Product Specification – February 13, 2018 V.10
DATA SHEET
CHIP RESISTORS
Mounting
Product specification
Chip Resistor Surface Mount
2
8
Mounting
The laws of heat conduction,
convection and radiation determine the
temperature rise in a resistor due to
power dissipation.
MOUNTING
Due to their rectangular shape and small dimensional
tolerances, Surface Mounted Resistors are suitable
for handling by automatic placement systems. Chip
placement can be on ceramic substrates and printedcircuit boards (PCBs). Electrical connection to the
circuit is by wave, vapour phase or infrared
soldering. The end terminations guarantee a reliable
contact and the protective coating enables ‘face
down’ mounting.
joints. Therefore a maximum solder joint
temperature of 110 °C is advised.
The laws of heat conduction, convection and
radiation determine the temperature rise in a
resistor owing to power dissipation. The maximum
body temperature usually occurs in the middle of the
resistor and is called the hot-spot temperature.
E X A MP L E O F M O U N T I N G E F F E C T S
The hot-spot temperature depends on the ambient
temperature and the dissipated power. This is
described in the data sheets under the chapter
heading “Functional description”.
In the graph (see Fig.1), this point is found by
drawing the line from point A (PCB = 95 °C) to
point B (T amb = 50 °C) and from here to the left axis.
The hot-spot temperature is important for mounting
because the connections to the chip resistors will
reach a temperature close to the hot-spot
temperature. Heat conducted by the connections
must not reach the melting point of the solder at the
The ambient temperature on large or very dense
printed-circuit boards (PCBs) is influenced by the
dissipated power. The ambient temperature will
again influence the hot-spot temperature. Therefore,
the packing density that is allowed on the PCB is
influenced by the dissipated power.
Assume that the maximum temperature of a PCB is
95 °C and the ambient temperature is 50 °C. In this
case the maximum temperature rise that may be
allowed is 45 °C.
To find the maximum packing density, this horizontal
line is extended until it intersects with the curve,
0.125 W (point C). The maximum packing density, 19
units/50 × 50 mm2 (point D), is found on the
horizontal axis
Fig. 1 PCB temperature as a function of applied power, mounting density and ambient temperature
www.yageo.com
Feb. 13, 2018 V.10
3
8
Mounting
THERMAL RESISTANCE (Rth)
Thermal resistance prohibits the
release of heat generated within
the resistor to the surrounding
environment. It is expressed in
K/W and defines the surface
temperature (T HS ) of the resistor
in relation to the ambient
temperature (T amb ) and the load
(P) of the resistor, as follows:
T HS = T amb + P × R th
Due to their direct contact with
the solder spot, chip resistors
dissipate over 85% of their heat
via conduction to the solder spot
and hence to the PCB. Thus the
PCB on which the chip resistor is
mounted functions as a heat sink.
Different PCBs have different
heat conductance. Figure 2 shows
the different values of heat
resistance per material type.
Substrates with a higher heat
conductance give lower thermal
resistance figures; substrates
with a lower heat conductance
give higher thermal resistance
figures. It should be noted that
the temperature of the
terminations of the chip resistor
is virtually the same as the hotspot temperature. Therefore the
power that may be dissipated by
the resistor is dependent on:
Fig. 2 Heat resistance for 1206 sized resistors as a function of distance and material
T amb (which is also dependent
on the packing density)
R th of the PCB
maximum solder spot
temperature (generally 110
°C).
(1) For size 0402: Rth = 800 K/W;
(3) For size 0805: Rth = 250 K/W;
(5) For size 1210: Rth = 125 K/W;
(7) For size 2010: Rth = 80 K/W;
(2) For size 0603: Rth = 400 K/W
(4) For size 1206: Rth = 200 K/W
(6) For size 1218: Rth = 100 K/W
(8) For size 2512: Rth = 100 K/W
Fig. 3 Hot-spot temperature rise (T) as a function of dissipated power
www.yageo.com
Feb. 13, 2018 V.10
4
8
Mounting
FOOTPRINT DIMENSIONS
SINGLE RESISTOR CHIPS
Fig. 4 Single resistor chips recommended dimensions of footprints
Table 1 Reflow soldering footprint dimensions for relevant chip resistors size; see Fig. 4
PRODUCT SIZE
CODE
A
B
C
D
Unit: mm
0075
0.34
0.14
0.1
0.15
N/A
0100
0.48
0.12
0.18
0.18~0.23
N/A
0201
1.0
0.3
0.35
0.4
N/A
0402
1.5
0.5
0.5
0.6
± 0.15
0603
2.6
0.8
0.9
0.8
± 0.25
0805
3.0
1.2
0.9
1.2
± 0.25
1206
4.2
2.2
1.0
1.5
± 0.25
1210
4.2
2.2
1.0
2.4
± 0.25
1218
4.2
2.2
1.0
4.8
± 0.25
2010
6.1
3.3
1.4
2.4
± 0.25
2512
8.0
4.4
1.8
4.0
± 0.25
Placement accuracy
Table 2 Wave soldering footprint dimensions for relevant chip resistors size; see Fig. 4
PRODUCT SIZE
CODE
A
B
C
D
Unit: mm
0603
2.70
0.90
0.90
0.80
± 0.25
0805
3.30
1.30
1.00
1.30
± 0.25
1206
4.70
2.50
1.10
1.70
± 0.25
1210
4.70
2.50
1.10
2.50
± 0.25
1218
4.70
2.50
1.10
4.80
± 0.25
2010
6.40
4.20
1.10
2.50
± 0.25
2512
8.20
5.50
1.35
3.20
± 0.25
Placement accuracy
www.yageo.com
Feb. 13, 2018 V.10
5
8
Mounting
RESISTOR ARRAYS, NETWORK AND RF ATTENUATORS
Fig. 5 Resistor arrays and network recommended dimensions of footprints
Table 3 Reflow soldering footprint dimensions for relevant chip resistors size; see Fig. 5
PRODUCT SIZE CODE
TYPE
Unit: mm
A
B
F
P
0404
ATV321
0.50 ± 0.10
0.42 ± 0.05
1.80 ± 0.20
0.65 ± 0.05
2 x 0201 (4P2R)
YC 102
0.30 ± 0.10
0.30 ± 0.05
0.90 ± 0.20
0.50 ± 0.05
4 x 0201 (8P4R)
YC104
0.30 ± 0.10
0.20 ± 0.05
0.90 ± 0.20
0.40 ± 0.05
2 × 0402 (4P2R)
YC/TC 122
0.50 ± 0.10
0.30 ± 0.05
1.80 ± 0.20
0.67 ± 0.05
4 × 0402 (8P4R)
YC/TC 124
0.50 ± 0.10
0.30 ± 0.05
1.80 ± 0.20
0.50 ± 0.05
2 × 0603 (4P2R)
YC 162
0.80 ± 0.10
0.45 ± 0.05
2.60 ± 0.20
0.80 ± 0.05
4 × 0603 (8P4R)
YC/TC 164
0.80 ± 0.10
0.45 ± 0.05
2.60 ± 0.20
0.80 ± 0.05
1220 (8P4R)
YC324
2.20 ± 0.10
0.71 ± 0.05
3.90 ± 0.20
1.27 ± 0.05
0616 (16P8R)
YC248
0.50 ± 0.10
0.30 ± 0.05
1.80 ± 0.20
0.50 ± 0.05
0612 (10P8R)
YC158
0.80 ± 0.10
0.35 ± 0.05
2.60 ± 0.20
0.64 ± 0.05
1225 (10P8R)
YC358
1.60 ± 0.10
0.90 ± 0.05
3.90 ± 0.20
1.27 ± 0.05
www.yageo.com
Feb. 13, 2018 V.10
6
8
Mounting
SOLDERING CONDITIONS
The lead free Surface Mount
Resistors are able to stand the
reflow soldering conditions as
below:
Temperature: above 220 °C
Endurance: 95 to 120 seconds
Cycles: 3 times
The test of "soldering heat
resistance" is carried out in
accordance with the schedule of
"MIL-STD-202G-method 210F", "The
robust construction of chip
resistors allows them to be
completely immersed in a solder
bath of 260 °C for 10 seconds".
Therefore, it is possible to mount
Surface Mount Resistors on one
side of a PCB and other discrete
components on the reverse (mixed
PCBs).
Surface Mount Resistors are
tested for solderability at 245 °C
during 2 seconds. The test
condition for no leaching is 260
°C for 30 seconds. Typical
examples of soldering processes
that provide reliable joints
without any damage, the
recommended soldering profiles
referring to "IEC 61760-1" are
given in Figs 6, 7 and 8.
Typical values (solid line)
Process limits (dotted lines)
Fig. 6 Infrared soldering, forced air convection reflow soldering-temperature/time profile for SnPb solders
www.yageo.com
Feb. 13, 2018 V.10
Mounting
7
8
Fig. 7 Infrared soldering, forced air convection reflow soldering-temperature/time profile for SnAgCu solders
The resistors may be soldered twice in accordance with this method if desired
Fig. 8 Double wave soldering for SnPb and leadfree SnAgCu solder– temperature/time profile (terminal temperature)
www.yageo.com
Feb. 13, 2018 V.10
8
8
Mounting
REVISION HISTORY
REVISION
DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 10
Feb. 12, 2018
- Update 2512 footprint dimensions
Version 9
Oct. 02, 2017
- Correct the highest reflow soldering temperaure of SnAgCu solders
to be 260oC
Version 8
June 15, 2017
- Add 0075 footprint dimensions
Version 7
Jun. 02, 2015
- add 0100
Version 6
Dec. 02, 2014
- add YC104
Version 5
March 25, 2008 -
- Footprint dimensions updated
- Soldering conditions test method amended from "MIL-STD-202G" to
"MIL-STD-202F"
- Solder bath of soldering conditions upgrade to 270 °C
- Profiles of infrared soldering amended
Version 4
Nov 26, 2004
- Converted to Yageo / Phycomp brand
- Expanded sizes from 0201 to 2512 on the profile of “Hot-spot
temperature rise (T) as a function of dissipated power”
- Profiles of infrared and double wave soldering amended
Version 3
Jul 25, 2003
- Updated company logo
Version 2
May 30, 2001
- Converted to Phycomp brand
www.yageo.com
Feb. 13, 2018 V.10
很抱歉,暂时无法提供与“YC164-FR-07330RL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.18440
- 100+0.10100
- 1000+0.06180
- 2500+0.04170
- 5000+0.02970
- 国内价格
- 1+0.03283
- 100+0.03064
- 300+0.02845
- 500+0.02626
- 2000+0.02517
- 5000+0.02451
