SD-001
SD-001
    SOFNG(硕方)
    SMD
    SD/SIM/TF卡插座 表面贴装 9Pin 拔插式
SD-001 数据手册
www.Sofng.com C ARD SOCKETS 短体表面贴装 Operation:SMT&(Push-Pull)抽拉式 LTEM NO.:SD-001 储存卡连接器 (Consumer Electronics) (17.20L× (17.20L×26.40W× 26.40W×2.85H & T-Flash Sockets) MEMORY-CARD-SOCKETS Technical parameter ╲ PROJECT LEVEL A[better product] ╲ Contact Rating Electrical Initial Contact Resistance Properties Insulation Resistance B[average product] 25mA, 24V DC 30mΩ max. 50mΩ max. 100MΩ min.500V DC Withstand Voltage 500V AC for 1 minute 350 V AC for 1 minut Durable There No Load 6,500 Cycles 5,500 Cycles Performance Rated Load 5,500 Cycles 4,000 Cycles Sterage temp. -35℃~+85℃(Operating Temp: ) SD CARD Page1 Unit:mm E C B D A Material declaration No. NAME MATERIAL PLATING ①A 开口端子 65-EH 青铜带(Yδ=0.25mm) - ②B 外 壳 磷青铜带(Yδ=0.25mm) - ③C 弹片端子 1 C5191-EH 磷铜带(Yδ=0.2mm) G/F ④D 弹片端子 2 C5191-EH 磷铜带(Yδ=0.2mm) G/F ⑤E 塑胶底座 LCP 耐高温塑料(260°C) SET SOFNG ELECTRONIC TECHNOLOGY Co., LTD CIRCUIT BOARD SIZE (Vertical view) Operating Force Inward 6.0~9.0N.(1N.=100gram-force) Exiting 5.0~8.0N.(1N.=100gram-force) Solder-ability IR Reflow:255℃,5sec. (Max.) Manual:350℃,3sec. DECIMALS ANGLES X :±0.25 X° :±3° X.X :±0.20 X.X° :±1° X.XX :±0.15 X.XX° :±0.5° Pin definition SD CARD Pin DESIGN Pin No. Pin NAME Type Description P① CD/DAT3 I/0/PP Card Detect/Date Line[Bit 3] P② CMD PP Command/Response P③ Vss1 S Supply voltage ground P④ VDD S Supply voltage P⑤ CLK l Clock P⑥ Vss2 S Supply voltage ground P⑦ DAT 0 l/0/PP Date Line [Bit 0] P⑧ DAT 1 l/0/PP Date Line [Bit 1] P⑨ DAT 2 l/0/PP Date Line [Bit 2] Contact ON / LOCK OFF Contact ON / LOCK ON AD AB DETAIL AB DETAIL AD 本品不屬於危害性廢棄物,須丟棄時可以委託 回收商予以回收再生處理。Products do not belong to hazardous waste,When waste can recycling processing 運送時本產品不要直接與水、酸鹼性化學物質 接觸,或放置於含有以上氣體環境中,並且需要 注記 NOTICE 注意會有滑落、側翻的危險發生;運輸過程中 不能有碰撞或者擠壓,須保證溫度與濕度適中 1.碩方公司擁有最終解釋權;The SOFNG company reserves the right of final interpretation; [常溫 25℃,濕度在 50℃以內],不可導致材料變 2.文件禁止外洩、轉載;Leaked and reproduced prohibited; 3.未經授權修改無效。Modify is invalid. 形或氧化。
SD-001 价格&库存
很抱歉,暂时无法提供与“SD-001”相匹配的价格&库存,您可以联系我们找货
SD-001
  • 1+1.24187
  • 10+0.98896
  • 50+0.84245
  • 100+0.70722
  • 500+0.64700
  • 1000+0.61088
库存:599
