RMCF / RMCP Series
Stackpole Electronics, Inc.
General Purpose Thick Film Standard Power
and High-Power Chip Resistor
Resistive Product Solutions
Features:
RMCF – standard power ratings
RMCP – high power ratings
Nickel barrier terminations standard
Power derating from 100% at 70 ºC to zero at +155 ºC
AEC-Q200 Compliant (except RMCP0201)
RoHS compliant and halogen free
Electrical Specifications - RMCF
Type / Code
Power Rating
@ 70ºC
(Watts)
Maximum
Working
Voltage
(1)
Maximum
Overload
Voltage
Max. Jumper
Current
(Amp)
RMCF01005
0.03 W
15 V
30 V
0.5 A
RMCF0201
0.05 W
25 V
50 V
0.5 A
RMCF0402
0.063 W
50 V
100 V
1A
RMCF0603
0.1 W
75 V
150 V
1A
RMCF0805
0.125 W
150 V
300 V
2A
RMCF1206
0.25 W
200 V
400 V
2A
RMCF1210
0.33 W (3)
200 V
400 V
3A
RMCF2010
0.75 W
200 V
400 V
3A
RMCF2512
1W
200 V
400 V
3A
Resistance
Temperature
Coefficient
Ohmic Range (Ω) and Tolerance (2)
± 300 ppm/ºC
± 200 ppm/ºC
± 400 ppm/ºC
± 200 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 500 ppm/ºC
± 400 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 200 ppm/ºC
± 400 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 400 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 400 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
10 - 97.6
100 - 1 M
1 - 9.76
10 - 10 M
1%
5%
1 - 9.76 (4)
10 - 1 M
1.02 M - 10 M
1.1 M - 20 M
0.1 - 0.499
0.5 - 0.976
1 - 9.76
1 - 20 M
10 - 1 M
1.02 M - 10 M
0.1 - 9.76
0.1 - 20 M
10 - 1 M
1.02 M - 10 M
0.1 - 9.76
0.1 - 20 M
10 - 1 M
1.02 M - 10 M
0.1 - 0.976
1 - 9.76
10 - 20 M
10 - 10 M
0.1 - 0.976
1 - 9.76
10 - 10 M
10 - 10 M
0.1 - 0.976
1 - 9.76
10 - 10 M
10 - 10 M
Notes: (1) Lesser of √ P * R or maximum working voltage
(2) Contact factory for extended ohmic values
(3) Power rating is 0.5 W for ohmic values 1 K Ω and below
(4) Contact factory for lower ohmic values
Rev Date: 01/10/2020
This specification may be changed at any time without prior notice
Please confirm technical specifications before you order and/or use.
1
www.seielect.com
marketing@seielect.com
RMCF / RMCP Series
Electrical Specifications - RMCP
Type / Code
Power Rating
@ 70ºC
(Watts)
Maximum
Working
(1)
Voltage
Maximum
Overload
Voltage
Max. Jumper
Current
(Amp)
RMCP0201
0.063
25
50
1
RMCP0402
0.125
50
100
1.5
RMCP0603
0.25
75
150
2
RMCP0805
0.33
150
300
2.5
RMCP1206
0.33
200
400
3.5
RMCP1210
0.5
200
400
5
RMCP2010
1
200
400
6
RMCP2512
2
250
500
7
Resistance
Temperature
Coefficient
1%, 5%
1 - 9.76
10 - 1 M
1 - 9.76
10 - 1 M
1 - 9.76
10 - 1 M
1 - 9.76
10 - 1 M
1 - 9.76
10 - 1 M
1 - 9.76
10 - 1 M
1 - 9.76
10 - 1 M
1 - 9.76
10 - 1 M
-200/+400 ppm/ºC
± 200 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
Mechanical Specifications
Type / Code
Average Unit
Weight (mg)
RMCF01005
0.07
RMCF0201
RMCP0201
RMCF0402
RMCP0402
RMCF0603
RMCP0603
RMCF0805
RMCP0805
RMCF1206
RMCP1206
RMCF1210
RMCP1210
RMCF2010
RMCP2010
RMCF2512
RMCP2512
0.16
0.57
0.62
1.88
2.04
5.00
4.37
8.86
8.95
15.55
15.96
23.56
24.24
40.02
39.45
L
Body Length
0.016 ± 0.0008
0.40 ± 0.02
0.024 ± 0.0012
0.60 ± 0.03
0.039 ± 0.004
1.00 ± 0.10
0.061 ± 0.006
1.55 ± 0.15
0.079 ± 0.008
2.00 ± 0.20
0.126 ± 0.010
3.20 ± 0.25
0.126 ± 0.010
3.20 ± 0.25
0.197 ± 0.008
5.00 ± 0.20
0.248 ± 0.008
6.30 ± 0.20
W
Body Width
0.008 ± 0.0008
0.20 ± 0.02
0.012 ± 0.0012
0.30 ± 0.03
0.020 ± 0.002
0.50 ± 0.05
0.031 ± 0.006
0.80 ± 0.15
0.049 ± 0.004
1.25 ± 0.10
0.063 ± 0.006
1.60 ± 0.15
0.098 ± 0.010
2.50 ± 0.25
0.098 ± 0.008
2.50 ± 0.20
0.126 ± 0.010
3.20 ± 0.25
2
H
Body Height
0.005 ± 0.0008
0.13 ± 0.02
0.009 ± 0.0012
0.23 ± 0.03
0.012 ± 0.002
0.30 ± 0.05
0.018 ± 0.004
0.45 ± 0.10
0.020 ± 0.006
0.50 ± 0.15
0.022 ± 0.006
0.55 ± 0.15
0.022 ± 0.006
0.55 ± 0.15
0.022 ± 0.006
0.55 ± 0.15
0.022 ± 0.006
0.55 ± 0.15
a
Top Termination
0.004 ± 0.0012
0.10 ± 0.03
0.006 ± 0.002
0.15 ± 0.05
0.008 ± 0.004
0.20 ± 0.10
0.012 ± 0.008
0.30 ± 0.20
0.014 ± 0.010
0.35 ± 0.25
0.020 ± 0.012
0.50 ± 0.30
0.020 ± 0.012
0.50 ± 0.30
0.024 ± 0.012
0.60 ± 0.30
0.024 ± 0.012
0.60 ± 0.30
b
Bottom Termination
0.004 ± 0.0012
0.10 ± 0.03
0.006 ± 0.002
0.15 ± 0.05
0.010 ± 0.006
0.25 ± 0.15
0.012 ± 0.008
0.30 ± 0.20
0.014 ± 0.010
0.35 ± 0.25
0.020 ± 0.012
0.50 ± 0.30
0.020 ± 0.012
0.50 ± 0.30
0.024 ± 0.014
0.60 ± 0.35
0.024 ± 0.014
0.60 ± 0.35
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
RMCF / RMCP Series
Performance Characteristics
Test
Test Specifications
Test Conditions (JIS-C 5202)
Short Time Overload
Dielectric Withstanding Voltage
Resistance to Soldering Heat
Solderability
± (2% + 0.1 Ω)
No flashover or breakdown
± 1%
95% coverage, minimum
Temperature Cycle
± (1% + 0.05 Ω)
Jumper (< 0.05 Ω)
2.5 X rated voltage for 5 seconds
100 VAC, 1 minute
260 ºC ± 5 ºC, for 10 seconds ± 0.5 seconds (Solder Bath)
235ºC ± 5ºC, for 2 seconds ±0.5 seconds (Colophonium flux)
-65 ºC: 30 minutes 25 ºC: 2 to 3 minutes
155 ºC: 30 minutes 25 ºC: 2 to 3 minutes
(5 Cycles)
40 ºC ± 2 ºC, 90% RH, Rated Load
90 minutes On, 30 minutes Off for 1000 hours -0 hour / +48hours
± (3% + 0.1 Ω)
Jumper (
很抱歉,暂时无法提供与“RMCF0603JG10K0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.08683
- 500+0.08172
- 1000+0.07406
- 5000+0.06384
- 10000+0.05772
- 国内价格 香港价格
- 10000+0.0251410000+0.00327
- 20000+0.0221820000+0.00288
- 30000+0.0207530000+0.00270
- 50000+0.0192050000+0.00249
- 70000+0.0183170000+0.00238
- 100000+0.01748100000+0.00227
- 国内价格 香港价格
- 1+0.885961+0.11499
- 10+0.1761310+0.02286
- 25+0.1272425+0.01652
- 50+0.1005550+0.01305
- 100+0.08038100+0.01044
- 250+0.06110250+0.00793
- 500+0.05032500+0.00653
- 1000+0.041931000+0.00545
- 5000+0.028895000+0.00375
