PTVSxS1UR series
400 W Transient Voltage Suppressor
Rev. 3 — 10 January 2011
Product data sheet
1. Product profile
1.1 General description
400 W unidirectional Transient Voltage Suppressor (TVS) in a SOD123W small and flat
lead low-profile Surface-Mounted Device (SMD) plastic package, designed for transient
overvoltage protection.
1.2 Features and benefits
Rated peak pulse power:
PPPM = 400 W (350 W for 3V3)
Reverse standoff voltage range:
VRWM = 3.3 V to 64 V
Reverse current: IRM = 0.001 μA
Small plastic package suitable for
surface-mounted design
Very low package height: 1 mm
AEC-Q101 qualified
1.3 Applications
Power supply protection
Automotive application
Industrial application
Power management
1.4 Quick reference data
Table 1.
Symbol
Parameter
PPPM
rated peak pulse power
VRWM
reverse standoff voltage
Conditions
[1][2]
[1]
In accordance with IEC 61643-321 (10/1000 μs current waveform).
[2]
For PTVS3V3S1UR: PPPM = 350 W
Min
Typ
Max
Unit
400
W
3.3
64
V
PTVSxS1UR series
Nexperia
2. Pinning information
Table 2.
Pinning
Pin
Description
1
cathode
2
anode
Simplified outline
Graphic symbol
[1]
1
2
2
1
006aaa152
[1]
The marking bar indicates the cathode.
3. Ordering information
Table 3.
Type number[1]
Package
PTVSxS1UR series
[1]
Name
Description
Version
plastic surface-mounted package; 2 leads
SOD123W
The series consists of 35 types with reverse standoff voltages from 3.3 V to 64 V.
4. Marking
Table 4.
PTVSxS1UR_SER
Product data sheet
Marking codes
Type number
Marking code
Type number
Marking code
PTVS3V3S1UR
A1
PTVS20VS1UR
AL
PTVS5V0S1UR
A2
PTVS22VS1UR
AM
PTVS6V0S1UR
A3
PTVS24VS1UR
AN
PTVS6V5S1UR
A4
PTVS26VS1UR
AP
PTVS7V0S1UR
A5
PTVS28VS1UR
AR
PTVS7V5S1UR
A6
PTVS30VS1UR
AS
PTVS8V0S1UR
A7
PTVS33VS1UR
AT
PTVS8V5S1UR
A8
PTVS36VS1UR
AU
PTVS9V0S1UR
A9
PTVS40VS1UR
AV
PTVS10VS1UR
AA
PTVS43VS1UR
AW
PTVS11VS1UR
AB
PTVS45VS1UR
AX
PTVS12VS1UR
AC
PTVS48VS1UR
AY
PTVS13VS1UR
AD
PTVS51VS1UR
AZ
PTVS14VS1UR
AE
PTVS54VS1UR
B1
PTVS15VS1UR
AF
PTVS58VS1UR
B2
PTVS16VS1UR
AG
PTVS60VS1UR
B3
PTVS17VS1UR
AH
PTVS64VS1UR
B4
PTVS18VS1UR
AK
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 12
PTVSxS1UR series
Nexperia
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
PPPM
Parameter
Conditions
Min
Max
Unit
[1][2]
400
W
[1]
see
Table 9
and 10
50
A
IPPM
rated peak pulse current
IFSM
Non-repetitive peak
forward current
Tj
junction temperature
150
°C
Tamb
ambient temperature
−55
+150
°C
Tstg
storage temperature
−65
+150
°C
single half-sine
wave; tp = 8.3 ms
[1]
[2]
Table 6.
ESD maximum ratings
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
electrostatic discharge voltage
IEC 61000-4-2
(contact discharge)
Min
Max
Unit
30
kV
Per diode
VESD
[1][2]
[1]
Device stressed with ten non-repetitive ElectroStatic Discharge (ESD) pulses.
[2]
Soldering point of cathode tab.
Table 7.
ESD standards compliance
Standard
Conditions
Per diode
PTVSxS1UR_SER
Product data sheet
IEC 61000-4-2; level 4 (ESD)
> 15 kV (air); > 8 kV (contact)
MIL-STD-883; class 3 (human body model)
> 4 kV
3 of 12
PTVSxS1UR series
Nexperia
6. Thermal characteristics
Table 8.
Symbol
Rth(j-a)
Rth(j-sp)
Parameter
Conditions
thermal resistance from
junction to ambient
in free air
junction to solder point
Min
Typ
Max
Unit
[1]
220
K/W
[2]
130
K/W
[3]
70
K/W
[4]
18
K/W
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
[2]
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2.
[3]
Device mounted on a ceramic PCB, Al2O3, standard footprint.
[4]
7. Characteristics
Table 9.
Characteristics per type; PTVS3V3S1UR to PTVS7V0S1UR
Tj = 25 °C unless otherwise specified.
Type number
Reverse standoff
voltage
Breakdown voltage
VBR (V)
VRWM (V)
Clamping voltage
VCL (V)
IRM (μA)
IR = 10 mA
PTVS3V3S1UR
Reverse leakage
current
at VRWM (V)
Max
Min
Typ
Max
Typ
Max
Max
IPPM (A)
3.3
5.20
5.60
6.00
5
600
8.0
43.8
PTVS5V0S1UR
5.0
6.40
6.70
7.00
5
400
9.2
43.5
PTVS6V0S1UR
6.0
6.67
7.02
7.37
5
400
10.3
38.8
PTVS6V5S1UR
6.5
7.22
7.60
7.98
5
250
11.2
35.7
PTVS7V0S1UR
7.0
7.78
8.20
8.60
3
100
12.0
33.3
Table 10. Characteristics per type; PTVS7V5S1UR to PTVS64VS1UR
Type number
Reverse standoff
voltage
Breakdown voltage
VBR (V)
VRWM (V)
Clamping voltage
VCL (V)
IRM (μA)
IR = 1 mA
Max
Reverse leakage
current
at VRWM (V)
Min
Typ
Max
Typ
Max
Max
IPPM (A)
PTVS7V5S1UR
7.5
8.33
8.77
9.21
0.2
50
12.9
31.0
PTVS8V0S1UR
8.0
8.89
9.36
9.83
0.03
25
13.6
29.4
PTVS8V5S1UR
8.5
9.44
9.92
10.40
0.01
10
14.4
27.8
PTVS9V0S1UR
9.0
10.00
10.55
11.10
0.005
5
15.4
26.0
PTVS10VS1UR
10
11.10
11.70
12.30
0.005
2.5
17.0
23.5
PTVS11VS1UR
11
12.20
12.85
13.50
0.005
2.5
18.2
22.0
PTVS12VS1UR
12
13.30
14.00
14.70
0.005
2.5
19.9
20.1
PTVS13VS1UR
13
14.40
15.15
15.90
0.001
0.1
21.5
18.6
PTVSxS1UR_SER
Product data sheet
4 of 12
PTVSxS1UR series
Nexperia
Table 10. Characteristics per type; PTVS7V5S1UR to PTVS64VS1UR …continued
Type number
Reverse standoff
voltage
Breakdown voltage
VBR (V)
VRWM (V)
Reverse leakage
current
Clamping voltage
VCL (V)
IRM (μA)
IR = 1 mA
at VRWM (V)
Max
Min
Typ
Max
Typ
Max
Max
IPPM (A)
PTVS14VS1UR
14
15.60
16.40
17.20
0.001
0.1
23.2
17.2
PTVS15VS1UR
15
16.70
17.60
18.50
0.001
0.1
24.4
16.4
PTVS16VS1UR
16
17.80
18.75
19.70
0.001
0.1
26.0
15.4
PTVS17VS1UR
17
18.90
19.90
20.90
0.001
0.1
27.6
14.5
PTVS18VS1UR
18
20.00
21.00
22.10
0.001
0.1
29.2
13.7
PTVS20VS1UR
23.35
24.50
0.001
0.1
32.4
12.3
PTVS22VS1UR
22
24.40
25.60
26.90
0.001
0.1
35.5
11.3
PTVS24VS1UR
24
26.70
28.10
29.50
0.001
0.1
38.9
10.3
PTVS26VS1UR
26
28.90
30.40
31.90
0.001
0.1
42.1
9.5
PTVS28VS1UR
28
31.10
32.80
34.40
0.001
0.1
45.4
8.8
PTVS30VS1UR
30
33.30
35.10
36.80
0.001
0.1
48.4
8.3
PTVS33VS1UR
33
36.70
38.70
40.60
0.001
0.1
53.3
7.5
PTVS36VS1UR
36
40.00
42.10
44.20
0.001
0.1
58.1
6.9
PTVS40VS1UR
40
44.40
46.80
49.10
0.001
0.1
64.5
6.2
PTVS43VS1UR
43
47.80
50.30
52.80
0.001
0.1
69.4
5.8
PTVS45VS1UR
45
50.00
52.65
55.30
0.001
0.1
72.7
5.5
PTVS48VS1UR
48
53.30
56.10
58.90
0.001
0.1
77.4
5.2
PTVS51VS1UR
51
56.70
59.70
62.70
0.001
0.1
82.4
4.9
PTVS54VS1UR
54
60.00
63.15
66.30
0.001
0.1
87.1
4.6
PTVS58VS1UR
58
64.40
67.80
71.20
0.001
0.1
93.6
4.3
PTVS60VS1UR
60
66.70
70.20
73.70
0.001
0.1
96.8
4.1
PTVS64VS1UR
64
71.10
74.85
78.60
0.001
0.1
103.0
3.9
PTVSxS1UR_SER
Product data sheet
5 of 12
PTVSxS1UR series
Nexperia
006aab319
150
006aab321
1.2
PPPM
IPP
PPPM(25°C)
100 % IPP; 10 μs
100
0.8
50 % IPP; 1000 μs
0.4
50
2.0
3.0
50
100
150
Fig 1.
200
Tj (°C)
tp (ms)
10/1000 μs pulse waveform according to
IEC 61643-321
Fig 2.
Relative variation of rated peak pulse power as
a function of junction temperature; typical
values
006aab418
105
PPPM
(W)
104
(1)
(2)
103
102
10−1
1
10
102
103
104
tp (μs)
Tamb = 25 °C
(1) PTVS5V0S1UR to PTVS64VS1UR
(2) PTVS3V3S1UR
Fig 3.
Rated peak pulse power as a function of pulse duration; typical values
PTVSxS1UR_SER
Product data sheet
6 of 12
PTVSxS1UR series
Nexperia
I
−VCL −VBR −VRWM
V
−IRM
−IR
P-N
−IPP
−IPPM
Fig 4.
006aab324
V-I characteristics for a unidirectional TVS protection diode
8. Test information
8.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
9. Package outline
1.9
1.5
1.1
0.9
1
0.6
0.3
3.7
3.3
2.8
2.4
2
1.05
0.75
Dimensions in mm
Fig 5.
PTVSxS1UR_SER
Product data sheet
0.22
0.10
08-11-06
Package outline SOD123W
7 of 12
PTVSxS1UR series
Nexperia
10. Packing information
Table 11. Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number[2]
Package
Description
Packing quantity
3000
PTVSxS1UR series SOD123W
4 mm pitch, 8 mm tape and reel
-115
[1]
For further information and the availability of packing methods, see Section 14.
[2]
11. Soldering
4.4
2.9
2.8
solder lands
solder resist
1.1 1.2
(2×) (2×)
2.1 1.6
solder paste
occupied area
1.1
(2×)
1.2
(2×)
Dimensions in mm
sod123w_fr
Reflow soldering is the only recommended soldering method.
Fig 6.
PTVSxS1UR_SER
Product data sheet
Reflow soldering footprint SOD123W
8 of 12
PTVSxS1UR series
Nexperia
12. Revision history
Table 12.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PTVSXS1UR_SER v.3
20110110
Product data sheet
PTVSXS1UR_SER v.2
Modifications:
Table 6 and 7: added.
Section 13 “Legal information”: updated.
PTVSXS1UR_SER v.2
20090910
Product data sheet
PTVSXS1UR_SER v.1
PTVSXS1UR_SER v.1
20090202
Product data sheet
PTVSxS1UR_SER
Product data sheet
9 of 12
PTVSxS1UR series
Nexperia
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
13.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
PTVSxS1UR_SER
Product data sheet
10 of 12
PTVSxS1UR series
Nexperia
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
13.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
14. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PTVSxS1UR_SER
Product data sheet
11 of 12
Nexperia
PTVSxS1UR series
15. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
8.1
9
10
11
12
13
13.1
13.2
13.3
13.4
14
15
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Thermal characteristics . . . . . . . . . . . . . . . . . . 4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 7
Quality information . . . . . . . . . . . . . . . . . . . . . . 7
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7
Packing information . . . . . . . . . . . . . . . . . . . . . 8
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9
Legal information. . . . . . . . . . . . . . . . . . . . . . . 10
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . 11
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Date of release: 10 January 2011
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
PTVS20VS1UR,115 PTVS22VS1UR,115 PTVS24VS1UR,115 PTVS26VS1UR,115 PTVS28VS1UR,115
PTVS30VS1UR,115 PTVS33VS1UR,115 PTVS36VS1UR,115 PTVS40VS1UR,115 PTVS43VS1UR,115
PTVS45VS1UR,115 PTVS48VS1UR,115 PTVS51VS1UR,115 PTVS54VS1UR,115 PTVS58VS1UR,115
PTVS60VS1UR,115 PTVS64VS1UR,115 PTVS15VS1UR,115 PTVS17VS1UR,115 PTVS6V0S1UR,115
PTVS6V5S1UR,115 PTVS10VS1UR,115 PTVS8V0S1UR,115 PTVS12VS1UR,115 PTVS7V0S1UR,115
PTVS18VS1UR,115 PTVS5V0S1UR,115 PTVS7V5S1UR,115 PTVS11VS1UR,115 PTVS8V5S1UR,115
PTVS9V0S1UR,115 PTVS14VS1UR,115 PTVS16VS1UR,115 PTVS3V3S1UR,115 PTVS13VS1UR,115
PTVS33VS1UR/8X PTVS5V0S1UR/8X PTVS24VS1UR/8X PTVS20VS1UR/8X PTVS36VS1UR/8X
PTVS22VS1UR/8X PTVS18VS1UR/8X PTVS6V0S1UR/8X PTVS3V3S1UR/8X PTVS26VS1UR/8X
PTVS12VS1UR/8X PTVS14VS1UR/8X PTVS17VS1UR/8X
