SMO-1511B
SMO-1511B
    SOFNG(硕方)
    SMD
    SD/SIM/TF卡插座 表面贴装 6Pin 自弹式
SMO-1511B 数据手册
www.Sofng.com C Operation:防呆式 MICRO-SIM SOCKETS & Push-Push ARD SOCKETS LTEM NO.:SMO-1511B-P6 (Consumer Electronics) (17.17L× (17.17L×15.75W× 15.75W×1.5H & MICRO-SIM Sockets) MEMORY-CARD-SOCKETS 外焊贴装 SMT Technical parameter ╲ LEVEL A[better product] ╲ PROJECT Contact Rating Electrical Initial Contact Resistance Properties Insulation Resistance Withstand Voltage B[average product] 侧向導入 LATERAL 25mA, 24V DC 50mΩ max. 精密部品 NICETY 80mΩ max. 100MΩ min.500V DC 500V AC for 1 minute 350 V AC for 1 minut There No Load 5,000 Cycles 3,500 Cycles Rated Load 3,500 Cycles 2,500 Cycles 可靠 STABILIZE Durable Performance 適合環保 RoHS Sterage temp. Page1 -25℃~+85℃(Operating Temp: ) Unit:mm C E)F SIM CARD ELECTRIC DETECT SWITCH FUNCTION ● WITHOUT CARD CLOSED CARD INSERTED OPEN CD GND WIHOUT CARD CD GND CARD INSERTED SWTICH OPERATION DIAGRAM ● B D A SOFNG ELECTRONIC TECHNOLOGY Co., LTD CIRCUIT BOARD SIZE (Vertical view) Operating Force Inward 8.0~10.0N.(1N.=100gram-force) Exiting 8.0~10.0N.(1N.=100gram-force) Solder-ability IR Reflow:250℃,5sec. (Max.) Manual:350℃,3sec. DECIMALS ANGLES X :±0.50 X° :±3° X.X :±0.35 X.X° :±1° X.XX :±0.25 X.XX° :±0.5° Pin definition T-Flash CARD Pin No. Pin NAME Type Description C ① 卡電源 1 VCC C ② 復位 1 RST C ③ 時鐘 1 CLK C ④ Reserved 1 Reserved C ⑤ 接地 1 GND C ⑥ Vpp 1 VPP C ⑦ 輸入/輸出 1 I/O C ⑧ Reserved 1 Reserved MICRO-SIM Material declaration NAME MATERIAL PLATING 本品不屬於危害性廢棄物,須丟棄時可以委託 A 基座 LCP 30%G/F (Black)耐热塑胶 - B 接触端子 C5191R-H (t=0.15mm)磷青铜【锡 30u〞基镀金 1u〞】 G/F C 外壳 SUS301-3/4H(t=0.15mm)不锈钢【焊点镀金 1u〞】 G/F D 滑块 PA6T 30%G/F (Black)耐热尼龙 SET E 线簧 象唛钢线 OD=0.21mm - 運送時本產品不要直接與水、酸鹼性化學物質 F 弹簧 SUS304(t=0.30mm)不锈钢 - 接觸,或放置於含有以上氣體環境中,並且需要 回收商予以回收再生處理。Products do not belong to hazardous waste,When waste can recycling processing 注意會有滑落、側翻的危險發生;運輸過程中 注記 NOTICE 1.碩方公司擁有最終解釋權;The SOFNG company reserves the right of final interpretation; 2.文件禁止外洩、轉載;Leaked and reproduced prohibited; 3.未經授權修改無效。Modify is invalid. 不能有碰撞或者擠壓,須保證溫度與濕度適中 [常溫 25℃,濕度在 50℃以內],不可導致材料變 形或氧化。
SMO-1511B 价格&库存
很抱歉,暂时无法提供与“SMO-1511B”相匹配的价格&库存,您可以联系我们找货
