SMO-1507-P8
SMO-1507-P8
    SOFNG(硕方)
    SMD
    SD/SIM/TF卡插座 表面贴装 8Pin 自弹式
SMO-1507-P8 数据手册
www.Sofng.com C Operation:MICRO-SIM& 8+2 SOCKETS & Push-push 自弹式 SIM 卡座 ARD SOCKETS LTEM NO.:SMO-1507-P8 (Consumer Electronics) (16.7L× (16.7L×15.6W× 15.6W×1.56H & 常开结构 MICRO-SIM Sockets) MEMORY-CARD-SOCKETS 内焊贴装 SMT Technical parameter ╲ LEVEL A[better product] ╲ PROJECT Contact Rating Electrical Initial Contact Resistance Properties Insulation Resistance Withstand Voltage B[average product] 侧向導入 LATERAL 50mA, 24V DC 50mΩ max. 80mΩ max. 精密部品 NICETY 100MΩ min.500V DC 500V AC for 1 minute 350 V AC for 1 minut There No Load 5,000 Cycles 3,500 Cycles Rated Load 3,500 Cycles 2,500 Cycles 可靠 STABILIZE Durable Performance 適合環保 RoHS Sterage temp. Page1 -25℃~+85℃(Operating Temp: Unit:mm A D C B F E ● ● ● ) SOFNG ELECTRONIC TECHNOLOGY Co., LTD CIRCUIT BOARD SIZE (Vertical view) Operating Force Inward 8.0~12.0N.(1N.=100gram-force) Exiting 8.0~12.0N.(1N.=100gram-force) Solder-ability IR Reflow:255℃,5sec. (Max.) Manual:350℃,3sec. DECIMALS Pin definition X :±0.50 X° :±3° X.X :±0.35 X.X° :±1° X.XX :±0.25 X.XX° :±0.5° CARD Pin NAME Type Description C ① 卡電源 1 VCC C ② 復位 1 RST C ③ 時鐘 1 CLK C ④ Reserved 1 Reserved C ⑤ 接地 1 GND C ⑥ Vpp 1 VPP C ⑦ 輸入/輸出 1 I/O C ⑧ Reserved 1 Reserved 15.00 Micro 12.30 Nano 8.80 Nano Pin No. 12.00 Micro T-Flash ANGLES VCC GND RST VPP CLK I/O Nano SIM Micro SIM MICRO-SIM Material declaration NAME MATERIAL PLATING 本品不屬於危害性廢棄物,須丟棄時可以委託 A 接触端子 TERMINAL C5210-EH (t=0.20mm)磷铜【镍基 Ni50u〞镀金 1u〞】 G/F B 上盖 COVER SUS304(t=0.25mm)不锈钢【GND 焊点镀金 1u〞】 G/F C 滑块 SLIDER LCP 耐热塑胶 (UL94V-0)BLACK SET D 弹簧 SPRING SWP-B 钢琴丝镀镍 Ni:30u〞 - E 卡勾 LINK SUS304(⊙=0.15mm)不锈钢 - F 基座 HOUSING LCP 耐热塑胶 (UL94V-0)BLACK SET 回收商予以回收再生處理。Products do not belong to hazardous waste,When waste can recycling processing 注記 NOTICE 1.碩方公司擁有最終解釋權;The SOFNG company reserves the right of final interpretation; 2.文件禁止外洩、轉載;Leaked and reproduced prohibited; 3.未經授權修改無效。Modify is invalid. 運送時本產品不要直接與水、酸鹼性化學物質 接觸,或放置於含有以上氣體環境中,並且需要 注意會有滑落、側翻的危險發生;運輸過程中 不能有碰撞或者擠壓,須保證溫度與濕度適中 [常溫 25℃,濕度在 50℃以內],不可導致材料變 形或氧化。
SMO-1507-P8 价格&库存
很抱歉,暂时无法提供与“SMO-1507-P8”相匹配的价格&库存,您可以联系我们找货
SMO-1507-P8
  • 1+5.86602
  • 10+4.71852
  • 30+4.14936
  • 100+3.58938
  • 500+3.24972
  • 1000+3.07530
库存:70
