74AHCT14APWJ
74AHCT14APWJ
    NEXPERIA(安世)
    TSSOP14_5.1X4.5MM
    IC INVERTER 6CH 6-INP 14TSSOP
74AHCT14APWJ 数据手册
74AHCT14A Hex inverting Schmitt trigger Rev. 2 — 26 October 2016 Product data sheet 1. General description The 74AHCT14A is a hexadecimal inverter with Schmitt-trigger inputs, capable of transforming slowly changing input signals into sharply defined, jitter-free output signals. Designed to operate over a VCC range from 4.5 V to 5.5 V, the inputs are TTL compatible. This range allows the device to be used to translate from 3.3 V to 5 V. This device is fully specified for partial Power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2. Features and benefits          Direct interface with TTL levels Supply voltage range from 4.5 V to 5.5 V Typical tpd of 3.7 ns at 5 V Typical VOL(p) < 0.8 V at VCC = 5 V, Tamb = 25 C Typical VOH(v) > 2.3 V at VCC = 5 V, Tamb = 25 C Supports mixed-mode voltage operation on all ports IOFF circuitry provides partial Power-down mode operation Latch-up performance exceeds 250 mA per JESD 78 Class II ESD protection:  HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 3 kV  MM JESD22-A115-A exceeds 200 V  CDM JESD22-C101E exceeds 2 kV  Specified from 40 C to +85 C and from 40 C to +125 C 74AHCT14A Nexperia Hex inverting Schmitt trigger 3. Ordering information Table 1. Ordering information Type number Package 74AHCT14APW Temperature range Name Description Version 40 C to +125 C plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 TSSOP14 4. Functional diagram       $ < $ < $ < $ < $ < $ <                  PQD Fig 1.  Logic symbol $ < PQD DDF Fig 2. IEC logic symbol Fig 3. Logic diagram (one Schmitt-trigger) 5. Pinning information 5.1 Pinning $+&7$ $   9&& <   $ $   < <   $ $   < <   $ *1'   < DDD Fig 4. Pin configuration TSSOP14 74AHCT14A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 October 2016 © Nexperia B.V. 2017. All rights reserved 2 of 13 74AHCT14A Nexperia Hex inverting Schmitt trigger 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A, 2A, 3A, 4A, 5A, 6A 1, 3, 5, 9, 11, 13 data input 1Y, 2Y, 3Y, 4Y, 5Y, 6Y 2, 4, 6, 8, 10, 12 data output GND 7 ground (0 V) VCC 14 supply voltage 6. Functional description Table 3. Function table[1] Input Output nA nY L H H L [1] H = HIGH voltage level; L = LOW voltage level. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions output voltage VO output HIGH or LOW state Max Unit 0.5 +7.0 V [1] 0.5 +7.0 V [2][3] 0.5 VCC + 0.5 V [2] 0.5 +7.0 V input voltage VI Min output power-down IIK input clamping current VI < 0 V 20 - mA IOK output clamping current VO < 0 V 20 - mA IO output current VO = 0 V to VCC - 25 mA ICC supply current - 75 mA IGND ground current 75 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot Tamb = 40 C to +125 C [4] [1] If the input current ratings are observed, the minimum input voltage ratings may be exceeded. [2] If the output current ratings are observed, the output voltage ratings may be exceeded. [3] This value is limited to 7 V maximum. [4] For TSSOP14 packages: above 75 C, the value of Ptot derates linearly at 7 mW/K. 74AHCT14A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 October 2016 © Nexperia B.V. 2017. All rights reserved 3 of 13 74AHCT14A Nexperia Hex inverting Schmitt trigger 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature t/V input transition rise and fall rate Min Typ Max Unit 4.5 5.0 5.5 V 0 - 5.5 V output HIGH or LOW state 0 - VCC V output power-down 0 - 5.5 V 40 +25 +125 C - - 1 VCC = 5.0 V  0.5 V ms/V 9. Static characteristics Table 6. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter VT+ VT VH VOH 25 C Conditions Min Typ Max Min Max Min Max VCC = 4.5 V - - 1.9 - 1.9 - 1.9 V VCC = 5.5 V - - 2.1 - 2.1 - 2.1 V negative-going VCC = 4.5 V threshold VCC = 5.5 V voltage 0.5 - - 0.5 - 0.5 - V 0.6 - - 0.6 - 0.6 - V hysteresis voltage VCC = 4.5 V 0.4 - 1.4 0.4 1.4 0.4 1.4 V VCC = 5.5 V 0.4 - 1.5 0.4 1.5 0.4 1.5 V positive-going threshold voltage HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 50 A IO = 8 mA VOL 40 C to +85 C 40 C to +125 C Unit LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 50 A IO = 8 mA 4.4 4.5 - 4.4 - 4.4 - V 3.94 - - 3.8 - 3.7 - V - 0 0.1 - 0.1 - 0.1 V - - 0.36 - 0.44 - 0.55 V IOFF power-off leakage current VI or VO = GND to 5.5 V; VCC = 0 V - - 0.5 - 5 - 5 A II input leakage current VI = VCC or GND; VCC = 0 V to 5.5 V - - 0.1 - 1 - 1 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 2 - 20 - 20 A ICC additional per input pin; VI = 3.4 V; supply current IO = 0 A; other pins at VCC or GND; VCC = 5.5 V - - 1.35 - 1.5 - 1.5 mA 74AHCT14A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 October 2016 © Nexperia B.V. 2017. All rights reserved 4 of 13 74AHCT14A Nexperia Hex inverting Schmitt trigger 9.1 Transfer characteristics waveforms 92 97 9, 9+ 97 9, 9+ 97 Fig 5. 97 92 PQD PQD Transfer characteristics Fig 6. DDD  Transfer characteristics definitions DDD  ,&& P$ ,&& P$                       9,1 9 9,1 9 a. VCC = 4.5 V Fig 7.  b. VCC = 5.5 V Typical transfer characteristics 74AHCT14A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 October 2016 © Nexperia B.V. 2017. All rights reserved 5 of 13 74AHCT14A Nexperia Hex inverting Schmitt trigger 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V. For test circuit, see Figure 9. Symbol Parameter propagation delay tpd 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max CL = 15 pF - 3.7 7.6 1 9 1 9.7 ns CL = 50 pF - 5 9.6 1 11 1 11.9 ns nA to nY; see Figure 8 [2] VCC = 4.5 V to 5.5 V CI input capacitance VI = VCC or GND; VCC = 5 V - 2 6 - 6 - 6 pF CO output capacitance VO = VCC or GND; VCC = 5 V - 5 - - - - - pF CPD power dissipation capacitance per buffer; CL = 0 pF; f = 10 MHz; VI = GND to VCC - 10 - - - - - pF [3] [1] Typical values are measured at Tamb = 25 C and VCC = 5 V. [2] tpd is the same as tPLH and tPHL. [3] CPD is used to determine the dynamic power dissipation PD (W). PD = CPD  VCC2  fi +  (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in Volts. 74AHCT14A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 October 2016 © Nexperia B.V. 2017. All rights reserved 6 of 13 74AHCT14A Nexperia Hex inverting Schmitt trigger Table 8. Noise characteristics GND = 0 V. For test circuit, see Figure 9. Symbol Parameter Tamb = 25 C Conditions Unit Min Typ Max VCC = 5 V; CL = 50 pF VOL(p) LOW-level output voltage (peak) - 0.4 0.8 V VOL(v) LOW-level output voltage (valley) 0.8 0.2 - V VOH(v) HIGH-level output voltage (valley) - 4.5 - V VIH(AC) AC HIGH-level input voltage 2 - - V VIL(AC) AC LOW-level input voltage - - 0.8 V 11. Waveforms 9, 90 Q$LQSXW 90 *1' W 3+/ W 3/+ 92+ 90 Q
74AHCT14APWJ 价格&库存
很抱歉,暂时无法提供与“74AHCT14APWJ”相匹配的价格&库存,您可以联系我们找货
