TF-001B
TF-001B
    SOFNG(硕方)
    SMD
    SD/SIM/TF卡插座 表面贴装 8Pin 自弹式
TF-001B 数据手册
www.Sofng.com C Operation:SMT& 内焊常闭 ARD SOCKETS (Push-Push)自弹式 T-Flash 连接器 LTEM NO.:TF-001B (Consumer Electronics) (15.3L× (15.3L×14.0W× 14.0W×1.9H & T-Flash Sockets) MEMORY-CARD-SOCKETS 表面贴装 SMT Technical parameter ╲ LEVEL A[better product] ╲ PROJECT Contact Rating Electrical Initial Contact Resistance Properties Insulation Resistance Withstand Voltage B[average product] 侧向導入 LATERAL 25mA, 24V DC 30mΩ max. 50mΩ max. 精密部品 NICETY 100MΩ min.500V DC 500V AC for 1 minute 350 V AC for 1 minut There No Load 6,500 Cycles 5,500 Cycles Rated Load 5,500 Cycles 4,000 Cycles 可靠 STABILIZE Durable Performance 適合環保 RoHS Sterage temp. Page1 -35℃~+85℃(Operating Temp: ) Unit:mm Up Height ● CARD CENTER CONNECTOR CENTER E D A F C B Material declaration Space No. NAME MATERIAL ①A 基座 LCP 30%G/F (Black)耐热塑胶 PLATING - ②B 滑块 PA6T 30%G/F (Black)耐热尼龙 SET ③C 接触端子 C5191R-H (t=0.15mm)磷青铜【锡 30u〞基镀金 1u〞】 G/F ④D 外壳 SUS301-3/4H(t=0.15mm)不锈钢【焊点镀金 1u〞】 G/F ⑤E 线簧 象唛钢线 OD=0.21mm - ⑥F 弹簧 SUS304(t=0.30mm)不锈钢 - SOFNG ELECTRONIC TECHNOLOGY Co., LTD CIRCUIT BOARD SIZE (Vertical view) Operating Force Inward 8.0~12.0N.(1N.=100gram-force) Exiting 6.0N.(1N.=100gram-force) Solder-ability IR Reflow:250℃,5sec. (Max.) Manual:350℃,3sec. SW CARD DETECTION SWITCH WHENCARD IS EJECTED SW WHEN CARD IS INSERTED GND SW GND Product Out-Line GND NO SIGNAL DECIMALS ANGLES X :±0.25 X° :±3° X.X :±0.20 X.X° :±1° X.XX :±0.15 X.XX° :±0.5° Pin definition T-Flash CARD Pin No. Pin NAME Type Description PIN① DAT2 I/0/PP Date Line[Bit 2] PIN② CD/DAT3 I/0/PP Card Detect Date Lin(Bit 3) PIN③ CMD PP Command Response PIN④ VDD S Supply voltage PIN⑤ CLX l Clock PIN⑥ Vss S Supply voltage ground PIN⑦ DAT 0 l/0/PP Date Line [Bit 0] PIN⑧ DAT 1 l/0/PP Date Line [Dit 1] P1 P8 T-Flash 本品不屬於危害性廢棄物,須丟棄時可以委託 回收商予以回收再生處理。Products do not belong to hazardous waste,When waste can recycling processing 運送時本產品不要直接與水、酸鹼性化學物質 接觸,或放置於含有以上氣體環境中,並且需要 注記 NOTICE 注意會有滑落、側翻的危險發生;運輸過程中 不能有碰撞或者擠壓,須保證溫度與濕度適中 1.碩方公司擁有最終解釋權;The SOFNG company reserves the right of final interpretation; 2.文件禁止外洩、轉載;Leaked and reproduced prohibited; 3.未經授權修改無效。Modify is invalid. [常溫 25℃,濕度在 50℃以內],不可導致材料變 形或氧化。
TF-001B 价格&库存
很抱歉,暂时无法提供与“TF-001B”相匹配的价格&库存,您可以联系我们找货
TF-001B
  • 1+3.17034
  • 10+2.53422
  • 30+2.26746
  • 100+1.92888
  • 500+1.70316
  • 1000+1.61082
库存:8929
