SNO-1304
SNO-1304
    SOFNG(硕方)
    SMD
    SD/SIM/TF卡插座 表面贴装 6Pin 拔插式
SNO-1304 数据手册
www.Sofng.com C Operation:NANO-SIM SOCKETS & ARD SOCKETS Push-Pull 外焊 LTEM NO.:SNO-1304 抽拉式 识别卡座 (Consumer Electronics) (12.3L× (12.3L×10.0W× 10.0W×1.35H & NANO-SIM Sockets) MEMORY-CARD-SOCKETS 表面贴装 SMT Technical parameter ╲ LEVEL A[better product] ╲ PROJECT Contact Rating Electrical Initial Contact Resistance Properties Insulation Resistance Withstand Voltage B[average product] 侧向操作 LATERAL 50mA, 24V DC 50mΩ max. 精密部品 NICETY 80mΩ max. 100MΩ min.500V DC 500V AC for 1 minute 350 V AC for 1 minut There No Load 5,000 Cycles 3,500 Cycles Rated Load 3,500 Cycles 2,500 Cycles 可靠 STABILIZE Durable Performance 適合環保 RoHS Sterage temp. Page1 -35℃~+75℃(Operating Temp: ) Unit:mm 0.08 ● ● ● SOFNG ELECTRONIC TECHNOLOGY Co., LTD CIRCUIT BOARD SIZE (Vertical view) Operating Force Inward 2.0~4.0N.(1N.=100gram-force) Exiting 3.0~5.0N.(1N.=100gram-force) Solder-ability IR Reflow:255℃,5sec. (Max.) Manual:350℃,3sec. ● ● DECIMALS Pin definition SIM ANGLES .X :±0.20 X.° :±1.5° .XX :±0.10 X.X° :±1.0° .XXX :±0.05 .XXX° :±0.5° CARD Pin No. Pin NAME Type Description C ① 卡電源 1 VCC C ② 復位 1 RST C ③ 時鐘 1 CLK C ⑤ 接地 1 GND C ⑥ Vpp 1 VPP C ⑦ 輸入/輸出 1 I/O NANO-SIM Reel label Material declaration RoHS label NAME MATERIAL PLATING LCP 耐热塑胶 (UL94V-0) BLACK SET ① 基座 Housing ② 接触端子 Terminal C5210-EH (t=0.20mm)磷铜【镍基 Ni50u〞镀金 1u〞】 G/F ③ 上盖 Cover SUS304-H(t=0.15mm)不锈钢【GND 焊点镀金 1u〞】 AU/Ni 注記 NOTICE 1800PCS/reel ● Vacuum Packed Bag RoHS label 1.碩方公司擁有最終解釋權;The SOFNG company reserves the right of final interpretation; 2.文件禁止外洩、轉載;Leaked and reproduced prohibited; 3.未經授權修改無效。Modify is invalid. Cardboard box label
SNO-1304 价格&库存
很抱歉,暂时无法提供与“SNO-1304”相匹配的价格&库存,您可以联系我们找货
