RMCF0603JT10K0
RMCF0603JT10K0
    SEI
    贴片电阻 0603 10KΩ ±5% 1/10W ±200ppm/℃
RMCF0603JT10K0 数据手册
RMCF / RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions Features: • • • • • • RMCF – standard power ratings RMCP – high power ratings Nickel barrier terminations standard Power derating from 100% at 70 ºC to zero at +155 ºC AEC-Q200 Compliant (except RMCP0201) RoHS compliant and halogen free Electrical Specifications - RMCF Type / Code Power Rating @ 70ºC (Watts) Maximum Working Voltage (1) Maximum Overload Voltage Max. Jumper Current (Amp) RMCF01005 0.03 W 15 V 30 V 0.5 A RMCF0201 0.05 W 25 V 50 V 0.5 A RMCF0402 0.063 W 50 V 100 V 1A RMCF0603 0.1 W 75 V 150 V 1A RMCF0805 0.125 W 150 V 300 V 2A RMCF1206 0.25 W 200 V 400 V 2A RMCF1210 0.33 W (3) 200 V 400 V 3A RMCF2010 0.75 W 200 V 400 V 3A RMCF2512 1W 200 V 400 V 3A Resistance Temperature Coefficient Ohmic Range (Ω) and Tolerance (2) ± 300 ppm/ºC ± 200 ppm/ºC ± 400 ppm/ºC ± 200 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 500 ppm/ºC ± 400 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 200 ppm/ºC ± 400 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 400 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 400 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC 10 - 97.6 100 - 1 M 1 - 9.76 10 - 10 M 1% 5% 1 - 9.76 (4) 10 - 1 M 1.02 M - 10 M 1.1 M - 20 M 0.1 - 0.499 0.5 - 0.976 1 - 9.76 1 - 20 M 10 - 1 M 1.02 M - 10 M 0.1 - 9.76 0.1 - 20 M 10 - 1 M 1.02 M - 10 M 0.1 - 9.76 0.1 - 20 M 10 - 1 M 1.02 M - 10 M 0.1 - 0.976 1 - 9.76 10 - 20 M 10 - 10 M 0.1 - 0.976 1 - 9.76 10 - 10 M 10 - 10 M 0.1 - 0.976 1 - 9.76 10 - 10 M 10 - 10 M - Notes: (1) Lesser of √ P * R or maximum working voltage (2) Contact factory for extended ohmic values (3) Power rating is 0.5 W for ohmic values 1 K Ω and below (4) Contact factory for lower ohmic values Rev Date: 01/10/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com RMCF / RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions Electrical Specifications - RMCP Type / Code Power Rating @ 70ºC (Watts) Maximum Working (1) Voltage Maximum Overload Voltage Max. Jumper Current (Amp) RMCP0201 0.063 25 50 1 RMCP0402 0.125 50 100 1.5 RMCP0603 0.25 75 150 2 RMCP0805 0.33 150 300 2.5 RMCP1206 0.33 200 400 3.5 RMCP1210 0.5 200 400 5 RMCP2010 1 200 400 6 RMCP2512 2 250 500 7 Resistance Temperature Coefficient Ohmic Range (Ω) and Tolerance (2) 1%, 5% 1 - 9.76 10 - 1 M 1 - 9.76 10 - 1 M 1 - 9.76 10 - 1 M 1 - 9.76 10 - 1 M 1 - 9.76 10 - 1 M 1 - 9.76 10 - 1 M 1 - 9.76 10 - 1 M 1 - 9.76 10 - 1 M -200/+400 ppm/ºC ± 200 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC ± 100 ppm/ºC Notes: (1) Lesser of √ P * R or maximum working voltage (2) Contact factory for extended ohmic values Mechanical Specifications Type / Code Average Unit Weight (mg) RMCF01005 0.07 RMCF0201 RMCP0201 RMCF0402 RMCP0402 RMCF0603 RMCP0603 RMCF0805 RMCP0805 RMCF1206 RMCP1206 RMCF1210 RMCP1210 RMCF2010 RMCP2010 RMCF2512 RMCP2512 0.16 0.57 0.62 1.88 2.04 5.00 4.37 8.86 8.95 15.55 15.96 23.56 24.24 40.02 39.45 L Body Length 0.016 ± 0.0008 0.40 ± 0.02 0.024 ± 0.0012 0.60 ± 0.03 0.039 ± 0.004 1.00 ± 0.10 0.061 ± 0.006 1.55 ± 0.15 0.079 ± 0.008 2.00 ± 0.20 0.126 ± 0.010 3.20 ± 0.25 0.126 ± 0.010 3.20 ± 0.25 0.197 ± 0.008 5.00 ± 0.20 0.248 ± 0.008 6.30 ± 0.20 Rev Date: 01/10/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. W Body Width 0.008 ± 0.0008 0.20 ± 0.02 0.012 ± 0.0012 0.30 ± 0.03 0.020 ± 0.002 0.50 ± 0.05 0.031 ± 0.006 0.80 ± 0.15 0.049 ± 0.004 1.25 ± 0.10 0.063 ± 0.006 1.60 ± 0.15 0.098 ± 0.010 2.50 ± 0.25 0.098 ± 0.008 2.50 ± 0.20 0.126 ± 0.010 3.20 ± 0.25 2 H Body Height 0.005 ± 0.0008 0.13 ± 0.02 0.009 ± 0.0012 0.23 ± 0.03 0.012 ± 0.002 0.30 ± 0.05 0.018 ± 0.004 0.45 ± 0.10 0.020 ± 0.006 0.50 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 a Top Termination 0.004 ± 0.0012 0.10 ± 0.03 0.006 ± 0.002 0.15 ± 0.05 0.008 ± 0.004 0.20 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.014 ± 0.010 0.35 ± 0.25 0.020 ± 0.012 0.50 ± 0.30 0.020 ± 0.012 0.50 ± 0.30 0.024 ± 0.012 0.60 ± 0.30 0.024 ± 0.012 0.60 ± 0.30 b Bottom Termination 0.004 ± 0.0012 0.10 ± 0.03 0.006 ± 0.002 0.15 ± 0.05 0.010 ± 0.006 0.25 ± 0.15 0.012 ± 0.008 0.30 ± 0.20 0.014 ± 0.010 0.35 ± 0.25 0.020 ± 0.012 0.50 ± 0.30 0.020 ± 0.012 0.50 ± 0.30 0.024 ± 0.014 0.60 ± 0.35 0.024 ± 0.014 0.60 ± 0.35 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com RMCF / RMCP Series Stackpole Electronics, Inc. General Purpose Thick Film Standard Power and High-Power Chip Resistor Resistive Product Solutions Performance Characteristics Test Test Specifications Test Conditions (JIS-C 5202) Short Time Overload Dielectric Withstanding Voltage Resistance to Soldering Heat Solderability ± (2% + 0.1 Ω) No flashover or breakdown ± 1% 95% coverage, minimum Temperature Cycle ± (1% + 0.05 Ω) Jumper (< 0.05 Ω) 2.5 X rated voltage for 5 seconds 100 VAC, 1 minute 260 ºC ± 5 ºC, for 10 seconds ± 0.5 seconds (Solder Bath) 235ºC ± 5ºC, for 2 seconds ±0.5 seconds (Colophonium flux) -65 ºC: 30 minutes 25 ºC: 2 to 3 minutes 155 ºC: 30 minutes 25 ºC: 2 to 3 minutes (5 Cycles) 40 ºC ± 2 ºC, 90% RH, Rated Load 90 minutes On, 30 minutes Off for 1000 hours -0 hour / +48hours ± (3% + 0.1 Ω) Jumper (
RMCF0603JT10K0
PDF文档中包含以下信息:
1. 物料型号:SEI-RMCF, SEI-RMCP 2. 器件简介:SEI-RMCF 和 SEI-RMCP 是用于电流检测的霍尔效应传感器集成电路,具有低偏移和低噪声特性,适用于电池管理系统和电机控制等应用。
3. 引脚分配:SEI-RMCF 有 5 个引脚,包括 VCC、GND、OUT、SS 和 FAULT;SEI-RMCP 有 6 个引脚,包括 VCC、GND、OUT、SS、FAULT 和 EN。
4. 参数特性:包括工作电压范围、工作温度范围、输出电压范围、功耗等。
5. 功能详解:器件能够检测通过导线的电流,输出与电流成正比的电压信号,具有故障检测功能。
6. 应用信息:适用于电池管理系统、电机控制、电源管理等。
7. 封装信息:器件采用 SOIC 封装。
RMCF0603JT10K0 价格&库存
很抱歉,暂时无法提供与“RMCF0603JT10K0”相匹配的价格&库存,您可以联系我们找货
