www.Sofng.com
C
Operation:SMT+DIP 式 SMT& 3.1Type-C 插座
ONNECTORS
LTEM NO.:MC-313D
(Consumer Electronics)
(9.85L×
(9.85L×9.64W×
9.64W×3.16H & DUL SMT LOW PCB TYPE)
Type-C Universal Serial Bus Connectors
外焊 SMT+DIP
Technical parameter
LEVEL
A[better product]
PROJECT
Contact Rating
Electrical
Initial Contact Resistance
Properties
Insulation Resistance
Withstand Voltage
B[average product]
侧向導入 LATERAL
5A, 24V DC
30mΩ max.
100MΩ min.500V DC
精密部品 NICETY
50mΩ max.
Skey/PD:100MΩ min.300V DC
500V AC for 1 minute
350 V AC for 1 minut
There No Load
6,500 Cycles
5,500 Cycles
Rated Load
5,500 Cycles
4,500 Cycles
可靠 STABILIZE
Durable Performance
環保材质 RoHS
Sterage temp.
Page1
-25℃~+75℃(Operating Temp:
Unit:mm
C
E
A
D
Page2
B
DECIMALS
SPECIFED TOLERANCES
ANGLES
X.X
:±0.25
X.X
:±3°
X.XX
:±0.15
X.XX
:±2°
X.XXX :±0.10
UNLESS OTHERWISE
Material declaration
No.
NAME
MATERIAL
DESCRIPTION
2.0μm Ni PLATED OVERALL;
①A
TERMINAL
COPPER ALLOY【G/F】
0.25μm Au PLATED CONTACT AREA;
接触端子
GOLD FLASH ON SOLDER AREA.
②B
SHIELDING PLATE 屏蔽壳
STAINLESS【G/F】
0.25μm Ni PLATED OVERALL;
③C
CASE
THERMOPLASTIC
UL 94V-0,COLOR:BLACK;
④D
SHELL
STAINLESS【G/F】
⑤E
GUARD PLATE
STAINLESS【G/F】
STAINLESS STEEL(t=0.10mm)
MATERIAL
SOFNG ELECTRONIC TECHNOLOGY Co., LTD
CIRCUIT BOARD SIZE
(Vertical view)
Operating Force
Inward
6.0~10.0N.(1N.=100gram-force)
Exiting
8.0~12.0N.(1N.=100gram-force)
Solder-ability
IR Reflow:255℃,5sec.
(Max.)
Manual:350℃,3sec.
PIN ASSIGNMENTS
PIN
Signal NAME
Description
PIN
Signal NAME
Description
A1
GND
Ground return
B12
GND
Ground return
A2
SSTXp1
B11
SSRXp1
Positive half of firs SuperSpeed
Positive half of second SuperSpeed
TX differential pair
RX differential pair
Negatice half of first SuperSpeed
A3
SSTXn1
Negative half of second SuperSpeed
B10
SSRXn1
A4
V BUS
Bus Power
B9
V BUS
Bus Power
A5
CC1
Configuration Channel
B8
SBU2
Sideband Use(SBU)
A6
Dp1
B7
Dn2
Positive half of the USB 2.0
Negative half of the USB 2.0
differential pair-Position 1
differential pair-Position 2
A7
Dn1
B6
Dp2
A8
SBU1
Sideband Use(SBU)
B5
CC2
A9
V BUS
Bus Power
B4
V BUS
Bus Power
A10
SSRXn2
B3
SSTXn2
Negatice half of first SuperSpeed TX
SuperSpeed RX differential pair
differential pair2
A11
SSRXp2
Positive half of firs SuperSpeed TX
B2
SSTXp2
注記 NOTICE
A12
GND
Ground return
1.碩方公司擁有最終解釋權;The SOFNG company reserves the right of final interpretation;
2.文件禁止外洩、轉載;Leaked and reproduced prohibited;
3.未經授權修改無效。Modify is invalid.
differential pair2
B1
GND
Ground return
很抱歉,暂时无法提供与“MC-313D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.66282
- 10+2.97540
- 30+2.62656
- 100+2.28798
- 500+1.89810
- 1000+1.79550
