74AHCV541A
Octal buffer/line driver; 3-state
Rev. 6 — 15 December 2016
Product data sheet
1. General description
The 74AHCV541A is an 8-bit buffer/line driver with 3-state outputs and Schmitt trigger
inputs. The device features two output enables (OE1 and OE2). A HIGH on OEn causes
the associated outputs to assume a high-impedance OFF-state.
Inputs are overvoltage tolerant. This feature allows the use of these devices as translators
in mixed voltage environments.
The data (An) and control (OEn) inputs include Schmitt trigger inputs, capable of
transforming slowly changing input signals into sharply defined, jitter-free output signals.
This device is fully specified for partial Power-down applications using IOFF.
The IOFF circuitry disables the output, preventing the damaging backflow current through
the device when it is powered down.
2. Features and benefits
Wide supply voltage range from 1.8 V to 5.5 V
Typical tpd of 3.0 ns at 5 V
Typical VOL(p) < 0.8 V at VCC = 3.3 V, Tamb = 25 C
Typical VOH(v) > 2.3 V at VCC = 3.3 V, Tamb = 25 C
Supports mixed-mode voltage operation on all ports
IOFF circuitry provides partial Power-down mode operation
Latch-up performance exceeds 250 mA per JESD 78 Class II
ESD protection:
HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 3 kV
MM JESD22-A115-A exceeds 200 V
CDM JESD22-C101E exceeds 2 kV
Specified from 40 C to +85 C and from 40 C to +125 C
74AHCV541A
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
plastic thin shrink small outline package; 20 leads;
body width 4.4 mm
SOT360-1
74AHCV541APW 40 C to +125 C
TSSOP20
74AHCV541ABQ 40 C to +125 C
DHVQFN20 plastic dual in-line compatible thermal enhanced very SOT764-1
thin quad flat package; no leads; 20 terminals;
body 2.5 4.5 0.85 mm
4. Functional diagram
Fig 1.
很抱歉,暂时无法提供与“74AHCV541APWJ”相匹配的价格&库存,您可以联系我们找货
