PTVSxP1UP series
600 W Transient Voltage Suppressor
Rev. 2 — 6 January 2011
Product data sheet
1. Product profile
1.1 General description
600 W unidirectional Transient Voltage Suppressor (TVS) in a SOD128 small and flat lead
Surface-Mounted Device (SMD) plastic package, designed for transient overvoltage
protection.
1.2 Features and benefits
Rated peak pulse power: PPPM = 600 W Very low package height: 1 mm
Small plastic package suitable for
Reverse standoff voltage range:
surface-mounted design
VRWM = 3.3 V to 64 V
AEC-Q101 qualified
Reverse current: IRM = 0.001 μA
1.3 Applications
Power supply protection
Automotive application
Industrial application
Power management
1.4 Quick reference data
Table 1.
Symbol
Parameter
PPPM
rated peak pulse power
VRWM
reverse standoff voltage
[1]
Conditions
[1]
In accordance with IEC 61643-321 (10/1000 μs current waveform).
Min
Typ
Max
Unit
600
W
3.3
64
V
PTVSxP1UP series
Nexperia
2. Pinning information
Table 2.
Pinning
Pin
Description
1
cathode
2
anode
Simplified outline
Graphic symbol
[1]
1
1
2
2
sym035
[1]
The marking bar indicates the cathode.
3. Ordering information
Table 3.
Type number[1]
Package
PTVSxP1UP series
[1]
Name
Description
Version
plastic surface-mounted package; 2 leads
SOD128
The series consists of 35 types with reverse standoff voltages from 3.3 V to 64 V.
4. Marking
Table 4.
PTVSXP1UP_SER
Product data sheet
Marking codes
Type number
Marking code
Type number
Marking code
PTVS3V3P1UP
AJ
PTVS20VP1UP
B3
PTVS5V0P1UP
AK
PTVS22VP1UP
B4
PTVS6V0P1UP
AL
PTVS24VP1UP
B5
PTVS6V5P1UP
AM
PTVS26VP1UP
B6
PTVS7V0P1UP
AN
PTVS28VP1UP
B7
PTVS7V5P1UP
AP
PTVS30VP1UP
B8
PTVS8V0P1UP
AQ
PTVS33VP1UP
B9
PTVS8V5P1UP
AR
PTVS36VP1UP
BA
PTVS9V0P1UP
AS
PTVS40VP1UP
BB
PTVS10VP1UP
AT
PTVS43VP1UP
BC
PTVS11VP1UP
AU
PTVS45VP1UP
BD
PTVS12VP1UP
AV
PTVS48VP1UP
BE
PTVS13VP1UP
AW
PTVS51VP1UP
BF
PTVS14VP1UP
AX
PTVS54VP1UP
BG
PTVS15VP1UP
AY
PTVS58VP1UP
BH
PTVS16VP1UP
AZ
PTVS60VP1UP
BJ
PTVS17VP1UP
B1
PTVS64VP1UP
BK
PTVS18VP1UP
B2
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 12
PTVSxP1UP series
Nexperia
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Min
Max
Unit
[1]
600
W
IPPM
rated peak pulse current
[1]
see
Table 9
and 10
IFSM
Non-repetitive peak
forward current
100
A
Tj
junction temperature
150
°C
Tamb
ambient temperature
−55
+150
°C
Tstg
storage temperature
−65
+150
°C
PPPM
[1]
Parameter
Conditions
single half-sine
wave; tp = 8.3 ms
Table 6.
ESD maximum ratings
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
electrostatic discharge voltage
IEC 61000-4-2
(contact discharge)
Min
Max
Unit
30
kV
Per diode
VESD
[1][2]
[1]
Device stressed with ten non-repetitive ElectroStatic Discharge (ESD) pulses.
[2]
Soldering point of cathode tab.
Table 7.
ESD standards compliance
Standard
Conditions
Per diode
IEC 61000-4-2; level 4 (ESD)
> 15 kV (air); > 8 kV (contact)
MIL-STD-883; class 3 (human body model)
> 4 kV
6. Thermal characteristics
Table 8.
Symbol
Rth(j-a)
Rth(j-sp)
PTVSXP1UP_SER
Product data sheet
Parameter
Conditions
thermal resistance from
junction to ambient
in free air
junction to solder point
Min
Typ
Max
Unit
[1]
200
K/W
[2]
120
K/W
[3]
60
K/W
[4]
12
K/W
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
[2]
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2.
[3]
Device mounted on a ceramic PCB, Al2O3, standard footprint.
[4]
3 of 12
PTVSxP1UP series
Nexperia
7. Characteristics
Table 9.
Characteristics per type; PTVS3V3P1UP to PTVS7V0P1UP
Tj = 25 °C unless otherwise specified.
Type number
Reverse standoff
voltage
Breakdown voltage
VBR (V)
VRWM (V)
Reverse leakage
current
Clamping voltage
VCL (V)
IRM (μA)
IR = 10 mA
at VRWM (V)
Max
Min
Typ
Max
Typ
Max
Max
IPPM (A)
PTVS3V3P1UP
3.3
5.20
5.60
6.00
5
600
8.0
75.0
PTVS5V0P1UP
5.0
6.40
6.70
7.00
5
400
9.2
65.2
PTVS6V0P1UP
6.0
6.67
7.02
7.37
5
400
10.3
58.3
PTVS6V5P1UP
6.5
7.22
7.60
7.98
5
250
11.2
53.6
PTVS7V0P1UP
7.0
7.78
8.20
8.60
3
100
12.0
50.0
Table 10. Characteristics per type; PTVS7V5P1UP to PTVS64VP1UP
Type number
Reverse standoff
voltage
Breakdown voltage
VBR (V)
VRWM (V)
Reverse leakage
current
Clamping voltage
VCL (V)
IRM (μA)
IR = 1 mA
at VRWM (V)
Max
Min
Typ
Max
Typ
Max
Max
IPPM (A)
PTVS7V5P1UP
7.5
8.33
8.77
9.21
0.2
50
12.9
46.5
PTVS8V0P1UP
8.0
8.89
9.36
9.83
0.03
25
13.6
44.1
PTVS8V5P1UP
8.5
9.44
9.92
10.40
0.01
10
14.4
41.7
PTVS9V0P1UP
9.0
10.00
10.55
11.10
0.005
5
15.4
39.0
PTVS10VP1UP
10
11.10
11.70
12.30
0.005
2.5
17.0
35.3
PTVS11VP1UP
11
12.20
12.85
13.50
0.005
2.5
18.2
33.0
PTVS12VP1UP
12
13.30
14.00
14.70
0.005
2.5
19.9
30.2
PTVS13VP1UP
13
14.40
15.15
15.90
0.001
0.1
21.5
27.9
PTVS14VP1UP
14
15.60
16.40
17.20
0.001
0.1
23.2
25.9
PTVS15VP1UP
15
16.70
17.60
18.50
0.001
0.1
24.4
24.6
PTVS16VP1UP
16
17.80
18.75
19.70
0.001
0.1
26.0
23.1
PTVS17VP1UP
17
18.90
19.90
20.90
0.001
0.1
27.6
21.7
PTVS18VP1UP
18
20.00
21.00
22.10
0.001
0.1
29.2
20.5
PTVS20VP1UP
23.35
24.50
0.001
0.1
32.4
18.5
PTVS22VP1UP
22
24.40
25.60
26.90
0.001
0.1
35.5
16.9
PTVS24VP1UP
24
26.70
28.10
29.50
0.001
0.1
38.9
15.4
PTVS26VP1UP
26
28.90
30.40
31.90
0.001
0.1
42.1
14.3
PTVS28VP1UP
28
31.10
32.80
34.40
0.001
0.1
45.4
13.2
PTVS30VP1UP
30
33.30
35.10
36.80
0.001
0.1
48.4
12.4
PTVS33VP1UP
33
36.70
38.70
40.60
0.001
0.1
53.3
11.3
PTVS36VP1UP
36
40.00
42.10
44.20
0.001
0.1
58.1
10.3
PTVS40VP1UP
40
44.40
46.80
49.10
0.001
0.1
64.5
9.3
PTVSXP1UP_SER
Product data sheet
4 of 12
PTVSxP1UP series
Nexperia
Table 10. Characteristics per type; PTVS7V5P1UP to PTVS64VP1UP …continued
Type number
Reverse standoff
voltage
Breakdown voltage
VBR (V)
VRWM (V)
Reverse leakage
current
Clamping voltage
VCL (V)
IRM (μA)
IR = 1 mA
at VRWM (V)
Max
Min
Typ
Max
Typ
Max
Max
IPPM (A)
PTVS43VP1UP
43
47.80
50.30
52.80
0.001
0.1
69.4
8.6
PTVS45VP1UP
45
50.00
52.65
55.30
0.001
0.1
72.7
8.3
PTVS48VP1UP
48
53.30
56.10
58.90
0.001
0.1
77.4
7.8
PTVS51VP1UP
51
56.70
59.70
62.70
0.001
0.1
82.4
7.3
PTVS54VP1UP
54
60.00
63.15
66.30
0.001
0.1
87.1
6.9
PTVS58VP1UP
58
64.40
67.80
71.20
0.001
0.1
93.6
6.4
PTVS60VP1UP
60
66.70
70.20
73.70
0.001
0.1
96.8
6.2
PTVS64VP1UP
64
71.10
74.85
78.60
0.001
0.1
103.0
5.8
PTVSXP1UP_SER
Product data sheet
5 of 12
PTVSxP1UP series
Nexperia
006aab319
150
006aab321
1.2
PPPM
IPP
PPPM(25°C)
100 % IPP; 10 μs
100
0.8
50 % IPP; 1000 μs
0.4
50
2.0
3.0
50
100
150
Fig 1.
10/1000 μs pulse waveform according to
IEC 61643-321
006aac172
105
200
Tj (°C)
tp (ms)
PPPM
(W)
Fig 2.
Relative variation of rated peak pulse power as
a function of junction temperature; typical
values
006aac173
104
Cd
(pF)
104
(1)
103
(2)
(3)
103
102
102
10−1
1
10
102
103
(4)
10
104
1
tp (μs)
102
10
VR (V)
Tamb = 25 °C
Tamb = 25 °C; f = 1 MHz
(1) PTVS5V0P1UP
(2) PTVS12VP1UP
(3) PTVS24VP1UP
(4) PTVS64VP1UP
Fig 3.
Rated peak pulse power as a function of pulse
duration; typical values
PTVSXP1UP_SER
Product data sheet
Fig 4.
Diode capacitance as a function of reverse
voltage; typical values
6 of 12
PTVSxP1UP series
Nexperia
I
−VCL −VBR −VRWM
V
−IRM
−IR
P-N
−IPP
−IPPM
Fig 5.
006aab324
V-I characteristics for a unidirectional TVS protection diode
8. Test information
8.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
9. Package outline
2.7
2.3
1.1
0.9
0.6
0.3
1
5.0
4.4
4.0
3.6
2
1.9
1.6
Dimensions in mm
Fig 6.
PTVSXP1UP_SER
Product data sheet
0.22
0.10
07-09-12
Package outline SOD128
7 of 12
PTVSxP1UP series
Nexperia
10. Packing information
Table 11. Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number[2]
Package
Description
Packing quantity
3000
PTVSxP1UP series SOD128
4 mm pitch, 12 mm tape and reel
-115
[1]
For further information and the availability of packing methods, see Section 14.
[2]
11. Soldering
6.2
4.4
4.2
solder lands
solder resist
1.9 2.1
(2×) (2×)
3.4 2.5
solder paste
occupied area
Dimensions in mm
1.2
(2×)
1.4
(2×)
sod128_fr
Reflow soldering is the only recommended soldering method.
Fig 7.
PTVSXP1UP_SER
Product data sheet
Reflow soldering footprint SOD128
8 of 12
PTVSxP1UP series
Nexperia
12. Revision history
Table 12.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PTVSXP1UP_SER v.2
20110106
Product data sheet
PTVSXP1UP_SER v.1
Modifications:
PTVSXP1UP_SER v.1
PTVSXP1UP_SER
Product data sheet
Table 6 “ESD maximum ratings”: added.
Section 13 “Legal information”: updated.
20100527
Product data sheet
9 of 12
PTVSxP1UP series
Nexperia
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
13.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
PTVSXP1UP_SER
Product data sheet
10 of 12
PTVSxP1UP series
Nexperia
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
13.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
14. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PTVSXP1UP_SER
Product data sheet
11 of 12
Nexperia
PTVSxP1UP series
15. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
8.1
9
10
11
12
13
13.1
13.2
13.3
13.4
14
15
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Thermal characteristics . . . . . . . . . . . . . . . . . . 3
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 7
Quality information . . . . . . . . . . . . . . . . . . . . . . 7
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7
Packing information . . . . . . . . . . . . . . . . . . . . . 8
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9
Legal information. . . . . . . . . . . . . . . . . . . . . . . 10
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . 11
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Date of release: 06 January 2011
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
PTVS3V3P1UP,115 PTVS64VP1UP,115 PTVS10VP1UP,115 PTVS11VP1UP,115 PTVS12VP1UP,115
PTVS13VP1UP,115 PTVS14VP1UP,115 PTVS15VP1UP,115 PTVS16VP1UP,115 PTVS17VP1UP,115
PTVS18VP1UP,115 PTVS20VP1UP,115 PTVS22VP1UP,115 PTVS24VP1UP,115 PTVS26VP1UP,115
PTVS28VP1UP,115 PTVS30VP1UP,115 PTVS33VP1UP,115 PTVS36VP1UP,115 PTVS40VP1UP,115
PTVS43VP1UP,115 PTVS45VP1UP,115 PTVS48VP1UP,115 PTVS51VP1UP,115 PTVS54VP1UP,115
PTVS58VP1UP,115 PTVS5V0P1UP,115 PTVS60VP1UP,115 PTVS6V0P1UP,115 PTVS6V5P1UP,115
PTVS7V0P1UP,115 PTVS7V5P1UP,115 PTVS8V0P1UP,115 PTVS8V5P1UP,115 PTVS9V0P1UP,115
