QSH-090-01-L-D-A-K-TR 数据手册
F-219
QSH–060–01–L–D–DP–A
QSH–060–01–L–D–A–K
QSH–030–01–F–D–A
(0.50 mm) .0197"
QSH SERIES
HIGH-SPEED GROUND PLANE SOCKET
Board Mates:
QTH
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?QSH
Cable Mates:
HQCD, HQDP
(See Also Available Note)
Insulator Material:
Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
Contact:
2 A per pin
(2 pins powered)
Ground Plane:
25 A per ground plane
(1 ground plane powered)
Operating Temp Range:
-55 °C to +125 °C
Voltage Rating:
175 VAC (5 mm Stack Height)
Max Cycles:
100
RoHS Compliant:
Yes
POWER/SIGNAL
APPLICATION
10 YEAR MFG
WITH 50 µ" GOLD
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
HIGH-SPEED CHANNEL PERFORMANCE
QTH/QSH @ 5 mm Mated Stack Height
Rating based on Samtec reference channel.
For full SI performance data visit Samtec.com
or contact SIG@samtec.com
PROCESSING
25
Compatible with
UMPT/UMPS for
flexible two-piece
power/signal solutions
G b p s
PINS PER ROW
NO. OF PAIRS
QSH
PLATING
OPTION
01
–F
= Gold Flash
on Signal Pins
and Ground Plane,
Matte Tin on tails
–030, –060, –090
(60 total pins per bank = –D)
RECOGNITIONS
–020, –040, –060
For complete scope of
recognitions see
www.samtec.com/quality
–L
(20 pairs per bank = –D–DP)
= 10 µ" (0.25 µm)
Gold on Signal Pins
and Ground Plane,
Matte Tin on tails
–D = (No. of Pins per Row/30) x
(20.00) .7875 + (1.27) .050
FILE NO. E111594
STANDARDS
• PISMO™ 1
Visit www.samtec.com/standards
for more information.
02
–DP = (No. of Pairs per Row/20) x
(20.00) .7875
(7.49)
.295
ALSO AVAILABLE
01
(MOQ Required)
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
Integral metal plane
for power or ground
Standoffs:
SO
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (020-060)
Board Stacking:
For applications requiring more
than two connectors per board
contact ipg@samtec.com
• 15 mm, 22 mm and
30 mm stack height
• 30 µ" (0.76 µm) Gold
(Specify -H plating for
Data Rate cable mating
applications.)
• Edge Mount & Guide Posts
• 80 (-DP), 120, 150
positions per row
• Retention Option
Blade &
Beam
Design
(0.50)
.0197
(0.15)
.006
(3.05)
.120
(7.24)
.285 (0.76)
.030
(0.89)
.035
DIA
–L
A
TYPE
–D
= SingleEnded
–D–DP
= Differential
Pair
(–01 only)
–C*
= Electro-Polished
Selective
50 µ" (1.27 µm) min
Au over 150 µ" (3.81 µm)
Ni on Signal Pins
in contact area,
10 µ" (0.25 µm) min
Au over 50 µ" (1.27 µm)
Ni on Ground Plane
in contact area,
Matte Tin over
50 µ" (1.27 µm) min
Ni on all solder tails
(3.25)
.128
*Note:
–C Plating passes
10 year MFG testing
(0.64)
.025
–K
= (8.25 mm)
.325" DIA
Polyimide Film
Pick & Place Pad
–TR
= Tape & Reel
(–090 positions
maximum)
–L
= Latching
Option
(Not available on
–060 (–D–DP)
& –090 positions)
QTH
MATED HEIGHT
LEAD STYLE
WITH QSH*
–01
–02
–03
–04
–05
–07
–09
(5.00) .197
(8.00) .315
(11.00) .433
(16.00) .630
(19.00) .748
(25.00) .984
(14.00) .551
*Processing conditions will affect
mated height. See SO Series for
board space tolerances
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
OTHER
OPTION
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Samtec:
QSH-060-01-L-D-A-K-TR QSH-030-01-L-D-A QSH-030-01-L-D-K-TR QSH-040-01-H-D-DP-A-K-TR QSH-030-01-CD-A-K QSH-060-01-C-D-A-K QSH-060-01-F-D-A-K-TR QSH-030-01-F-D-A QSH-060-01-F-D-A QSH-090-01-F-D-A
QSH-060-01-L-D-A QSH-030-01-F-D-A-TR QSH-020-01-L-D-DP-A QSH-090-01-L-D-A QSH-030-01-L-D-A-K QSH030-01-F-D-A-K QSH-060-01-H-D-A-K QSH-080-01-F-D-DP-A QSH-040-01-H-D-DP-A QSH-030-01-L-D-RA QSH020-01-C-D-DP-A QSH-020-01-F-D-DP-A-K-TR QSH-030-01-C-D-A-K-TR QSH-030-01-F-D QSH-030-01-F-D-A-K-TR
QSH-090-01-F-D-A-K-TR QSH-060-01-H-D-A-K-TR QSH-090-01-H-D-A-K QSH-060-01-L-D-A-K QSH-060-01-L-DRA QSH-060-01-L-D-A-TR QSH-040-01-F-D-DP-A-K-TR QSH-020-01-L-D-DP-A-TR QSH-090-01-L-D-A-K-TR QSH060-01-L-D-A-RT1 QSH-120-01-L-D-A QSH-040-01-C-D-DP-A-K QSH-020-01-C-D-DP-A-K QSH-020-01-L-D-DP-A-K
QSH-030-01-L-D-A-K-TR QSH-020-01-H-D-DP-A QSH-040-01-F-D-DP-A QSH-060-01-L-D-DP-A QSH-020-01-L-DDP-A-K-TR QSH-030-01-L-D-A-TR QSH-040-01-L-D-DP-A-K QSH-040-01-C-D-DP-A QSH-030-01-H-D-A-K QSH040-01-L-D-DP-A-K-TR QSH-090-01-C-D-A QSH-090-01-F-D-A-K QSH-020-01-F-D-DP-A-K QSH-030-01-L-D-A-RT1
QSH-060-01-F-D-A-K QSH-060-01-L-D-RA-K QSH-060-01-C-D-A QSH-090-01-L-D-A-K QSH-120-01-F-D-A QSH030-01-L-D-RA-K QSH-120-01-L-D-A-K QSH-080-01-C-D-DP-A QSH-020-01-F-D-DP-A QSH-060-01-F-D-DP-A
QSH-060-01-C-D-A-K-TR QSH-150-01-L-D-A QSH-060-01-H-D-A QSH-030-01-H-D-A QSH-030-01-H-D-A-K-TR
QSH-040-01-L-D-DP-A QSH-030-01-C-D-A QSH-030-01-L-D-K QSH-090-01-H-D-A QSH-090-01-C-D-A-K QSH-04001-H-D-DP-A-RT1-K QSH-060-01-C-D-A-RT1 QSH-020-01-F-D-DP-RA QSH-020-01-L-D-DP-LC-K QSH-090-01-L-DA-RT1 QSH-040-01-L-D-DP-RA-K QSH-060-01-C-D-A-FL QSH-060-01-F-D-DP-RA-GP QSH-040-01-C-D-DP-FL-LCK QSH-020-01-L-D-DP-RA QSH-030-01-L-D-L-TR QSH-040-01-F-D-DP-RA-GP QSH-060-01-L-D-DP-LC-K QSH020-01-L-D-DP-RA-GP QSH-060-01-F-D-DP-RA QSH-060-01-L-D-DP-RA-GP QSH-030-01-L-D QSH-060-01-H-D-ATR QSH-060-01-L-D-LC QSH-100-01-L-D-DP-A QSH-030-01-L-D-LC QSH-040-01-F-D-DP-TR QSH-090-01-L-DEM2 QSH-100-01-H-D-DP-A QSH-080-01-L-D-DP-A-K QSH-090-01-F-D QSH-090-01-L-D
QSH-090-01-L-D-A-K-TR 价格&库存
很抱歉,暂时无法提供与“QSH-090-01-L-D-A-K-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+68.69958
- 25+65.44492
- 50+61.57452
- 国内价格 香港价格
- 1+62.972601+7.58740
- 10+62.8910010+7.57760
- 25+60.9552025+7.34430
- 50+58.7745050+7.08160
- 100+54.65790100+6.58560
- 250+49.95830250+6.01930
- 475+47.43940475+5.71580
- 950+43.74270950+5.27040
- 2375+37.865202375+4.56230
