2N7002/HAMR
2N7002/HAMR
    NEXPERIA(安世)
    TO236AB
    MOS管 N-Channel Id=0.3A VDS=60V TO-236AB
2N7002/HAMR 数据手册
2N7002 60 V, 300 mA N-channel Trench MOSFET Rev. 7 — 8 September 2011 Product data sheet 1. Product profile 1.1 General description N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using Trench MOSFET technology. 1.2 Features and benefits  Suitable for logic level gate drive sources  Surface-mounted package  Trench MOSFET technology  Very fast switching 1.3 Applications  Logic level translators  High-speed line drivers 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 150 °C - - 60 V ID drain current VGS = 10 V; Tsp = 25 °C; see Figure 1; see Figure 3 - - 300 mA Ptot total power dissipation Tsp = 25 °C; see Figure 2 - - 0.83 W VGS = 10 V; ID = 500 mA; Tj = 25 °C; see Figure 6; see Figure 8 - 2.8 5 Ω Static characteristics drain-source on-state resistance RDSon 2. Pinning information Table 2. Pinning information Pin Symbol Description 1 G gate 2 S source 3 D drain Simplified outline Graphic symbol 3 D G 1 2 SOT23 (TO-236AB) mbb076 S 2N7002 Nexperia 60 V, 300 mA N-channel Trench MOSFET 3. Ordering information Table 3. Ordering information Type number Package 2N7002 Name Description Version TO-236AB plastic surface-mounted package; 3 leads SOT23 4. Marking Table 4. Marking codes Type number Marking code[1] 2N7002 12% [1] % = placeholder for manufacturing site code 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 150 °C - 60 V VDGR drain-gate voltage 25 °C ≤ Tj ≤ 150 °C; RGS = 20 kΩ - 60 V VGS gate-source voltage -30 30 V VGSM peak gate-source voltage pulsed; tp ≤ 50 µs; δ = 0.25 -40 40 V ID drain current VGS = 10 V; Tsp = 25 °C; see Figure 1; see Figure 3 - 300 mA VGS = 10 V; Tsp = 100 °C; see Figure 1 - 190 mA IDM peak drain current pulsed; tp ≤ 10 µs; Tsp = 25 °C; see Figure 3 - 1.2 A Ptot total power dissipation Tsp = 25 °C; see Figure 2 - 0.83 W Tj junction temperature -65 150 °C Tstg storage temperature -65 150 °C Source-drain diode IS source current Tsp = 25 °C - 300 mA ISM peak source current pulsed; tp ≤ 10 µs; Tsp = 25 °C - 1.2 A 2N7002 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 8 September 2011 © Nexperia B.V. 2017. All rights reserved 2 of 13 2N7002 Nexperia 60 V, 300 mA N-channel Trench MOSFET 03aa25 120 03aa17 120 Ider (%) Pder (%) 80 80 40 40 0 0 0 50 100 150 200 0 50 100 150 Tsp (°C) Fig 1. 200 Tsp (°C) Normalized continuous drain current as a function of solder point temperature Fig 2. Normalized total power dissipation as a function of solder point temperature 003aab350 10 ID (A) Limit RDSon = VDS / ID tp = 10 µs 1 100 µs 10-1 1 ms DC 10 ms 100 ms 10-2 1 Fig 3. 10 102 VDS (V) Safe operating area; continous and peak drain currents as a function of drain-source voltage 2N7002 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 8 September 2011 © Nexperia B.V. 2017. All rights reserved 3 of 13 2N7002 Nexperia 60 V, 300 mA N-channel Trench MOSFET 6. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-a) thermal resistance from junction to ambient Mounted on a printed-circuit board; minimum footprint ; vertical in still air - - 350 K/W Rth(j-sp) thermal resistance from junction to solder point see Figure 4 - - 150 K/W 003aab351 103 Zth(j-sp) (K/W) 102 δ = 0.5 0.2 0.1 10 δ= P 0.05 tp T 0.02 single pulse t tp T 1 10-5 Fig 4. 10-4 10-3 10-2 10-1 1 tp (s) 10 Transient thermal impedance from junction to solder point as a function of pulse duration 2N7002 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 8 September 2011 © Nexperia B.V. 2017. All rights reserved 4 of 13 2N7002 Nexperia 60 V, 300 mA N-channel Trench MOSFET 7. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS drain-source breakdown voltage ID = 10 µA; VGS = 0 V; Tj = 25 °C 60 - - V ID = 10 µA; VGS = 0 V; Tj = -55 °C 55 - - V VGSth gate-source threshold voltage ID = 0.25 mA; VDS = VGS; Tj = 25 °C; see Figure 9; see Figure 10 1 2 2.5 V ID = 0.25 mA; VDS = VGS; Tj = 150 °C; see Figure 9; see Figure 10 0.6 - - V ID = 0.25 mA; VDS = VGS; Tj = -55 °C; see Figure 9; see Figure 10 - - 2.75 V IDSS drain leakage current VDS = 48 V; VGS = 0 V; Tj = 25 °C - 0.01 1 µA VDS = 48 V; VGS = 0 V; Tj = 150 °C - - 10 µA IGSS gate leakage current VGS = 15 V; VDS = 0 V; Tj = 25 °C - 10 100 nA VGS = -15 V; VDS = 0 V; Tj = 25 °C - 10 100 nA VGS = 10 V; ID = 500 mA; Tj = 25 °C; see Figure 6; see Figure 8 - 2.8 5 Ω VGS = 10 V; ID = 500 mA; Tj = 150 °C; see Figure 6; see Figure 8 - - 9.25 Ω VGS = 4.5 V; ID = 75 mA; Tj = 25 °C; see Figure 6; see Figure 8 - 3.8 5.3 Ω VDS = 10 V; f = 1 MHz; VGS = 0 V; Tj = 25 °C - 31 50 pF - 6.8 30 pF - 3.5 10 pF VGS = 10 V; VDS = 50 V; RL = 250 Ω; RG(ext) = 50 Ω; RGS = 50 Ω - 2.5 10 ns - 11 15 ns RDSon drain-source on-state resistance Dynamic characteristics Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance ton turn-on time toff turn-off time Source-drain diode VSD source-drain voltage IS = 300 mA; VGS = 0 V; Tj = 25 °C; see Figure 11 - 0.85 1.5 V Qr recovered charge - 30 - nC trr reverse recovery time VGS = 0 V; IS = 300 mA; dIS/dt = -100 A/µs - 30 - ns 2N7002 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 8 September 2011 © Nexperia B.V. 2017. All rights reserved 5 of 13 2N7002 Nexperia 60 V, 300 mA N-channel Trench MOSFET 003aab352 1 10 ID (A) 5 003aab353 10000 VGS (V) = 4 RDSon (mΩ) 0.8 8000 4.5 4.5 0.6 6000 4 5 0.4 4000 10 VGS (V) = 3.5 0.2 2000 0 0 0 Fig 5. 1 2 3 VDS (V) 4 Output characteristics: drain current as a function of drain-source voltage; typical values 0 Fig 6. 003aab354 1 ID (A) 0.2 0.4 0.6 0.8 ID (A) 1 Drain-source on-state resistance as a function of drain current; typical values 03aa28 2.4 a 0.8 1.8 0.6 1.2 0.4 Tj = 150 °C 25 °C 0.6 0.2 0 0 Fig 7. 2 4 VGS (V) Transfer characteristics: drain current as a function of gate-source voltage; typical values 2N7002 Product data sheet 0 −60 6 Fig 8. 0 60 120 180 Tj (°C) Normalized drain-source on-state resistance factor as a function of junction temperature All information provided in this document is subject to legal disclaimers. Rev. 7 — 8 September 2011 © Nexperia B.V. 2017. All rights reserved 6 of 13 2N7002 Nexperia 60 V, 300 mA N-channel Trench MOSFET 003aab101 3 VGS(th) (V) typ 10-4 min 1 0 -60 Fig 9. ID (A) max 2 003aab100 10-3 min typ max 10-5 10-6 0 60 120 Tj (°C) Gate-source threshold voltage as a function of junction temperature 003aab356 1 0 180 1 2 VGS (V) 3 Fig 10. Sub-threshold drain current as a function of gate-source voltage 003aab357 102 IS (A) 0.8 C (pF) Ciss 0.6 10 0.4 Coss Crss 0.2 Tj = 25 °C 150 °C 0 0.2 0.4 0.6 0.8 VSD (V) 1 Fig 11. Source current as a function of source-drain voltage; typical values 2N7002 Product data sheet 1 10-1 1 10 VDS (V) 102 Fig 12. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 7 — 8 September 2011 © Nexperia B.V. 2017. All rights reserved 7 of 13 2N7002 Nexperia 60 V, 300 mA N-channel Trench MOSFET 8. Package outline Plastic surface-mounted package; 3 leads SOT23 D E B A X HE v M A 3 Q A A1 1 2 e1 bp c w M B Lp e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max. bp c D E e e1 HE Lp Q v w mm 1.1 0.9 0.1 0.48 0.38 0.15 0.09 3.0 2.8 1.4 1.2 1.9 0.95 2.5 2.1 0.45 0.15 0.55 0.45 0.2 0.1 OUTLINE VERSION SOT23 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-04 06-03-16 TO-236AB Fig 13. Package outline SOT23 (TO-236AB) 2N7002 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 8 September 2011 © Nexperia B.V. 2017. All rights reserved 8 of 13 2N7002 Nexperia 60 V, 300 mA N-channel Trench MOSFET 9. Soldering 3.3 2.9 1.9 solder lands solder resist 3 2 1.7 solder paste occupied area 0.6 (3×) 0.7 (3×) Dimensions in mm 0.5 (3×) 0.6 (3×) 1 sot023_fr Fig 14. Reflow soldering footprint for SOT23 (TO-236AB) 2.2 1.2 (2×) 1.4 (2×) solder lands 4.6 solder resist 2.6 occupied area Dimensions in mm 1.4 preferred transport direction during soldering 2.8 4.5 sot023_fw Fig 15. Wave soldering footprint for SOT23 (TO-236AB) 2N7002 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 8 September 2011 © Nexperia B.V. 2017. All rights reserved 9 of 13 2N7002 Nexperia 60 V, 300 mA N-channel Trench MOSFET 10. Revision history Table 8. Revision history Document ID Release date Data sheet status Change notice Supersedes 2N7002 v.7 20110908 Product data sheet - 2N7002 v.6 Modifications: 2N7002 v.6 • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • Legal texts have been adapted to the new company name where appropriate. 20060428 Product data sheet 2N7002 v.5 2N7002 v.5 20051115 Product data sheet 2N7002 v.4 2N7002 v.4 20050426 Product data sheet 2N7002 v.3 2N7002 v.3 20000727 Product specification 2N7002 v.2 19970617 Product specification 2N7002 v.1 19901031 Product specification 2N7002 Product data sheet HZG336 2N7002 v.2 2N7002 v.1 - All information provided in this document is subject to legal disclaimers. Rev. 7 — 8 September 2011 - © Nexperia B.V. 2017. All rights reserved 10 of 13 2N7002 Nexperia 60 V, 300 mA N-channel Trench MOSFET 11. Legal information 11.1 Data sheet status Document status [1] [2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 11.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 11.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. 2N7002 Product data sheet Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. All information provided in this document is subject to legal disclaimers. Rev. 7 — 8 September 2011 © Nexperia B.V. 2017. All rights reserved 11 of 13 2N7002 Nexperia 60 V, 300 mA N-channel Trench MOSFET Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. 11.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. 12. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 2N7002 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 8 September 2011 © Nexperia B.V. 2017. All rights reserved 12 of 13 Nexperia 2N7002 60 V, 300 mA N-channel Trench MOSFET 13. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 11.1 11.2 11.3 11.4 12 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .1 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2 Thermal characteristics . . . . . . . . . . . . . . . . . . .4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .8 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Contact information. . . . . . . . . . . . . . . . . . . . . .12 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 08 September 2011
2N7002/HAMR 价格&库存
很抱歉,暂时无法提供与“2N7002/HAMR”相匹配的价格&库存,您可以联系我们找货
2N7002/HAMR
    • 5000+0.11360
    库存:1476
    2N7002/HAMR
    • 3000+0.330613000+0.04286
    • 6000+0.294636000+0.03819
    • 9000+0.276299000+0.03582
    • 15000+0.2556315000+0.03314
    • 21000+0.2433821000+0.03155
    • 30000+0.2314830000+0.03001
    2N7002/HAMR
    • 1+0.10600
    库存:1476
    2N7002/HAMR
    • 1+1.673481+0.21692
    • 10+1.0222110+0.13250
    • 100+0.62846100+0.08146
    • 500+0.45749500+0.05930
    • 1000+0.401781000+0.05208
    2N7002/HAMR
    • 20+0.20175
    • 200+0.15747
    • 600+0.13284
    • 3000+0.11816
    • 9000+0.10530
    • 21000+0.09850
    库存:2208
    2N7002/HAMR
    • 1000+0.32124
    • 10000+0.32124
    • 100000+0.24093
    库存:1960057
