TF-008
TF-008
    SOFNG(硕方)
    SMD
    SD/SIM/TF卡插座 表面贴装 8Pin 拔插式
TF-008 数据手册
www.Sofng.com C ARD SOCKETS Operation:SMT&(Push-Pull)抽拉式 内焊超薄型 LTEM NO.:TF-008 T-Flash 连接器 (Consumer Electronics) (11.25L× (11.25L×11.35W× 11.35W×1.35H & T-Flash Sockets) MEMORY-CARD-SOCKETS Technical parameter ╲ PROJECT LEVEL ╲ A[better product] Contact Rating Electrical Initial Contact Resistance Properties Insulation Resistance B[average product] 25mA, 24V DC 30mΩ max. 50mΩ max. 8 7 6 5 4 3 2 1 100MΩ min.500V DC Withstand Voltage 500V AC for 1 minute 350 V AC for 1 minut Durable There No Load 6,500 Cycles 5,500 Cycles Performance Rated Load 5,500 Cycles 4,000 Cycles Sterage temp. -35℃~+85℃(Operating Temp: ) T-Flash Page1 Unit:mm D A C B Material declaration No. NAME MATERIAL PLATING ①A 外壳 SUS301-3/4H(t=0.12mm)不锈钢【焊点镀金 1u〞】 G/F ②B 基座 LCP 30% (Black)耐热塑料 THERMAL PLASTIC - ③C 接触端子 C5191R-H (t=0.12mm)磷青铜【30u〞锡基镀金 1u〞】 G/F ④D 检测端子 C5191R-H (t=0.12mm)磷青铜【30u〞锡基镀金 1u〞】 G/F SOFNG ELECTRONIC TECHNOLOGY Co., LTD CIRCUIT BOARD SIZE (Vertical view) Operating Force Inward 2.0~3.0N.(1N.=100gram-force) Exiting 2.0N.(1N.=100gram-force) Solder-ability IR Reflow:255℃,5sec. (Max.) Manual:350℃,3sec. DECIMALS ANGLES X :±0.25 X° :±3° X.X :±0.20 X.X° :±1° X.XX :±0.15 X.XX° :±0.5° Pin definition T-Flash COMPONENT CARD Pin No. Pin NAME Type Description PIN① DAT2 I/0/PP Date Line[Bit 2] PIN② CD/DAT3 I/0/PP Card Detect Date Lin(Bit 3) PIN③ CMD PP Command Response PIN④ VDD S Supply voltage PIN⑤ CLX l Clock PIN⑥ Vss S Supply voltage ground PIN⑦ DAT 0 l/0/PP Date Line [Bit 0] PIN⑧ DAT 1 l/0/PP Date Line [Dit 1] 本品不屬於危害性廢棄物,須丟棄時可以委託 回收商予以回收再生處理。Products do not belong to hazardous waste,When waste can recycling processing 運送時本產品不要直接與水、酸鹼性化學物質 接觸,或放置於含有以上氣體環境中,並且需要 注記 NOTICE 注意會有滑落、側翻的危險發生;運輸過程中 不能有碰撞或者擠壓,須保證溫度與濕度適中 1.碩方公司擁有最終解釋權;The SOFNG company reserves the right of final interpretation; [常溫 25℃,濕度在 50℃以內],不可導致材料變 2.文件禁止外洩、轉載;Leaked and reproduced prohibited; 3.未經授權修改無效。Modify is invalid. 形或氧化。
TF-008 价格&库存
很抱歉,暂时无法提供与“TF-008”相匹配的价格&库存,您可以联系我们找货
TF-008
  • 1+2.09304
  • 10+1.83654
  • 30+1.73394
  • 100+1.60056
  • 500+1.42614
  • 1000+1.39536
库存:865
