F-219
QTH–090–01–C–D–A
QTH–030–01–L–D–A
QTH–060–07–F–D–A
(0.50 mm) .0197"
QTH SERIES
HIGH-SPEED GROUND PLANE HEADER
For complete specifications and
recommended PCB layouts see
www.samtec.com?QTH
Insulator Material:
Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over 50 µ" (1.27 µm) Ni
Current Rating:
Contact:
2 A per pin
(2 pins powered)
Ground Plane:
25 A per ground plane
(1 ground plane powered)
Operating Temp Range:
-55 °C to +125 °C
Voltage Rating:
175 VAC (5 mm Stack Height)
Max Cycles: 100
RoHS Compliant: Yes
POWER/SIGNAL
APPLICATION
10 YEAR MFG
WITH 50 µ" GOLD
HIGH MATING
CYCLES
HIGH-SPEED CHANNEL PERFORMANCE
25
QTH/QSH @ 5 mm Mated Stack Height
Rating based on Samtec reference channel.
For full SI performance data visit Samtec.com
or contact SIG@samtec.com
Lead–Free Solderable: Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (030-060)
(0.15 mm) .006" max (090)*
*(.004" stencil solution
may be available; contact
IPG@samtec.com)
Board Stacking:
For applications requiring
more than two connectors per
board contact ipg@samtec.com
LEAD
STYLE
Specify
LEAD
STYLE
from
chart
–030, –060, –090
(60 total pins per bank = –D)
–020, –040, –060
For complete scope of
recognitions see
www.samtec.com/quality
Compatible with
UMPT/UMPS for
flexible two-piece
power/signal solutions
G b p s
PINS PER ROW
NO. OF PAIRS
QTH
RECOGNITIONS
(20 pairs per bank = –D–DP)
PLATING
OPTION
–F
= Gold Flash on
Signal Pins and
Ground Plane,
Matte Tin on tails
–L
–DP = (No. of Pairs per Row/20) x (20.00) .7875
(20.00) .7875
STANDARDS
01
• PISMO™ 1
Visit www.samtec.com/standards
for more information.
(7.11)
.280
02
ALSO AVAILABLE
(0.50)
.0197
(MOQ Required)
A
–01 & –02
–03 thru –09
(0.76)
.030
(0.89)
.035
DIA
–L
(0.64)
.025
*Note:
–C Plating passes
10 year MFG testing
= Single-Ended
–D–DP
= Differential Pair
(–01 only)
= (7.00 mm)
.275" DIA
Polyimide
film Pick &
Place Pad
(N/A with -05 &
-07 lead style)
–TR
= Tape & Reel
(–090 positions
maximum)
–L
QTH
LEAD
STYLE
–01
–02
–03
–04
–05
–07
–09
A
HEIGHT
WITH
QSH*
(4.27)
.168
(7.26)
.286
(10.27)
.404
(15.25)
.600
(18.26)
.718
(24.24)
.954
(13.26)
.522
(5.00)
.197
(8.00)
.315
(11.00)
.433
(16.00)
.630
(19.00)
.748
(25.00)
.984
(14.00)
.551
*Processing conditions
will affect mated height.
See SO Series for
board space tolerances
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
OTHER
OPTION
–K
–D
–C*
= Electro-Polished
Selective
50 µ" (1.27 µm) min
Au over 150 µ" (3.81 µm)
Ni on Signal Pins in
contact area,
10 µ" (0.25 µm) min
Au over 50 µ" (1.27 µm)
A
Ni on Ground Plane
in contact area,
Matte Tin over
50 µ" (1.27 µm) min
Ni on all solder tails
(0.20)
.008
A
TYPE
= 10 µ" (0.25 µm)
Gold on Signal Pins
and Ground Plane,
Matte Tin on tails
–D = (No. of Pins per Row/30) x (20.00) .7875
FILE NO. E111594
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
Standard Stack Heights
from 5 mm to 25 mm
EXTENDED LIFE
PRODUCT
PROCESSING
• 15 mm, 22 mm and
30 mm stack height
• 30 µ" (0.76 µm) Gold
(Specify -H plating for
Data Rate cable mating
applications.)
• Edge Mount & Guide Posts
• 80 (-DP), 120, 150
positions per row
• Retention Option
Integral metal plane for
power or ground
Board Mates:
QSH
Cable Mates:
HQCD, HQDP
(See Also Available Note)
Standoffs:
SO
SPECIFICATIONS
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
= Latching
Option
(–01 lead
style only)
(N/A on
–060 (–D–DP)
& –090)
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Samtec:
QTH-030-01-L-D-A QTH-120-01-L-D-A-K QTH-090-03-L-D-A QTH-060-01-L-D-A QTH-060-02-F-D-A-K QTH-09001-L-D-A QTH-060-01-F-D-A QTH-060-02-L-D-A QTH-020-01-L-D-DP-A QTH-030-01-F-D-A QTH-030-01-H-D-A
QTH-030-04-L-D-A QTH-060-01-F-D-A-K-TR QTH-090-04-L-D-A QTH-030-05-F-D-A QTH-060-02-L-D-A-K-TR QTH060-04-L-D-A-K-TR QTH-040-05-F-D-DP-A QTH-030-02-F-D-A QTH-060-07-F-D-A QTH-030-01-L-D-A-RT1 QTH090-03-L-D-A-K QTH-040-01-F-D-DP-A QTH-060-03-L-D-A QTH-020-04-L-D-DP-A QTH-040-02-L-D-DP-A QTH030-01-C-D-A-K QTH-060-02-F-D-A-K-TR QTH-030-09-L-D-A-K QTH-060-01-L-D-A-K QTH-030-01-L-D-RA-K QTH060-01-C-D-A QTH-120-02-L-D-A-K QTH-090-04-F-D-A QTH-090-05-L-D-A QTH-090-01-L-D-A-K QTH-030-02-L-DA-K-TR QTH-060-04-F-D-A QTH-020-01-H-D-DP-A QTH-090-03-F-D-A QTH-030-01-L-D-A-K QTH-030-02-L-D-A-K
QTH-020-02-F-D-DP-A QTH-030-01-F-D-A-K-TR QTH-040-01-C-D-DP-A-K QTH-030-01-F-D-A-K QTH-060-01-L-DDP-A QTH-060-05-F-D-A QTH-020-01-L-D-DP-A-K QTH-090-01-F-D-A QTH-030-03-L-D-A-K QTH-030-04-L-D-A-K
QTH-020-05-L-D-DP-A QTH-030-07-F-D-A QTH-120-01-L-D-A QTH-120-03-L-D-A QTH-060-01-L-D-A-K-TR QTH060-05-L-D-A QTH-030-03-F-D-A-K QTH-020-01-F-D-DP-A QTH-060-02-H-D-A-K-TR QTH-020-03-F-D-DP-A QTH060-04-L-D-A QTH-090-04-L-D-A-K QTH-060-03-L-D-A-K-TR QTH-090-02-L-D-A-K-TR QTH-030-04-F-D-A QTH020-02-L-D-DP-A QTH-030-07-L-D-A QTH-030-01-L-D-A-K-TR QTH-060-01-H-D-A QTH-030-02-L-D-A QTH-060-03F-D-A QTH-030-03-L-D-A QTH-040-01-L-D-DP-A-K-TR QTH-040-03-L-D-DP-A QTH-060-02-L-D-A-K QTH-020-01-LD-DP-A-K-TR QTH-030-03-F-D-A-K-TR QTH-060-02-C-D-A QTH-030-04-F-D-A-K QTH-090-02-F-D-A QTH-030-05L-D-A QTH-060-04-L-D-A-K QTH-020-03-L-D-DP-A QTH-030-04-L-D-A-K-TR QTH-090-05-F-D-A QTH-040-01-L-DDP-A-K QTH-060-03-F-D-A-K QTH-030-09-L-D-A-K-TR QTH-060-03-L-D-A-K QTH-060-07-L-D-A QTH-060-01-H-DA-K QTH-060-01-L-D-A-RT1 QTH-090-01-L-D-A-K-TR QTH-030-02-F-D-A-K-TR QTH-060-02-F-D-A QTH-030-03-FD-A QTH-040-01-L-D-DP-A QTH-030-01-C-D-A
很抱歉,暂时无法提供与“QTH-090-03-L-D-A-K”相匹配的价格&库存,您可以联系我们找货
