www.Sofng.com
C
Operation:SMT&Push-Push
ARD SOCKETS
LTEM NO.:TF-15X15
(Consumer Electronics)
(14.50L×
(14.50L×14.75W×
14.75W×1.90H & T-Flash Sockets)
MEMORY-CARD-SOCKETS
外焊贴装 SMT
Technical parameter
LEVEL
A[better product]
PROJECT
Contact Rating
Electrical
Initial Contact Resistance
Properties
Insulation Resistance
Withstand Voltage
B[average product]
侧向導入 LATERAL
25mA, 24V DC
30mΩ max.
100MΩ min.500V DC
精密部品 NICETY
50mΩ max.
Skey/PD:100MΩ min.300V DC
500V AC for 1 minute
350 V AC for 1 minut
There No Load
6,500 Cycles
5,500 Cycles
Rated Load
5,500 Cycles
4,500 Cycles
可靠 STABILIZE
Durable Performance
適合環保 RoHS
Sterage temp.
Page1
-25℃~+85℃(Operating Temp:
Unit:mm
F
E
B
A
Page2
D
C
Cd
GND
CARD DETECTION SWITCH
GND
WHENCARD
IS EJECTED
Cd
GND
GND
GND
DECIMALS
SPECIFED TOLERANCES
UNLESS OTHERWISE
WHEN CARD
IS INSERTED
Cd
GND
ANGLES
X.X
:±0.35
X.X
:±3°
X.XX
:±0.25
X.XX
:±2°
X.XXX :±0.15
Material declaration
No.
NAME
MATERIAL
PLATING
①A
基座
LCP 30%G/F (Black)耐热塑胶
②B
滑块
PA6T 30%G/F (Black)耐热尼龙
SET
③C
接触端子
C5191R-H (t=0.15mm)磷青铜【锡 30u〞基镀金 1u〞】
G/F
④D
外壳
SUS301-3/4H(t=0.15mm)不锈钢【焊点镀金 1u〞】
G/F
⑤E
线簧
象唛钢线 OD=0.21mm
⑥F
弹簧
SUS304(t=0.30mm)不锈钢
MATERIAL
SOFNG ELECTRONIC TECHNOLOGY Co., LTD
CIRCUIT BOARD SIZE
(Vertical view)
Operating Force
Inward
8.0~12.0N.(1N.=100gram-force)
Exiting
10N.[±100gf]
Pin definition
T-Flash
CARD
Pin No.
Pin NAME
Type
Description
P①
DAT2
I/0/PP
Date Line[Bit 2]
P②
CD/DAT3
I/0/PP
Card Detect Date Lin(Bit 3)
P③
CMD
PP
Command Response
P④
VDD
S
Supply voltage
P⑤
CLX
l
Clock
P⑥
Vss
S
Supply voltage ground
P⑦
DAT 0
l/0/PP
Date Line [Bit 0]
P⑧
DAT 1
l/0/PP
Date Line [Dit 1]
P1
P8
T-Flash
本品不屬於危害性廢棄物,須丟棄時可以委託
回收商予以回收再生處理。Products do not
belong to hazardous waste,When waste can
recycling processing
運送時本產品不要直接與水、酸鹼性化學物質
接觸,或放置於含有以上氣體環境中,並且需要
注記 NOTICE
注意會有滑落、側翻的危險發生;運輸過程中
不能有碰撞或者擠壓,須保證溫度與濕度適中
1.碩方公司擁有最終解釋權;The SOFNG company reserves the right of final interpretation;
2.文件禁止外洩、轉載;Leaked and reproduced prohibited;
3.未經授權修改無效。Modify is invalid.
[常溫 25℃,濕度在 50℃以內],不可導致材料變
形或氧化。
很抱歉,暂时无法提供与“TF-15X15”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.90138
- 50+0.70674
- 200+0.61170
- 400+0.60252
- 1000+0.50761
- 5000+0.47035
- 国内价格
- 5+0.99337
- 50+0.77886
- 150+0.67412
- 1000+0.55941
- 2000+0.53375
- 5000+0.51835
