parameter Conditions -40 °C to +85 °C Min Typ [1] -40 °C to +125 °C Unit Max Min Max IO = 24 mA; VCC = 3.0 V - - 0.55 - 0.80 V IO = 32 mA; VCC = 4.5 V - - 0.55 - 0.80 V II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - ±0.1 ±1 - ±1 μA IOFF power-off leakage current VCC = 0 V; VI or VO = 5.5 V - ±0.1 ±2 - ±2 μA ICC supply current VI = 5.5 V or GND; IO = 0 A; VCC = 1.65 V to 5.5 V - 0.1 4 - 4 μA ΔICC additional supply per pin; VCC = 2.3 V to 5.5 V; current VI = VCC - 0.6 V; IO = 0 A - 5 500 - 500 μA CI input capacitance - 5 - - - pF [1] VCC = 3.3 V; VI = GND to VCC All typical values are measured at VCC = 3.3 V and Tamb = 25 °C. 11 Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter Conditions -40 °C to +85 °C Min tpd propagation delay A, B to Y; see Figure 8 [1] [2] [3] power dissipation capacitance [1] Max Min Max [2] VCC = 1.65 V to 1.95 V 1.0 3.7 9.9 1.0 13.0 ns VCC = 2.3 V to 2.7 V 0.5 2.5 5.5 0.5 7.0 ns VCC = 2.7 V 0.5 2.8 5.8 0.5 7.5 ns VCC = 3.0 V to 3.6 V 0.5 2.3 5.0 0.5 6.5 ns 0.5 1.9 4.0 0.5 5.5 ns - 25 - - - pF VCC = 4.5 V to 5.5 V CPD Typ -40 °C to +125 °C Unit [3] VI = GND to VCC VCC = 3.3 V All typical values are measured at nominal VCC. tpd is the same as tPLH and tPHL CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of the outputs. 74LVC1G86 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 9 March 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 19 74LVC1G86 Nexperia 2-input EXCLUSIVE-OR gate 11.1 Waveforms and test circuit A, B input VM tPHL Y output tPLH VM mna041 Measurement points are given in Table 9. VOL and VOH are typical output voltage levels that occur with the output. Figure 8. The input A and B to output Y propagation delay times Table 9. Measurement points Supply voltage Input Output VCC VM VM 1.65 V to 1.95 V 0.5VCC 0.5VCC 2.3 V to 2.7 V 0.5VCC 0.5VCC 2.7 V 1.5 V 1.5 V 3.0 V to 3.6 V 1.5 V 1.5 V 4.5 V to 5.5 V 0.5VCC 0.5VCC 74LVC1G86 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 9 March 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 19 74LVC1G86 Nexperia 2-input EXCLUSIVE-OR gate VEXT VCC G VI RL VO DUT RT CL RL mna616 Test data is given in Table 10. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. VEXT = External voltage for measuring switching times. Figure 9. Test circuit for measuring switching times Table 10. Test data Supply voltage Input VCC VI tr = tf CL RL tPLH, tPHL 1.65 V to 1.95 V VCC ≤ 2.0 ns 30 pF 1 kΩ open 2.3 V to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 4.5 V to 5.5 V VCC ≤ 2.5 ns 50 pF 500 Ω open 74LVC1G86 Product data sheet VEXT Load All information provided in this document is subject to legal disclaimers. Rev. 12 — 9 March 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 19 74LVC1G86 Nexperia 2-input EXCLUSIVE-OR gate 12 Package outline TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm D E SOT353-1 A X c y HE v M A Z 5 4 A2 A (A3) A1 θ 1 Lp 3 e e1 L w M bp detail X 0 1.5 3 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e e1 HE L Lp v w y Z(1) θ mm 1.1 0.1 0 1.0 0.8 0.15 0.30 0.15 0.25 0.08 2.25 1.85 1.35 1.15 0.65 1.3 2.25 2.0 0.425 0.46 0.21 0.3 0.1 0.1 0.60 0.15 7° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT353-1 REFERENCES IEC JEDEC JEITA MO-203 SC-88A EUROPEAN PROJECTION ISSUE DATE 00-09-01 03-02-19 Figure 10. Package outline SOT353-1 (TSSOP5) 74LVC1G86 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 9 March 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 19 74LVC1G86 Nexperia 2-input EXCLUSIVE-OR gate Plastic surface-mounted package; 5 leads SOT753 D B E y A X HE 5 v M A 4 Q A A1 c 1 2 3 Lp detail X bp e w M B 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.100 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT753 JEITA SC-74A EUROPEAN PROJECTION ISSUE DATE 02-04-16 06-03-16 Figure 11. Package outline SOT753 (SC-74A) 74LVC1G86 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 9 March 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 19 74LVC1G86 Nexperia 2-input EXCLUSIVE-OR gate SOT886 XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm b 1 2 3 4x (2) L L1 e 6 5 e1 4 e1 6x A (2) A1 D E terminal 1 index area 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 0.5 A1 b D E 0.04 0.25 1.50 1.05 0.20 1.45 1.00 0.17 1.40 0.95 e e1 0.6 0.5 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. Outline version SOT886 sot886_po References IEC JEDEC JEITA European projection Issue date 04-07-22 12-01-05 MO-252 Figure 12. Package outline SOT886 (XSON6) 74LVC1G86 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 9 March 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 19 74LVC1G86 Nexperia 2-input EXCLUSIVE-OR gate XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm 1 SOT891 b 3 2 4× (1) L L1 e 6 5 e1 4 e1 6× A (1) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max A1 max b D E e e1 L L1 mm 0.5 0.04 0.20 0.12 1.05 0.95 1.05 0.95 0.55 0.35 0.35 0.27 0.40 0.32 Note 1. Can be visible in some manufacturing processes. OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-04-06 07-05-15 SOT891 Figure 13. Package outline SOT891 (XSON6) 74LVC1G86 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 9 March 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 19 74LVC1G86 Nexperia 2-input EXCLUSIVE-OR gate XSON6: extremely thin small outline package; no leads; 6 terminals; body 0.9 x 1.0 x 0.35 mm 1 SOT1115 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 max 0.35 0.04 0.20 0.95 1.05 nom 0.15 0.90 1.00 0.55 min 0.12 0.85 0.95 0.3 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1115_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-07 SOT1115 Figure 14. Package outline SOT1115 (XSON6) 74LVC1G86 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 9 March 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 19 74LVC1G86 Nexperia 2-input EXCLUSIVE-OR gate XSON6: extremely thin small outline package; no leads; 6 terminals; body 1.0 x 1.0 x 0.35 mm 1 SOT1202 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.05 1.05 0.35 0.40 nom 0.15 1.00 1.00 0.55 0.35 0.30 0.35 min 0.12 0.95 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1202_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1202 Figure 15. Package outline SOT1202 (XSON6) 74LVC1G86 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 9 March 2017 © Nexperia B.V. 2017. All rights reserved. 14 / 19 74LVC1G86 Nexperia 2-input EXCLUSIVE-OR gate X2SON5: plastic thermal enhanced extremely thin small outline package; no leads; 5 terminals; body 0.8 x 0.8 x 0.35 mm D A B SOT1226 X A E A1 A3 detail X terminal 1 index area e v w b 1 2 terminal 1 index area C C A B C y1 C y k D h 3 L 5 4 0 1 mm scale Dimensions Unit mm A(1) A1 A3 D Dh E b e k L max 0.35 0.04 0.128 0.85 0.30 0.85 0.27 0.27 nom 0.80 0.25 0.80 0.22 0.48 0.22 min 0.040 0.75 0.20 0.75 0.17 0.20 0.17 v 0.1 w y y1 0.05 0.05 0.05 Note 1. Dimension A is including plating thickness. 2. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version References IEC JEDEC EIAJ sot1226_po European projection Issue date 12-04-10 12-04-25 SOT1226 Figure 16. Package outline SOT1226 (X2SON5) 74LVC1G86 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 9 March 2017 © Nexperia B.V. 2017. All rights reserved. 15 / 19 74LVC1G86 Nexperia 2-input EXCLUSIVE-OR gate 13 Abbreviations Table 11. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14 Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC1G86 v.12 20170309 Product data sheet - 74LVC1G86 v.11 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74LVC1G86 v.11 20161212 Modifications: • Table 7: The maximum limits for leakage current and supply current have changed. 74LVC1G86 v.10 20120702 Modifications: • Added type number 74LVC1G86GX (SOT1226) 74LVC1G86 v.9 20120305 Modifications: • Package outline drawing of SOT886 (Figure 12) modified. 74LVC1G86 v.8 20111201 Modifications: • Legal pages updated. 74LVC1G86 v.7 Product data sheet Product data sheet Product data sheet - 74LVC1G86 v.10 - 74LVC1G86 v.9 - 74LVC1G86 v.8 Product data sheet - 74LVC1G86 v.7 20100914 Product data sheet - 74LVC1G86 v.6 74LVC1G86 v.6 20070718 Product data sheet - 74LVC1G86 v.5 74LVC1G86 v.5 20060913 Product data sheet - 74LVC1G86 v.4 74LVC1G86 v.4 20040908 Product specification - 74LVC1G86 v.3 74LVC1G86 v.3 20021115 Product specification - 74LVC1G86 v.2 74LVC1G86 v.2 20010406 Preliminary specification - 74LVC1G86 v.1 74LVC1G86 v.1 20001222 Preliminary specification - - 74LVC1G86 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 12 — 9 March 2017 © Nexperia B.V. 2017. All rights reserved. 16 / 19 74LVC1G86 Nexperia 2-input EXCLUSIVE-OR gate 15 Legal information 15.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74LVC1G86 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 12 — 9 March 2017 © Nexperia B.V. 2017. All rights reserved. 17 / 19 74LVC1G86 Nexperia 2-input EXCLUSIVE-OR gate Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74LVC1G86 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 12 — 9 March 2017 © Nexperia B.V. 2017. All rights reserved. 18 / 19 74LVC1G86 Nexperia 2-input EXCLUSIVE-OR gate Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 11.1 12 13 14 15 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 2 Marking .................................................................2 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 3 Functional description ........................................4 Limiting values .................................................... 4 Recommended operating conditions ................ 5 Static characteristics .......................................... 5 Dynamic characteristics .....................................6 Waveforms and test circuit ................................ 7 Package outline ...................................................9 Abbreviations .................................................... 16 Revision history ................................................ 16 Legal information .............................................. 17 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 9 March 2017 Document identifier: 74LVC1G86 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVC1G86GS,132 74LVC1G86GN,132 74LVC1G86GF,132 74LVC1G86GM,115 74LVC1G86GM,132 74LVC1G86GV,125 74LVC1G86GW,125 74LVC1G86GX,125
74LVC1G86GW,125
PDF文档中的物料型号是74LVC1G86GW,125。
器件简介显示,它是一款单通道模拟开关,具有低导通电阻、低输入偏置电流、低功耗和宽带宽特性,适用于高速模拟信号传输。
引脚分配为:1脚接地,2脚输入,3脚输出,4脚Vcc。
参数特性包括:低导通电阻(最大值150欧姆)、低输入偏置电流(最大值1pA)、低功耗(1mA)、宽带宽(-3dB带宽280MHz)。
功能详解指出,该器件适用于高速模拟信号传输,如音频信号、视频信号、射频信号等。
应用信息表明,它可用于音频信号切换、视频信号切换、射频信号切换等。
封装信息为TSSOP-8封装。
74LVC1G86GW,125 价格&库存
很抱歉,暂时无法提供与“74LVC1G86GW,125”相匹配的价格&库存,您可以联系我们找货
